[PATCH v3 41/42] validation: Test rtems_interrupt_get_affinity()
Fri Jul 23 13:56:49 UTC 2021
Update #3269.
 .../testsuites/validation/validation-0.yml    |   1 +
 testsuites/validation/tc-intr-get-affinity.c  | 639 ++++++++++++++++++
 2 files changed, 640 insertions(+)
 create mode 100644 testsuites/validation/tc-intr-get-affinity.c
diff --git a/spec/build/testsuites/validation/validation-0.yml b/spec/build/testsuites/validation/validation-0.yml
index 6f68727f01..5b337b3a34 100644
--- a/spec/build/testsuites/validation/validation-0.yml
+++ b/spec/build/testsuites/validation/validation-0.yml
@@ -18,6 +18,7 @@ source:
 - testsuites/validation/tc-intr-clear.c
 - testsuites/validation/tc-intr-entry-install.c
 - testsuites/validation/tc-intr-entry-remove.c
+- testsuites/validation/tc-intr-get-affinity.c
 - testsuites/validation/tc-intr-get-attributes.c
 - testsuites/validation/tc-intr-is-pending.c
 - testsuites/validation/tc-intr-raise.c
diff --git a/testsuites/validation/tc-intr-get-affinity.c b/testsuites/validation/tc-intr-get-affinity.c
new file mode 100644
index 0000000000..43d8c75fec
--- /dev/null
+++ b/testsuites/validation/tc-intr-get-affinity.c
@@ -0,0 +1,639 @@
+ * @file
+ * @ingroup RTEMSTestCaseRtemsIntrReqGetAffinity
+ * Copyright (C) 2021 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+ * This file is part of the RTEMS quality process and was automatically
+ * generated.  If you find something that needs to be fixed or
+ * worded better please post a report or patch to an RTEMS mailing list
+ * or raise a bug report:
+ * https://www.rtems.org/bugs.html
+ * For information on updating and regenerating please refer to the How-To
+ * section in the Software Requirements Engineering chapter of the
+ * RTEMS Software Engineering manual.  The manual is provided as a part of
+ * a release.  For development sources please refer to the online
+ * documentation at:
+ * https://docs.rtems.org
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <string.h>
+#include <bsp/irq-generic.h>
+#include <rtems/irq-extension.h>
+#include "tx-support.h"
+#include <rtems/test.h>
+ * @defgroup RTEMSTestCaseRtemsIntrReqGetAffinity \
+ *   spec:/rtems/intr/req/get-affinity
+ * @ingroup RTEMSTestSuiteTestsuitesValidation0
+typedef enum {
+  RtemsIntrReqGetAffinity_Pre_Vector_Valid,
+  RtemsIntrReqGetAffinity_Pre_Vector_Invalid,
+  RtemsIntrReqGetAffinity_Pre_Vector_NA
+} RtemsIntrReqGetAffinity_Pre_Vector;
+typedef enum {
+  RtemsIntrReqGetAffinity_Pre_CPUSetSize_Valid,
+  RtemsIntrReqGetAffinity_Pre_CPUSetSize_TooSmall,
+  RtemsIntrReqGetAffinity_Pre_CPUSetSize_Askew,
+  RtemsIntrReqGetAffinity_Pre_CPUSetSize_NA
+} RtemsIntrReqGetAffinity_Pre_CPUSetSize;
+typedef enum {
+  RtemsIntrReqGetAffinity_Pre_CPUSet_Valid,
+  RtemsIntrReqGetAffinity_Pre_CPUSet_Null,
+  RtemsIntrReqGetAffinity_Pre_CPUSet_NA
+} RtemsIntrReqGetAffinity_Pre_CPUSet;
+typedef enum {
+  RtemsIntrReqGetAffinity_Pre_CanGetAffinity_Yes,
+  RtemsIntrReqGetAffinity_Pre_CanGetAffinity_No,
+  RtemsIntrReqGetAffinity_Pre_CanGetAffinity_NA
+} RtemsIntrReqGetAffinity_Pre_CanGetAffinity;
+typedef enum {
+  RtemsIntrReqGetAffinity_Post_Status_Ok,
+  RtemsIntrReqGetAffinity_Post_Status_InvAddr,
+  RtemsIntrReqGetAffinity_Post_Status_InvId,
+  RtemsIntrReqGetAffinity_Post_Status_InvSize,
+  RtemsIntrReqGetAffinity_Post_Status_Unsat,
+  RtemsIntrReqGetAffinity_Post_Status_NA
+} RtemsIntrReqGetAffinity_Post_Status;
+typedef enum {
+  RtemsIntrReqGetAffinity_Post_CPUSetObj_Set,
+  RtemsIntrReqGetAffinity_Post_CPUSetObj_Nop,
+  RtemsIntrReqGetAffinity_Post_CPUSetObj_NA
+} RtemsIntrReqGetAffinity_Post_CPUSetObj;
+ * @brief Test context for spec:/rtems/intr/req/get-affinity test case.
