[PATCH 2/4] score: Simplify SMP processor state handling
Wed Jul 28 11:18:02 UTC 2021
The per-CPU states which control the SMP system initialization were added quite
early during the SMP support development.  Replace this initial implementation
with a simplified one.  There is no longer a global SMP lock required which
serialized the state changes of all processors.  The new implementation better
integrates with the per-CPU jobs.
 cpukit/include/rtems/score/percpu.h           |  42 ++---
 cpukit/include/rtems/score/smpimpl.h          |  60 +++++--
 cpukit/score/src/percpu.c                     | 151 +-----------------
 cpukit/score/src/smp.c                        | 133 +++++++++++++--
 cpukit/score/src/smpmulticastaction.c         |  36 ++---
 cpukit/score/src/threadstartmultitasking.c    |   4 +-
 testsuites/smptests/smpfatal01/init.c         |  57 +++++--
 testsuites/smptests/smpfatal01/smpfatal01.doc |   3 +-
 testsuites/smptests/smpfatal02/init.c         |  21 ++-
 testsuites/smptests/smpfatal02/smpfatal02.doc |   3 +-
 10 files changed, 260 insertions(+), 250 deletions(-)
diff --git a/cpukit/include/rtems/score/percpu.h b/cpukit/include/rtems/score/percpu.h
index e79596c244..f72339620d 100644
--- a/cpukit/include/rtems/score/percpu.h
+++ b/cpukit/include/rtems/score/percpu.h
@@ -102,15 +102,18 @@ struct Scheduler_Context;
  * The processor state controls the life cycle of processors at the lowest
  * level.  No multi-threading or other high-level concepts matter here.
- * State changes must be initiated via _Per_CPU_State_change().  This function
- * may not return in case someone requested a shutdown.  The
- * _SMP_Send_message() function will be used to notify other processors about
- * state changes if the other processor is in the up state.
+ * The state of a processor is indicated by the Per_CPU_Control::state membe.
+ * The current state of a processor can be get by _Per_CPU_Get_state().  Only
+ * the processor associated with the control may change its state using
+ * _Per_CPU_Set_state().
  * Due to the sequential nature of the basic system initialization one
  * processor has a special role.  It is the processor executing the boot_card()
  * function.  This processor is called the boot processor.  All other
- * processors are called secondary.
+ * processors are called secondary.  The boot processor uses
+ * _SMP_Request_start_multitasking() to indicate that processors should start
+ * multiprocessing.  Secondary processors will wait for this request in
+ * _SMP_Start_multitasking_on_secondary_processor().
  * @dot
  * digraph states {
@@ -150,22 +153,12 @@ typedef enum {
    * the first time.  The boot processor will wait for all secondary processors
    * to change into this state.  In case a secondary processor does not reach
    * this state the system will not start.  The secondary processors wait now
-   * for a change into the PER_CPU_STATE_REQUEST_START_MULTITASKING state set
-   * by the boot processor once all secondary processors reached the
-   * PER_CPU_STATE_READY_TO_START_MULTITASKING state.
+   * for a change into the PER_CPU_STATE_UP state set requested by the boot
+   * processor through ::_SMP_Ready_to_start_multitasking once all secondary
+   * processors reached the PER_CPU_STATE_READY_TO_START_MULTITASKING state.
   PER_CPU_STATE_READY_TO_START_MULTITASKING,
-   * @brief Multitasking start of processor is requested.
-   * The boot processor completed system initialization and is about to perform
-   * a context switch to its heir thread.  Secondary processors should now
-   * issue a context switch to the heir thread.  This normally enables
-   * interrupts on the processor for the first time.
-  PER_CPU_STATE_REQUEST_START_MULTITASKING,
    * @brief Normal multitasking state.
@@ -547,11 +540,12 @@ typedef struct Per_CPU_Control {
     char *data;
-     * @brief Indicates the current state of the CPU.
+     * @brief Indicates the current state of the processor.
-     * This member is protected by the _Per_CPU_State_lock lock.
