[PATCH rtems-libbsd.nfs 1/4] Implement portable kernel symbol namespace tool
Gedare Bloom
gedare at rtems.org
Tue Jul 27 21:16:59 UTC 2021
On Tue, Jul 27, 2021 at 2:09 AM <chrisj at rtems.org> wrote:
> From: Chris Johns <chrisj at rtems.org>
> - The script's use of sort proved to not be portable
> - No need to check the commits as symbols are only added
> - Regenerated kernel header to reset the sort order
> Update #4475
> CONTRIBUTING.md | 72 +-
> create-kernel-namespace.sh | 133 -
> rtems-kern-symbols | 502 +
> .../machine/rtems-bsd-kernel-namespace.h | 11418 ++++++++--------
> 4 files changed, 6283 insertions(+), 5842 deletions(-)
> delete mode 100755 create-kernel-namespace.sh
> create mode 100755 rtems-kern-symbols
> diff --git a/CONTRIBUTING.md b/CONTRIBUTING.md
> index 20dc938b..5dae62f8 100644
> --- a/CONTRIBUTING.md
> +++ b/CONTRIBUTING.md
> @@ -121,6 +121,76 @@ $ git log freebsd-org
> to figure out the current FreeBSD baseline.
> +Updates to FreeBSD or RTEMS Kernel Support
> +If you update code or change any defines that effect code in the following paths:
> +* `freebsd/sys/*.[ch]`
> +* `rtemsbsd/rtems/rtems-kernel-*.c`
> +you need to see if any new kernel symbols have been generated for
s/for/or
> +exposed. The tool `rtems-kern-symbols` command support this operation.
s/support/supports
> +The public (global) kernel symbosl need to reside in a private
s/symbosl/symbols
> +namespace to avoid clashing with symbols in the user space code or
> +applications. The FreeBSD kernel names functions and variables
> +assuming a private kernel only symbols space. RTEMS builds FreeBSD
> +kernel and user space code in the same symbols sapce so there can be
s/sapce/space
> +clashes. We manage this by maintained a header file that maps the
s/maintained/maintaining
> +global kernel symbols to a private namespace. For example `malloc` is
> +mapped to `_bsd_malloc`.
> +The set of symbols to map is not easy to obtain because symbols may be
> +the result of complex preprocessing of the source, the code is
> +specific to a BSP or the code is controlled by a buildset.
> +The approach is not remove symbols unless you are certain the symbols
s/is/is to ?
> +has been removed from the source. This is a manual operation.
s/has/have
s/source/libbsd source ?
> +You are required to check symbols with a 32bit and 64bit
> +architecture.
> +If you are working a specific BSP and related drivers please make sure
s/working/working on
> +the kernel symbols are checked. It is too much to ask every developer
> +to build all BSPs and check.
> +RTEMS Kernel Symbols Tool
> +The python tool `rtems-kern-symbols` can read a kernel header load the existing of headers.
"to load" or "load of" ?
> +The kernel namespace header can be regenerated from the original
> +header. This checks the kernel header is already sorted. If you think
> +there is a sorting issue in the existing header please regenerate
> +without adding new symbols.
> +$ ./rtems-kern-symbols --regenerate --output=tmp.h
> +The tools needs access to your built RTEMS tools. You can set your
"tool needs"
> +environment `PATH` variable or you can specify the top level path as an argument:
> +$ ./rtems-kern-symbols --tools=/opt/work/rtems/6
This is inconsistent with other ecosystem support, use --rtems-tools instead?
> +Options:
> +* You can provide a different kernel header using the `--kern-header`
> +argument. The default is the LibbSD header.
> +* The `--report` option provides a report.
> +* The `--diff` option pvoides a unified diff of any changes.
provides
> +* The `--write` option is need to write any changes
needed
> +* The `--output` option lets you write to different file
different from what?
> +The tool manages a number of exlcuded symbols. These are symbols in
excluded
> +the kernel space that are not mapped to the RTEMS kernal namespace.
kernel
> How to Import Code from FreeBSD
> @@ -134,7 +204,7 @@ How to Import Code from FreeBSD
> * Immediately check in the imported files without the changes to `libbsd.py` and the buildsets. Do not touch the imported files yourself at this point.
> * Port the imported files to RTEMS. See 'Rules for Modifying FreeBSD Source'.
