[PATCH rtems-libbsd.nfs 4/4] kern-symbols: Add symbols from the everything build set
chrisj at rtems.org
chrisj at rtems.org
Tue Jul 27 08:09:21 UTC 2021
- Minor fix to rtems-kern-symbols
Update #4475
rtems-kern-symbols | 2 +-
.../machine/rtems-bsd-kernel-namespace.h | 127 ++++++++++++++++++
2 files changed, 128 insertions(+), 1 deletion(-)
diff --git a/rtems-kern-symbols b/rtems-kern-symbols
index e34a14a7..af4afd8b 100755
--- a/rtems-kern-symbols
+++ b/rtems-kern-symbols
@@ -329,7 +329,7 @@ class kernel_symbols:
for bsp in self.bsps:
arch = self.bsp_arch(bsp)
with open('sym-data-' + arch + '.txt', 'w') as o:
- o.writelines(os.linesep.join(ks.bsps[bsp]['output']))
+ o.writelines(os.linesep.join(self.bsps[bsp]['output']))
def merge(self, symbols):
self.output['symbols'] = \
diff --git a/rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h b/rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h
index 108709ce..76e76b58 100644
--- a/rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h
+++ b/rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h
@@ -111,9 +111,11 @@
#define M_CRYPTO_DATA _bsd_M_CRYPTO_DATA
#define M_DEVBUF _bsd_M_DEVBUF
#define M_EVDEV _bsd_M_EVDEV
+#define M_FIXEDREGULATOR _bsd_M_FIXEDREGULATOR
#define M_GIF _bsd_M_GIF
#define M_GRE _bsd_M_GRE
#define M_IFADDR _bsd_M_IFADDR
+#define M_IFLIB _bsd_M_IFLIB
#define M_IFMADDR _bsd_M_IFMADDR
#define M_IOV _bsd_M_IOV
#define M_IP6MADDR _bsd_M_IP6MADDR
@@ -132,6 +134,7 @@
#define M_OFWPROP _bsd_M_OFWPROP
#define M_PCB _bsd_M_PCB
#define M_PFHASH _bsd_M_PFHASH
+#define M_REGULATOR _bsd_M_REGULATOR
#define M_RTABLE _bsd_M_RTABLE
#define M_RTWN_PRIV _bsd_M_RTWN_PRIV
#define M_SONAME _bsd_M_SONAME
@@ -277,6 +280,8 @@
#define Skein_512_Output _bsd_Skein_512_Output
#define Skein_512_Process_Block _bsd_Skein_512_Process_Block
#define Skein_512_Update _bsd_Skein_512_Update
+#define Skein_Get64_LSB_First _bsd_Skein_Get64_LSB_First
+#define Skein_Put64_LSB_First _bsd_Skein_Put64_LSB_First
#define TB_DRAIN_WAITER _bsd_TB_DRAIN_WAITER
#define X_ip6_mforward _bsd_X_ip6_mforward
#define X_ip6_mrouter_done _bsd_X_ip6_mrouter_done
@@ -292,6 +297,7 @@
#define _cv_wait _bsd__cv_wait
#define _cv_wait_sig _bsd__cv_wait_sig
#define _cv_wait_unlock _bsd__cv_wait_unlock
+#define _kevent _bsd__kevent
#define _libmd_SHA224_Final _bsd__libmd_SHA224_Final
#define _libmd_SHA224_Init _bsd__libmd_SHA224_Init
#define _libmd_SHA224_Update _bsd__libmd_SHA224_Update
@@ -1686,6 +1692,7 @@
#define hid_start_parse _bsd_hid_start_parse
#define hmac_ipad_buffer _bsd_hmac_ipad_buffer
#define hmac_opad_buffer _bsd_hmac_opad_buffer
+#define hostb_alloc_start _bsd_hostb_alloc_start
#define hz _bsd_hz
#define ic_printf _bsd_ic_printf
#define icmp6_ctloutput _bsd_icmp6_ctloutput
@@ -2279,6 +2286,54 @@
#define ifhwioctl _bsd_ifhwioctl
#define ifindex_table _bsd_ifindex_table
#define ifioctl _bsd_ifioctl
+#define iflib_add_int_delay_sysctl _bsd_iflib_add_int_delay_sysctl