+     * Only the processor associated with this control is allowed to change
+     * this member.
-     * @see _Per_CPU_State_change().
+     * @see _Per_CPU_Get_state() and _Per_CPU_Set_state().
     Atomic_Uint state;
@@ -801,6 +795,7 @@ static inline void _Per_CPU_Set_state(
   Per_CPU_State    state
+  _Assert( cpu_self == _Per_CPU_Get() );
   _Atomic_Store_uint(
     &cpu_self->state,
     (unsigned int) state,
@@ -808,11 +803,6 @@ static inline void _Per_CPU_Set_state(
-void _Per_CPU_State_change(
-  Per_CPU_Control *cpu,
-  Per_CPU_State new_state
  * @brief Waits for a processor to change into a non-initial state.
diff --git a/cpukit/include/rtems/score/smpimpl.h b/cpukit/include/rtems/score/smpimpl.h
index 32704d7288..2770402562 100644
--- a/cpukit/include/rtems/score/smpimpl.h
+++ b/cpukit/include/rtems/score/smpimpl.h
@@ -50,6 +50,12 @@ extern "C" {
 #define SMP_MESSAGE_PERFORM_JOBS 0x2UL
+ * @brief SMP message to force the message processing in
+ *   _SMP_Try_to_process_message().
+#define SMP_MESSAGE_FORCE_PROCESSING 0x1UL
  * @brief SMP fatal codes.
@@ -99,6 +105,15 @@ static inline void _SMP_Fatal( SMP_Fatal_code code )
 extern Processor_mask _SMP_Online_processors;
+ * @brief Indicates if the system is ready to start multitasking.
+ * Only the boot processor is allowed to change this object.  If the object has
+ * a non-zero value and no fatal error occurred, then secondary processors
+ * should call _Thread_Start_multitasking() to start multiprocessing.
+extern Atomic_Uint _SMP_Ready_to_start_multitasking;
  * @brief Performs high-level initialization of a secondary processor and runs
  * the application threads.
@@ -129,12 +144,44 @@ RTEMS_NO_RETURN void _SMP_Start_multitasking_on_secondary_processor(
   Per_CPU_Control *cpu_self
+ * @brief Processes the SMP message.
+ * @param[in, out] cpu_self is the processor control of the processor executing
+ *   this function.
+ * @return Returns the processed message.
+long unsigned _SMP_Process_message(
+  Per_CPU_Control *cpu_self,
+  long unsigned    message
+ * @brief Tries to process the current SMP message.
+ * This function may be used in busy wait loops.
+ * @param cpu_self is the processor control of the processor executing this
+ *   function.
+ * @param message is used to check if the SMP message processing should be
+ *   carried out.  If it is not equal to zero, then _SMP_Process_message() is
+ *   called if a newly fetched message.  This parameter is not used to process
+ *   the message.
+void _SMP_Try_to_process_message(
+  unsigned long    message
  * @brief Interrupts handler for inter-processor interrupts.
- * @param[in, out] cpu_self The cpu control for the operation.
+ *   this function.
- * @return The received message.
 static inline long unsigned _SMP_Inter_processor_interrupt_handler(
@@ -155,14 +202,7 @@ static inline long unsigned _SMP_Inter_processor_interrupt_handler(
   if ( RTEMS_PREDICT_FALSE( message != 0 ) ) {
-    if ( ( message & SMP_MESSAGE_SHUTDOWN ) != 0 ) {
-      _SMP_Fatal( SMP_FATAL_SHUTDOWN_RESPONSE );
-      /* does not continue past here */
-    if ( ( message & SMP_MESSAGE_PERFORM_JOBS ) != 0 ) {
-      _Per_CPU_Perform_jobs( cpu_self );
+    return _SMP_Process_message( cpu_self, message );
   return message;
diff --git a/cpukit/score/src/percpu.c b/cpukit/score/src/percpu.c
index 7fbc1c8637..611f55c0c1 100644
--- a/cpukit/score/src/percpu.c
+++ b/cpukit/score/src/percpu.c
@@ -3,8 +3,8 @@
  * @ingroup RTEMSScorePerCPU
- * @brief This source file contains a definition of ::_Per_CPU_Information and
- *   the implementation of _Per_CPU_State_change().