+typedef struct {
+   * @brief This member contains the current vector number.
+  rtems_vector_number vector;
+   * @brief This member contains some valid vector number.
+  rtems_vector_number some_vector;
+   * @brief This member provides the object referenced by the ``affinity``
+   *   parameter.
+  cpu_set_t cpuset_obj;
+   * @brief This member contains the return value of the
+   *   rtems_interrupt_get_affinity() call.
+  rtems_status_code status;
+   * @brief If this member is true, then the ``vector`` parameter shall be
+   *   valid.
+  bool valid_vector;
+   * @brief This member specifies if the ``affinity_size`` parameter value.
+  size_t cpusetsize;
+   * @brief This member specifies if the ``affinity`` parameter value.
+  cpu_set_t *cpuset;
+   * @brief This member defines the pre-condition states for the next action.
+  size_t pcs[ 4 ];
+   * @brief This member indicates if the test action loop is currently
+   *   executed.
+  bool in_action_loop;
+} RtemsIntrReqGetAffinity_Context;
+static RtemsIntrReqGetAffinity_Context
+  RtemsIntrReqGetAffinity_Instance;
+static const char * const RtemsIntrReqGetAffinity_PreDesc_Vector[] = {
+  "Valid",
+  "Invalid",
+  "NA"
+static const char * const RtemsIntrReqGetAffinity_PreDesc_CPUSetSize[] = {
+  "Valid",
+  "TooSmall",
+  "Askew",
+  "NA"
+static const char * const RtemsIntrReqGetAffinity_PreDesc_CPUSet[] = {
+  "Valid",
+  "Null",
+  "NA"
+static const char * const RtemsIntrReqGetAffinity_PreDesc_CanGetAffinity[] = {
+  "Yes",
+  "No",
+  "NA"
+static const char * const * const RtemsIntrReqGetAffinity_PreDesc[] = {
+  RtemsIntrReqGetAffinity_PreDesc_Vector,
+  RtemsIntrReqGetAffinity_PreDesc_CPUSetSize,
+  RtemsIntrReqGetAffinity_PreDesc_CPUSet,
+  RtemsIntrReqGetAffinity_PreDesc_CanGetAffinity,
+  NULL
+typedef RtemsIntrReqGetAffinity_Context Context;
+static void CheckGetAffinity(
+  Context                          *ctx,
+  const rtems_interrupt_attributes *attr
+  rtems_status_code sc;
+  sc = rtems_interrupt_get_affinity(
+    ctx->vector,
+    ctx->cpusetsize,
+    ctx->cpuset
+  if ( attr->can_get_affinity ) {
+    T_rsc_success( sc );
+  } else {
+    T_rsc( sc, RTEMS_UNSATISFIED );
+static void RtemsIntrReqGetAffinity_Pre_Vector_Prepare(
+  RtemsIntrReqGetAffinity_Context   *ctx,
+  RtemsIntrReqGetAffinity_Pre_Vector state
+  switch ( state ) {
+    case RtemsIntrReqGetAffinity_Pre_Vector_Valid: {
+       * While the ``vector`` parameter is associated with an interrupt vector.
+      ctx->valid_vector = true;
+      break;
+    case RtemsIntrReqGetAffinity_Pre_Vector_Invalid: {
+       * While the ``vector`` parameter is not associated with an interrupt
+       * vector.
