[PATCH] score: Remove _Internal_errors_What_happened
Gedare Bloom
gedare at rtems.org
Tue Jul 27 19:56:19 UTC 2021
Thanks, this also needs a rtems-docs/c-user/fatal-error update
On Tue, Jul 27, 2021 at 2:13 AM Sebastian Huber
> Users have access to the fatal error source and code though the fatal error
> extension. The user-specific fatal error handling should be done in statically
> initialized fatal error handlers. The _Internal_errors_What_happened was
> updated after the fatal error extension. In addition, there was no API to get
> the information stored in _Internal_errors_What_happened. Remove this object
> to save some bytes of storage.
> cpukit/include/rtems/score/interr.h | 18 +-----------------
> cpukit/score/src/interr.c | 11 +----------
> testsuites/sptests/spsize/size.c | 2 --
> 3 files changed, 2 insertions(+), 29 deletions(-)
> diff --git a/cpukit/include/rtems/score/interr.h b/cpukit/include/rtems/score/interr.h
> index e5a0a62cf6..65cac29500 100644
> --- a/cpukit/include/rtems/score/interr.h
> +++ b/cpukit/include/rtems/score/interr.h
> @@ -214,21 +214,6 @@ typedef enum {
> typedef CPU_Uint32ptr Internal_errors_t;
> - * This type holds the fatal error information.
> -typedef struct {
> - /** This is the source of the error. */
> - Internal_errors_Source the_source;
> - /** This is the error code. */
> - Internal_errors_t the_error;
> -} Internal_errors_Information;
> - * When a fatal error occurs, the error information is stored here.
> -extern Internal_errors_Information _Internal_errors_What_happened;
> * @brief Initiates system termination.
> @@ -253,8 +238,7 @@ extern Internal_errors_Information _Internal_errors_What_happened;
> * may install an initial extension that performs a system reset. In this case
> * the non-initial extensions will be not called.
> - * Once all fatal handler executed the error information will be stored to
> - * _Internal_errors_What_happened and the system state is set to
> + * Once all fatal handler executed the system state is set to
> * SYSTEM_STATE_TERMINATED.
> * The final step is to call the CPU specific _CPU_Fatal_halt().
> diff --git a/cpukit/score/src/interr.c b/cpukit/score/src/interr.c
> index 3f5ec2c473..fd5a4c92b8 100644
> --- a/cpukit/score/src/interr.c
> +++ b/cpukit/score/src/interr.c
> @@ -4,8 +4,7 @@
> * @ingroup RTEMSScoreIntErr
> * @brief This source file contains the definition of ::_System_state_Current
> - * and ::_Internal_errors_What_happened and implementation of _Terminate() and
> - * _Internal_error().
> + * and the implementation of _Terminate() and _Internal_error().
> @@ -28,22 +27,14 @@
> System_state_Codes _System_state_Current;
> -Internal_errors_Information _Internal_errors_What_happened;
> void _Terminate(
> Internal_errors_Source the_source,
> _User_extensions_Fatal( the_source, the_error );
> - _Internal_errors_What_happened.the_source = the_source;
> - _Internal_errors_What_happened.the_error = the_error;
> _System_state_Set( SYSTEM_STATE_TERMINATED );
> _SMP_Request_shutdown();
> _CPU_Fatal_halt( the_source, the_error );
> /* will not return from this routine */
> diff --git a/testsuites/sptests/spsize/size.c b/testsuites/sptests/spsize/size.c
> index d26e34f51d..1b6881bb24 100644
> --- a/testsuites/sptests/spsize/size.c
> +++ b/testsuites/sptests/spsize/size.c
> @@ -272,8 +272,6 @@ uninitialized =
> /*init.h*/ 0 +
> -/*interr.h*/ (sizeof _Internal_errors_What_happened) +
> /*intr.h*/ 0 +
> /*isr.h*/ (sizeof _ISR_Nest_level) +
> 2.26.2
> devel mailing list
> devel at rtems.org
