[PATCH rtems-libbsd v2 2/5] usb_template: Configure template driver only for CDC Ethernet
Ahamed Husni
ahamedhusni73 at gmail.com
Wed Jul 28 15:10:40 UTC 2021
On Wed, 28 Jul 2021, 17:27 Husni Faiz, <ahamedhusni73 at gmail.com> wrote:
> Add the conditional macro to prevent the driver from referencing
> the templates which are not imported yet.
> Include functions which adds the hw.usb.template sysctl variable.
> Signed-off-by: Husni Faiz <ahamedhusni73 at gmail.com>
> freebsd/sys/dev/usb/template/usb_template.c | 4 ++++
> freebsd/sys/dev/usb/usb_device.c | 8 ++++++--
> 2 files changed, 10 insertions(+), 2 deletions(-)
> diff --git a/freebsd/sys/dev/usb/template/usb_template.c
> b/freebsd/sys/dev/usb/template/usb_template.c
> index 0650da15..76567e85 100644
> --- a/freebsd/sys/dev/usb/template/usb_template.c
> +++ b/freebsd/sys/dev/usb/template/usb_template.c
> @@ -1433,12 +1433,15 @@ usb_temp_setup_by_index(struct usb_device *udev,
> uint16_t index)
> usb_error_t err;
> switch (index) {
> +#ifndef __rtems__
> case USB_TEMP_MSC:
> err = usb_temp_setup(udev, &usb_template_msc);
> break;
> +#endif /* __rtems__ */
> case USB_TEMP_CDCE:
> err = usb_temp_setup(udev, &usb_template_cdce);
> break;
> +#ifndef __rtems__
> case USB_TEMP_MTP:
> err = usb_temp_setup(udev, &usb_template_mtp);
> break;
> @@ -1469,6 +1472,7 @@ usb_temp_setup_by_index(struct usb_device *udev,
> uint16_t index)
> case USB_TEMP_CDCEEM:
> err = usb_temp_setup(udev, &usb_template_cdceem);
> break;
> default:
> return (USB_ERR_INVAL);
> diff --git a/freebsd/sys/dev/usb/usb_device.c
> b/freebsd/sys/dev/usb/usb_device.c
> index ee240949..619cae5a 100644
> --- a/freebsd/sys/dev/usb/usb_device.c
> +++ b/freebsd/sys/dev/usb/usb_device.c
> @@ -28,6 +28,10 @@
> * SUCH DAMAGE.
> +#ifdef __rtems__
> +#include <rtems/bsd/modules.h>
> +#endif
> #ifdef USB_GLOBAL_INCLUDE_FILE
> #include USB_GLOBAL_INCLUDE_FILE
> #else
> @@ -123,7 +127,7 @@ int usb_template = USB_TEMPLATE;
> int usb_template = -1;
> #endif
> -#ifndef __rtems__
> +#if !defined(__rtems__) || defined(RTEMS_BSD_MODULE_DEV_USB_TEMPLATE)
> SYSCTL_PROC(_hw_usb, OID_AUTO, template,
> CTLTYPE_INT | CTLFLAG_RWTUN | CTLFLAG_MPSAFE,
> NULL, 0, sysctl_hw_usb_template,
> @@ -255,7 +259,7 @@ sysctl_hw_usb_template(SYSCTL_HANDLER_ARGS)
> return (0);
> -#endif /* __rtems__ */
> +#endif /* !__rtmes__ || RTEMS_BSD_MODULE_DEV_USB_TEMPLATE */
Ah, a typo here (rtmes). Should I send a new set of patches?
> /* English is default language */
> 2.25.1
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210728/048625cc/attachment.html>