+#define iflib_admin_intr_deferred _bsd_iflib_admin_intr_deferred
+#define iflib_config_gtask_deinit _bsd_iflib_config_gtask_deinit
+#define iflib_config_gtask_init _bsd_iflib_config_gtask_init
+#define iflib_ctx_lock_get _bsd_iflib_ctx_lock_get
+#define iflib_device_attach _bsd_iflib_device_attach
+#define iflib_device_deregister _bsd_iflib_device_deregister
+#define iflib_device_detach _bsd_iflib_device_detach
+#define iflib_device_iov_add_vf _bsd_iflib_device_iov_add_vf
+#define iflib_device_iov_init _bsd_iflib_device_iov_init
+#define iflib_device_iov_uninit _bsd_iflib_device_iov_uninit
+#define iflib_device_probe _bsd_iflib_device_probe
+#define iflib_device_probe_vendor _bsd_iflib_device_probe_vendor
+#define iflib_device_register _bsd_iflib_device_register
+#define iflib_device_resume _bsd_iflib_device_resume
+#define iflib_device_shutdown _bsd_iflib_device_shutdown
+#define iflib_device_suspend _bsd_iflib_device_suspend
+#define iflib_dma_alloc _bsd_iflib_dma_alloc
+#define iflib_dma_alloc_align _bsd_iflib_dma_alloc_align
+#define iflib_dma_alloc_multi _bsd_iflib_dma_alloc_multi
+#define iflib_dma_free _bsd_iflib_dma_free
+#define iflib_dma_free_multi _bsd_iflib_dma_free_multi
+#define iflib_get_dev _bsd_iflib_get_dev
+#define iflib_get_flags _bsd_iflib_get_flags
+#define iflib_get_ifp _bsd_iflib_get_ifp
+#define iflib_get_media _bsd_iflib_get_media
+#define iflib_get_rx_mbuf_sz _bsd_iflib_get_rx_mbuf_sz
+#define iflib_get_sctx _bsd_iflib_get_sctx
+#define iflib_get_softc _bsd_iflib_get_softc
+#define iflib_get_softc_ctx _bsd_iflib_get_softc_ctx
+#define iflib_in_detach _bsd_iflib_in_detach
+#define iflib_io_tqg_attach _bsd_iflib_io_tqg_attach
+#define iflib_iov_intr_deferred _bsd_iflib_iov_intr_deferred
+#define iflib_irq_alloc _bsd_iflib_irq_alloc
+#define iflib_irq_alloc_generic _bsd_iflib_irq_alloc_generic
+#define iflib_irq_free _bsd_iflib_irq_free
+#define iflib_led_create _bsd_iflib_led_create
+#define iflib_link_state_change _bsd_iflib_link_state_change
+#define iflib_pseudo_deregister _bsd_iflib_pseudo_deregister
+#define iflib_pseudo_register _bsd_iflib_pseudo_register
+#define iflib_pseudodriver _bsd_iflib_pseudodriver
+#define iflib_request_reset _bsd_iflib_request_reset
+#define iflib_rx_intr_deferred _bsd_iflib_rx_intr_deferred
+#define iflib_set_detach _bsd_iflib_set_detach
+#define iflib_set_mac _bsd_iflib_set_mac
+#define iflib_softirq_alloc_generic _bsd_iflib_softirq_alloc_generic
+#define iflib_stop _bsd_iflib_stop
+#define iflib_tx_intr_deferred _bsd_iflib_tx_intr_deferred
#define ifma_restart _bsd_ifma_restart
#define ifmedia_add _bsd_ifmedia_add
#define ifmedia_baudrate _bsd_ifmedia_baudrate
@@ -2287,6 +2342,13 @@
#define ifmedia_list_add _bsd_ifmedia_list_add
#define ifmedia_removeall _bsd_ifmedia_removeall
#define ifmedia_set _bsd_ifmedia_set
+#define ifmp_ring_alloc _bsd_ifmp_ring_alloc
