[PATCH v3 20/42] sparc/irq: Implement new interrupt directives
Sebastian Huber
Fri Jul 23 13:56:28 UTC 2021
Update #3269.
bsps/sparc/erc32/include/bsp/irq.h | 3 +-
bsps/sparc/erc32/include/erc32.h | 12 ++++-
bsps/sparc/leon2/include/bsp/irq.h | 3 +-
bsps/sparc/leon2/include/leon.h | 16 +++++-
bsps/sparc/leon3/start/eirq.c | 87 +++++++++++++++++++++++++++---
bsps/sparc/shared/irq/irq-shared.c | 48 ++++++++++++++---
6 files changed, 148 insertions(+), 21 deletions(-)
diff --git a/bsps/sparc/erc32/include/bsp/irq.h b/bsps/sparc/erc32/include/bsp/irq.h
index a61f51d6b6..83b383ba7a 100644
--- a/bsps/sparc/erc32/include/bsp/irq.h
+++ b/bsps/sparc/erc32/include/bsp/irq.h
@@ -23,8 +23,7 @@
#define BSP_INTERRUPT_VECTOR_MAX_STD 15 /* Standard IRQ controller */
#define BSP_INTERRUPT_VECTOR_COUNT (BSP_INTERRUPT_VECTOR_MAX_STD + 1)
-/* No extra check is needed */
-#undef BSP_INTERRUPT_CUSTOM_VALID_VECTOR
+#define BSP_INTERRUPT_CUSTOM_VALID_VECTOR
RTEMS_INLINE_ROUTINE rtems_status_code bsp_interrupt_set_affinity(
rtems_vector_number vector,
diff --git a/bsps/sparc/erc32/include/erc32.h b/bsps/sparc/erc32/include/erc32.h
index a677b13d25..f9cdbc960a 100644
--- a/bsps/sparc/erc32/include/erc32.h
+++ b/bsps/sparc/erc32/include/erc32.h
@@ -352,7 +352,7 @@ static __inline__ int bsp_irq_fixup(int irq)
_level = sparc_disable_interrupts(); \
ERC32_MEC.Test_Control = ERC32_MEC.Test_Control | 0x80000; \
- ERC32_MEC.Interrupt_Force = (1 << (_source)); \
+ ERC32_MEC.Interrupt_Force |= (1 << (_source)); \
sparc_enable_interrupts( _level ); \
} while (0)
@@ -406,7 +406,17 @@ static __inline__ int bsp_irq_fixup(int irq)
/* Make all SPARC BSPs have common macros for interrupt handling on local CPU */
#define BSP_Clear_interrupt(_source) ERC32_Clear_interrupt(_source)
#define BSP_Force_interrupt(_source) ERC32_Force_interrupt(_source)
+#define BSP_Clear_forced_interrupt( _source ) \
+ do { \
+ uint32_t _level; \
+ _level = sparc_disable_interrupts(); \
+ ERC32_MEC.Interrupt_Force &= ~(1 << (_source)); \
+ sparc_enable_interrupts( _level ); \
+ } while (0)
#define BSP_Is_interrupt_pending(_source) ERC32_Is_interrupt_pending(_source)
+#define BSP_Is_interrupt_forced(_source) \
+ (ERC32_MEC.Interrupt_Force & (1 << (_source)))
#define BSP_Is_interrupt_masked(_source) ERC32_Is_interrupt_masked(_source)
#define BSP_Unmask_interrupt(_source) ERC32_Unmask_interrupt(_source)
#define BSP_Mask_interrupt(_source) ERC32_Mask_interrupt(_source)
diff --git a/bsps/sparc/leon2/include/bsp/irq.h b/bsps/sparc/leon2/include/bsp/irq.h
index 5f2359014a..a4ce3c55ff 100644
--- a/bsps/sparc/leon2/include/bsp/irq.h
+++ b/bsps/sparc/leon2/include/bsp/irq.h
@@ -21,7 +21,6 @@
#endif /* LIBBSP_LEON2_IRQ_CONFIG_H */
diff --git a/bsps/sparc/leon2/include/leon.h b/bsps/sparc/leon2/include/leon.h
index fc90e1f7e6..11196aee6d 100644
--- a/bsps/sparc/leon2/include/leon.h
+++ b/bsps/sparc/leon2/include/leon.h
@@ -295,7 +295,11 @@ static __inline__ int bsp_irq_fixup(int irq)
#define LEON_Force_interrupt( _source ) \