+ * @brief This source file contains the uniprocessor definition of
+ *   ::_Per_CPU_Information and the some static assertions.
@@ -21,10 +21,6 @@
 #endif
-#include <rtems/score/assert.h>
-#include <rtems/score/isrlock.h>
-#include <rtems/score/smpimpl.h>
-#include <rtems/config.h>
 RTEMS_STATIC_ASSERT(
   sizeof( CPU_Uint32ptr ) >= sizeof( uintptr_t ),
@@ -36,148 +32,7 @@ RTEMS_STATIC_ASSERT(
   CPU_Uint32ptr_greater_equal_uint32_t
-#if defined(RTEMS_SMP)
-ISR_LOCK_DEFINE( static, _Per_CPU_State_lock, "Per-CPU State" )
-static void _Per_CPU_State_acquire( ISR_lock_Context *lock_context )
-  _ISR_lock_ISR_disable_and_acquire( &_Per_CPU_State_lock, lock_context );
-static void _Per_CPU_State_release( ISR_lock_Context *lock_context )
-  _ISR_lock_Release_and_ISR_enable( &_Per_CPU_State_lock, lock_context );
-static void _Per_CPU_State_busy_wait(
-  Per_CPU_State state;
-  state = _Per_CPU_Get_state( cpu );
-  switch ( new_state ) {
-    case PER_CPU_STATE_REQUEST_START_MULTITASKING:
-      while (
-        state != PER_CPU_STATE_READY_TO_START_MULTITASKING
-          && state != PER_CPU_STATE_SHUTDOWN
-        _Per_CPU_Perform_jobs( cpu );
-      break;
-    case PER_CPU_STATE_UP:
-      while (
-        state != PER_CPU_STATE_REQUEST_START_MULTITASKING
-      break;
-    default:
-      /* No need to wait */
-      break;
-static Per_CPU_State _Per_CPU_State_get_next(
-  Per_CPU_State current_state,
-  switch ( current_state ) {
-    case PER_CPU_STATE_INITIAL:
-        case PER_CPU_STATE_READY_TO_START_MULTITASKING:
-        case PER_CPU_STATE_SHUTDOWN:
-          /* Change is acceptable */
-          break;
-        default:
-          new_state = PER_CPU_STATE_SHUTDOWN;
-          break;
-      break;
-          break;
-        default:
-          break;
-      break;
-          break;
-        default:
-          break;
-      break;
-    default:
-      break;
-  return new_state;
-  ISR_lock_Context lock_context;
-  Per_CPU_State next_state;
-  _Per_CPU_State_busy_wait( cpu, new_state );
-  _Per_CPU_State_acquire( &lock_context );
-  next_state = _Per_CPU_State_get_next( _Per_CPU_Get_state( cpu ), new_state );
-  _Per_CPU_Set_state( cpu, next_state );
-  if ( next_state == PER_CPU_STATE_SHUTDOWN ) {
-    uint32_t cpu_max = rtems_configuration_get_maximum_processors();
-    uint32_t cpu_index;
-    for ( cpu_index = 0 ; cpu_index < cpu_max ; ++cpu_index ) {
-      Per_CPU_Control *cpu_other = _Per_CPU_Get_by_index( cpu_index );
-      if ( cpu_other != cpu ) {
-        switch ( _Per_CPU_Get_state( cpu_other ) ) {
-            _SMP_Send_message( cpu_index, SMP_MESSAGE_SHUTDOWN );
-            break;
-          default:
-            /* Nothing to do */
-            break;
-        _Per_CPU_Set_state( cpu_other, PER_CPU_STATE_SHUTDOWN );
-  _Per_CPU_State_release( &lock_context );
-  if (
-    next_state == PER_CPU_STATE_SHUTDOWN
-      && new_state != PER_CPU_STATE_SHUTDOWN
-    _SMP_Fatal( SMP_FATAL_SHUTDOWN );
-#else
+#if !defined(RTEMS_SMP)
    * On single core systems, we can efficiently directly access a single
