[PATCH v3 42/42] validation: Test rtems_interrupt_set_affinity()
Sebastian Huber
Fri Jul 23 13:56:50 UTC 2021
Update #3269.
.../testsuites/validation/validation-0.yml | 1 +
testsuites/validation/tc-intr-set-affinity.c | 670 ++++++++++++++++++
2 files changed, 671 insertions(+)
create mode 100644 testsuites/validation/tc-intr-set-affinity.c
diff --git a/spec/build/testsuites/validation/validation-0.yml b/spec/build/testsuites/validation/validation-0.yml
index 5b337b3a34..9f7ab9f6c1 100644
--- a/spec/build/testsuites/validation/validation-0.yml
+++ b/spec/build/testsuites/validation/validation-0.yml
@@ -23,6 +23,7 @@ source:
- testsuites/validation/tc-intr-is-pending.c
- testsuites/validation/tc-intr-raise.c
- testsuites/validation/tc-intr-raise-on.c
+- testsuites/validation/tc-intr-set-affinity.c
- testsuites/validation/tc-intr-vector-disable.c
- testsuites/validation/tc-intr-vector-enable.c
- testsuites/validation/tc-intr-vector-is-enabled.c
diff --git a/testsuites/validation/tc-intr-set-affinity.c b/testsuites/validation/tc-intr-set-affinity.c
new file mode 100644
index 0000000000..b2b47baea8
--- /dev/null
+++ b/testsuites/validation/tc-intr-set-affinity.c
@@ -0,0 +1,670 @@
+ * @file
+ * @ingroup RTEMSTestCaseRtemsIntrReqSetAffinity
+ * Copyright (C) 2021 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+ * This file is part of the RTEMS quality process and was automatically
+ * generated. If you find something that needs to be fixed or
+ * worded better please post a report or patch to an RTEMS mailing list
+ * or raise a bug report:
+ * https://www.rtems.org/bugs.html
+ * For information on updating and regenerating please refer to the How-To
+ * section in the Software Requirements Engineering chapter of the
+ * RTEMS Software Engineering manual. The manual is provided as a part of
+ * a release. For development sources please refer to the online
+ * documentation at:
+ * https://docs.rtems.org
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <bsp/irq-generic.h>
+#include <rtems/irq-extension.h>
+#include "tx-support.h"
+#include <rtems/test.h>
+ * @defgroup RTEMSTestCaseRtemsIntrReqSetAffinity \
+ * spec:/rtems/intr/req/set-affinity
+ * @ingroup RTEMSTestSuiteTestsuitesValidation0
+typedef enum {
+ RtemsIntrReqSetAffinity_Pre_Vector_Valid,
+ RtemsIntrReqSetAffinity_Pre_Vector_Invalid,
+ RtemsIntrReqSetAffinity_Pre_Vector_NA
+} RtemsIntrReqSetAffinity_Pre_Vector;
+typedef enum {
+ RtemsIntrReqSetAffinity_Pre_CPUSetKind_Valid,
+ RtemsIntrReqSetAffinity_Pre_CPUSetKind_Huge,
+ RtemsIntrReqSetAffinity_Pre_CPUSetKind_Askew,
+ RtemsIntrReqSetAffinity_Pre_CPUSetKind_NA
+} RtemsIntrReqSetAffinity_Pre_CPUSetKind;
+typedef enum {
+ RtemsIntrReqSetAffinity_Pre_CPUSet_Valid,
+ RtemsIntrReqSetAffinity_Pre_CPUSet_Null,
+ RtemsIntrReqSetAffinity_Pre_CPUSet_NA
+} RtemsIntrReqSetAffinity_Pre_CPUSet;
+typedef enum {
+ RtemsIntrReqSetAffinity_Pre_CanSetAffinity_Yes,
+ RtemsIntrReqSetAffinity_Pre_CanSetAffinity_No,
+ RtemsIntrReqSetAffinity_Pre_CanSetAffinity_NA
+} RtemsIntrReqSetAffinity_Pre_CanSetAffinity;
+typedef enum {
+ RtemsIntrReqSetAffinity_Post_Status_Ok,
+ RtemsIntrReqSetAffinity_Post_Status_InvAddr,
+ RtemsIntrReqSetAffinity_Post_Status_InvId,
+ RtemsIntrReqSetAffinity_Post_Status_InvNum,
+ RtemsIntrReqSetAffinity_Post_Status_Unsat,
+ RtemsIntrReqSetAffinity_Post_Status_NA
+} RtemsIntrReqSetAffinity_Post_Status;
+typedef enum {
+ RtemsIntrReqSetAffinity_Post_SetAffinity_Yes,
+ RtemsIntrReqSetAffinity_Post_SetAffinity_Nop,
+ RtemsIntrReqSetAffinity_Post_SetAffinity_NA
+} RtemsIntrReqSetAffinity_Post_SetAffinity;
+ * @brief Test context for spec:/rtems/intr/req/set-affinity test case.
