[PATCH v3 20/42] sparc/irq: Implement new interrupt directives
Fri Jul 23 16:36:55 UTC 2021
On Fri, Jul 23, 2021 at 7:58 AM Sebastian Huber
> Update #3269.
>  bsps/sparc/erc32/include/bsp/irq.h |  3 +-
>  bsps/sparc/erc32/include/erc32.h   | 12 ++++-
>  bsps/sparc/leon2/include/bsp/irq.h |  3 +-
>  bsps/sparc/leon2/include/leon.h    | 16 +++++-
>  bsps/sparc/leon3/start/eirq.c      | 87 +++++++++++++++++++++++++++---
>  bsps/sparc/shared/irq/irq-shared.c | 48 ++++++++++++++---
>  6 files changed, 148 insertions(+), 21 deletions(-)
> diff --git a/bsps/sparc/erc32/include/bsp/irq.h b/bsps/sparc/erc32/include/bsp/irq.h
> index a61f51d6b6..83b383ba7a 100644
> --- a/bsps/sparc/erc32/include/bsp/irq.h
> +++ b/bsps/sparc/erc32/include/bsp/irq.h
> @@ -23,8 +23,7 @@
>  #define BSP_INTERRUPT_VECTOR_MAX_STD 15 /* Standard IRQ controller */
>  #define BSP_INTERRUPT_VECTOR_COUNT (BSP_INTERRUPT_VECTOR_MAX_STD + 1)
> -/* No extra check is needed */
> -#undef BSP_INTERRUPT_CUSTOM_VALID_VECTOR
> +#define BSP_INTERRUPT_CUSTOM_VALID_VECTOR
>  RTEMS_INLINE_ROUTINE rtems_status_code bsp_interrupt_set_affinity(
>    rtems_vector_number   vector,
> diff --git a/bsps/sparc/erc32/include/erc32.h b/bsps/sparc/erc32/include/erc32.h
> index a677b13d25..f9cdbc960a 100644
> --- a/bsps/sparc/erc32/include/erc32.h
> +++ b/bsps/sparc/erc32/include/erc32.h
> @@ -352,7 +352,7 @@ static __inline__ int bsp_irq_fixup(int irq)
>      _level = sparc_disable_interrupts(); \
>      ERC32_MEC.Test_Control = ERC32_MEC.Test_Control | 0x80000; \
> -    ERC32_MEC.Interrupt_Force = (1 << (_source)); \
> +    ERC32_MEC.Interrupt_Force |= (1 << (_source)); \
>      sparc_enable_interrupts( _level ); \
>    } while (0)
> @@ -406,7 +406,17 @@ static __inline__ int bsp_irq_fixup(int irq)
>  /* Make all SPARC BSPs have common macros for interrupt handling on local CPU */
>  #define BSP_Clear_interrupt(_source) ERC32_Clear_interrupt(_source)
>  #define BSP_Force_interrupt(_source) ERC32_Force_interrupt(_source)
> +#define BSP_Clear_forced_interrupt( _source ) \
> +  do { \
> +    uint32_t _level; \
> +    _level = sparc_disable_interrupts(); \
> +      ERC32_MEC.Interrupt_Force &= ~(1 << (_source)); \
> +    sparc_enable_interrupts( _level ); \
> +  } while (0)
>  #define BSP_Is_interrupt_pending(_source) ERC32_Is_interrupt_pending(_source)
> +#define BSP_Is_interrupt_forced(_source) \
> +  (ERC32_MEC.Interrupt_Force & (1 << (_source)))
>  #define BSP_Is_interrupt_masked(_source) ERC32_Is_interrupt_masked(_source)
>  #define BSP_Unmask_interrupt(_source) ERC32_Unmask_interrupt(_source)
>  #define BSP_Mask_interrupt(_source) ERC32_Mask_interrupt(_source)
> diff --git a/bsps/sparc/leon2/include/bsp/irq.h b/bsps/sparc/leon2/include/bsp/irq.h
> index 5f2359014a..a4ce3c55ff 100644
> --- a/bsps/sparc/leon2/include/bsp/irq.h
> +++ b/bsps/sparc/leon2/include/bsp/irq.h
> @@ -21,7 +21,6 @@
>  #endif /* LIBBSP_LEON2_IRQ_CONFIG_H */
> diff --git a/bsps/sparc/leon2/include/leon.h b/bsps/sparc/leon2/include/leon.h
> index fc90e1f7e6..11196aee6d 100644
> --- a/bsps/sparc/leon2/include/leon.h
> +++ b/bsps/sparc/leon2/include/leon.h
> @@ -295,7 +295,11 @@ static __inline__ int bsp_irq_fixup(int irq)
>  #define LEON_Force_interrupt( _source ) \
>    do { \