    * statically allocated per cpu structure.  And the fields are initialized
diff --git a/cpukit/score/src/smp.c b/cpukit/score/src/smp.c
index 0488464da0..bf53876dab 100644
--- a/cpukit/score/src/smp.c
+++ b/cpukit/score/src/smp.c
@@ -4,12 +4,13 @@
  * @ingroup RTEMSScoreSMP
  * @brief This source file contains the definition of ::_SMP_Online_processors
- *   and ::_SMP_Processor_maximum and the implementation of
- *   _SMP_Handler_initialize(), _SMP_Request_shutdown(),
- *   _SMP_Request_start_multitasking(), _SMP_Send_message(),
- *   _SMP_Send_message_broadcast(), _SMP_Send_message_multicast(),
- *   _SMP_Should_start_processor(), and
- *   _SMP_Start_multitasking_on_secondary_processor().
+ *   ::_SMP_Ready_to_start_multitasking, and ::_SMP_Processor_maximum and the
+ *   implementation of _SMP_Handler_initialize(),  _SMP_Process_message(),
+ *   _SMP_Request_shutdown(), _SMP_Request_start_multitasking(),
+ *   _SMP_Send_message(), _SMP_Send_message_broadcast(),
+ *   _SMP_Send_message_multicast(), _SMP_Should_start_processor(),
+ *   _SMP_Start_multitasking_on_secondary_processor(), and
@@ -37,6 +38,8 @@
+Atomic_Uint _SMP_Ready_to_start_multitasking;
 uint32_t _SMP_Processor_maximum;
 static const Scheduler_Assignment *_Scheduler_Get_initial_assignment(
@@ -159,20 +162,38 @@ void _SMP_Request_start_multitasking( void )
   uint32_t         cpu_max;
   uint32_t         cpu_index;
-  cpu_self = _Per_CPU_Get();
-  _Per_CPU_State_change( cpu_self, PER_CPU_STATE_READY_TO_START_MULTITASKING );
   cpu_max = _SMP_Get_processor_maximum();
+  cpu_self = _Per_CPU_Get();
+   * Wait until all other online processors reached the
+   * PER_CPU_STATE_READY_TO_START_MULTITASKING state.  The waiting is done
+   * without a timeout.  If secondary processors cannot reach this state, then
+   * it is expected that they indicate this failure with an
+   * ::SMP_MESSAGE_SHUTDOWN message or reset the system.
     Per_CPU_Control *cpu;
     cpu = _Per_CPU_Get_by_index( cpu_index );
-    if ( _Per_CPU_Is_processor_online( cpu ) ) {
-      _Per_CPU_State_change( cpu, PER_CPU_STATE_REQUEST_START_MULTITASKING );
+    if ( cpu != cpu_self && _Per_CPU_Is_processor_online( cpu ) ) {
+      while (
+        _Per_CPU_Get_state( cpu ) != PER_CPU_STATE_READY_TO_START_MULTITASKING
+        _SMP_Try_to_process_message(
+          cpu_self,
+          _Atomic_Load_ulong( &cpu_self->message, ATOMIC_ORDER_RELAXED )
+  _Atomic_Store_uint(
+    &_SMP_Ready_to_start_multitasking,
+    0xffffffffU,
+    ATOMIC_ORDER_RELEASE
 bool _SMP_Should_start_processor( uint32_t cpu_index )
@@ -183,6 +204,22 @@ bool _SMP_Should_start_processor( uint32_t cpu_index )
   return _Scheduler_Should_start_processor( assignment );
+static void _SMP_Wait_for_start_multitasking( Per_CPU_Control *cpu_self )
+  unsigned int ready;
+  do {
+      cpu_self,
+    ready = (Per_CPU_State) _Atomic_Load_uint(
+      ATOMIC_ORDER_ACQUIRE
+  } while ( ready == 0 );
@@ -199,28 +236,92 @@ void _SMP_Start_multitasking_on_secondary_processor(