+typedef struct {
+ * @brief This member contains the current vector number.
+ rtems_vector_number vector;
+ * @brief This member contains some valid vector number.
+ rtems_vector_number some_vector;
+ * @brief This member provides the object referenced by the ``affinity``
+ * parameter.
+ cpu_set_t cpuset_obj[ 2 ];
+ * @brief This member contains the return value of the
+ * rtems_interrupt_set_affinity() call.
+ rtems_status_code status;
+ * @brief If this member is true, then the ``vector`` parameter shall be
+ * valid.
+ bool valid_vector;
+ * @brief This member specifies if the ``affinity_size`` parameter value.
+ size_t cpusetsize;
+ * @brief This member specifies if the ``affinity`` parameter value.
+ cpu_set_t *cpuset;
+ * @brief This member defines the pre-condition states for the next action.
+ size_t pcs[ 4 ];
+ * @brief This member indicates if the test action loop is currently
+ * executed.
+ bool in_action_loop;
+} RtemsIntrReqSetAffinity_Context;
+static RtemsIntrReqSetAffinity_Context
+ RtemsIntrReqSetAffinity_Instance;
+static const char * const RtemsIntrReqSetAffinity_PreDesc_Vector[] = {
+ "Valid",
+ "Invalid",
+ "NA"
+static const char * const RtemsIntrReqSetAffinity_PreDesc_CPUSetKind[] = {
+ "Valid",
+ "Huge",
+ "Askew",
+ "NA"
+static const char * const RtemsIntrReqSetAffinity_PreDesc_CPUSet[] = {
+ "Valid",
+ "Null",
+ "NA"
+static const char * const RtemsIntrReqSetAffinity_PreDesc_CanSetAffinity[] = {
+ "Yes",
+ "No",
+ "NA"
+static const char * const * const RtemsIntrReqSetAffinity_PreDesc[] = {
+ RtemsIntrReqSetAffinity_PreDesc_Vector,
+ RtemsIntrReqSetAffinity_PreDesc_CPUSetKind,
+ RtemsIntrReqSetAffinity_PreDesc_CPUSet,
+ RtemsIntrReqSetAffinity_PreDesc_CanSetAffinity,
+ NULL
+typedef RtemsIntrReqSetAffinity_Context Context;
+static void CheckSetAffinity(
+ Context *ctx,
+ const rtems_interrupt_attributes *attr
+ rtems_status_code sc;
+ cpu_set_t set;
+ cpu_set_t set2;
+ CPU_ZERO( &set );
+ if ( attr->can_get_affinity ) {
+ sc = rtems_interrupt_get_affinity( ctx->vector, sizeof( set ), &set );
+ T_rsc_success( sc );
+ } else {
+ CPU_SET( 0, &set );
+ CPU_COPY( &set, &ctx->cpuset_obj[ 0 ] );
+ sc = rtems_interrupt_set_affinity(
+ ctx->vector,
+ ctx->cpusetsize,
+ ctx->cpuset
+ if ( attr->can_set_affinity ) {
+ } else {
+ T_rsc( sc, RTEMS_UNSATISFIED );
+ CPU_FILL( &set2 );
+ sc = rtems_interrupt_get_affinity( ctx->vector, sizeof( set2 ), &set2 );
+ T_eq_int( CPU_CMP( &set, &set2 ), 0 );
+static void RtemsIntrReqSetAffinity_Pre_Vector_Prepare(
+ RtemsIntrReqSetAffinity_Context *ctx,
+ RtemsIntrReqSetAffinity_Pre_Vector state
+ switch ( state ) {
+ case RtemsIntrReqSetAffinity_Pre_Vector_Valid: {
+ * While the ``vector`` parameter is associated with an interrupt vector.