> -    LEON_REG.Interrupt_Force = (1 << (_source)); \
> +      LEON_REG.Interrupt_Force |= (1 << (_source)); \
>    } while (0)
>  #define LEON_Is_interrupt_pending( _source ) \
> @@ -348,7 +352,17 @@ static __inline__ int bsp_irq_fixup(int irq)
>  /* Make all SPARC BSPs have common macros for interrupt handling */
>  #define BSP_Clear_interrupt(_source) LEON_Clear_interrupt(_source)
>  #define BSP_Force_interrupt(_source) LEON_Force_interrupt(_source)
> +  do { \
> +      LEON_REG.Interrupt_Force &= ~(1 << (_source)); \
> +  } while (0)
>  #define BSP_Is_interrupt_pending(_source) LEON_Is_interrupt_pending(_source)
> +  (LEON_REG.Interrupt_Force & (1 << (_source)))
>  #define BSP_Is_interrupt_masked(_source) LEON_Is_interrupt_masked(_source)
>  #define BSP_Unmask_interrupt(_source) LEON_Unmask_interrupt(_source)
>  #define BSP_Mask_interrupt(_source) LEON_Mask_interrupt(_source)
> diff --git a/bsps/sparc/leon3/start/eirq.c b/bsps/sparc/leon3/start/eirq.c
> index 5519d6efe7..80c0efd3fa 100644
> --- a/bsps/sparc/leon3/start/eirq.c
> +++ b/bsps/sparc/leon3/start/eirq.c
> @@ -66,6 +66,20 @@ rtems_status_code bsp_interrupt_get_attributes(
>    rtems_interrupt_attributes *attributes
> +  bool is_standard_interrupt;
> +  is_standard_interrupt = (vector <= BSP_INTERRUPT_VECTOR_MAX_STD);
> +  attributes->is_maskable = (vector != 15);
15? BSP_INTERRUPT_VECTOR_MAX_STD?
> +  attributes->can_enable = true;
> +  attributes->maybe_enable = true;
> +  attributes->can_disable = true;
> +  attributes->maybe_disable = true;
> +  attributes->can_raise = true;
> +  attributes->can_raise_on = is_standard_interrupt;
> +  attributes->can_clear = true;
> +  attributes->cleared_by_acknowledge = true;
> +  attributes->can_get_affinity = is_standard_interrupt;
> +  attributes->can_set_affinity = is_standard_interrupt;
>    return RTEMS_SUCCESSFUL;
> @@ -74,16 +88,56 @@ rtems_status_code bsp_interrupt_is_pending(
>    bool               *pending
> +#if defined(RTEMS_SMP)
> +  rtems_interrupt_level level;
> +  uint32_t bit;
>    bsp_interrupt_assert(bsp_interrupt_is_valid_vector(vector));
>    bsp_interrupt_assert(pending != NULL);
> -  *pending = false;
> -  return RTEMS_UNSATISFIED;
> +  bit = 1U << vector;
> +  rtems_interrupt_local_disable(level);
> +  *pending = (LEON3_IrqCtrl_Regs->ipend & bit) != 0 ||
> +    (LEON3_IrqCtrl_Regs->force[rtems_scheduler_get_processor()] & bit) != 0;
> +  rtems_interrupt_local_enable(level);
> +  return RTEMS_SUCCESSFUL;
> +#else
> +  bsp_interrupt_assert(bsp_interrupt_is_valid_vector(vector));
> +  *pending = !BSP_Is_interrupt_pending(vector);
> +#endif
>  rtems_status_code bsp_interrupt_raise(rtems_vector_number vector)
> +  uint32_t bit;
> +  if ( vector <= BSP_INTERRUPT_VECTOR_MAX_STD ) {
> +    uint32_t cpu_count;
> +    uint32_t cpu_index;
> +    cpu_count = rtems_scheduler_get_processor_maximum();
> +    for (cpu_index = 0; cpu_index < cpu_count; ++cpu_index) {
> +      LEON3_IrqCtrl_Regs->force[cpu_index] = bit;
> +  } else {
> +    rtems_interrupt_lock_context lock_context;
> +     * This is a very dangerous operation and should only be used for test
> +     * software.  We may accidentally clear the pending state set by
> +     * peripherals with this read-modify-write operation.