     _SMP_Fatal( SMP_FATAL_MULTITASKING_START_ON_UNASSIGNED_PROCESSOR );
+  _Per_CPU_Set_state( cpu_self, PER_CPU_STATE_READY_TO_START_MULTITASKING );
+  _SMP_Wait_for_start_multitasking( cpu_self );
   _Thread_Start_multitasking();
 void _SMP_Request_shutdown( void )
   ISR_Level level;
+  uint32_t  cpu_max;
+  uint32_t  cpu_index_self;
+  uint32_t  cpu_index;
   _ISR_Local_disable( level );
   (void) level;
-  _Per_CPU_State_change( _Per_CPU_Get(), PER_CPU_STATE_SHUTDOWN );
+  cpu_max = _SMP_Processor_configured_maximum;
+  cpu_index_self = _SMP_Get_current_processor();
+  for ( cpu_index = 0 ; cpu_index < cpu_max ; ++cpu_index ) {
+    Per_CPU_Control *cpu;
+    cpu = _Per_CPU_Get_by_index( cpu_index );
+    if ( cpu_index == cpu_index_self ) {
+      _Per_CPU_Set_state( cpu, PER_CPU_STATE_SHUTDOWN );
+    } else {
+      _Atomic_Fetch_or_ulong(
+        &cpu->message,
+        SMP_MESSAGE_SHUTDOWN,
+      if ( _Per_CPU_Get_state( cpu ) == PER_CPU_STATE_UP ) {
+        _CPU_SMP_Send_interrupt( cpu_index );
+  if ( ( message & SMP_MESSAGE_SHUTDOWN ) != 0 ) {
+    /* Check the state to prevent recursive shutdowns */
+    if ( _Per_CPU_Get_state( cpu_self ) != PER_CPU_STATE_SHUTDOWN ) {
+      _Per_CPU_Set_state( cpu_self, PER_CPU_STATE_SHUTDOWN );
+      _SMP_Fatal( SMP_FATAL_SHUTDOWN_RESPONSE );
+  if ( ( message & SMP_MESSAGE_PERFORM_JOBS ) != 0 ) {
+    _Per_CPU_Perform_jobs( cpu_self );
+  if ( message != 0 ) {
+    /* Fetch the actual message */
+    message = _Atomic_Exchange_ulong(
+      &cpu_self->message,
+      0,
+    _SMP_Process_message( cpu_self, message );
 void _SMP_Send_message( uint32_t cpu_index, unsigned long message )
   Per_CPU_Control *cpu = _Per_CPU_Get_by_index( cpu_index );
-  _Atomic_Fetch_or_ulong( &cpu->message, message, ATOMIC_ORDER_RELEASE );
+  (void) _Atomic_Fetch_or_ulong(
+    &cpu->message, message,
-  _CPU_SMP_Send_interrupt( cpu_index );
 void _SMP_Send_message_broadcast( unsigned long message )
diff --git a/cpukit/score/src/smpmulticastaction.c b/cpukit/score/src/smpmulticastaction.c
index 5d65ef14ca..8dbdef80c7 100644
--- a/cpukit/score/src/smpmulticastaction.c
+++ b/cpukit/score/src/smpmulticastaction.c
@@ -92,27 +92,6 @@ void _Per_CPU_Add_job( Per_CPU_Control *cpu, Per_CPU_Job *job )
   _Per_CPU_Jobs_release_and_ISR_enable( cpu, &lock_context );
-static void _Per_CPU_Try_perform_jobs( Per_CPU_Control *cpu_self )
-  unsigned long message;
-  message = _Atomic_Load_ulong( &cpu_self->message, ATOMIC_ORDER_RELAXED );
-    bool success;
-    success = _Atomic_Compare_exchange_ulong(
-      &cpu_self->message, &message,
-      message & ~SMP_MESSAGE_PERFORM_JOBS, ATOMIC_ORDER_RELAXED,
-      ATOMIC_ORDER_RELAXED
-    if ( success ) {
 void _Per_CPU_Wait_for_job(
   const Per_CPU_Control *cpu,
   const Per_CPU_Job     *job
@@ -122,17 +101,22 @@ void _Per_CPU_Wait_for_job(
     _Atomic_Load_ulong( &job->done, ATOMIC_ORDER_ACQUIRE )
       != PER_CPU_JOB_DONE
+    Per_CPU_Control *cpu_self;
     switch ( _Per_CPU_Get_state( cpu ) ) {
-         * Calling this function with the current processor is intentional.