+ ctx->valid_vector = true;
+ break;
+ case RtemsIntrReqSetAffinity_Pre_Vector_Invalid: {
+ * While the ``vector`` parameter is not associated with an interrupt
+ * vector.
+ ctx->valid_vector = false;
+ break;
+ case RtemsIntrReqSetAffinity_Pre_Vector_NA:
+ break;
+static void RtemsIntrReqSetAffinity_Pre_CPUSetKind_Prepare(
+ RtemsIntrReqSetAffinity_Pre_CPUSetKind state
+ case RtemsIntrReqSetAffinity_Pre_CPUSetKind_Valid: {
+ * While the ``affinity_size`` parameter is an integral multiple of the
+ * size of long, while the ``affinity_size`` and ``affinity`` parameter
+ * specify a processor set which is within the implementation limits.
+ ctx->cpusetsize = sizeof( ctx->cpuset_obj[ 0 ] );
+ break;
+ case RtemsIntrReqSetAffinity_Pre_CPUSetKind_Huge: {
+ * specify a processor set which exceeds the implementation limits.
+ ctx->cpusetsize = sizeof( ctx->cpuset_obj );
+ CPU_ZERO( &ctx->cpuset_obj[ 0 ] );
+ break;
+ case RtemsIntrReqSetAffinity_Pre_CPUSetKind_Askew: {
+ * While the ``affinity_size`` parameter is not an integral multiple of
+ * the size of long.
+ ctx->cpusetsize = SIZE_MAX;
+ break;
+ case RtemsIntrReqSetAffinity_Pre_CPUSetKind_NA:
+ break;
+static void RtemsIntrReqSetAffinity_Pre_CPUSet_Prepare(
+ RtemsIntrReqSetAffinity_Pre_CPUSet state
+ case RtemsIntrReqSetAffinity_Pre_CPUSet_Valid: {
+ * While the ``affinity`` parameter references an object of type
+ * cpu_set_t.
+ ctx->cpuset = &ctx->cpuset_obj[ 0 ];
+ break;
+ case RtemsIntrReqSetAffinity_Pre_CPUSet_Null: {
+ * While the ``affinity`` parameter is equal to NULL.
+ ctx->cpuset = NULL;
+ break;
+ case RtemsIntrReqSetAffinity_Pre_CPUSet_NA:
+ break;
+static void RtemsIntrReqSetAffinity_Pre_CanSetAffinity_Prepare(
+ RtemsIntrReqSetAffinity_Pre_CanSetAffinity state
+ case RtemsIntrReqSetAffinity_Pre_CanSetAffinity_Yes: {
+ * While setting the affinity for the interrupt vector specified by
+ * ``vector`` parameter is supported.
+ /* Validation done by CheckSetAffinity() for each interrupt vector */
+ break;
+ case RtemsIntrReqSetAffinity_Pre_CanSetAffinity_No: {
+ * ``vector`` parameter is not supported.
+ break;
+ case RtemsIntrReqSetAffinity_Pre_CanSetAffinity_NA:
+ break;
+static void RtemsIntrReqSetAffinity_Post_Status_Check(
+ RtemsIntrReqSetAffinity_Post_Status state
+ case RtemsIntrReqSetAffinity_Post_Status_Ok: {
+ * The return status of rtems_interrupt_set_affinity() shall be
+ * RTEMS_SUCCESSFUL.
+ break;
+ case RtemsIntrReqSetAffinity_Post_Status_InvAddr: {
+ * RTEMS_INVALID_ADDRESS.
+ T_rsc( ctx->status, RTEMS_INVALID_ADDRESS );
+ break;
+ case RtemsIntrReqSetAffinity_Post_Status_InvId: {
+ * RTEMS_INVALID_ID.
+ T_rsc( ctx->status, RTEMS_INVALID_ID );
+ break;
+ case RtemsIntrReqSetAffinity_Post_Status_InvNum: {
+ * RTEMS_INVALID_NUMBER.
+ T_rsc( ctx->status, RTEMS_INVALID_NUMBER );
+ break;
+ case RtemsIntrReqSetAffinity_Post_Status_Unsat: {
+ * RTEMS_UNSATISFIED.
