[PATCH 1/4] score: Remove processor event broadcast/receive
Sebastian Huber
Wed Jul 28 11:18:01 UTC 2021
Remove _CPU_SMP_Processor_event_broadcast() and
_CPU_SMP_Processor_event_receive(). These functions are hard to use since they
are subject to the lost wake up problem.
cpukit/include/rtems/score/percpu.h | 35 ++++++++++++++++++-
.../cpu/aarch64/include/rtems/score/cpu.h | 12 -------
.../score/cpu/arm/include/rtems/score/cpu.h | 12 -------
.../score/cpu/i386/include/rtems/score/cpu.h | 10 ------
.../cpu/no_cpu/include/rtems/score/cpu.h | 29 ---------------
.../cpu/powerpc/include/rtems/score/cpu.h | 10 ------
.../score/cpu/riscv/include/rtems/score/cpu.h | 10 ------
.../score/cpu/sparc/include/rtems/score/cpu.h | 10 ------
.../cpu/x86_64/include/rtems/score/cpu.h | 10 ------
cpukit/score/src/percpu.c | 20 +++++------
cpukit/score/src/percpustatewait.c | 14 ++++----
cpukit/score/src/smpmulticastaction.c | 4 +--
testsuites/smptests/smpfatal01/init.c | 6 ++--
testsuites/smptests/smpfatal02/init.c | 4 +--
testsuites/smptests/smpmulticast01/init.c | 2 +-
testsuites/smptests/smppsxsignal01/init.c | 5 ++-
testsuites/smptests/smpsignal01/init.c | 5 ++-
17 files changed, 61 insertions(+), 137 deletions(-)
diff --git a/cpukit/include/rtems/score/percpu.h b/cpukit/include/rtems/score/percpu.h
index 3242383b9d..e79596c244 100644
--- a/cpukit/include/rtems/score/percpu.h
+++ b/cpukit/include/rtems/score/percpu.h
@@ -553,7 +553,7 @@ typedef struct Per_CPU_Control {
* @see _Per_CPU_State_change().
- Per_CPU_State state;
+ Atomic_Uint state;
* @brief FIFO list of jobs to be performed by this processor.
@@ -775,6 +775,39 @@ RTEMS_INLINE_ROUTINE void _Per_CPU_Release_all(
#if defined( RTEMS_SMP )
+ * @brief Gets the current processor state.
+ * @param cpu is the processor control.
+ * @return Returns the current state of the processor.
+static inline Per_CPU_State _Per_CPU_Get_state( const Per_CPU_Control *cpu )
+ return (Per_CPU_State)
+ _Atomic_Load_uint( &cpu->state, ATOMIC_ORDER_ACQUIRE );
+ * @brief Sets the processor state of the current processor.
+ * @param cpu_self is the processor control of the processor executing this
+ * function.
+ * @param state is the new processor state.
