ttcp only on 6-freebsd-12 and not on master of libbsd
Christian Mauderer oss at c-mauderer.de
Sat Jul 24 20:11:01 UTC 2021
Hello Joel,
On 24/07/2021 22:02, Joel Sherrill wrote:
> On Sat, Jul 24, 2021, 1:55 PM Christian Mauderer <oss at c-mauderer.de
> <mailto:oss at c-mauderer.de>> wrote:
>     Hello Joel,
>     I wrote a short script to find different commits based on author and
>     subject (see attached python-script). It seems that there are quite
>     some
>     differences (see attached output).
> Quick work!
Yes, a quick and _dirty_ hacked together script ;-)
Most likely that script is not fit for inclusion into our repos. It's
python3, it's using an external lib and I haven't take care that it
matches a coding style. The last one is a small problem.
>     The big blog of HDMI on Beagle patches that is only on master is caused
>     by me. These have been developed by Vijay while I was a mentor for his
>     project. Would be a question whether that's a feature that should be on
>     the stable branch too or not. Some commits will be most likely only on
>     one branch (for example 816a2f912f where Chris updated rtems_waf).
> Anything 5 is stable. I would personally say it's ok to merge Vijay's
> work to 6-freebsd-12.
Sorry, I used the wrong term: For me the *-freebsd-12 is something that
I would recommend for projects that want something solid. So I would
also see 6-freebsd-12 as a mostly stable version (also it's under active
development).
> The biggest consideration for me is not negatively impacting Chris
> sorting out merging NFSv4 and all that comes along with that. But this
> should be independent.
Good point. Maybe we should wait a bit. I think cherry-picking patches
between the branches can be done after that too.
Best regards
Christian
> --joel
>     Best regards
>     Christian
>     On 24/07/2021 18:40, Joel Sherrill wrote:
>      > On Sat, Jul 24, 2021, 11:30 AM Christian Mauderer
>     <oss at c-mauderer.de <mailto:oss at c-mauderer.de>
>      > <mailto:oss at c-mauderer.de <mailto:oss at c-mauderer.de>>> wrote:
>      >     Hello Joel,
>      >     On 24/07/2021 18:18, Joel Sherrill wrote:
>      >      > On Sat, Jul 24, 2021, 10:19 AM Christian Mauderer
>      >      > <mailto:oss at c-mauderer.de <mailto:oss at c-mauderer.de>
>     <mailto:oss at c-mauderer.de <mailto:oss at c-mauderer.de>>>> wrote:
>      >      >     Hello,
>      >      >     in a discussion with Husni I noted that the patches adding
>      >     ttcp are
>      >      >     only
>      >      >     on the 6-freebsd-12 branch of libbsd. Is there a
>     reason that
>      >     they are
>      >      >     not on master too?
>      >      > Yes but forgetting isn't a good reason. I know I have a recent
>      >     patch so
>      >      > apps using C99 or C++03 can compile using libbsd missing
>     also. I
>      >     will
>      >      > survey OAR and make sure we catch up.
>      >     I missed something like that in the past too and I will miss
>     it in the
>      >     future. And I'm sure that I have some on master that are not on
>      >     6-freebsd-12. So no problem. Just wanted to check that there
>     is no
>      >     other
>      >     reason.
>      > We probably need to collectively be more diligent about asking
>     that any
>      > patches go onto 6-freedbsd-12 and master. Some also should go to
>      > 5-freebsd-12. We are all busy and just forget.
>      >     By the way: Please tell me if you find patches that I missed ;-)
>      > I would if we can figure.out how to spot them.
>      >      > Is there any reason rtemsbsd/ just shouldn't be the same?
>      >     Most of it most likely is the same. But there are
>     differences. Some of
>      >     them might shouldn't be there but they are there. Try to checkout
>      >     master
>      >     and do a
>      >          git diff 6-freebsd-12 -- rtemsbsd/
>      >     I don't think that someone wants to clean that up on an update.
>      > Is it possible to take the output of that and do a git blame on the
>      > 6-freebsd-12 branch, grab the hash and author, and generate a master
>      > list of hashes and who was responsible for review?
>      > It would make the audit easier.
>      > Changes to the FreeBSD directory might be harder. I know Kinsey back
>      > ported some stuff.