+      ctx->valid_vector = false;
+      break;
+    case RtemsIntrReqGetAffinity_Pre_Vector_NA:
+      break;
+static void RtemsIntrReqGetAffinity_Pre_CPUSetSize_Prepare(
+  RtemsIntrReqGetAffinity_Pre_CPUSetSize state
+    case RtemsIntrReqGetAffinity_Pre_CPUSetSize_Valid: {
+       * While the ``affinity_size`` parameter is an integral multiple of the
+       * size of long, while the ``affinity_size`` parameter specifies a
+       * processor set which is large enough to contain the processor affinity
+       * set of the interrupt specified by ``vector``.
+      ctx->cpusetsize = sizeof( ctx->cpuset_obj );
+      break;
+    case RtemsIntrReqGetAffinity_Pre_CPUSetSize_TooSmall: {
+       * processor set which is not large enough to contain the processor
+       * affinity set of the interrupt specified by ``vector``.
+      ctx->cpusetsize = 0;
+      break;
+    case RtemsIntrReqGetAffinity_Pre_CPUSetSize_Askew: {
+       * While the ``affinity_size`` parameter is not an integral multiple of
+       * the size of long.
+      ctx->cpusetsize = SIZE_MAX;
+      break;
+    case RtemsIntrReqGetAffinity_Pre_CPUSetSize_NA:
+      break;
+static void RtemsIntrReqGetAffinity_Pre_CPUSet_Prepare(
+  RtemsIntrReqGetAffinity_Pre_CPUSet state
+    case RtemsIntrReqGetAffinity_Pre_CPUSet_Valid: {
+       * While the ``affinity`` parameter references an object of type
+       * cpu_set_t.
+      ctx->cpuset = &ctx->cpuset_obj;
+      break;
+    case RtemsIntrReqGetAffinity_Pre_CPUSet_Null: {
+       * While the ``affinity`` parameter is equal to NULL.
+      ctx->cpuset = NULL;
+      break;
+    case RtemsIntrReqGetAffinity_Pre_CPUSet_NA:
+      break;
+static void RtemsIntrReqGetAffinity_Pre_CanGetAffinity_Prepare(
+  RtemsIntrReqGetAffinity_Pre_CanGetAffinity state
+    case RtemsIntrReqGetAffinity_Pre_CanGetAffinity_Yes: {
+       * While getting the affinity for the interrupt vector specified by
+       * ``vector`` parameter is supported.
+      /* Validation done by CheckGetAffinity() for each interrupt vector */
+      break;
+    case RtemsIntrReqGetAffinity_Pre_CanGetAffinity_No: {
+       * ``vector`` parameter is not supported.
+      break;
+    case RtemsIntrReqGetAffinity_Pre_CanGetAffinity_NA:
+      break;
+static void RtemsIntrReqGetAffinity_Post_Status_Check(
+  RtemsIntrReqGetAffinity_Post_Status state
+    case RtemsIntrReqGetAffinity_Post_Status_Ok: {
+       * The return status of rtems_interrupt_get_affinity() shall be
+       * RTEMS_SUCCESSFUL.
+      break;
+    case RtemsIntrReqGetAffinity_Post_Status_InvAddr: {
+       * RTEMS_INVALID_ADDRESS.
+      T_rsc( ctx->status, RTEMS_INVALID_ADDRESS );
+      break;
+    case RtemsIntrReqGetAffinity_Post_Status_InvId: {
+       * RTEMS_INVALID_ID.
+      T_rsc( ctx->status, RTEMS_INVALID_ID );
+      break;
+    case RtemsIntrReqGetAffinity_Post_Status_InvSize: {
+       * RTEMS_INVALID_SIZE.
+      T_rsc( ctx->status, RTEMS_INVALID_SIZE );
+      break;
+    case RtemsIntrReqGetAffinity_Post_Status_Unsat: {
+       * RTEMS_UNSATISFIED.