+ break;
+ case RtemsIntrReqSetAffinity_Post_Status_NA:
+ break;
+static void RtemsIntrReqSetAffinity_Post_SetAffinity_Check(
+ RtemsIntrReqSetAffinity_Post_SetAffinity state
+ case RtemsIntrReqSetAffinity_Post_SetAffinity_Yes: {
+ * The affinity set of the interrupt specified by ``vector`` shall be set
+ * to the processor set specified by ``affinity_size`` and ``affinity``
+ * at some point during the rtems_interrupt_set_affinity() call.
+ break;
+ case RtemsIntrReqSetAffinity_Post_SetAffinity_Nop: {
+ * The affinity set of the interrupt specified by ``vector`` shall not be
+ * modified by the rtems_interrupt_set_affinity() call.
+ * Validation done by CheckSetAffinity() for each interrupt vector and in
+ * the action code.
+ break;
+ case RtemsIntrReqSetAffinity_Post_SetAffinity_NA:
+ break;
+static void RtemsIntrReqSetAffinity_Setup(
+ ctx->some_vector = GetValidInterruptVectorNumber( NULL );
+static void RtemsIntrReqSetAffinity_Setup_Wrap( void *arg )
+ RtemsIntrReqSetAffinity_Context *ctx;
+ ctx = arg;
+ ctx->in_action_loop = false;
+ RtemsIntrReqSetAffinity_Setup( ctx );
+static void RtemsIntrReqSetAffinity_Prepare(
+ CPU_FILL_S( sizeof( ctx->cpuset_obj ), &ctx->cpuset_obj[ 0 ] );
+static void RtemsIntrReqSetAffinity_Action(
+ if (
+ ctx->valid_vector && ctx->cpusetsize == sizeof( ctx->cpuset_obj[ 0 ] ) &&
+ ctx->cpuset == &ctx->cpuset_obj[ 0 ]
+ for (
+ ctx->vector = 0;
+ ctx->vector < BSP_INTERRUPT_VECTOR_COUNT;
+ ++ctx->vector
+ rtems_interrupt_attributes attr;
+ memset( &attr, 0, sizeof( attr ) );
+ sc = rtems_interrupt_get_attributes( ctx->vector, &attr );
+ if ( sc == RTEMS_INVALID_ID ) {
+ continue;
+ CheckSetAffinity( ctx, &attr );
+ } else {
+ cpu_set_t set;
+ cpu_set_t set2;
+ CPU_ZERO( &set );
+ CPU_ZERO( &set2 );
+ if ( ctx->valid_vector ) {
+ ctx->vector = ctx->some_vector;
+ T_true( sc == RTEMS_SUCCESSFUL || sc == RTEMS_UNSATISFIED );
+ } else {
+ ctx->vector = BSP_INTERRUPT_VECTOR_COUNT;
+ ctx->status = rtems_interrupt_set_affinity(
+ ctx->vector,
+ ctx->cpusetsize,
+ ctx->cpuset
+typedef struct {
+ uint16_t Skip : 1;
+ uint16_t Pre_Vector_NA : 1;
+ uint16_t Pre_CPUSetKind_NA : 1;
+ uint16_t Pre_CPUSet_NA : 1;
+ uint16_t Pre_CanSetAffinity_NA : 1;
+ uint16_t Post_Status : 3;
+ uint16_t Post_SetAffinity : 2;
+} RtemsIntrReqSetAffinity_Entry;
+static const RtemsIntrReqSetAffinity_Entry
+RtemsIntrReqSetAffinity_Entries[] = {
+ { 0, 0, 0, 0, 0, RtemsIntrReqSetAffinity_Post_Status_InvAddr,
+ RtemsIntrReqSetAffinity_Post_SetAffinity_Nop },
+ { 0, 0, 0, 0, 1, RtemsIntrReqSetAffinity_Post_Status_InvId,
+ RtemsIntrReqSetAffinity_Post_SetAffinity_NA },
+ { 0, 0, 0, 0, 1, RtemsIntrReqSetAffinity_Post_Status_InvAddr,
