[PATCH rtems-libbsd.nfs 4/4] kern-symbols: Add symbols from the everything build set
Gedare Bloom
gedare at rtems.org
Tue Jul 27 21:19:13 UTC 2021
squash into 1/4 if you regenerate 1 after review?
On Tue, Jul 27, 2021 at 2:09 AM <chrisj at rtems.org> wrote:
> From: Chris Johns <chrisj at rtems.org>
> - Minor fix to rtems-kern-symbols
> Update #4475
> rtems-kern-symbols | 2 +-
> .../machine/rtems-bsd-kernel-namespace.h | 127 ++++++++++++++++++
> 2 files changed, 128 insertions(+), 1 deletion(-)
> diff --git a/rtems-kern-symbols b/rtems-kern-symbols
> index e34a14a7..af4afd8b 100755
> --- a/rtems-kern-symbols
> +++ b/rtems-kern-symbols
> @@ -329,7 +329,7 @@ class kernel_symbols:
> for bsp in self.bsps:
> arch = self.bsp_arch(bsp)
> with open('sym-data-' + arch + '.txt', 'w') as o:
> - o.writelines(os.linesep.join(ks.bsps[bsp]['output']))
> + o.writelines(os.linesep.join(self.bsps[bsp]['output']))
> def merge(self, symbols):
> self.output['symbols'] = \
> diff --git a/rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h b/rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h
> index 108709ce..76e76b58 100644
> --- a/rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h
> +++ b/rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h
> @@ -111,9 +111,11 @@
> #define M_CRYPTO_DATA _bsd_M_CRYPTO_DATA
> #define M_DEVBUF _bsd_M_DEVBUF
> #define M_EVDEV _bsd_M_EVDEV
> +#define M_FIXEDREGULATOR _bsd_M_FIXEDREGULATOR
> #define M_GIF _bsd_M_GIF
> #define M_GRE _bsd_M_GRE
> #define M_IFADDR _bsd_M_IFADDR
> +#define M_IFLIB _bsd_M_IFLIB
> #define M_IFMADDR _bsd_M_IFMADDR
> #define M_IOV _bsd_M_IOV
> #define M_IP6MADDR _bsd_M_IP6MADDR
> @@ -132,6 +134,7 @@
> #define M_OFWPROP _bsd_M_OFWPROP
> #define M_PCB _bsd_M_PCB
> #define M_PFHASH _bsd_M_PFHASH
> +#define M_REGULATOR _bsd_M_REGULATOR
> #define M_RTABLE _bsd_M_RTABLE
> #define M_RTWN_PRIV _bsd_M_RTWN_PRIV
> #define M_SONAME _bsd_M_SONAME
> @@ -277,6 +280,8 @@
> #define Skein_512_Output _bsd_Skein_512_Output
> #define Skein_512_Process_Block _bsd_Skein_512_Process_Block
> #define Skein_512_Update _bsd_Skein_512_Update
> +#define Skein_Get64_LSB_First _bsd_Skein_Get64_LSB_First
> +#define Skein_Put64_LSB_First _bsd_Skein_Put64_LSB_First
> #define TB_DRAIN_WAITER _bsd_TB_DRAIN_WAITER
> #define X_ip6_mforward _bsd_X_ip6_mforward
> #define X_ip6_mrouter_done _bsd_X_ip6_mrouter_done
> @@ -292,6 +297,7 @@
> #define _cv_wait _bsd__cv_wait
> #define _cv_wait_sig _bsd__cv_wait_sig
> #define _cv_wait_unlock _bsd__cv_wait_unlock
> +#define _kevent _bsd__kevent
> #define _libmd_SHA224_Final _bsd__libmd_SHA224_Final
> #define _libmd_SHA224_Init _bsd__libmd_SHA224_Init
> #define _libmd_SHA224_Update _bsd__libmd_SHA224_Update
> @@ -1686,6 +1692,7 @@
> #define hid_start_parse _bsd_hid_start_parse
> #define hmac_ipad_buffer _bsd_hmac_ipad_buffer
> #define hmac_opad_buffer _bsd_hmac_opad_buffer
> +#define hostb_alloc_start _bsd_hostb_alloc_start
> #define hz _bsd_hz
> #define ic_printf _bsd_ic_printf
> #define icmp6_ctloutput _bsd_icmp6_ctloutput
> @@ -2279,6 +2286,54 @@
> #define ifhwioctl _bsd_ifhwioctl