> * Add a test to the testsuite if possible.
> -* Run `./create-kernel-namespace.sh` if you imported kernel space headers. Add only your new defines via `git add -p rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h`.
> +* Run `./rtems-kern-symbols` as discussed above
> * Create one commit from this.
> The -S or --stats option generates reports the changes we have made to
> diff --git a/create-kernel-namespace.sh b/create-kernel-namespace.sh
> deleted file mode 100755
> index ed4efa10..00000000
> --- a/create-kernel-namespace.sh
> +++ /dev/null
> @@ -1,133 +0,0 @@
> -#!/bin/sh -x
> -# Copyright (c) 2016 embedded brains GmbH. All rights reserved.
> -# embedded brains GmbH
> -# Dornierstr. 4
> -# 82178 Puchheim
> -# Germany
> -# <rtems at embedded-brains.de>
> -# Redistribution and use in source and binary forms, with or without
> -# modification, are permitted provided that the following conditions
> -# are met:
> -# 1. Redistributions of source code must retain the above copyright
> -# notice, this list of conditions and the following disclaimer.
> -# 2. Redistributions in binary form must reproduce the above copyright
> -# notice, this list of conditions and the following disclaimer in the
> -# documentation and/or other materials provided with the distribution.
> -# THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
> -# ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> -# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> -# ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
> -# FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
> -# DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
> -# OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
> -# HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
> -# LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
> -# OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
> -# SUCH DAMAGE.
> -# This script generates the kernel namespace header file
> -# <machine/rtems-bsd-kernel-namespace.h>.
> -objdump --syms `for i in build/*rtems* ; do \
> - find $i/freebsd/sys/ -name '*.o' ; \
> - echo $i/rtemsbsd/rtems/rtems-kernel-*.o ; \
> - done` \
> - | awk '/^[0-9a-f]+[[:blank:]]+g/ {print $6}' \
> - | sed 's/^_bsd_//' \
> - | sed '/^accept$/d' \
> - | sed '/^arc4random$/d' \
> - | sed '/^bind$/d' \
> - | sed '/^blackhole$/d' \
> - | sed '/^bpf_filter$/d' \
> - | sed '/^bpf_jitter$/d' \
> - | sed '/^bpf_jitter_enable$/d' \
> - | sed '/^bpf_validate$/d' \
> - | sed '/^connect$/d' \
> - | sed '/^drop_redirect$/d' \
> - | sed '/^drop_synfin$/d' \
> - | sed '/^free$/d' \
> - | sed '/^getentropy$/d' \
> - | sed '/^getpeername$/d' \
> - | sed '/^getsockname$/d' \
> - | sed '/^getsockopt$/d' \
> - | sed '/^ifqmaxlen$/d' \
> - | sed '/^in6addr_any$/d' \
> - | sed '/^in6addr_loopback$/d' \
> - | sed '/^in6addr_nodelocal_allnodes$/d' \
> - | sed '/^in6addr_linklocal_allnodes$/d' \
> - | sed '/^kevent$/d' \
> - | sed '/^kqueue$/d' \
> - | sed '/^listen$/d' \
> - | sed '/^malloc$/d' \
> - | sed '/^max_datalen$/d' \
> - | sed '/^max_hdr$/d' \
> - | sed '/^max_linkhdr$/d' \
> - | sed '/^max_protohdr$/d' \
> - | sed '/^maxsockets$/d' \
> - | sed '/^nd6_debug$/d' \
> - | sed '/^nd6_delay$/d' \
> - | sed '/^nd6_gctimer$/d' \
> - | sed '/^nd6_maxnudhint$/d' \
