[PATCH] score: Canonicalize _CPU_Fatal_halt()
Joel Sherrill
joel at rtems.org
Wed Jul 28 13:42:43 UTC 2021
This looks pretty mechanical and OK.
In reviewing horizontally, I see one implementation that calls
printk(). Is that necessary and of value now?
Also do we have a preference for while forever loops? I see at least
two ways they are implemented.
This change appears to faithfully move inline code to cpu.c but I
hadn't looked across them all.
--joel
On Wed, Jul 28, 2021 at 8:34 AM Sebastian Huber
> Move _CPU_Fatal_halt() declaration to <rtems/score/cpuimpl.h> and make sure it
> is a proper declaration of a function which does not return. Fix the type of
> the error code. If necessary, add the implementation to cpu.c. Implementing
> _CPU_Fatal_halt() makes it possible to wrap this function for example to fully
> test _Terminate().
> cpukit/score/cpu/aarch64/cpu.c | 16 ++++++++--
> .../cpu/aarch64/include/rtems/score/cpu.h | 13 ---------
> .../cpu/aarch64/include/rtems/score/cpuimpl.h | 2 ++
> cpukit/score/cpu/arm/cpu.c | 20 +++++++++++--
> .../score/cpu/arm/include/rtems/score/cpu.h | 13 ---------
> .../cpu/arm/include/rtems/score/cpuimpl.h | 2 ++
> cpukit/score/cpu/bfin/cpu.c | 9 ++++++
> .../score/cpu/bfin/include/rtems/score/cpu.h | 23 ---------------
> .../cpu/bfin/include/rtems/score/cpuimpl.h | 2 ++
> .../score/cpu/i386/include/rtems/score/cpu.h | 11 -------
> .../cpu/i386/include/rtems/score/cpuimpl.h | 2 ++
> cpukit/score/cpu/lm32/cpu.c | 13 +++++++++
> .../score/cpu/lm32/include/rtems/score/cpu.h | 17 -----------
> .../cpu/lm32/include/rtems/score/cpuimpl.h | 2 ++
> cpukit/score/cpu/m68k/cpu.c | 24 +++++++++++++++
> .../score/cpu/m68k/include/rtems/score/cpu.h | 29 -------------------
> .../cpu/m68k/include/rtems/score/cpuimpl.h | 2 ++
> cpukit/score/cpu/mips/cpu.c | 13 +++++++++
> .../score/cpu/mips/include/rtems/score/cpu.h | 17 -----------
> .../cpu/mips/include/rtems/score/cpuimpl.h | 2 ++
> cpukit/score/cpu/moxie/cpu.c | 8 +++++
> .../score/cpu/moxie/include/rtems/score/cpu.h | 17 -----------
> .../cpu/moxie/include/rtems/score/cpuimpl.h | 2 ++
> .../score/cpu/nios2/include/rtems/score/cpu.h | 2 --
> .../cpu/nios2/include/rtems/score/cpuimpl.h | 2 ++
> cpukit/score/cpu/nios2/nios2-fatal-halt.c | 4 +--
> .../cpu/no_cpu/include/rtems/score/cpu.h | 17 -----------
> .../cpu/no_cpu/include/rtems/score/cpuimpl.h | 13 +++++++++
> cpukit/score/cpu/or1k/cpu.c | 10 ++++++-
> .../score/cpu/or1k/include/rtems/score/cpu.h | 17 -----------
> .../cpu/or1k/include/rtems/score/cpuimpl.h | 2 ++
> cpukit/score/cpu/powerpc/cpu.c | 14 +++++++++
> .../cpu/powerpc/include/rtems/score/cpu.h | 14 ---------
> .../cpu/powerpc/include/rtems/score/cpuimpl.h | 2 ++
> .../score/cpu/riscv/include/rtems/score/cpu.h | 2 --
> .../cpu/riscv/include/rtems/score/cpuimpl.h | 2 ++
> cpukit/score/cpu/sh/cpu.c | 9 +++++-
> cpukit/score/cpu/sh/include/rtems/score/cpu.h | 26 -----------------
> .../cpu/sh/include/rtems/score/cpuimpl.h | 2 ++
> .../score/cpu/sparc/include/rtems/score/cpu.h | 11 -------
> .../cpu/sparc/include/rtems/score/cpuimpl.h | 2 ++
> cpukit/score/cpu/sparc64/cpu.c | 10 +++++++
> .../cpu/sparc64/include/rtems/score/cpu.h | 19 ------------
> .../cpu/sparc64/include/rtems/score/cpuimpl.h | 2 ++