+#define ifmp_ring_check_drainage _bsd_ifmp_ring_check_drainage
+#define ifmp_ring_enqueue _bsd_ifmp_ring_enqueue
+#define ifmp_ring_free _bsd_ifmp_ring_free
+#define ifmp_ring_is_idle _bsd_ifmp_ring_is_idle
+#define ifmp_ring_is_stalled _bsd_ifmp_ring_is_stalled
+#define ifmp_ring_reset_stats _bsd_ifmp_ring_reset_stats
#define ifnet _bsd_ifnet
#define ifnet_byindex _bsd_ifnet_byindex
#define ifnet_byindex_locked _bsd_ifnet_byindex_locked
@@ -2336,6 +2398,21 @@
#define iicdev_writeto _bsd_iicdev_writeto
#define im6o_mc_filter _bsd_im6o_mc_filter
#define imo_multi_filter _bsd_imo_multi_filter
+#define imx6_anatop_write_4 _bsd_imx6_anatop_write_4
+#define imx6_ccm_sata_enable _bsd_imx6_ccm_sata_enable
+#define imx_ccm_ahb_hz _bsd_imx_ccm_ahb_hz
+#define imx_ccm_ecspi_hz _bsd_imx_ccm_ecspi_hz
+#define imx_ccm_get_cacrr _bsd_imx_ccm_get_cacrr
+#define imx_ccm_hdmi_enable _bsd_imx_ccm_hdmi_enable
+#define imx_ccm_ipg_hz _bsd_imx_ccm_ipg_hz
+#define imx_ccm_ipu_enable _bsd_imx_ccm_ipu_enable
+#define imx_ccm_perclk_hz _bsd_imx_ccm_perclk_hz
+#define imx_ccm_sdhci_hz _bsd_imx_ccm_sdhci_hz
+#define imx_ccm_set_cacrr _bsd_imx_ccm_set_cacrr
+#define imx_ccm_ssi_configure _bsd_imx_ccm_ssi_configure
+#define imx_ccm_uart_hz _bsd_imx_ccm_uart_hz
+#define imx_ccm_usb_enable _bsd_imx_ccm_usb_enable
+#define imx_ccm_usbphy_enable _bsd_imx_ccm_usbphy_enable
#define in4_cksum _bsd_in4_cksum
#define in6_addrscope _bsd_in6_addrscope
#define in6_are_prefix_equal _bsd_in6_are_prefix_equal
@@ -2936,6 +3013,16 @@
#define led_create_state _bsd_led_create_state
#define led_destroy _bsd_led_destroy
#define led_set _bsd_led_set
+#define legacy_pcib_alloc_msi _bsd_legacy_pcib_alloc_msi
+#define legacy_pcib_alloc_msix _bsd_legacy_pcib_alloc_msix
+#define legacy_pcib_alloc_resource _bsd_legacy_pcib_alloc_resource
+#define legacy_pcib_driver _bsd_legacy_pcib_driver
+#define legacy_pcib_map_msi _bsd_legacy_pcib_map_msi
+#define legacy_pcib_maxslots _bsd_legacy_pcib_maxslots
+#define legacy_pcib_read_config _bsd_legacy_pcib_read_config
+#define legacy_pcib_read_ivar _bsd_legacy_pcib_read_ivar
+#define legacy_pcib_write_config _bsd_legacy_pcib_write_config
+#define legacy_pcib_write_ivar _bsd_legacy_pcib_write_ivar
#define legal_vif_num _bsd_legal_vif_num
#define lem_txrx _bsd_lem_txrx
#define link_alloc_sdl _bsd_link_alloc_sdl
@@ -3339,6 +3426,7 @@
#define ofw_iicbus_driver _bsd_ofw_iicbus_driver
#define ofw_parse_bootargs _bsd_ofw_parse_bootargs
#define ofw_reg_to_paddr _bsd_ofw_reg_to_paddr
+#define ofw_regulator_bus_driver _bsd_ofw_regulator_bus_driver
#define ofwbus_driver _bsd_ofwbus_driver
#define ofwgpiobus_devclass _bsd_ofwgpiobus_devclass
#define ohci_detach _bsd_ohci_detach
@@ -3773,6 +3861,8 @@
#define pru_soreceive_notsupp _bsd_pru_soreceive_notsupp
#define pru_sosend_notsupp _bsd_pru_sosend_notsupp
#define qgroup_config _bsd_qgroup_config
+#define qgroup_if_config_tqg _bsd_qgroup_if_config_tqg
+#define qgroup_if_io_tqg _bsd_qgroup_if_io_tqg