+static inline void _Per_CPU_Set_state(
+ Per_CPU_Control *cpu_self,
+ Per_CPU_State state
+ _Atomic_Store_uint(
+ &cpu_self->state,
+ (unsigned int) state,
+ ATOMIC_ORDER_RELEASE
void _Per_CPU_State_change(
Per_CPU_Control *cpu,
Per_CPU_State new_state
diff --git a/cpukit/score/cpu/aarch64/include/rtems/score/cpu.h b/cpukit/score/cpu/aarch64/include/rtems/score/cpu.h
index 316079a6cd..595f6c7351 100644
--- a/cpukit/score/cpu/aarch64/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/aarch64/include/rtems/score/cpu.h
@@ -360,18 +360,6 @@ RTEMS_NO_RETURN void _CPU_Context_restore( Context_Control *new_context );
__asm__ volatile ( "wfe" : : : "memory" );
- static inline void _CPU_SMP_Processor_event_broadcast( void )
- _AARCH64_Data_synchronization_barrier();
- _AARCH64_Send_event();
- static inline void _CPU_SMP_Processor_event_receive( void )
- _AARCH64_Wait_for_event();
- _AARCH64_Data_memory_barrier();
#endif
diff --git a/cpukit/score/cpu/arm/include/rtems/score/cpu.h b/cpukit/score/cpu/arm/include/rtems/score/cpu.h
index dcda4d525c..b554aa263e 100644
--- a/cpukit/score/cpu/arm/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/arm/include/rtems/score/cpu.h
@@ -510,18 +510,6 @@ RTEMS_NO_RETURN void _CPU_Context_restore( Context_Control *new_context );
- _ARM_Data_synchronization_barrier();
- _ARM_Send_event();
- _ARM_Wait_for_event();
- _ARM_Data_memory_barrier();
#endif
diff --git a/cpukit/score/cpu/i386/include/rtems/score/cpu.h b/cpukit/score/cpu/i386/include/rtems/score/cpu.h
index 0cb4590087..813ed526d8 100644
--- a/cpukit/score/cpu/i386/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/i386/include/rtems/score/cpu.h
@@ -470,16 +470,6 @@ void _CPU_Context_Initialize(
uint32_t _CPU_SMP_Get_current_processor( void );
void _CPU_SMP_Send_interrupt( uint32_t target_processor_index );
- __asm__ volatile ( "" : : : "memory" );
#endif
#define _CPU_Context_Initialize_fp( _fp_area ) \
diff --git a/cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h b/cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h
index 120b51b633..c4cb512e20 100644
--- a/cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h
@@ -1347,35 +1347,6 @@ static inline CPU_Counter_ticks _CPU_Counter_difference(
- * @brief Broadcasts a processor event.
- * Some architectures provide a low-level synchronization primitive for
- * processors in a multi-processor environment. Processors waiting for this
- * event may go into a low-power state and stop generating system bus
- * transactions. This function must ensure that preceding store operations
- * can be observed by other processors.
- * @see _CPU_SMP_Processor_event_receive().
- * @brief Receives a processor event.
- * This function will wait for the processor event and may wait forever if no
- * such event arrives.
- * @see _CPU_SMP_Processor_event_broadcast().
* @brief Gets the is executing indicator of the thread context.
diff --git a/cpukit/score/cpu/powerpc/include/rtems/score/cpu.h b/cpukit/score/cpu/powerpc/include/rtems/score/cpu.h
index f22e1cd7ec..ee02bd4ee4 100644
--- a/cpukit/score/cpu/powerpc/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/powerpc/include/rtems/score/cpu.h
@@ -973,16 +973,6 @@ void _CPU_Context_restore_fp(
#endif
typedef struct {
diff --git a/cpukit/score/cpu/riscv/include/rtems/score/cpu.h b/cpukit/score/cpu/riscv/include/rtems/score/cpu.h
index d9056d0ad1..16dde8204c 100644
--- a/cpukit/score/cpu/riscv/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/riscv/include/rtems/score/cpu.h
@@ -474,16 +474,6 @@ static inline uint32_t _CPU_SMP_Get_current_processor( void )
-static inline void _CPU_SMP_Processor_event_broadcast( void )
-static inline void _CPU_SMP_Processor_event_receive( void )
static inline bool _CPU_Context_Get_is_executing(