+      break;
+    case RtemsIntrReqGetAffinity_Post_Status_NA:
+      break;
+static void RtemsIntrReqGetAffinity_Post_CPUSetObj_Check(
+  RtemsIntrReqGetAffinity_Post_CPUSetObj state
+    case RtemsIntrReqGetAffinity_Post_CPUSetObj_Set: {
+       * The value of the object referenced by the ``affinity`` parameter shall
+       * be set to the processor affinity set of the interrupt specified by the
+       * ``vector`` parameter at some point during the call after the return of
+       * the rtems_interrupt_get_affinity() call.
+      break;
+    case RtemsIntrReqGetAffinity_Post_CPUSetObj_Nop: {
+       * Objects referenced by the ``affinity`` parameter in past calls to
+       * rtems_interrupt_get_affinity() shall not be accessed by the
+       * Validation done by CheckGetAffinity() for each interrupt vector and in
+       * the action code.
+      break;
+    case RtemsIntrReqGetAffinity_Post_CPUSetObj_NA:
+      break;
+static void RtemsIntrReqGetAffinity_Setup(
+  rtems_interrupt_attributes required;
+  memset( &required, 0, sizeof( required ) );
+  required.can_get_affinity = true;
+  ctx->some_vector = GetValidInterruptVectorNumber( &required );
+static void RtemsIntrReqGetAffinity_Setup_Wrap( void *arg )
+  RtemsIntrReqGetAffinity_Context *ctx;
+  ctx = arg;
+  ctx->in_action_loop = false;
+  RtemsIntrReqGetAffinity_Setup( ctx );
+static void RtemsIntrReqGetAffinity_Action(
+  if (
+    ctx->valid_vector && ctx->cpusetsize == sizeof( ctx->cpuset_obj ) &&
+    ctx->cpuset == &ctx->cpuset_obj
+    for (
+      ctx->vector = 0;
+      ctx->vector < BSP_INTERRUPT_VECTOR_COUNT;
+      ++ctx->vector
+      rtems_interrupt_attributes attr;
+      memset( &attr, 0, sizeof( attr ) );
+      sc = rtems_interrupt_get_attributes( ctx->vector, &attr );
+      if ( sc == RTEMS_INVALID_ID ) {
+        continue;
+      CheckGetAffinity( ctx, &attr );
+  } else {
+    cpu_set_t set;
+    if ( ctx->valid_vector ) {
+      ctx->vector = ctx->some_vector;
+    } else {
+      ctx->vector = BSP_INTERRUPT_VECTOR_COUNT;
+    CPU_ZERO( &ctx->cpuset_obj );
+    ctx->status = rtems_interrupt_get_affinity(
+      ctx->vector,
+      ctx->cpusetsize,
+      ctx->cpuset
+    CPU_ZERO( &set );
+    T_eq_int( CPU_CMP( &ctx->cpuset_obj, &set ), 0 );
+typedef struct {
+  uint16_t Skip : 1;
+  uint16_t Pre_Vector_NA : 1;
+  uint16_t Pre_CPUSetSize_NA : 1;
+  uint16_t Pre_CPUSet_NA : 1;
+  uint16_t Pre_CanGetAffinity_NA : 1;
+  uint16_t Post_Status : 3;
+  uint16_t Post_CPUSetObj : 2;
+} RtemsIntrReqGetAffinity_Entry;
+static const RtemsIntrReqGetAffinity_Entry
+RtemsIntrReqGetAffinity_Entries[] = {
+  { 0, 0, 0, 0, 0, RtemsIntrReqGetAffinity_Post_Status_InvAddr,
+    RtemsIntrReqGetAffinity_Post_CPUSetObj_Nop },
+  { 0, 0, 0, 0, 0, RtemsIntrReqGetAffinity_Post_Status_InvId,
+  { 0, 0, 0, 0, 1, RtemsIntrReqGetAffinity_Post_Status_InvAddr,
