[PATCH 1/3] rsb: Store patches in separate directories
Alex White
alex.white at oarcorp.com
Tue Jul 27 14:13:52 UTC 2021
On Tue, Jul 27, 2021 at 12:46 AM Chris Johns <chrisj at rtems.org> wrote:
> On 27/7/21 3:39 pm, Sebastian Huber wrote:
> > On 27/07/2021 05:30, Alex White wrote:
> >> This prevents patches with the same name from conflicting and causing
> >> the build to fail.
> > Why can't the patches have a unique file name?
> Yeap and if specific to Xilinx and their repos it should be labelled in a manner
> that highlights that. Further you cannot create a release without unique file
> names because we have a single source directory ....
> https://ftp.rtems.org/pub/rtems/releases/5/5.1/sources/
> And I see no reason to change this.
I just realized that even if I separate these patches by build name, the problem would remain that patches for the same build item with the same name (however improbable they are) would conflict.
It looks like it would be better for me to create an RTEMS ticket to hold these patches and rename them to work around this issue. I'll do that.
Thanks,
Alex
> Chris
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210727/5a366b44/attachment.html>
