[PATCH rtems-libbsd v2 2/5] usb_template: Configure template driver only for CDC Ethernet
Husni Faiz
ahamedhusni73 at gmail.com
Wed Jul 28 11:56:32 UTC 2021
Add the conditional macro to prevent the driver from referencing
the templates which are not imported yet.
Include functions which adds the hw.usb.template sysctl variable.
Signed-off-by: Husni Faiz <ahamedhusni73 at gmail.com>
freebsd/sys/dev/usb/template/usb_template.c | 4 ++++
freebsd/sys/dev/usb/usb_device.c | 8 ++++++--
2 files changed, 10 insertions(+), 2 deletions(-)
diff --git a/freebsd/sys/dev/usb/template/usb_template.c b/freebsd/sys/dev/usb/template/usb_template.c
index 0650da15..76567e85 100644
--- a/freebsd/sys/dev/usb/template/usb_template.c
+++ b/freebsd/sys/dev/usb/template/usb_template.c
@@ -1433,12 +1433,15 @@ usb_temp_setup_by_index(struct usb_device *udev, uint16_t index)
usb_error_t err;
switch (index) {
+#ifndef __rtems__
case USB_TEMP_MSC:
err = usb_temp_setup(udev, &usb_template_msc);
break;
+#endif /* __rtems__ */
case USB_TEMP_CDCE:
err = usb_temp_setup(udev, &usb_template_cdce);
break;
+#ifndef __rtems__
case USB_TEMP_MTP:
err = usb_temp_setup(udev, &usb_template_mtp);
break;
@@ -1469,6 +1472,7 @@ usb_temp_setup_by_index(struct usb_device *udev, uint16_t index)
case USB_TEMP_CDCEEM:
err = usb_temp_setup(udev, &usb_template_cdceem);
break;
default:
return (USB_ERR_INVAL);
diff --git a/freebsd/sys/dev/usb/usb_device.c b/freebsd/sys/dev/usb/usb_device.c
index ee240949..619cae5a 100644
--- a/freebsd/sys/dev/usb/usb_device.c
+++ b/freebsd/sys/dev/usb/usb_device.c
@@ -28,6 +28,10 @@
* SUCH DAMAGE.
+#ifdef __rtems__
+#include <rtems/bsd/modules.h>
+#endif
#ifdef USB_GLOBAL_INCLUDE_FILE
#include USB_GLOBAL_INCLUDE_FILE
#else
@@ -123,7 +127,7 @@ int usb_template = USB_TEMPLATE;
int usb_template = -1;
#endif
-#ifndef __rtems__
+#if !defined(__rtems__) || defined(RTEMS_BSD_MODULE_DEV_USB_TEMPLATE)
SYSCTL_PROC(_hw_usb, OID_AUTO, template,
CTLTYPE_INT | CTLFLAG_RWTUN | CTLFLAG_MPSAFE,
NULL, 0, sysctl_hw_usb_template,
@@ -255,7 +259,7 @@ sysctl_hw_usb_template(SYSCTL_HANDLER_ARGS)
return (0);
-#endif /* __rtems__ */
+#endif /* !__rtmes__ || RTEMS_BSD_MODULE_DEV_USB_TEMPLATE */
/* English is default language */
2.25.1
