[PATCH 1/3] rsb: Store patches in separate directories
Wed Jul 28 00:44:17 UTC 2021
On 28/7/21 12:13 am, Alex White wrote:
> On Tue, Jul 27, 2021 at 12:46 AM Chris Johns <chrisj at rtems.org> wrote:
>> On 27/7/21 3:39 pm, Sebastian Huber wrote:
>> > On 27/07/2021 05:30, Alex White wrote:
>> >> This prevents patches with the same name from conflicting and causing
>> >> the build to fail.
>> > Why can't the patches have a unique file name?
>> Yeap and if specific to Xilinx and their repos it should be labelled in a manner
>> that highlights that. Further you cannot create a release without unique file
>> names because we have a single source directory ....
>> https://ftp.rtems.org/pub/rtems/releases/5/5.1/sources/
>> And I see no reason to change this.
> I just realized that even if I separate these patches by build name, the problem
> would remain that patches for the same build item with the same name (however
> improbable they are) would conflict.
> It looks like it would be better for me to create an RTEMS ticket to hold these
> patches and rename them to work around this issue. I'll do that.
Alex,
Could you please explain what the issue is rather than presenting us with
solutions we then reject? I have no idea what the problem is you are attempting
to solve.
Please do not create a ticket until there is general agreement this is the best
solution.
Thanks
