[PATCH] score: Remove _Internal_errors_What_happened
Sebastian Huber
Tue Jul 27 08:12:56 UTC 2021
Users have access to the fatal error source and code though the fatal error
extension. The user-specific fatal error handling should be done in statically
initialized fatal error handlers. The _Internal_errors_What_happened was
updated after the fatal error extension. In addition, there was no API to get
the information stored in _Internal_errors_What_happened. Remove this object
to save some bytes of storage.
cpukit/include/rtems/score/interr.h | 18 +-----------------
cpukit/score/src/interr.c | 11 +----------
testsuites/sptests/spsize/size.c | 2 --
3 files changed, 2 insertions(+), 29 deletions(-)
diff --git a/cpukit/include/rtems/score/interr.h b/cpukit/include/rtems/score/interr.h
index e5a0a62cf6..65cac29500 100644
--- a/cpukit/include/rtems/score/interr.h
+++ b/cpukit/include/rtems/score/interr.h
@@ -214,21 +214,6 @@ typedef enum {
typedef CPU_Uint32ptr Internal_errors_t;
- * This type holds the fatal error information.
-typedef struct {
- /** This is the source of the error. */
- Internal_errors_Source the_source;
- /** This is the error code. */
- Internal_errors_t the_error;
-} Internal_errors_Information;
- * When a fatal error occurs, the error information is stored here.
-extern Internal_errors_Information _Internal_errors_What_happened;
* @brief Initiates system termination.
@@ -253,8 +238,7 @@ extern Internal_errors_Information _Internal_errors_What_happened;
* may install an initial extension that performs a system reset. In this case
* the non-initial extensions will be not called.
- * Once all fatal handler executed the error information will be stored to
- * _Internal_errors_What_happened and the system state is set to
+ * Once all fatal handler executed the system state is set to
* SYSTEM_STATE_TERMINATED.
* The final step is to call the CPU specific _CPU_Fatal_halt().
diff --git a/cpukit/score/src/interr.c b/cpukit/score/src/interr.c
index 3f5ec2c473..fd5a4c92b8 100644
--- a/cpukit/score/src/interr.c
+++ b/cpukit/score/src/interr.c
@@ -4,8 +4,7 @@
* @ingroup RTEMSScoreIntErr
* @brief This source file contains the definition of ::_System_state_Current
- * and ::_Internal_errors_What_happened and implementation of _Terminate() and
- * _Internal_error().
+ * and the implementation of _Terminate() and _Internal_error().
@@ -28,22 +27,14 @@
System_state_Codes _System_state_Current;
-Internal_errors_Information _Internal_errors_What_happened;
void _Terminate(
Internal_errors_Source the_source,
_User_extensions_Fatal( the_source, the_error );
- _Internal_errors_What_happened.the_source = the_source;
- _Internal_errors_What_happened.the_error = the_error;
_System_state_Set( SYSTEM_STATE_TERMINATED );
_SMP_Request_shutdown();
_CPU_Fatal_halt( the_source, the_error );
/* will not return from this routine */
diff --git a/testsuites/sptests/spsize/size.c b/testsuites/sptests/spsize/size.c
index d26e34f51d..1b6881bb24 100644
--- a/testsuites/sptests/spsize/size.c
+++ b/testsuites/sptests/spsize/size.c
@@ -272,8 +272,6 @@ uninitialized =
/*init.h*/ 0 +
-/*interr.h*/ (sizeof _Internal_errors_What_happened) +
/*intr.h*/ 0 +
/*isr.h*/ (sizeof _ISR_Nest_level) +
2.26.2
