[PATCH 4/4] score: Move per-CPU jobs support
Sebastian Huber
Wed Jul 28 11:18:04 UTC 2021
Add percpujobs.c to contain the per-CPU jobs implementation.
cpukit/Makefile.am | 1 +
cpukit/score/src/percpujobs.c | 124 ++++++++++++++++++++++++++
cpukit/score/src/smpmulticastaction.c | 89 +-----------------
spec/build/cpukit/objsmp.yml | 4 +-
4 files changed, 130 insertions(+), 88 deletions(-)
create mode 100644 cpukit/score/src/percpujobs.c
diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
index c83167668d..5673c4e8fb 100644
--- a/cpukit/Makefile.am
+++ b/cpukit/Makefile.am
@@ -1150,6 +1150,7 @@ endif
if HAS_SMP
+librtemscpu_a_SOURCES += score/src/percpujobs.c
librtemscpu_a_SOURCES += score/src/percpustatewait.c
librtemscpu_a_SOURCES += score/src/profilingsmplock.c
librtemscpu_a_SOURCES += score/src/schedulerdefaultpinunpin.c
diff --git a/cpukit/score/src/percpujobs.c b/cpukit/score/src/percpujobs.c
new file mode 100644
index 0000000000..4ce96dc738
--- /dev/null
+++ b/cpukit/score/src/percpujobs.c
@@ -0,0 +1,124 @@
+ * @file
+ * @ingroup RTEMSScorePerCPU
+ * @brief This source file contains the implementation of _Per_CPU_Add_job(),
+ * _Per_CPU_Perform_jobs(), and _Per_CPU_Wait_for_job().
+ * Copyright (C) 2019 embedded brains GmbH
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems/score/smpimpl.h>
+#include <rtems/score/assert.h>
+#define _Per_CPU_Jobs_ISR_disable_and_acquire( cpu, lock_context ) \
+ _ISR_lock_ISR_disable_and_acquire( &( cpu )->Jobs.Lock, lock_context )
+#define _Per_CPU_Jobs_release_and_ISR_enable( cpu, lock_context ) \
+ _ISR_lock_Release_and_ISR_enable( &( cpu )->Jobs.Lock, lock_context )
+void _Per_CPU_Perform_jobs( Per_CPU_Control *cpu )
+ ISR_lock_Context lock_context;
+ Per_CPU_Job *job;
+ _Per_CPU_Jobs_ISR_disable_and_acquire( cpu, &lock_context );
+ job = cpu->Jobs.head;
+ cpu->Jobs.head = NULL;
+ _Per_CPU_Jobs_release_and_ISR_enable( cpu, &lock_context );
+ while ( job != NULL ) {
+ const Per_CPU_Job_context *context;
+ Per_CPU_Job *next;
+ context = job->context;
+ next = job->next;
+ ( *context->handler )( context->arg );
+ _Atomic_Store_ulong( &job->done, PER_CPU_JOB_DONE, ATOMIC_ORDER_RELEASE );
+ job = next;
+void _Per_CPU_Add_job( Per_CPU_Control *cpu, Per_CPU_Job *job )
+ _Atomic_Store_ulong( &job->done, 0, ATOMIC_ORDER_RELAXED );
+ _Assert( job->next == NULL );
+ if ( cpu->Jobs.head == NULL ) {
+ cpu->Jobs.head = job;
+ } else {
+ *cpu->Jobs.tail = job;
+ cpu->Jobs.tail = &job->next;
+void _Per_CPU_Wait_for_job(
+ const Per_CPU_Control *cpu,
+ const Per_CPU_Job *job
+ while (
+ _Atomic_Load_ulong( &job->done, ATOMIC_ORDER_ACQUIRE )
+ != PER_CPU_JOB_DONE
+ Per_CPU_Control *cpu_self;
+ switch ( _Per_CPU_Get_state( cpu ) ) {
+ case PER_CPU_STATE_INITIAL:
+ case PER_CPU_STATE_READY_TO_START_MULTITASKING:
+ case PER_CPU_STATE_UP:
+ * Calling this function with the current processor is intentional. We
+ * have to perform our own jobs here in case inter-processor interrupts
+ * are not working.