#define qgroup_softirq _bsd_qgroup_softirq
#define r12a_beacon_init _bsd_r12a_beacon_init
#define r12a_beacon_set_rate _bsd_r12a_beacon_set_rate
@@ -4005,6 +4095,42 @@
#define register_tcp_functions_as_name _bsd_register_tcp_functions_as_name
#define register_tcp_functions_as_names _bsd_register_tcp_functions_as_names
#define registered_toedevs _bsd_registered_toedevs
+#define regnode_class _bsd_regnode_class
+#define regnode_create _bsd_regnode_create
+#define regnode_disable _bsd_regnode_disable
+#define regnode_enable _bsd_regnode_enable
+#define regnode_fixed_class _bsd_regnode_fixed_class
+#define regnode_fixed_register _bsd_regnode_fixed_register
+#define regnode_get_device _bsd_regnode_get_device
+#define regnode_get_flags _bsd_regnode_get_flags
+#define regnode_get_name _bsd_regnode_get_name
+#define regnode_get_parent _bsd_regnode_get_parent
+#define regnode_get_parent_name _bsd_regnode_get_parent_name
+#define regnode_get_softc _bsd_regnode_get_softc
+#define regnode_get_stdparam _bsd_regnode_get_stdparam
+#define regnode_get_voltage _bsd_regnode_get_voltage
+#define regnode_method_check_voltage _bsd_regnode_method_check_voltage
+#define regnode_register _bsd_regnode_register
+#define regnode_set_constraint _bsd_regnode_set_constraint
+#define regnode_set_voltage _bsd_regnode_set_voltage
+#define regnode_status _bsd_regnode_status
+#define regnode_stop _bsd_regnode_stop
+#define regnode_topo_slock _bsd_regnode_topo_slock
+#define regnode_topo_unlock _bsd_regnode_topo_unlock
+#define regnode_topo_xlock _bsd_regnode_topo_xlock
+#define regulator_check_voltage _bsd_regulator_check_voltage
+#define regulator_disable _bsd_regulator_disable
+#define regulator_enable _bsd_regulator_enable
+#define regulator_get_by_id _bsd_regulator_get_by_id
+#define regulator_get_by_name _bsd_regulator_get_by_name
+#define regulator_get_name _bsd_regulator_get_name
+#define regulator_get_voltage _bsd_regulator_get_voltage
+#define regulator_range_sel8_to_volt _bsd_regulator_range_sel8_to_volt
+#define regulator_range_volt_to_sel8 _bsd_regulator_range_volt_to_sel8
+#define regulator_release _bsd_regulator_release
+#define regulator_set_voltage _bsd_regulator_set_voltage
+#define regulator_status _bsd_regulator_status
+#define regulator_stop _bsd_regulator_stop
#define resource_disabled _bsd_resource_disabled
#define resource_find_match _bsd_resource_find_match
#define resource_int_value _bsd_resource_int_value
@@ -5616,6 +5742,7 @@
#define usbd_transfer_timeout_ms _bsd_usbd_transfer_timeout_ms
#define usbd_transfer_unsetup _bsd_usbd_transfer_unsetup
#define usbd_xfer_clr_flag _bsd_usbd_xfer_clr_flag
+#define usbd_xfer_frame_allow_cache_line_blow_up _bsd_usbd_xfer_frame_allow_cache_line_blow_up
#define usbd_xfer_frame_data _bsd_usbd_xfer_frame_data
#define usbd_xfer_frame_len _bsd_usbd_xfer_frame_len
#define usbd_xfer_get_fps_shift _bsd_usbd_xfer_get_fps_shift
2.24.1
