[PATCH 4/4] score: Move per-CPU jobs support
Gedare Bloom
gedare at rtems.org
Wed Jul 28 16:20:59 UTC 2021
ok, other than notes I made on 2/4. Address the overlap with
SMP_MESSAGE_SHUTDOWN, rest can be checked in without review.
On Wed, Jul 28, 2021 at 5:18 AM Sebastian Huber
> Add percpujobs.c to contain the per-CPU jobs implementation.
> cpukit/Makefile.am | 1 +
> cpukit/score/src/percpujobs.c | 124 ++++++++++++++++++++++++++
> cpukit/score/src/smpmulticastaction.c | 89 +-----------------
> spec/build/cpukit/objsmp.yml | 4 +-
> 4 files changed, 130 insertions(+), 88 deletions(-)
> create mode 100644 cpukit/score/src/percpujobs.c
> diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
> index c83167668d..5673c4e8fb 100644
> --- a/cpukit/Makefile.am
> +++ b/cpukit/Makefile.am
> @@ -1150,6 +1150,7 @@ endif
> if HAS_SMP
> +librtemscpu_a_SOURCES += score/src/percpujobs.c
> librtemscpu_a_SOURCES += score/src/percpustatewait.c
> librtemscpu_a_SOURCES += score/src/profilingsmplock.c
> librtemscpu_a_SOURCES += score/src/schedulerdefaultpinunpin.c
> diff --git a/cpukit/score/src/percpujobs.c b/cpukit/score/src/percpujobs.c
> new file mode 100644
> index 0000000000..4ce96dc738
> --- /dev/null
> +++ b/cpukit/score/src/percpujobs.c
> @@ -0,0 +1,124 @@
> +/* SPDX-License-Identifier: BSD-2-Clause */
> + * @file
> + * @ingroup RTEMSScorePerCPU
> + * @brief This source file contains the implementation of _Per_CPU_Add_job(),
> + * _Per_CPU_Perform_jobs(), and _Per_CPU_Wait_for_job().
> + * Copyright (C) 2019 embedded brains GmbH
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + * notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + * notice, this list of conditions and the following disclaimer in the
> + * documentation and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> + * POSSIBILITY OF SUCH DAMAGE.
> +#ifdef HAVE_CONFIG_H
> +#include "config.h"
> +#endif
> +#include <rtems/score/smpimpl.h>
> +#include <rtems/score/assert.h>
> +#define _Per_CPU_Jobs_ISR_disable_and_acquire( cpu, lock_context ) \
> + _ISR_lock_ISR_disable_and_acquire( &( cpu )->Jobs.Lock, lock_context )
> +#define _Per_CPU_Jobs_release_and_ISR_enable( cpu, lock_context ) \
> + _ISR_lock_Release_and_ISR_enable( &( cpu )->Jobs.Lock, lock_context )
> +void _Per_CPU_Perform_jobs( Per_CPU_Control *cpu )
> + ISR_lock_Context lock_context;
> + Per_CPU_Job *job;
> + _Per_CPU_Jobs_ISR_disable_and_acquire( cpu, &lock_context );
> + job = cpu->Jobs.head;
> + cpu->Jobs.head = NULL;
> + _Per_CPU_Jobs_release_and_ISR_enable( cpu, &lock_context );
> + while ( job != NULL ) {
> + const Per_CPU_Job_context *context;
> + Per_CPU_Job *next;
> + context = job->context;
> + next = job->next;
> + ( *context->handler )( context->arg );
> + _Atomic_Store_ulong( &job->done, PER_CPU_JOB_DONE, ATOMIC_ORDER_RELEASE );
> + job = next;
> +void _Per_CPU_Add_job( Per_CPU_Control *cpu, Per_CPU_Job *job )
> + _Atomic_Store_ulong( &job->done, 0, ATOMIC_ORDER_RELAXED );
> + _Assert( job->next == NULL );
> + if ( cpu->Jobs.head == NULL ) {
> + cpu->Jobs.head = job;
> + } else {
> + *cpu->Jobs.tail = job;
> + cpu->Jobs.tail = &job->next;
> +void _Per_CPU_Wait_for_job(
> + const Per_CPU_Control *cpu,
> + const Per_CPU_Job *job
> + while (
> + _Atomic_Load_ulong( &job->done, ATOMIC_ORDER_ACQUIRE )
> + != PER_CPU_JOB_DONE
> + Per_CPU_Control *cpu_self;
> + switch ( _Per_CPU_Get_state( cpu ) ) {
> + case PER_CPU_STATE_INITIAL:
> + case PER_CPU_STATE_READY_TO_START_MULTITASKING:
> + case PER_CPU_STATE_UP:
> + * Calling this function with the current processor is intentional. We
> + * have to perform our own jobs here in case inter-processor interrupts
> + * are not working.