const Context_Control *context
diff --git a/cpukit/score/cpu/sparc/include/rtems/score/cpu.h b/cpukit/score/cpu/sparc/include/rtems/score/cpu.h
index 0abc929c54..910ec83a87 100644
--- a/cpukit/score/cpu/sparc/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/sparc/include/rtems/score/cpu.h
@@ -1004,16 +1004,6 @@ RTEMS_NO_RETURN void _CPU_Context_restore( Context_Control *new_context );
#endif
#endif
#if defined(SPARC_USE_LAZY_FP_SWITCH)
diff --git a/cpukit/score/cpu/x86_64/include/rtems/score/cpu.h b/cpukit/score/cpu/x86_64/include/rtems/score/cpu.h
index 1e97250188..056c0224a9 100644
--- a/cpukit/score/cpu/x86_64/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/x86_64/include/rtems/score/cpu.h
@@ -338,16 +338,6 @@ static inline CPU_Counter_ticks _CPU_Counter_difference(
diff --git a/cpukit/score/src/percpu.c b/cpukit/score/src/percpu.c
index e254f306eb..7fbc1c8637 100644
--- a/cpukit/score/src/percpu.c
+++ b/cpukit/score/src/percpu.c
@@ -55,7 +55,9 @@ static void _Per_CPU_State_busy_wait(
- Per_CPU_State state = cpu->state;
+ Per_CPU_State state;
+ state = _Per_CPU_Get_state( cpu );
switch ( new_state ) {
case PER_CPU_STATE_REQUEST_START_MULTITASKING:
@@ -64,8 +66,7 @@ static void _Per_CPU_State_busy_wait(
&& state != PER_CPU_STATE_SHUTDOWN
_Per_CPU_Perform_jobs( cpu );
- _CPU_SMP_Processor_event_receive();
- state = cpu->state;
break;
case PER_CPU_STATE_UP:
@@ -74,8 +75,7 @@ static void _Per_CPU_State_busy_wait(
break;
default:
@@ -143,8 +143,8 @@ void _Per_CPU_State_change(
_Per_CPU_State_acquire( &lock_context );
- next_state = _Per_CPU_State_get_next( cpu->state, new_state );
- cpu->state = next_state;
+ next_state = _Per_CPU_State_get_next( _Per_CPU_Get_state( cpu ), new_state );
+ _Per_CPU_Set_state( cpu, next_state );
if ( next_state == PER_CPU_STATE_SHUTDOWN ) {
uint32_t cpu_max = rtems_configuration_get_maximum_processors();
@@ -154,7 +154,7 @@ void _Per_CPU_State_change(
Per_CPU_Control *cpu_other = _Per_CPU_Get_by_index( cpu_index );
if ( cpu_other != cpu ) {
- switch ( cpu_other->state ) {
+ switch ( _Per_CPU_Get_state( cpu_other ) ) {
_SMP_Send_message( cpu_index, SMP_MESSAGE_SHUTDOWN );
break;
@@ -163,13 +163,11 @@ void _Per_CPU_State_change(
break;
- cpu_other->state = PER_CPU_STATE_SHUTDOWN;
+ _Per_CPU_Set_state( cpu_other, PER_CPU_STATE_SHUTDOWN );
- _CPU_SMP_Processor_event_broadcast();
_Per_CPU_State_release( &lock_context );
if (
diff --git a/cpukit/score/src/percpustatewait.c b/cpukit/score/src/percpustatewait.c
index 9d9f590df5..7186626897 100644
--- a/cpukit/score/src/percpustatewait.c
+++ b/cpukit/score/src/percpustatewait.c
@@ -33,8 +33,11 @@ bool _Per_CPU_State_wait_for_non_initial_state(
uint32_t timeout_in_ns
- const Per_CPU_Control *cpu = _Per_CPU_Get_by_index( cpu_index );
+ const Per_CPU_Control *cpu;
+ cpu = _Per_CPU_Get_by_index( cpu_index );
if ( timeout_in_ns > 0 ) {
rtems_counter_ticks ticks =
@@ -45,19 +48,16 @@ bool _Per_CPU_State_wait_for_non_initial_state(
while ( ticks > delta && state == PER_CPU_STATE_INITIAL ) {
rtems_counter_ticks b;
ticks -= delta;
b = rtems_counter_read();
delta = rtems_counter_difference( b, a );
a = b;
} else {
while ( state == PER_CPU_STATE_INITIAL ) {
diff --git a/cpukit/score/src/smpmulticastaction.c b/cpukit/score/src/smpmulticastaction.c
index 55c495a2cf..5d65ef14ca 100644
--- a/cpukit/score/src/smpmulticastaction.c
+++ b/cpukit/score/src/smpmulticastaction.c
@@ -122,12 +122,10 @@ void _Per_CPU_Wait_for_job(
_Atomic_Load_ulong( &job->done, ATOMIC_ORDER_ACQUIRE )
!= PER_CPU_JOB_DONE
- switch ( cpu->state ) {
+ switch ( _Per_CPU_Get_state( cpu ) ) {
case PER_CPU_STATE_INITIAL:
case PER_CPU_STATE_READY_TO_START_MULTITASKING:
- /* Fall through */
* Calling this function with the current processor is intentional.
