[PATCH] build: Add "family/" prefix to BSP familiy enable
Thu Jul 22 06:44:44 UTC 2021
On 22/07/2021 08:37, Chris Johns wrote:
> On 22/7/21 4:20 pm, Sebastian Huber wrote:
>> On 22/07/2021 02:39, Chris Johns wrote:
>>> On 22/7/21 5:22 am, Sebastian Huber wrote:
>>>> BSP family and BSP variant names may be equal.  This prefix avoids
>>>> ambiguity in the enabled-by expressions.
>>>>    wscript | 2 +-
>>>>    1 file changed, 1 insertion(+), 1 deletion(-)
>>>> diff --git a/wscript b/wscript
>>>> index f27dba6831..b7a0412150 100755
>>>> --- a/wscript
>>>> +++ b/wscript
>>>> @@ -1394,7 +1394,7 @@ def configure_variant(conf, cp, bsp_map, path_list,
>>>> top_group, variant):
>>>>        conf.env["ENABLE"] = [
>>>>            get_compiler(conf, cp, variant),
>>>>            arch,
>>>> -        arch_family,
>>>> +        "family/" + arch_family,
>>>              "bsps/" + arch_family,
>>> ... as discussed in the other thread? If you are happy with the change as shown
>>> please push.
>> Yes, this is good and matches with our directory layout. I checked it in with
>> this change.
>> We could also merge the default-by-family and default-by-variant lists with this
>> approach,
> I am not sure. My initial reaction was "yes" but how would different settings
> for a BSP and a family be handled? I am assuming a BSP variant setting is able
> to override a family setting. Is that possible if they are merged?
Yes, a BSP variant would have higher priority, this is enforced by the
search order:
         for default in self.data["default-by-variant"]:
             if OptionItem._is_variant(default["variants"], variant):
                 value = default["value"]
                 break
         for default in self.data["default-by-family"]:
             if OptionItem._is_variant(default["families"], family):
                 break
>> for example:
>> diff --git a/spec/build/bsps/optconsolebaud.yml
>> b/spec/build/bsps/optconsolebaud.yml
>> index 4b0869beca..0233fdd61b 100644
>> --- a/spec/build/bsps/optconsolebaud.yml
>> +++ b/spec/build/bsps/optconsolebaud.yml
>> @@ -6,13 +6,10 @@ build-type: option
>>   copyrights:
>>   - Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
>>   default: 115200
>> -default-by-family:
>> -- value: 9600
>> -  families:
>> -  - powerpc/motorola_powerpc
>>   default-by-variant:
>>   - value: 9600
>>     variants:
>> +  - bsps/powerpc/motorola_powerpc
> Oh I think my patch piece may have been wrong. This has two `/` and so three
> components. We _must_ have unique family names
The BSP family names are just names in an architecture directory, so
this rule would be not enforced by the directory layout.
> and so the arch part is not
> really needed. My concern is this type code ...
> https://git.rtems.org/rtems_waf/tree/rtems.py#n758
> that breaks. Is this an issue? I think a single `/` in a BSP or family is cleaner.
Why is this an issue? This BSP family stuff is local to the RTEMS build
system.
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