> + cpu_self = _Per_CPU_Get();
> + _SMP_Try_to_process_message(
> + cpu_self,
> + _Atomic_Load_ulong( &cpu_self->message, ATOMIC_ORDER_RELAXED )
> + break;
> + default:
> + _SMP_Fatal( SMP_FATAL_WRONG_CPU_STATE_TO_PERFORM_JOBS );
> + break;
> diff --git a/cpukit/score/src/smpmulticastaction.c b/cpukit/score/src/smpmulticastaction.c
> index 8dbdef80c7..03d9e064fe 100644
> --- a/cpukit/score/src/smpmulticastaction.c
> +++ b/cpukit/score/src/smpmulticastaction.c
> @@ -3,12 +3,11 @@
> * @file
> - * @ingroup RTEMSScorePerCPU
> * @ingroup RTEMSScoreSMP
> - * @brief This source file contains the implementation of _Per_CPU_Add_job(),
> - * _Per_CPU_Perform_jobs(), _Per_CPU_Wait_for_job(), _SMP_Broadcast_action(),
> - * _SMP_Multicast_action(), _SMP_Othercast_action(), and _SMP_Synchronize().
> + * _SMP_Broadcast_action(), _SMP_Multicast_action(), _SMP_Othercast_action(),
> + * and _SMP_Synchronize().
> @@ -43,88 +42,6 @@
> -#define _Per_CPU_Jobs_ISR_disable_and_acquire( cpu, lock_context ) \
> - _ISR_lock_ISR_disable_and_acquire( &( cpu )->Jobs.Lock, lock_context )
> -#define _Per_CPU_Jobs_release_and_ISR_enable( cpu, lock_context ) \
> - _ISR_lock_Release_and_ISR_enable( &( cpu )->Jobs.Lock, lock_context )
> -void _Per_CPU_Perform_jobs( Per_CPU_Control *cpu )
> - ISR_lock_Context lock_context;
> - Per_CPU_Job *job;
> - _Per_CPU_Jobs_ISR_disable_and_acquire( cpu, &lock_context );
> - job = cpu->Jobs.head;
> - cpu->Jobs.head = NULL;
> - _Per_CPU_Jobs_release_and_ISR_enable( cpu, &lock_context );
> - while ( job != NULL ) {
> - const Per_CPU_Job_context *context;
> - Per_CPU_Job *next;
> - context = job->context;
> - next = job->next;
> - ( *context->handler )( context->arg );
> - _Atomic_Store_ulong( &job->done, PER_CPU_JOB_DONE, ATOMIC_ORDER_RELEASE );
> - job = next;
> -void _Per_CPU_Add_job( Per_CPU_Control *cpu, Per_CPU_Job *job )
> - _Atomic_Store_ulong( &job->done, 0, ATOMIC_ORDER_RELAXED );
> - _Assert( job->next == NULL );
> - if ( cpu->Jobs.head == NULL ) {
> - cpu->Jobs.head = job;
> - } else {
> - *cpu->Jobs.tail = job;
> - cpu->Jobs.tail = &job->next;
> -void _Per_CPU_Wait_for_job(
> - const Per_CPU_Control *cpu,
> - const Per_CPU_Job *job
> - while (
> - _Atomic_Load_ulong( &job->done, ATOMIC_ORDER_ACQUIRE )
> - != PER_CPU_JOB_DONE
> - Per_CPU_Control *cpu_self;
> - switch ( _Per_CPU_Get_state( cpu ) ) {
> - case PER_CPU_STATE_INITIAL:
> - case PER_CPU_STATE_READY_TO_START_MULTITASKING:
> - case PER_CPU_STATE_UP:
> - * Calling this function with the current processor is intentional. We
> - * have to perform our own jobs here in case inter-processor interrupts
> - * are not working.
> - cpu_self = _Per_CPU_Get();
> - _SMP_Try_to_process_message(
> - cpu_self,
> - _Atomic_Load_ulong( &cpu_self->message, ATOMIC_ORDER_RELAXED )
> - break;
> - default:
> - _SMP_Fatal( SMP_FATAL_WRONG_CPU_STATE_TO_PERFORM_JOBS );
> - break;
> typedef struct {
> Per_CPU_Job_context Context;
> Per_CPU_Job Jobs[ CPU_MAXIMUM_PROCESSORS ];
> diff --git a/spec/build/cpukit/objsmp.yml b/spec/build/cpukit/objsmp.yml
> index 1eb1faa3d6..992ed50666 100644
> --- a/spec/build/cpukit/objsmp.yml
> +++ b/spec/build/cpukit/objsmp.yml
> @@ -5,12 +5,12 @@ copyrights:
> - Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
> cppflags: []
> cxxflags: []
> -enabled-by:
> -- RTEMS_SMP
> +enabled-by: RTEMS_SMP
> includes: []
> install: []
> links: []
> source:
> +- cpukit/score/src/percpujobs.c
> - cpukit/score/src/percpustatewait.c
> - cpukit/score/src/profilingsmplock.c
> - cpukit/score/src/schedulerdefaultaskforhelp.c
> 2.26.2
> devel mailing list
> devel at rtems.org