>      > --joel
>      >     Best regards
>      >     Christian
>     https://git.rtems.org/rtems-libbsd/commit/?h=6-freebsd-12&id=af06b267c5ce04e8a4a7719cb0c723ee4a27f4b4
>     <https://git.rtems.org/rtems-libbsd/commit/?h=6-freebsd-12&id=af06b267c5ce04e8a4a7719cb0c723ee4a27f4b4>
>       <https://git.rtems.org/rtems-libbsd/commit/?h=6-freebsd-12&id=af06b267c5ce04e8a4a7719cb0c723ee4a27f4b4 <https://git.rtems.org/rtems-libbsd/commit/?h=6-freebsd-12&id=af06b267c5ce04e8a4a7719cb0c723ee4a27f4b4>>
>       <https://git.rtems.org/rtems-libbsd/commit/?h=6-freebsd-12&id=af06b267c5ce04e8a4a7719cb0c723ee4a27f4b4 <https://git.rtems.org/rtems-libbsd/commit/?h=6-freebsd-12&id=af06b267c5ce04e8a4a7719cb0c723ee4a27f4b4> <https://git.rtems.org/rtems-libbsd/commit/?h=6-freebsd-12&id=af06b267c5ce04e8a4a7719cb0c723ee4a27f4b4 <https://git.rtems.org/rtems-libbsd/commit/?h=6-freebsd-12&id=af06b267c5ce04e8a4a7719cb0c723ee4a27f4b4>>>
>     https://git.rtems.org/rtems-libbsd/commit/?h=6-freebsd-12&id=7960ab7a43d5a7c6ceccdd67f8e379adfce7a633
>     <https://git.rtems.org/rtems-libbsd/commit/?h=6-freebsd-12&id=7960ab7a43d5a7c6ceccdd67f8e379adfce7a633>
>       <https://git.rtems.org/rtems-libbsd/commit/?h=6-freebsd-12&id=7960ab7a43d5a7c6ceccdd67f8e379adfce7a633 <https://git.rtems.org/rtems-libbsd/commit/?h=6-freebsd-12&id=7960ab7a43d5a7c6ceccdd67f8e379adfce7a633>>
>       <https://git.rtems.org/rtems-libbsd/commit/?h=6-freebsd-12&id=7960ab7a43d5a7c6ceccdd67f8e379adfce7a633 <https://git.rtems.org/rtems-libbsd/commit/?h=6-freebsd-12&id=7960ab7a43d5a7c6ceccdd67f8e379adfce7a633> <https://git.rtems.org/rtems-libbsd/commit/?h=6-freebsd-12&id=7960ab7a43d5a7c6ceccdd67f8e379adfce7a633 <https://git.rtems.org/rtems-libbsd/commit/?h=6-freebsd-12&id=7960ab7a43d5a7c6ceccdd67f8e379adfce7a633>>>
>     https://git.rtems.org/rtems-libbsd/commit/?h=6-freebsd-12&id=6cc63cbe657c3ee664727cce1a54acc7e7b5fe9d
>     <https://git.rtems.org/rtems-libbsd/commit/?h=6-freebsd-12&id=6cc63cbe657c3ee664727cce1a54acc7e7b5fe9d>
>       <https://git.rtems.org/rtems-libbsd/commit/?h=6-freebsd-12&id=6cc63cbe657c3ee664727cce1a54acc7e7b5fe9d <https://git.rtems.org/rtems-libbsd/commit/?h=6-freebsd-12&id=6cc63cbe657c3ee664727cce1a54acc7e7b5fe9d>>
>       <https://git.rtems.org/rtems-libbsd/commit/?h=6-freebsd-12&id=6cc63cbe657c3ee664727cce1a54acc7e7b5fe9d <https://git.rtems.org/rtems-libbsd/commit/?h=6-freebsd-12&id=6cc63cbe657c3ee664727cce1a54acc7e7b5fe9d> <https://git.rtems.org/rtems-libbsd/commit/?h=6-freebsd-12&id=6cc63cbe657c3ee664727cce1a54acc7e7b5fe9d <https://git.rtems.org/rtems-libbsd/commit/?h=6-freebsd-12&id=6cc63cbe657c3ee664727cce1a54acc7e7b5fe9d>>>
>     https://git.rtems.org/rtems-libbsd/commit/?h=6-freebsd-12&id=8dfea31d729fafab69b5cf1846598f5104b0faeb
>     <https://git.rtems.org/rtems-libbsd/commit/?h=6-freebsd-12&id=8dfea31d729fafab69b5cf1846598f5104b0faeb>
>       <https://git.rtems.org/rtems-libbsd/commit/?h=6-freebsd-12&id=8dfea31d729fafab69b5cf1846598f5104b0faeb <https://git.rtems.org/rtems-libbsd/commit/?h=6-freebsd-12&id=8dfea31d729fafab69b5cf1846598f5104b0faeb>>
>       <https://git.rtems.org/rtems-libbsd/commit/?h=6-freebsd-12&id=8dfea31d729fafab69b5cf1846598f5104b0faeb <https://git.rtems.org/rtems-libbsd/commit/?h=6-freebsd-12&id=8dfea31d729fafab69b5cf1846598f5104b0faeb> <https://git.rtems.org/rtems-libbsd/commit/?h=6-freebsd-12&id=8dfea31d729fafab69b5cf1846598f5104b0faeb <https://git.rtems.org/rtems-libbsd/commit/?h=6-freebsd-12&id=8dfea31d729fafab69b5cf1846598f5104b0faeb>>>
>      >      >     Background for the question: I expect that an update to
>      >     FreeBSD 13 will
>      >      >     use only what is on the master branch. That's
>     basically what
>      >     master is
>      >      >     for: Tracking the development to keep up with new stuff in
>      >     FreeBSD and
>      >      >     make it easy to jump to the next FreeBSD release. In other
>      >     words: I
>      >      >     think a (possible future) 6-freebsd-13 branch will be
>     based
>      >     on master
>      >      >     and not on 6-freebsd-12. Am I wrong with that assumption?
>      >      >     Again: please correct me if I'm wrong but with that in
>     mind I
>      >     would say
>      >      >     that it is a good idea to port to master and
>     6-freebsd-12 or (for
>      >      >     experimental stuff) only to master. But not only to
>     6-freebsd-12.
>      >      >     Best regards
>      >      >     Christian