> - | sed '/^nd6_mmaxtries$/d' \
> - | sed '/^nd6_onlink_ns_rfc4861$/d' \
> - | sed '/^nd6_prune$/d' \
> - | sed '/^nd6_umaxtries$/d' \
> - | sed '/^nd6_useloopback$/d' \
> - | sed '/^nmbclusters$/d' \
> - | sed '/^nmbjumbo16$/d' \
> - | sed '/^nmbjumbo9$/d' \
> - | sed '/^nmbjumbop$/d' \
> - | sed '/^nmbufs$/d' \
> - | sed '/^nolocaltimewait$/d' \
> - | sed '/^path_mtu_discovery$/d' \
> - | sed '/^pause$/d' \
> - | sed '/^pf_osfp_entry_pl$/d' \
> - | sed '/^pf_osfp_pl$/d' \
> - | sed '/^pipe$/d' \
> - | sed '/^poll$/d' \
> - | sed '/^random$/d' \
> - | sed '/^realloc$/d' \
> - | sed '/^reallocf$/d' \
> - | sed '/^recvfrom$/d' \
> - | sed '/^recvmsg$/d' \
> - | sed '/^rtems/d' \
> - | sed '/^select$/d' \
> - | sed '/^sendmsg$/d' \
> - | sed '/^sendto$/d' \
> - | sed '/^setfib$/d' \
> - | sed '/^setsockopt$/d' \
> - | sed '/^shutdown$/d' \
> - | sed '/^socket$/d' \
> - | sed '/^socketpair$/d' \
> - | sed '/^soreceive_stream$/d' \
> - | sed '/^srandom$/d' \
> - | sed '/^strdup$/d' \
> - | sed '/^sysctlbyname$/d' \
> - | sed '/^sysctl$/d' \
> - | sed '/^sysctlnametomib$/d' \
> - | sed '/sys_init/d' \
> - | sed '/^taskqueue_/d' \
> - | sed '/^tcp_offload_listen_start$/d' \
> - | sed '/^tcp_offload_listen_stop$/d' \
> - | sed '/^ticks$/d' \
> - | sed '/^useloopback$/d' \
> - | sed '/^_Watchdog_Ticks_since_boot$/d' \
> - | sort -u > symbols.txt
> -cat << eof > rtems-bsd-kernel-namespace.h
> -#ifndef _RTEMS_BSD_MACHINE_RTEMS_BSD_KERNEL_SPACE_H_
> -#error "the header file <machine/rtems-bsd-kernel-space.h> must be included first"
> -#endif
> -eof
> -sed 's/^\(.*\)/#define \1 _bsd_\1/' < symbols.txt >> rtems-bsd-kernel-namespace.h
> -rm symbols.txt
> -mv rtems-bsd-kernel-namespace.h rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h
> diff --git a/rtems-kern-symbols b/rtems-kern-symbols
> new file mode 100755
> index 00000000..e34a14a7
> --- /dev/null
> +++ b/rtems-kern-symbols
> @@ -0,0 +1,502 @@
> +#! /usr/bin/env python
> +# SPDX-License-Identifier: BSD-2-Clause
> +"""RTEMS LibBBSD Kernel Symbols
> +Generate the symbols for the kernel headers and merge in any new ones
> +# Copyright (C) 2021 Chris Johns <chrisj at rtems.org>, All rights reserved.
> +# Redistribution and use in source and binary forms, with or without
> +# modification, are permitted provided that the following conditions
> +# are met:
> +# 1. Redistributions of source code must retain the above copyright
> +# notice, this list of conditions and the following disclaimer.
> +# 2. Redistributions in binary form must reproduce the above copyright
> +# notice, this list of conditions and the following disclaimer in the
> +# documentation and/or other materials provided with the distribution.
> +# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> +# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> +# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> +# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
> +# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> +# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> +# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> +# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> +# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> +# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> +# POSSIBILITY OF SUCH DAMAGE.