+ { 0, 0, 0, 0, 0, RtemsIntrReqSetAffinity_Post_Status_InvNum,
+ { 0, 0, 0, 0, 0, RtemsIntrReqSetAffinity_Post_Status_Ok,
+ RtemsIntrReqSetAffinity_Post_SetAffinity_Yes },
+ { 0, 0, 0, 0, 0, RtemsIntrReqSetAffinity_Post_Status_Unsat,
+static const uint8_t
+RtemsIntrReqSetAffinity_Map[] = {
+ 4, 5, 0, 0, 3, 3, 0, 0, 3, 3, 0, 0, 1, 1, 2, 2, 1, 1, 2, 2, 1, 1, 2, 2
+static size_t RtemsIntrReqSetAffinity_Scope( void *arg, char *buf, size_t n )
+ ctx = arg;
+ if ( ctx->in_action_loop ) {
+ return T_get_scope( RtemsIntrReqSetAffinity_PreDesc, buf, n, ctx->pcs );
+ return 0;
+static T_fixture RtemsIntrReqSetAffinity_Fixture = {
+ .setup = RtemsIntrReqSetAffinity_Setup_Wrap,
+ .stop = NULL,
+ .teardown = NULL,
+ .scope = RtemsIntrReqSetAffinity_Scope,
+ .initial_context = &RtemsIntrReqSetAffinity_Instance
+static inline RtemsIntrReqSetAffinity_Entry RtemsIntrReqSetAffinity_GetEntry(
+ size_t index
+ return RtemsIntrReqSetAffinity_Entries[
+ RtemsIntrReqSetAffinity_Map[ index ]
+ * @fn void T_case_body_RtemsIntrReqSetAffinity( void )
+T_TEST_CASE_FIXTURE(
+ RtemsIntrReqSetAffinity,
+ &RtemsIntrReqSetAffinity_Fixture
+ size_t index;
+ ctx = T_fixture_context();
+ ctx->in_action_loop = true;
+ index = 0;
+ for (
+ ctx->pcs[ 0 ] = RtemsIntrReqSetAffinity_Pre_Vector_Valid;
+ ctx->pcs[ 0 ] < RtemsIntrReqSetAffinity_Pre_Vector_NA;
+ ++ctx->pcs[ 0 ]
+ for (
+ ctx->pcs[ 1 ] = RtemsIntrReqSetAffinity_Pre_CPUSetKind_Valid;
+ ctx->pcs[ 1 ] < RtemsIntrReqSetAffinity_Pre_CPUSetKind_NA;
+ ++ctx->pcs[ 1 ]
+ for (
+ ctx->pcs[ 2 ] = RtemsIntrReqSetAffinity_Pre_CPUSet_Valid;
+ ctx->pcs[ 2 ] < RtemsIntrReqSetAffinity_Pre_CPUSet_NA;
+ ++ctx->pcs[ 2 ]
+ for (
+ ctx->pcs[ 3 ] = RtemsIntrReqSetAffinity_Pre_CanSetAffinity_Yes;
+ ctx->pcs[ 3 ] < RtemsIntrReqSetAffinity_Pre_CanSetAffinity_NA;
+ ++ctx->pcs[ 3 ]
+ RtemsIntrReqSetAffinity_Entry entry;
+ size_t pcs[ 4 ];
+ entry = RtemsIntrReqSetAffinity_GetEntry( index );
+ ++index;
+ memcpy( pcs, ctx->pcs, sizeof( pcs ) );
+ if ( entry.Pre_CanSetAffinity_NA ) {
+ ctx->pcs[ 3 ] = RtemsIntrReqSetAffinity_Pre_CanSetAffinity_NA;
+ RtemsIntrReqSetAffinity_Prepare( ctx );
+ RtemsIntrReqSetAffinity_Pre_Vector_Prepare( ctx, ctx->pcs[ 0 ] );
+ RtemsIntrReqSetAffinity_Pre_CPUSetKind_Prepare( ctx, ctx->pcs[ 1 ] );
+ RtemsIntrReqSetAffinity_Pre_CPUSet_Prepare( ctx, ctx->pcs[ 2 ] );
+ RtemsIntrReqSetAffinity_Pre_CanSetAffinity_Prepare(
+ ctx,
+ ctx->pcs[ 3 ]
+ RtemsIntrReqSetAffinity_Action( ctx );
+ RtemsIntrReqSetAffinity_Post_Status_Check( ctx, entry.Post_Status );
+ RtemsIntrReqSetAffinity_Post_SetAffinity_Check(
+ ctx,
+ entry.Post_SetAffinity
+ memcpy( ctx->pcs, pcs, sizeof( ctx->pcs ) );
2.26.2