do { \
- LEON_REG.Interrupt_Force = (1 << (_source)); \
+ LEON_REG.Interrupt_Force |= (1 << (_source)); \
} while (0)
#define LEON_Is_interrupt_pending( _source ) \
@@ -348,7 +352,17 @@ static __inline__ int bsp_irq_fixup(int irq)
/* Make all SPARC BSPs have common macros for interrupt handling */
#define BSP_Clear_interrupt(_source) LEON_Clear_interrupt(_source)
#define BSP_Force_interrupt(_source) LEON_Force_interrupt(_source)
+ do { \
+ LEON_REG.Interrupt_Force &= ~(1 << (_source)); \
+ } while (0)
#define BSP_Is_interrupt_pending(_source) LEON_Is_interrupt_pending(_source)
+ (LEON_REG.Interrupt_Force & (1 << (_source)))
#define BSP_Is_interrupt_masked(_source) LEON_Is_interrupt_masked(_source)
#define BSP_Unmask_interrupt(_source) LEON_Unmask_interrupt(_source)
#define BSP_Mask_interrupt(_source) LEON_Mask_interrupt(_source)
diff --git a/bsps/sparc/leon3/start/eirq.c b/bsps/sparc/leon3/start/eirq.c
index 5519d6efe7..80c0efd3fa 100644
--- a/bsps/sparc/leon3/start/eirq.c
+++ b/bsps/sparc/leon3/start/eirq.c
@@ -66,6 +66,20 @@ rtems_status_code bsp_interrupt_get_attributes(
rtems_interrupt_attributes *attributes
+ bool is_standard_interrupt;
+ is_standard_interrupt = (vector <= BSP_INTERRUPT_VECTOR_MAX_STD);
+ attributes->is_maskable = (vector != 15);
+ attributes->can_enable = true;
+ attributes->maybe_enable = true;
+ attributes->can_disable = true;
+ attributes->maybe_disable = true;
+ attributes->can_raise = true;
+ attributes->can_raise_on = is_standard_interrupt;
+ attributes->can_clear = true;
+ attributes->cleared_by_acknowledge = true;
+ attributes->can_get_affinity = is_standard_interrupt;
+ attributes->can_set_affinity = is_standard_interrupt;
return RTEMS_SUCCESSFUL;
@@ -74,16 +88,56 @@ rtems_status_code bsp_interrupt_is_pending(
bool *pending
+#if defined(RTEMS_SMP)
+ rtems_interrupt_level level;
+ uint32_t bit;
bsp_interrupt_assert(bsp_interrupt_is_valid_vector(vector));
bsp_interrupt_assert(pending != NULL);
- *pending = false;
- return RTEMS_UNSATISFIED;
+ bit = 1U << vector;
+ rtems_interrupt_local_disable(level);
+ *pending = (LEON3_IrqCtrl_Regs->ipend & bit) != 0 ||
+ (LEON3_IrqCtrl_Regs->force[rtems_scheduler_get_processor()] & bit) != 0;
+ rtems_interrupt_local_enable(level);
+ return RTEMS_SUCCESSFUL;
+#else
+ bsp_interrupt_assert(bsp_interrupt_is_valid_vector(vector));
+ *pending = !BSP_Is_interrupt_pending(vector);
+#endif
rtems_status_code bsp_interrupt_raise(rtems_vector_number vector)
+ uint32_t bit;
+ if ( vector <= BSP_INTERRUPT_VECTOR_MAX_STD ) {
+ uint32_t cpu_count;
+ uint32_t cpu_index;
+ cpu_count = rtems_scheduler_get_processor_maximum();
+ for (cpu_index = 0; cpu_index < cpu_count; ++cpu_index) {
+ LEON3_IrqCtrl_Regs->force[cpu_index] = bit;
+ } else {
+ rtems_interrupt_lock_context lock_context;
+ * This is a very dangerous operation and should only be used for test
+ * software. We may accidentally clear the pending state set by
+ * peripherals with this read-modify-write operation.