-         * We have to perform our own jobs here in case inter-processor
-         * interrupts are not working.
+         * Calling this function with the current processor is intentional.  We
+         * have to perform our own jobs here in case inter-processor interrupts
+         * are not working.
-        _Per_CPU_Try_perform_jobs( _Per_CPU_Get() );
+          cpu_self,
         break;
       default:
         _SMP_Fatal( SMP_FATAL_WRONG_CPU_STATE_TO_PERFORM_JOBS );
diff --git a/cpukit/score/src/threadstartmultitasking.c b/cpukit/score/src/threadstartmultitasking.c
index 094a535394..9fa52a58ac 100644
--- a/cpukit/score/src/threadstartmultitasking.c
+++ b/cpukit/score/src/threadstartmultitasking.c
@@ -22,6 +22,7 @@
+#include <rtems/score/smpimpl.h>
 void _Thread_Start_multitasking( void )
@@ -29,7 +30,8 @@ void _Thread_Start_multitasking( void )
   Thread_Control  *heir;
-  _Per_CPU_State_change( cpu_self, PER_CPU_STATE_UP );
+  _Per_CPU_Set_state( cpu_self, PER_CPU_STATE_UP );
+  _SMP_Try_to_process_message( cpu_self, SMP_MESSAGE_FORCE_PROCESSING );
    * Threads begin execution in the _Thread_Handler() function.   This
diff --git a/testsuites/smptests/smpfatal01/init.c b/testsuites/smptests/smpfatal01/init.c
index 0fd5f3fc46..6ee08cf653 100644
--- a/testsuites/smptests/smpfatal01/init.c
+++ b/testsuites/smptests/smpfatal01/init.c
@@ -32,6 +32,8 @@ const char rtems_test_name[] = "SMPFATAL 1";
 static uint32_t main_cpu;
+static uint32_t other_cpu;
 static SMP_barrier_Control barrier = SMP_BARRIER_CONTROL_INITIALIZER;
 static void Init(rtems_task_argument arg)
@@ -45,35 +47,59 @@ static void fatal_extension(
   rtems_fatal_code code
-  SMP_barrier_State barrier_state = SMP_BARRIER_STATE_INITIALIZER;
+  assert(!always_set_to_false);
   if (source == RTEMS_FATAL_SOURCE_SMP) {
+    SMP_barrier_State barrier_state = SMP_BARRIER_STATE_INITIALIZER;
+    uint32_t cpu_count = rtems_scheduler_get_processor_maximum();
     uint32_t self = rtems_scheduler_get_processor();
-    assert(!always_set_to_false);
-    assert(code == SMP_FATAL_SHUTDOWN);
+    if (self == other_cpu) {
+      assert(code == SMP_FATAL_SHUTDOWN);
+    } else {
+      assert(code == SMP_FATAL_SHUTDOWN_RESPONSE);
+    _SMP_barrier_Wait(&barrier, &barrier_state, cpu_count);
     if (self == main_cpu) {
       uint32_t cpu;
-      for (cpu = 0; cpu < MAX_CPUS; ++cpu) {
+      for (cpu = 0; cpu < cpu_count; ++cpu) {
         const Per_CPU_Control *per_cpu = _Per_CPU_Get_by_index( cpu );
         Per_CPU_State state = _Per_CPU_Get_state(per_cpu);
         assert(state == PER_CPU_STATE_SHUTDOWN);
+      for (cpu = cpu_count; cpu < MAX_CPUS; ++cpu) {