diff --git a/testsuites/smptests/smpfatal01/init.c b/testsuites/smptests/smpfatal01/init.c
index 3f276a48fc..0fd5f3fc46 100644
--- a/testsuites/smptests/smpfatal01/init.c
+++ b/testsuites/smptests/smpfatal01/init.c
@@ -58,7 +58,7 @@ static void fatal_extension(
for (cpu = 0; cpu < MAX_CPUS; ++cpu) {
const Per_CPU_Control *per_cpu = _Per_CPU_Get_by_index( cpu );
- Per_CPU_State state = per_cpu->state;
+ Per_CPU_State state = _Per_CPU_Get_state(per_cpu);
assert(state == PER_CPU_STATE_SHUTDOWN);
@@ -92,7 +92,7 @@ static rtems_status_code test_driver_init(
if (cpu == self) {
assert(state == PER_CPU_STATE_INITIAL);
@@ -110,7 +110,7 @@ static rtems_status_code test_driver_init(
uint32_t other = (self + 1) % cpu_count;
Per_CPU_Control *per_cpu = _Per_CPU_Get_by_index( other );
- per_cpu->state = PER_CPU_STATE_SHUTDOWN;
+ _Per_CPU_Set_state(per_cpu, PER_CPU_STATE_SHUTDOWN);
} else {
TEST_END();
exit(0);
diff --git a/testsuites/smptests/smpfatal02/init.c b/testsuites/smptests/smpfatal02/init.c
index 6aa48d6cc0..25321ca27b 100644
--- a/testsuites/smptests/smpfatal02/init.c
+++ b/testsuites/smptests/smpfatal02/init.c
@@ -60,7 +60,7 @@ static void fatal_extension(
@@ -96,7 +96,7 @@ static rtems_status_code test_driver_init(
if (cpu == self) {
diff --git a/testsuites/smptests/smpmulticast01/init.c b/testsuites/smptests/smpmulticast01/init.c
index 96462e32e3..fbe6fb6abf 100644
--- a/testsuites/smptests/smpmulticast01/init.c
+++ b/testsuites/smptests/smpmulticast01/init.c
@@ -390,7 +390,7 @@ static void set_wrong_cpu_state(void *arg)
cpu_self = arg;
T_step_eq_ptr(0, cpu_self, _Per_CPU_Get());
- cpu_self->state = 123;
+ _Per_CPU_Set_state(cpu_self, 123);
while (true) {
/* Do nothing */
diff --git a/testsuites/smptests/smppsxsignal01/init.c b/testsuites/smptests/smppsxsignal01/init.c
index 1882715b3b..d23a664e9a 100644
--- a/testsuites/smptests/smppsxsignal01/init.c
+++ b/testsuites/smptests/smppsxsignal01/init.c
@@ -32,7 +32,7 @@ typedef enum {
} test_state;
typedef struct {
- test_state state;
+ volatile test_state state;
pthread_t consumer;
pthread_t producer;
uint32_t consumer_processor;
@@ -42,13 +42,12 @@ typedef struct {
static void change_state(test_context *ctx, test_state new_state)
ctx->state = new_state;
static void wait_for_state(const test_context *ctx, test_state desired_state)
while ( ctx->state != desired_state ) {
+ /* Wait */
diff --git a/testsuites/smptests/smpsignal01/init.c b/testsuites/smptests/smpsignal01/init.c
index 025e84c6a2..471c058348 100644
--- a/testsuites/smptests/smpsignal01/init.c
+++ b/testsuites/smptests/smpsignal01/init.c
@@ -33,7 +33,7 @@ typedef enum {
} test_state;
typedef struct {
- test_state state;
rtems_id consumer;
rtems_id producer;
@@ -45,13 +45,12 @@ typedef struct {
+ /* Wait */
2.26.2