+ cpu_self = _Per_CPU_Get();
+ _SMP_Try_to_process_message(
+ cpu_self,
+ _Atomic_Load_ulong( &cpu_self->message, ATOMIC_ORDER_RELAXED )
+ break;
+ default:
+ _SMP_Fatal( SMP_FATAL_WRONG_CPU_STATE_TO_PERFORM_JOBS );
+ break;
diff --git a/cpukit/score/src/smpmulticastaction.c b/cpukit/score/src/smpmulticastaction.c
index 8dbdef80c7..03d9e064fe 100644
--- a/cpukit/score/src/smpmulticastaction.c
+++ b/cpukit/score/src/smpmulticastaction.c
@@ -3,12 +3,11 @@
* @file
- * @ingroup RTEMSScorePerCPU
* @ingroup RTEMSScoreSMP
- * @brief This source file contains the implementation of _Per_CPU_Add_job(),
- * _Per_CPU_Perform_jobs(), _Per_CPU_Wait_for_job(), _SMP_Broadcast_action(),
- * _SMP_Multicast_action(), _SMP_Othercast_action(), and _SMP_Synchronize().
+ * _SMP_Broadcast_action(), _SMP_Multicast_action(), _SMP_Othercast_action(),
+ * and _SMP_Synchronize().
@@ -43,88 +42,6 @@
-#define _Per_CPU_Jobs_ISR_disable_and_acquire( cpu, lock_context ) \
- _ISR_lock_ISR_disable_and_acquire( &( cpu )->Jobs.Lock, lock_context )
-#define _Per_CPU_Jobs_release_and_ISR_enable( cpu, lock_context ) \
- _ISR_lock_Release_and_ISR_enable( &( cpu )->Jobs.Lock, lock_context )
-void _Per_CPU_Perform_jobs( Per_CPU_Control *cpu )
- ISR_lock_Context lock_context;
- Per_CPU_Job *job;
- _Per_CPU_Jobs_ISR_disable_and_acquire( cpu, &lock_context );
- job = cpu->Jobs.head;
- cpu->Jobs.head = NULL;
- _Per_CPU_Jobs_release_and_ISR_enable( cpu, &lock_context );
- while ( job != NULL ) {
- const Per_CPU_Job_context *context;
- Per_CPU_Job *next;
- context = job->context;
- next = job->next;
- ( *context->handler )( context->arg );
- _Atomic_Store_ulong( &job->done, PER_CPU_JOB_DONE, ATOMIC_ORDER_RELEASE );
- job = next;
-void _Per_CPU_Add_job( Per_CPU_Control *cpu, Per_CPU_Job *job )
- _Atomic_Store_ulong( &job->done, 0, ATOMIC_ORDER_RELAXED );
- _Assert( job->next == NULL );
- if ( cpu->Jobs.head == NULL ) {
- cpu->Jobs.head = job;
- } else {
- *cpu->Jobs.tail = job;
- cpu->Jobs.tail = &job->next;
-void _Per_CPU_Wait_for_job(
- const Per_CPU_Control *cpu,
- const Per_CPU_Job *job
- while (
- _Atomic_Load_ulong( &job->done, ATOMIC_ORDER_ACQUIRE )
- != PER_CPU_JOB_DONE
- Per_CPU_Control *cpu_self;
- switch ( _Per_CPU_Get_state( cpu ) ) {
- case PER_CPU_STATE_INITIAL:
- case PER_CPU_STATE_READY_TO_START_MULTITASKING:
- case PER_CPU_STATE_UP:
- * Calling this function with the current processor is intentional. We
- * have to perform our own jobs here in case inter-processor interrupts
- * are not working.
- cpu_self = _Per_CPU_Get();
- _SMP_Try_to_process_message(
- cpu_self,
- _Atomic_Load_ulong( &cpu_self->message, ATOMIC_ORDER_RELAXED )
- break;
- default:
- _SMP_Fatal( SMP_FATAL_WRONG_CPU_STATE_TO_PERFORM_JOBS );
- break;
typedef struct {
Per_CPU_Job_context Context;
Per_CPU_Job Jobs[ CPU_MAXIMUM_PROCESSORS ];
diff --git a/spec/build/cpukit/objsmp.yml b/spec/build/cpukit/objsmp.yml
index 1eb1faa3d6..992ed50666 100644
--- a/spec/build/cpukit/objsmp.yml
+++ b/spec/build/cpukit/objsmp.yml
@@ -5,12 +5,12 @@ copyrights:
- Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
cppflags: []
cxxflags: []
-enabled-by:
-- RTEMS_SMP
+enabled-by: RTEMS_SMP
includes: []
install: []
links: []
source:
+- cpukit/score/src/percpujobs.c
- cpukit/score/src/percpustatewait.c
- cpukit/score/src/profilingsmplock.c
- cpukit/score/src/schedulerdefaultaskforhelp.c
2.26.2