+        const Per_CPU_Control *per_cpu = _Per_CPU_Get_by_index( cpu );
+        Per_CPU_State state = _Per_CPU_Get_state(per_cpu);
+        assert(state == PER_CPU_STATE_INITIAL);
       TEST_END();
+    } else {
-  _SMP_barrier_Wait(
-    &barrier,
-    &barrier_state,
-    rtems_scheduler_get_processor_maximum()
+static void shutdown_handler(void *arg)
+  _SMP_Request_shutdown();
+  _SMP_Fatal(SMP_FATAL_SHUTDOWN);
+static const Per_CPU_Job_context shutdown_context = {
+  .handler = shutdown_handler
+static Per_CPU_Job shutdown_job = {
+  .context = &shutdown_context
 static rtems_status_code test_driver_init(
   rtems_device_major_number major,
   rtems_device_minor_number minor,
@@ -89,6 +115,7 @@ static rtems_status_code test_driver_init(
   assert(rtems_configuration_get_maximum_processors() == MAX_CPUS);
   main_cpu = self;
+  other_cpu = (self + 1) % cpu_count;
@@ -107,10 +134,14 @@ static rtems_status_code test_driver_init(
   if (cpu_count > 1) {
-    uint32_t other = (self + 1) % cpu_count;
-    Per_CPU_Control *per_cpu = _Per_CPU_Get_by_index( other );
-    _Per_CPU_Set_state(per_cpu, PER_CPU_STATE_SHUTDOWN);
+    Per_CPU_Control *per_cpu = _Per_CPU_Get_by_index( other_cpu );
+    _Per_CPU_Add_job(per_cpu, &shutdown_job);
+      &per_cpu->message,
+      SMP_MESSAGE_PERFORM_JOBS,
   } else {
     TEST_END();
     exit(0);
diff --git a/testsuites/smptests/smpfatal01/smpfatal01.doc b/testsuites/smptests/smpfatal01/smpfatal01.doc
index c037cfe78b..c6b54b7dd1 100644
--- a/testsuites/smptests/smpfatal01/smpfatal01.doc
+++ b/testsuites/smptests/smpfatal01/smpfatal01.doc
@@ -4,7 +4,8 @@ test set name: smpfatal01
 directives:
-  - _Per_CPU_State_change()
+  - _SMP_Request_shutdown()
+  - _SMP_Request_start_multitasking()
 concepts:
diff --git a/testsuites/smptests/smpfatal02/init.c b/testsuites/smptests/smpfatal02/init.c
index 25321ca27b..5528a4315d 100644
--- a/testsuites/smptests/smpfatal02/init.c
+++ b/testsuites/smptests/smpfatal02/init.c
@@ -47,6 +47,7 @@ static void fatal_extension(
@@ -57,25 +58,29 @@ static void fatal_extension(
     assert(code == 0xdeadbeef);
     TEST_END();
   } else if ( source == RTEMS_FATAL_SOURCE_SMP ) {
     assert(self != main_cpu);
-    &barrier,
-    &barrier_state,
diff --git a/testsuites/smptests/smpfatal02/smpfatal02.doc b/testsuites/smptests/smpfatal02/smpfatal02.doc
index 9e2e002b37..b962f528ad 100644
--- a/testsuites/smptests/smpfatal02/smpfatal02.doc
+++ b/testsuites/smptests/smpfatal02/smpfatal02.doc
@@ -4,7 +4,8 @@ test set name: smpfatal02
 directives:
+  - _Terminate()
+  - _SMP_Start_multitasking_on_secondary_processor()
 concepts:
2.26.2
