[PATCH] build: Add "family/" prefix to BSP familiy enable
Thu Jul 22 06:37:04 UTC 2021
On 22/7/21 4:20 pm, Sebastian Huber wrote:
> On 22/07/2021 02:39, Chris Johns wrote:
>> On 22/7/21 5:22 am, Sebastian Huber wrote:
>>> BSP family and BSP variant names may be equal.  This prefix avoids
>>> ambiguity in the enabled-by expressions.
>>>   wscript | 2 +-
>>>   1 file changed, 1 insertion(+), 1 deletion(-)
>>> diff --git a/wscript b/wscript
>>> index f27dba6831..b7a0412150 100755
>>> --- a/wscript
>>> +++ b/wscript
>>> @@ -1394,7 +1394,7 @@ def configure_variant(conf, cp, bsp_map, path_list,
>>> top_group, variant):
>>>       conf.env["ENABLE"] = [
>>>           get_compiler(conf, cp, variant),
>>>           arch,
>>> -        arch_family,
>>> +        "family/" + arch_family,
>>             "bsps/" + arch_family,
>> ... as discussed in the other thread? If you are happy with the change as shown
>> please push.
> Yes, this is good and matches with our directory layout. I checked it in with
> this change.
> We could also merge the default-by-family and default-by-variant lists with this
> approach,
I am not sure. My initial reaction was "yes" but how would different settings
for a BSP and a family be handled? I am assuming a BSP variant setting is able
to override a family setting. Is that possible if they are merged?
> for example:
> diff --git a/spec/build/bsps/optconsolebaud.yml
> b/spec/build/bsps/optconsolebaud.yml
> index 4b0869beca..0233fdd61b 100644
> --- a/spec/build/bsps/optconsolebaud.yml
> +++ b/spec/build/bsps/optconsolebaud.yml
> @@ -6,13 +6,10 @@ build-type: option
>  copyrights:
>  - Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
>  default: 115200
> -default-by-family:
> -- value: 9600
> -  families:
> -  - powerpc/motorola_powerpc
>  default-by-variant:
>  - value: 9600
>    variants:
> +  - bsps/powerpc/motorola_powerpc
Oh I think my patch piece may have been wrong. This has two `/` and so three
components. We _must_ have unique family names and so the arch part is not
really needed. My concern is this type code ...
https://git.rtems.org/rtems_waf/tree/rtems.py#n758
that breaks. Is this an issue? I think a single `/` in a BSP or family is cleaner.