> #define ifindex_table _bsd_ifindex_table
> #define ifioctl _bsd_ifioctl
> +#define iflib_add_int_delay_sysctl _bsd_iflib_add_int_delay_sysctl
> +#define iflib_admin_intr_deferred _bsd_iflib_admin_intr_deferred
> +#define iflib_config_gtask_deinit _bsd_iflib_config_gtask_deinit
> +#define iflib_config_gtask_init _bsd_iflib_config_gtask_init
> +#define iflib_ctx_lock_get _bsd_iflib_ctx_lock_get
> +#define iflib_device_attach _bsd_iflib_device_attach
> +#define iflib_device_deregister _bsd_iflib_device_deregister
> +#define iflib_device_detach _bsd_iflib_device_detach
> +#define iflib_device_iov_add_vf _bsd_iflib_device_iov_add_vf
> +#define iflib_device_iov_init _bsd_iflib_device_iov_init
> +#define iflib_device_iov_uninit _bsd_iflib_device_iov_uninit
> +#define iflib_device_probe _bsd_iflib_device_probe
> +#define iflib_device_probe_vendor _bsd_iflib_device_probe_vendor
> +#define iflib_device_register _bsd_iflib_device_register
> +#define iflib_device_resume _bsd_iflib_device_resume
> +#define iflib_device_shutdown _bsd_iflib_device_shutdown
> +#define iflib_device_suspend _bsd_iflib_device_suspend
> +#define iflib_dma_alloc _bsd_iflib_dma_alloc
> +#define iflib_dma_alloc_align _bsd_iflib_dma_alloc_align
> +#define iflib_dma_alloc_multi _bsd_iflib_dma_alloc_multi
> +#define iflib_dma_free _bsd_iflib_dma_free
> +#define iflib_dma_free_multi _bsd_iflib_dma_free_multi
> +#define iflib_get_dev _bsd_iflib_get_dev
> +#define iflib_get_flags _bsd_iflib_get_flags
> +#define iflib_get_ifp _bsd_iflib_get_ifp
> +#define iflib_get_media _bsd_iflib_get_media
> +#define iflib_get_rx_mbuf_sz _bsd_iflib_get_rx_mbuf_sz
> +#define iflib_get_sctx _bsd_iflib_get_sctx
> +#define iflib_get_softc _bsd_iflib_get_softc
> +#define iflib_get_softc_ctx _bsd_iflib_get_softc_ctx
> +#define iflib_in_detach _bsd_iflib_in_detach
> +#define iflib_io_tqg_attach _bsd_iflib_io_tqg_attach
> +#define iflib_iov_intr_deferred _bsd_iflib_iov_intr_deferred
> +#define iflib_irq_alloc _bsd_iflib_irq_alloc
> +#define iflib_irq_alloc_generic _bsd_iflib_irq_alloc_generic
> +#define iflib_irq_free _bsd_iflib_irq_free
> +#define iflib_led_create _bsd_iflib_led_create
> +#define iflib_link_state_change _bsd_iflib_link_state_change
> +#define iflib_pseudo_deregister _bsd_iflib_pseudo_deregister
> +#define iflib_pseudo_register _bsd_iflib_pseudo_register
> +#define iflib_pseudodriver _bsd_iflib_pseudodriver
> +#define iflib_request_reset _bsd_iflib_request_reset
> +#define iflib_rx_intr_deferred _bsd_iflib_rx_intr_deferred
> +#define iflib_set_detach _bsd_iflib_set_detach
> +#define iflib_set_mac _bsd_iflib_set_mac
> +#define iflib_softirq_alloc_generic _bsd_iflib_softirq_alloc_generic
> +#define iflib_stop _bsd_iflib_stop
> +#define iflib_tx_intr_deferred _bsd_iflib_tx_intr_deferred
> #define ifma_restart _bsd_ifma_restart
> #define ifmedia_add _bsd_ifmedia_add
> #define ifmedia_baudrate _bsd_ifmedia_baudrate
> @@ -2287,6 +2342,13 @@
> #define ifmedia_list_add _bsd_ifmedia_list_add
> #define ifmedia_removeall _bsd_ifmedia_removeall
> #define ifmedia_set _bsd_ifmedia_set