+  { 0, 0, 0, 0, 0, RtemsIntrReqGetAffinity_Post_Status_InvSize,
+  { 0, 0, 0, 0, 0, RtemsIntrReqGetAffinity_Post_Status_Unsat,
+  { 0, 0, 0, 0, 0, RtemsIntrReqGetAffinity_Post_Status_Ok,
+    RtemsIntrReqGetAffinity_Post_CPUSetObj_Set }
+static const uint8_t
+RtemsIntrReqGetAffinity_Map[] = {
+  5, 4, 0, 0, 3, 4, 0, 0, 3, 3, 0, 0, 1, 1, 2, 2, 1, 1, 2, 2, 1, 1, 2, 2
+static size_t RtemsIntrReqGetAffinity_Scope( void *arg, char *buf, size_t n )
+  ctx = arg;
+  if ( ctx->in_action_loop ) {
+    return T_get_scope( RtemsIntrReqGetAffinity_PreDesc, buf, n, ctx->pcs );
+  return 0;
+static T_fixture RtemsIntrReqGetAffinity_Fixture = {
+  .setup = RtemsIntrReqGetAffinity_Setup_Wrap,
+  .stop = NULL,
+  .teardown = NULL,
+  .scope = RtemsIntrReqGetAffinity_Scope,
+  .initial_context = &RtemsIntrReqGetAffinity_Instance
+static inline RtemsIntrReqGetAffinity_Entry RtemsIntrReqGetAffinity_GetEntry(
+  size_t index
+  return RtemsIntrReqGetAffinity_Entries[
+    RtemsIntrReqGetAffinity_Map[ index ]
+ * @fn void T_case_body_RtemsIntrReqGetAffinity( void )
+T_TEST_CASE_FIXTURE(
+  RtemsIntrReqGetAffinity,
+  &RtemsIntrReqGetAffinity_Fixture
+  size_t index;
+  ctx = T_fixture_context();
+  ctx->in_action_loop = true;
+  index = 0;
+  for (
+    ctx->pcs[ 0 ] = RtemsIntrReqGetAffinity_Pre_Vector_Valid;
+    ctx->pcs[ 0 ] < RtemsIntrReqGetAffinity_Pre_Vector_NA;
+    ++ctx->pcs[ 0 ]
+    for (
+      ctx->pcs[ 1 ] = RtemsIntrReqGetAffinity_Pre_CPUSetSize_Valid;
+      ctx->pcs[ 1 ] < RtemsIntrReqGetAffinity_Pre_CPUSetSize_NA;
+      ++ctx->pcs[ 1 ]
+      for (
+        ctx->pcs[ 2 ] = RtemsIntrReqGetAffinity_Pre_CPUSet_Valid;
+        ctx->pcs[ 2 ] < RtemsIntrReqGetAffinity_Pre_CPUSet_NA;
+        ++ctx->pcs[ 2 ]
+        for (
+          ctx->pcs[ 3 ] = RtemsIntrReqGetAffinity_Pre_CanGetAffinity_Yes;
+          ctx->pcs[ 3 ] < RtemsIntrReqGetAffinity_Pre_CanGetAffinity_NA;
+          ++ctx->pcs[ 3 ]
+          RtemsIntrReqGetAffinity_Entry entry;
+          size_t pcs[ 4 ];
+          entry = RtemsIntrReqGetAffinity_GetEntry( index );
+          ++index;
+          memcpy( pcs, ctx->pcs, sizeof( pcs ) );
+          if ( entry.Pre_CanGetAffinity_NA ) {
+            ctx->pcs[ 3 ] = RtemsIntrReqGetAffinity_Pre_CanGetAffinity_NA;
+          RtemsIntrReqGetAffinity_Pre_Vector_Prepare( ctx, ctx->pcs[ 0 ] );
+          RtemsIntrReqGetAffinity_Pre_CPUSetSize_Prepare( ctx, ctx->pcs[ 1 ] );
+          RtemsIntrReqGetAffinity_Pre_CPUSet_Prepare( ctx, ctx->pcs[ 2 ] );
+          RtemsIntrReqGetAffinity_Pre_CanGetAffinity_Prepare(
+            ctx,
+            ctx->pcs[ 3 ]
+          RtemsIntrReqGetAffinity_Action( ctx );
+          RtemsIntrReqGetAffinity_Post_Status_Check( ctx, entry.Post_Status );
+          RtemsIntrReqGetAffinity_Post_CPUSetObj_Check(
+            ctx,
+            entry.Post_CPUSetObj
+          memcpy( ctx->pcs, pcs, sizeof( ctx->pcs ) );
2.26.2
