[PATCH 20/41] sparc/irq: Implement new interrupt directives
Sebastian Huber
Wed Jul 21 18:31:03 UTC 2021
On 21/07/2021 20:28, Gedare Bloom wrote:
> Why not throw an error here instead? In production, you wouldn't want
> this code...
The main issue is the bad chip design. If we don't have this code, we
can't test the extended interrupts. In production, you want tested code.
>> + rtems_interrupt_lock_context lock_context;
>> + * This is a very dangerous operation and should only be used for test
>> + * software. We may accidentally clear the pending state set by
>> + * peripherals with this read-modify-write operation.
>> + LEON3_IRQCTRL_ACQUIRE(&lock_context);
>> + LEON3_IrqCtrl_Regs->ipend |= bit;
>> + LEON3_IRQCTRL_RELEASE(&lock_context);
>> + return RTEMS_SUCCESSFUL;
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