> +from __future__ import print_function
> +import argparse
> +import os
> +import re
> +import sys
> +version = "1.0"
> +kern_objects = [
> + ( 'freebsd/sys', '.*\.o' ),
> + ( 'rtemsbsd/rtems', 'rtems-kernel-.*\.o' )
> +] # yapf: disable
> +kern_excludes = [
> + '^_bsd_' ,
> + '^rtems_',
> + '^accept$',
> + '^arc4random$',
> + '^bind$',
> + '^blackhole$',
> + '^bootverbose$',
> + '^bpf_filter$',
> + '^bpf_jitter$',
> + '^bpf_jitter_enable$',
> + '^bpf_validate$',
> + '^cache_enter$',
> + '^connect$',
> + '^drop_redirect$',
> + '^drop_synfin$',
> + '^free$',
> + '^getentropy$',
> + '^getpeername$',
> + '^getsockname$',
> + '^getsockopt$',
> + '^global_epoch$',
> + '^global_epoch_preempt$',
> + '^ifqmaxlen$',
> + '^in6addr_any$',
> + '^in6addr_linklocal_allnodes$',
> + '^in6addr_loopback$',
> + '^in6addr_nodelocal_allnodes$',
> + '^in_epoch$',
> + '^kevent$',
> + '^kqueue$',
> + '^listen$',
> + '^malloc$',
> + '^max_datalen$',
> + '^max_hdr$',
> + '^max_linkhdr$',
> + '^max_protohdr$',
> + '^maxsockets$',
> + '^nd6_debug$',
> + '^nd6_delay$',
> + '^nd6_gctimer$',
> + '^nd6_maxnudhint$',
> + '^nd6_mmaxtries$',
> + '^nd6_onlink_ns_rfc4861$',
> + '^nd6_prune$',
> + '^nd6_umaxtries$',
> + '^nd6_useloopback$',
> + '^net_epoch$',
> + '^net_epoch_preempt$',
> + '^nmbclusters$',
> + '^nmbjumbo16$',
> + '^nmbjumbo9$',
> + '^nmbjumbop$',
> + '^nmbufs$',
> + '^nolocaltimewait$',
> + '^path_mtu_discovery$',
> + '^pause$',
> + '^pf_osfp_entry_pl$',
> + '^pf_osfp_pl$',
> + '^pipe$',
> + '^poll$',
> + '^pselect$',
> + '^random$',
> + '^realloc$',
> + '^reallocf$',
> + '^recvfrom$',
> + '^recvmsg$',
> + '^rtems',
> + '^select$',
> + '^sendmsg$',
> + '^sendto$',
> + '^setfib$',
> + '^setsockopt$',
> + '^shutdown$',
> + '^socket$',
> + '^socketpair$',
> + '^soreceive_stream$',
> + '^srandom$',
> + '^strdup$',
> + '^sysctlbyname$',
> + '^sysctl$',
> + '^sysctlnametomib$',
> + 'sys_init',
> + '^taskqueue_',
> + '^tcp_offload_listen_start$',
> + '^tcp_offload_listen_stop$',
> + '^ticks$',
> + '^useloopback$',
> + '^_Watchdog_Ticks_since_boot$'
> +] # yapf: disable
> +kern_header = 'rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h'
Not that it worked before, but paths should avoid using explicitly '/' (or '\').
> +class exit(Exception):
> + """Base class for exceptions."""
> + def __init__(self, code):
> + self.code = code
> +class error(Exception):
> + def set_output(self, msg):
> + self.msg = msg
> + def __str__(self):
> + return self.msg
> +class general_error(error):
> + """Raise for a general error."""
> + def __init__(self, what):
> + self.set_output('error: ' + str(what))
> +class command:
> + def __init__(self, cmd, cwd='.'):
> + self.exit_code = 0
> + self.output = None
> + self.cmd = cmd
> + self.cwd = cwd
> + self.result = None
> + def run(self):
> + import subprocess
> + # Support Python 2.6
> + if "check_output" not in dir(subprocess):
> + def f(*popenargs, **kwargs):
> + if 'stdout' in kwargs:
> + raise ValueError(
> + 'stdout argument not allowed, it will be overridden.')
> + process = subprocess.Popen(stdout=subprocess.PIPE,
> + *popenargs,
> + **kwargs)
> + output, unused_err = process.communicate()
> + retcode = process.poll()
> + if retcode:
> + cmd = kwargs.get("args")
> + if cmd is None:
> + cmd = popenargs[0]
> + raise subprocess.CalledProcessError(retcode, cmd)
> + return output
> + subprocess.check_output = f
> + try:
> + if os.name == 'nt':
> + cmd = ['sh', '-c'] + self.cmd
> + else:
> + cmd = self.cmd
> + output = subprocess.check_output(cmd,
> + cwd=self.cwd).decode("utf-8")
> + self.output = output.split(os.linesep)
> + except subprocess.CalledProcessError as cpe:
> + self.exit_code = cpe.returncode
> + output = cpe.output.decode("utf-8")
> + except OSError as ose:
> + cs = ' '.join(cmd)
> + if len(cs) > 80:
> + cs = cs[:80] + '...'
