[PATCH rtems-libbsd 3/4] nexus-devices: Include CDC Ethernet for Beagle
Ahamed Husni ahamedhusni73 at gmail.com
Tue Jul 27 15:04:29 UTC 2021
On Fri, Jul 16, 2021 at 1:25 AM Christian Mauderer <oss at c-mauderer.de>
wrote:
> On 06/07/2021 19:00, Husni Faiz wrote:
> > Configure bus for CDC Ethernet
> > Include CDC Ethernet in Beagle BSP
> > Signed-off-by: Husni Faiz <ahamedhusni73 at gmail.com>
> >   rtemsbsd/include/bsp/nexus-devices.h           |  5 +++++
> >   rtemsbsd/include/machine/rtems-bsd-nexus-bus.h | 17 +++++++++++++++++
> >   2 files changed, 22 insertions(+)
> > diff --git a/rtemsbsd/include/bsp/nexus-devices.h
> b/rtemsbsd/include/bsp/nexus-devices.h
> > index e6487470..6a35632e 100644
> > --- a/rtemsbsd/include/bsp/nexus-devices.h
> > +++ b/rtemsbsd/include/bsp/nexus-devices.h
> > @@ -83,6 +83,11 @@ SYSINIT_REFERENCE(rtwn_rtl8188eufw);
> >   RTEMS_BSD_DRIVER_USB;
> >   RTEMS_BSD_DRIVER_USB_MASS;
> > +#ifdef RTEMS_BSD_MODULE_DEV_USB_TEMPLATE
> > +RTEMS_BSD_DRIVER_USB_TEMPLATE;
> > +RTEMS_BSD_DRIVER_CDCE;
> > +#endif
> Same like in patch 2: Shouldn't there be an include for
> rtems/bsd/modules.h somewhere?
> I checked the nexus-devices.h and it already has the modules.h included.
>   #elif defined(LIBBSP_ARM_LPC32XX_BSP_H)
> >   #include <bsp/irq.h>
> > diff --git a/rtemsbsd/include/machine/rtems-bsd-nexus-bus.h
> b/rtemsbsd/include/machine/rtems-bsd-nexus-bus.h
> > index 50a43873..84f561f5 100644
> > --- a/rtemsbsd/include/machine/rtems-bsd-nexus-bus.h
> > +++ b/rtemsbsd/include/machine/rtems-bsd-nexus-bus.h
> > @@ -282,6 +282,15 @@ extern "C" {
> >       SYSINIT_DRIVER_REFERENCE(umass, uhub)
> >   #endif /* RTEMS_BSD_DRIVER_USB_MASS */
> > + * USB Template base driver.
> > +#if !defined(RTEMS_BSD_DRIVER_USB_TEMPLATE)
> > +  #define RTEMS_BSD_DRIVER_USB_TEMPLATE           \
> > +    SYSINIT_REFERENCE(usb_temp_init);             \
> > +    SYSINIT_DRIVER_REFERENCE(usb_template, usb)
> > +#endif /* RTEMS_BSD_DRIVER_USB_TEMPLATE */
> >    * USB SAF1761 host controller driver.
> > @@ -490,6 +499,14 @@ extern "C" {
> >       SYSINIT_DRIVER_REFERENCE(re, pci);
> >   #endif /* RTEMS_BSD_DRIVER_PCI_RE */
> > + * CDC Ethernet Driver.
> > +#if !defined(RTEMS_BSD_DRIVER_CDCE)
> > +  #define RTEMS_BSD_DRIVER_CDCE                   \
> > +    SYSINIT_DRIVER_REFERENCE(cdce, uhub);
> > +#endif /* RTEMS_BSD_DRIVER_FEC */
> >    ** MMI Physical Layer Support.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210727/bb1f3eb4/attachment.html>