+ LEON3_IRQCTRL_ACQUIRE(&lock_context);
+ LEON3_IrqCtrl_Regs->ipend |= bit;
+ LEON3_IRQCTRL_RELEASE(&lock_context);
@@ -93,14 +147,31 @@ rtems_status_code bsp_interrupt_raise_on(
+ bsp_interrupt_assert(cpu_index < rtems_scheduler_get_processor_maximum());
+ if ( vector > BSP_INTERRUPT_VECTOR_MAX_STD ) {
+ return RTEMS_UNSATISFIED;
+ LEON3_IrqCtrl_Regs->force[cpu_index] = 1U << vector;
#endif
rtems_status_code bsp_interrupt_clear(rtems_vector_number vector)
+ uint32_t bit;
+ LEON3_IrqCtrl_Regs->iclear = bit;
+ if (vector <= BSP_INTERRUPT_VECTOR_MAX_STD) {
+ LEON3_IrqCtrl_Regs->force[rtems_scheduler_get_processor()] = bit << 16;
rtems_status_code bsp_interrupt_vector_is_enabled(
@@ -109,9 +180,9 @@ rtems_status_code bsp_interrupt_vector_is_enabled(
- bsp_interrupt_assert(enabled != NULL);
- *enabled = false;
+ *enabled =
+ !BSP_Cpu_Is_interrupt_masked(vector, _LEON3_Get_current_processor());
diff --git a/bsps/sparc/shared/irq/irq-shared.c b/bsps/sparc/shared/irq/irq-shared.c
index 68ad57d723..8896aca761 100644
--- a/bsps/sparc/shared/irq/irq-shared.c
+++ b/bsps/sparc/shared/irq/irq-shared.c
@@ -26,17 +26,41 @@ static inline int bsp_irq_cpu(int irq)
#if !defined(LEON3)
+bool bsp_interrupt_is_valid_vector(rtems_vector_number vector)
+ if (vector == 0) {
+ return false;
+ return vector <= BSP_INTERRUPT_VECTOR_MAX_STD;
rtems_status_code bsp_interrupt_facility_initialize(void)
/* Nothing to do */
+static bool is_maskable(rtems_vector_number vector)
+ return vector != 15;
+ attributes->is_maskable = is_maskable(vector);
+ attributes->can_disable = is_maskable(vector);
+ attributes->maybe_disable = is_maskable(vector);
+ attributes->can_raise_on = true;
+ attributes->can_set_affinity = true;
@@ -47,14 +71,16 @@ rtems_status_code bsp_interrupt_is_pending(
- *pending = false;
+ *pending = BSP_Is_interrupt_pending(vector) ||
+ BSP_Is_interrupt_forced(vector);
+ BSP_Force_interrupt(vector);
@@ -64,14 +90,17 @@ rtems_status_code bsp_interrupt_raise_on(
#endif
+ BSP_Clear_forced_interrupt(vector);
+ BSP_Clear_interrupt(vector);
@@ -81,8 +110,8 @@ rtems_status_code bsp_interrupt_vector_is_enabled(
- *enabled = false;
+ *enabled = !BSP_Cpu_Is_interrupt_masked(vector, bsp_irq_cpu(vector));
rtems_status_code bsp_interrupt_vector_enable(rtems_vector_number vector)
@@ -95,6 +124,11 @@ rtems_status_code bsp_interrupt_vector_enable(rtems_vector_number vector)
rtems_status_code bsp_interrupt_vector_disable(rtems_vector_number vector)
+ if (!is_maskable(vector)) {
BSP_Cpu_Mask_interrupt(vector, 0);
2.26.2