> + raise general_error('bootstrap failed: %s in %s: %s' % \
> + (cs, self.cwd, (str(ose))))
> + except KeyboardInterrupt:
> + pass
> + except:
> + raise
> +class kernel_symbols:
> + def __init__(self, excludes):
> + self.excludes = [re.compile(exc) for exc in excludes]
> + self.bsps = {}
> + self.header = {'source': [], 'symbols': []}
> + self.output = {'source': [], 'symbols': []}
> + self.analysis = {'unmapped': [], 'new': []}
> + @staticmethod
> + def _find(base, spec):
> + found = []
> + filter = re.compile(spec[1])
> + for root, dirs, files in os.walk(os.path.join(base, spec[0]),
> + topdown=True):
> + for f in files:
> + if filter.match(f):
> + found += [os.path.join(root, f)]
> + return found
> + @staticmethod
> + def _find_bsps(build):
> + bsps = []
> + filter = re.compile('^.*-rtems[0-9].*-.*')
> + with os.scandir(build) as sdir:
> + for entry in sdir:
> + if entry.is_dir() and filter.match(entry.name) != None:
> + bsps += [entry.name]
> + return bsps
> + @staticmethod
> + def bsp_arch(bsp):
> + bs = bsp.split('-')
> + return bs[0] + '-' + bs[1]
> + def _clean(self, symbols):
> + syms = []
> + for sym in symbols:
> + add = True
> + for exclude in self.excludes:
> + if exclude.match(sym) is not None:
> + add = False
> + break
> + if add:
> + syms += [sym]
> + return sorted(list(set(syms)))
> + def load_header(self, header):
> + with open(header, 'r') as h:
> + self.header['source'] = h.read().splitlines()
> + filter = re.compile('^#define\s')
> + for line in self.header['source']:
> + if filter.match(line) != None:
> + ls = line.split()
> + if len(ls) == 3:
> + self.header['symbols'] += [ls[1]]
> + def load_symbols(self, specs, excludes, build, tools):
> + bsps = self._find_bsps(build)
> + for bsp in bsps:
> + self.bsps[bsp] = {'output': [], 'objects': [], 'symbols': []}
> + for spec in specs:
> + self.bsps[bsp]['objects'] += self._find(
> + os.path.join(build, bsp), spec)
> + arch = self.bsp_arch(bsp)
> + if tools is not None:
> + cmd = os.path.join(tools, 'bin', arch + '-nm')
> + else:
> + cmd = arch + '-nm'
> + nm = command([cmd] + self.bsps[bsp]['objects'])
> + nm.run()
> + self.bsps[bsp]['output'] = nm.output
> + object = '-'
> + syms = []
> + for line in nm.output:
> + if len(line) == 0:
> + continue
> + if line[-1] == ':':
> + object = os.path.basename(line[:-1])
> + continue
> + ls = line.split()
> + if len(ls) == 3:
> + ls = ls[1:]
> + if ls[0] in ['A', 'B', 'C', 'D', 'R', 'T', 'W']:
> + if ls[1] in syms:
> + print('warning: duplicate symbol: %s:%s: %s' %
> + (bsp, object, ls[1]))
> + syms += [ls[1]]
> + self.bsps[bsp]['symbols'] += syms
> + def generate_header(self):
> + out = [
> + '/*', '* RTEMS Libbsd, this file is generated. Do not edit.', '*/',
> + '#ifndef _RTEMS_BSD_MACHINE_RTEMS_BSD_KERNEL_SPACE_H_',
> + '#error "the header file <machine/rtems-bsd-kernel-space.h> must be included first"',
> + '#endif', ''
> + for sym in self.output['symbols']:
> + out += ['#define %s _bsd_%s' % (sym, sym)]
> + self.output['source'] = out
> + def write_header(self, header):
> + with open(header, 'wb') as o:
> + o.write(
> + os.linesep.join(self.output['source'] + ['']).encode("utf-8"))
> + def write_sym_data(self):
> + for bsp in self.bsps:
> + with open('sym-data-' + arch + '.txt', 'w') as o:
> + o.writelines(os.linesep.join(ks.bsps[bsp]['output']))
> + def merge(self, symbols):
> + self.output['symbols'] = \
> + self._clean(self.output['symbols'] + symbols)
> + def merge_bsp(self):
> + self.merge(self.bsps[bsp]['symbols'])
> + def analyse(self):
> + for sym in self.bsps[bsp]['symbols']:
> + if sym in self.header['symbols']:
> + key = 'unmapped'
> + else:
> + key = 'new'
> + self.analysis[key] += [sym]
> + for key in self.analysis:
> + self.analysis[key] = self._clean(self.analysis[key])