> +#define ifmp_ring_alloc _bsd_ifmp_ring_alloc
> +#define ifmp_ring_check_drainage _bsd_ifmp_ring_check_drainage
> +#define ifmp_ring_enqueue _bsd_ifmp_ring_enqueue
> +#define ifmp_ring_free _bsd_ifmp_ring_free
> +#define ifmp_ring_is_idle _bsd_ifmp_ring_is_idle
> +#define ifmp_ring_is_stalled _bsd_ifmp_ring_is_stalled
> +#define ifmp_ring_reset_stats _bsd_ifmp_ring_reset_stats
> #define ifnet _bsd_ifnet
> #define ifnet_byindex _bsd_ifnet_byindex
> #define ifnet_byindex_locked _bsd_ifnet_byindex_locked
> @@ -2336,6 +2398,21 @@
> #define iicdev_writeto _bsd_iicdev_writeto
> #define im6o_mc_filter _bsd_im6o_mc_filter
> #define imo_multi_filter _bsd_imo_multi_filter
> +#define imx6_anatop_write_4 _bsd_imx6_anatop_write_4
> +#define imx6_ccm_sata_enable _bsd_imx6_ccm_sata_enable
> +#define imx_ccm_ahb_hz _bsd_imx_ccm_ahb_hz
> +#define imx_ccm_ecspi_hz _bsd_imx_ccm_ecspi_hz
> +#define imx_ccm_get_cacrr _bsd_imx_ccm_get_cacrr
> +#define imx_ccm_hdmi_enable _bsd_imx_ccm_hdmi_enable
> +#define imx_ccm_ipg_hz _bsd_imx_ccm_ipg_hz
> +#define imx_ccm_ipu_enable _bsd_imx_ccm_ipu_enable
> +#define imx_ccm_perclk_hz _bsd_imx_ccm_perclk_hz
> +#define imx_ccm_sdhci_hz _bsd_imx_ccm_sdhci_hz
> +#define imx_ccm_set_cacrr _bsd_imx_ccm_set_cacrr
> +#define imx_ccm_ssi_configure _bsd_imx_ccm_ssi_configure
> +#define imx_ccm_uart_hz _bsd_imx_ccm_uart_hz
> +#define imx_ccm_usb_enable _bsd_imx_ccm_usb_enable
> +#define imx_ccm_usbphy_enable _bsd_imx_ccm_usbphy_enable
> #define in4_cksum _bsd_in4_cksum
> #define in6_addrscope _bsd_in6_addrscope
> #define in6_are_prefix_equal _bsd_in6_are_prefix_equal
> @@ -2936,6 +3013,16 @@
> #define led_create_state _bsd_led_create_state
> #define led_destroy _bsd_led_destroy
> #define led_set _bsd_led_set
> +#define legacy_pcib_alloc_msi _bsd_legacy_pcib_alloc_msi
> +#define legacy_pcib_alloc_msix _bsd_legacy_pcib_alloc_msix
> +#define legacy_pcib_alloc_resource _bsd_legacy_pcib_alloc_resource
> +#define legacy_pcib_driver _bsd_legacy_pcib_driver
> +#define legacy_pcib_map_msi _bsd_legacy_pcib_map_msi
> +#define legacy_pcib_maxslots _bsd_legacy_pcib_maxslots
> +#define legacy_pcib_read_config _bsd_legacy_pcib_read_config
> +#define legacy_pcib_read_ivar _bsd_legacy_pcib_read_ivar
> +#define legacy_pcib_write_config _bsd_legacy_pcib_write_config
> +#define legacy_pcib_write_ivar _bsd_legacy_pcib_write_ivar
> #define legal_vif_num _bsd_legal_vif_num
> #define lem_txrx _bsd_lem_txrx
> #define link_alloc_sdl _bsd_link_alloc_sdl
> @@ -3339,6 +3426,7 @@
> #define ofw_iicbus_driver _bsd_ofw_iicbus_driver
> #define ofw_parse_bootargs _bsd_ofw_parse_bootargs
> #define ofw_reg_to_paddr _bsd_ofw_reg_to_paddr
> +#define ofw_regulator_bus_driver _bsd_ofw_regulator_bus_driver
> #define ofwbus_driver _bsd_ofwbus_driver
> #define ofwgpiobus_devclass _bsd_ofwgpiobus_devclass
> #define ohci_detach _bsd_ohci_detach
> @@ -3773,6 +3861,8 @@
> #define pru_soreceive_notsupp _bsd_pru_soreceive_notsupp
> #define pru_sosend_notsupp _bsd_pru_sosend_notsupp
> #define qgroup_config _bsd_qgroup_config
> +#define qgroup_if_config_tqg _bsd_qgroup_if_config_tqg