> +    LEON3_IRQCTRL_ACQUIRE(&lock_context);
> +    LEON3_IrqCtrl_Regs->ipend |= bit;
> +    LEON3_IRQCTRL_RELEASE(&lock_context);
> @@ -93,14 +147,31 @@ rtems_status_code bsp_interrupt_raise_on(
> +  bsp_interrupt_assert(cpu_index < rtems_scheduler_get_processor_maximum());
> +  if ( vector > BSP_INTERRUPT_VECTOR_MAX_STD ) {
> +    return RTEMS_UNSATISFIED;
> +  LEON3_IrqCtrl_Regs->force[cpu_index] = 1U << vector;
>  #endif
>  rtems_status_code bsp_interrupt_clear(rtems_vector_number vector)
> +  uint32_t bit;
> +  LEON3_IrqCtrl_Regs->iclear = bit;
> +  if (vector <= BSP_INTERRUPT_VECTOR_MAX_STD) {
> +    LEON3_IrqCtrl_Regs->force[rtems_scheduler_get_processor()] = bit << 16;
>  rtems_status_code bsp_interrupt_vector_is_enabled(
> @@ -109,9 +180,9 @@ rtems_status_code bsp_interrupt_vector_is_enabled(
> -  bsp_interrupt_assert(enabled != NULL);
> -  *enabled = false;
> +  *enabled =
> +    !BSP_Cpu_Is_interrupt_masked(vector, _LEON3_Get_current_processor());
> diff --git a/bsps/sparc/shared/irq/irq-shared.c b/bsps/sparc/shared/irq/irq-shared.c
> index 68ad57d723..8896aca761 100644
> --- a/bsps/sparc/shared/irq/irq-shared.c
> +++ b/bsps/sparc/shared/irq/irq-shared.c
> @@ -26,17 +26,41 @@ static inline int bsp_irq_cpu(int irq)
>  #if !defined(LEON3)
> +bool bsp_interrupt_is_valid_vector(rtems_vector_number vector)
> +  if (vector == 0) {
> +    return false;
> +  return vector <= BSP_INTERRUPT_VECTOR_MAX_STD;
>  rtems_status_code bsp_interrupt_facility_initialize(void)
>    /* Nothing to do */
> +static bool is_maskable(rtems_vector_number vector)
> +  return vector != 15;
15?
> +  attributes->is_maskable = is_maskable(vector);
> +  attributes->can_disable = is_maskable(vector);
> +  attributes->maybe_disable = is_maskable(vector);
> +  attributes->can_raise_on = true;
> +  attributes->can_set_affinity = true;
> @@ -47,14 +71,16 @@ rtems_status_code bsp_interrupt_is_pending(
> -  *pending = false;
> +  *pending = BSP_Is_interrupt_pending(vector) ||
> +    BSP_Is_interrupt_forced(vector);
> +  BSP_Force_interrupt(vector);
> @@ -64,14 +90,17 @@ rtems_status_code bsp_interrupt_raise_on(
>  #endif
> +  BSP_Clear_forced_interrupt(vector);
> +  BSP_Clear_interrupt(vector);
> @@ -81,8 +110,8 @@ rtems_status_code bsp_interrupt_vector_is_enabled(
> -  *enabled = false;
> +  *enabled = !BSP_Cpu_Is_interrupt_masked(vector, bsp_irq_cpu(vector));
>  rtems_status_code bsp_interrupt_vector_enable(rtems_vector_number vector)
> @@ -95,6 +124,11 @@ rtems_status_code bsp_interrupt_vector_enable(rtems_vector_number vector)
>  rtems_status_code bsp_interrupt_vector_disable(rtems_vector_number vector)
> +  if (!is_maskable(vector)) {
>    BSP_Cpu_Mask_interrupt(vector, 0);
> 2.26.2
> devel mailing list
> devel at rtems.org