> + def diff(self):
> + import difflib
> + return list(
> + difflib.unified_diff(self.header['source'], self.output['source']))
> + def report(self):
> + out = [
> + 'Symbols:',
> + ' mapped : %d' % (len(self.header['symbols'])),
> + ' unmapped : %d' % (len(self.analysis['unmapped'])),
> + ' new : %d' % (len(self.analysis['new']))
> + max_len = 0
> + if max_len < len(bsp):
> + max_len = len(bsp)
> + out += ['BSPs: %*s Unmapped Total' % (max_len - 4, ' ')]
> + unmapped = len(self._clean(self.bsps[bsp]['symbols']))
> + total = len(self.bsps[bsp]['symbols'])
> + out += [' %-*s: %-8d %d' % (max_len, bsp, unmapped, total)]
> + out += ['Unmapped:'] + [' ' + sym for sym in self.analysis['unmapped']]
> + out += ['New:'] + [' ' + sym for sym in self.analysis['new']]
> + return out
> +def run(args):
> + try:
> + argsp = argparse.ArgumentParser(
> + prog='rtems-kern-symbols',
> + description="RTEMS LibBSD Kernel Symbols")
> + argsp.add_argument('-t',
> + '--tools',
> + help='RTEMS Tools (default: %(default)s).',
> + type=str,
> + default=None)
> + '-w',
> + '--write',
> + action='store_true',
> + help=
> + 'Write the header to the output file name (default: %(default)s).')
> + '-d',
> + '--diff',
> + help='Show a diff if the header has changed (default: %(default)s).'
> + '-o',
> + '--output',
> + type=str,
> + default=kern_header,
> + help='output path to the write the header (default: %(default)s).')
> + '-b',
> + '--build',
> + type=str,
> + default='build',
> + help='path to the rtems libbsd build output (default: %(default)s).'
> + '-K',
> + '--kern-header',
> + type=str,
> + help=
> + 'kernel header to load existing symbols from(default: %(default)s).'
> + '-S',
> + '--sym-data',
> + action="store_true",
> + help=
> + 'Write the BSP symbol data that is parsed (default: %(default)s).')
> + '-r',
> + '--regenerate',
> + help=
> + 'Regenerate the header file from the symbols in it, write option ignored (default: %(default)s).'
> + argsp.add_argument('-R',
> + '--report',
> + help='Generate a report (default: %(default)s).')
> + argopts = argsp.parse_args(args[1:])
> + print('RTEMS LibBSD Kernel Symbols, %s' % (version))
> + if not os.path.exists(argopts.build):
> + raise general_error('path does not exist: %s' % (argopts.build))
> + ks = kernel_symbols(kern_excludes)
> + ks.load_header(argopts.kern_header)
> + if argopts.regenerate:
> + ks.merge(ks.header['symbols'])
> + print('Regenerating: symbols: %d: %s' %
> + (len(ks.output['symbols']), argopts.output))
> + ks.generate_header()
> + diff = ks.diff()
> + if len(diff) == 0:
> + print('info: no changes; header not updated')
> + else:
> + print('info: writing: %s' % (argopts.output))
> + ks.write_header(argopts.output)
> + raise exit(0)
> + ks.load_symbols(kern_objects, kern_excludes, argopts.build,
> + argopts.tools)
> + if argopts.sym_data:
> + ks.write_sym_data()
> + ks.analyse()
> + ks.merge_bsp()
> + diff = ks.diff()
> + if argopts.write:
> + else:
> + if argopts.report:
> + print(os.linesep.join(ks.report()))
> + if argopts.diff:
> + print('Diff: %d' % (len(diff)))
> + print(os.linesep.join(diff))
> + except general_error as gerr:
> + print(gerr)
> + print('RTEMS Kernel Symbols FAILED', file=sys.stderr)
> + sys.exit(1)
> + log.notice('abort: user terminated')
> + sys.exit(1)
> + except exit as ec:
> + sys.exit(ec.code)
> + sys.exit(0)
> +if __name__ == "__main__":
> + run(sys.argv)
> diff --git a/rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h b/rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h
> index 3300b3fd..108709ce 100644
> --- a/rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h
> +++ b/rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h
> @@ -1,5712 +1,5714 @@
> +* RTEMS Libbsd, this file is generated. Do not edit.
> #endif