> +#define qgroup_if_io_tqg _bsd_qgroup_if_io_tqg
> #define qgroup_softirq _bsd_qgroup_softirq
> #define r12a_beacon_init _bsd_r12a_beacon_init
> #define r12a_beacon_set_rate _bsd_r12a_beacon_set_rate
> @@ -4005,6 +4095,42 @@
> #define register_tcp_functions_as_name _bsd_register_tcp_functions_as_name
> #define register_tcp_functions_as_names _bsd_register_tcp_functions_as_names
> #define registered_toedevs _bsd_registered_toedevs
> +#define regnode_class _bsd_regnode_class
> +#define regnode_create _bsd_regnode_create
> +#define regnode_disable _bsd_regnode_disable
> +#define regnode_enable _bsd_regnode_enable
> +#define regnode_fixed_class _bsd_regnode_fixed_class
> +#define regnode_fixed_register _bsd_regnode_fixed_register
> +#define regnode_get_device _bsd_regnode_get_device
> +#define regnode_get_flags _bsd_regnode_get_flags
> +#define regnode_get_name _bsd_regnode_get_name
> +#define regnode_get_parent _bsd_regnode_get_parent
> +#define regnode_get_parent_name _bsd_regnode_get_parent_name
> +#define regnode_get_softc _bsd_regnode_get_softc
> +#define regnode_get_stdparam _bsd_regnode_get_stdparam
> +#define regnode_get_voltage _bsd_regnode_get_voltage
> +#define regnode_method_check_voltage _bsd_regnode_method_check_voltage
> +#define regnode_register _bsd_regnode_register
> +#define regnode_set_constraint _bsd_regnode_set_constraint
> +#define regnode_set_voltage _bsd_regnode_set_voltage
> +#define regnode_status _bsd_regnode_status
> +#define regnode_stop _bsd_regnode_stop
> +#define regnode_topo_slock _bsd_regnode_topo_slock
> +#define regnode_topo_unlock _bsd_regnode_topo_unlock
> +#define regnode_topo_xlock _bsd_regnode_topo_xlock
> +#define regulator_check_voltage _bsd_regulator_check_voltage
> +#define regulator_disable _bsd_regulator_disable
> +#define regulator_enable _bsd_regulator_enable
> +#define regulator_get_by_id _bsd_regulator_get_by_id
> +#define regulator_get_by_name _bsd_regulator_get_by_name
> +#define regulator_get_name _bsd_regulator_get_name
> +#define regulator_get_voltage _bsd_regulator_get_voltage
> +#define regulator_range_sel8_to_volt _bsd_regulator_range_sel8_to_volt
> +#define regulator_range_volt_to_sel8 _bsd_regulator_range_volt_to_sel8
> +#define regulator_release _bsd_regulator_release
> +#define regulator_set_voltage _bsd_regulator_set_voltage
> +#define regulator_status _bsd_regulator_status
> +#define regulator_stop _bsd_regulator_stop
> #define resource_disabled _bsd_resource_disabled
> #define resource_find_match _bsd_resource_find_match
> #define resource_int_value _bsd_resource_int_value
> @@ -5616,6 +5742,7 @@
> #define usbd_transfer_timeout_ms _bsd_usbd_transfer_timeout_ms
> #define usbd_transfer_unsetup _bsd_usbd_transfer_unsetup
> #define usbd_xfer_clr_flag _bsd_usbd_xfer_clr_flag
> +#define usbd_xfer_frame_allow_cache_line_blow_up _bsd_usbd_xfer_frame_allow_cache_line_blow_up
> #define usbd_xfer_frame_data _bsd_usbd_xfer_frame_data
> #define usbd_xfer_frame_len _bsd_usbd_xfer_frame_len
> #define usbd_xfer_get_fps_shift _bsd_usbd_xfer_get_fps_shift
> 2.24.1
> devel mailing list
> devel at rtems.org