> cpukit/score/cpu/v850/cpu.c | 8 +++++
> .../score/cpu/v850/include/rtems/score/cpu.h | 20 -------------
> .../cpu/v850/include/rtems/score/cpuimpl.h | 2 ++
> cpukit/score/cpu/x86_64/cpu.c | 13 +++++++++
> .../cpu/x86_64/include/rtems/score/cpu.h | 8 -----
> .../cpu/x86_64/include/rtems/score/cpuimpl.h | 2 ++
> cpukit/score/src/interr.c | 4 +--
> 51 files changed, 211 insertions(+), 287 deletions(-)
> diff --git a/cpukit/score/cpu/aarch64/cpu.c b/cpukit/score/cpu/aarch64/cpu.c
> index 75b1125cf7..d09403a349 100644
> --- a/cpukit/score/cpu/aarch64/cpu.c
> +++ b/cpukit/score/cpu/aarch64/cpu.c
> @@ -38,8 +38,7 @@
> #include "config.h"
> #endif
> -#include <rtems/score/assert.h>
> -#include <rtems/score/cpu.h>
> +#include <rtems/score/cpuimpl.h>
> #include <rtems/score/thread.h>
> #include <rtems/score/tls.h>
> @@ -195,3 +194,16 @@ void _CPU_Initialize( void )
> /* Do nothing */
> +void _CPU_Fatal_halt( uint32_t source, CPU_Uint32ptr error )
> + ISR_Level level;
> + _CPU_ISR_Disable( level );
> + (void) level;
> + __asm__ volatile ("mov x0, %0\n"
> + : "=r" (error)
> + : "0" (error)
> + : "x0" );
> + while (1);
> diff --git a/cpukit/score/cpu/aarch64/include/rtems/score/cpu.h b/cpukit/score/cpu/aarch64/include/rtems/score/cpu.h
> index 595f6c7351..dacc18638e 100644
> --- a/cpukit/score/cpu/aarch64/include/rtems/score/cpu.h
> +++ b/cpukit/score/cpu/aarch64/include/rtems/score/cpu.h
> @@ -295,19 +295,6 @@ void _CPU_Context_Initialize(
> *(*(_destination)) = _CPU_Null_fp_context; \
> } while (0)
> -#define _CPU_Fatal_halt( _source, _err ) \
> - do { \
> - uint64_t _level; \
> - uint32_t _error = _err; \
> - _CPU_ISR_Disable( _level ); \
> - (void) _level; \
> - __asm__ volatile ("mov x0, %0\n" \
> - : "=r" (_error) \
> - : "0" (_error) \
> - : "x0" ); \
> - while (1); \
> - } while (0);
> * @brief CPU initialization.
> diff --git a/cpukit/score/cpu/aarch64/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/aarch64/include/rtems/score/cpuimpl.h
> index 4c3da6794a..0536ecd860 100644
> --- a/cpukit/score/cpu/aarch64/include/rtems/score/cpuimpl.h
> +++ b/cpukit/score/cpu/aarch64/include/rtems/score/cpuimpl.h
> @@ -58,6 +58,8 @@
> extern "C" {
> #endif
> +RTEMS_NO_RETURN void _CPU_Fatal_halt( uint32_t source, CPU_Uint32ptr error );
> void _CPU_Context_volatile_clobber( uintptr_t pattern );
> void _CPU_Context_validate( uintptr_t pattern );
> diff --git a/cpukit/score/cpu/arm/cpu.c b/cpukit/score/cpu/arm/cpu.c
> index 07b9588afd..d3471dc99f 100644
> --- a/cpukit/score/cpu/arm/cpu.c
> +++ b/cpukit/score/cpu/arm/cpu.c
> @@ -26,8 +26,7 @@
> #include "config.h"
> #endif
> @@ -171,3 +170,20 @@ void _CPU_Initialize( void )
> #endif /* ARM_MULTILIB_ARCH_V4 */
> + ISR_Level level;
> + (void) level;
> + __asm__ volatile ("mov r0, %0\n"
> + : "=r" (error)
> + : "0" (error)
> + : "r0" );
> + while ( true ) {
> + /* Do nothing */
> diff --git a/cpukit/score/cpu/arm/include/rtems/score/cpu.h b/cpukit/score/cpu/arm/include/rtems/score/cpu.h
> index b554aa263e..b8e3604fbb 100644
> --- a/cpukit/score/cpu/arm/include/rtems/score/cpu.h
> +++ b/cpukit/score/cpu/arm/include/rtems/score/cpu.h
> @@ -434,19 +434,6 @@ void _CPU_Context_Initialize(
> } while (0)
> - do { \
> - uint32_t _level; \
> - (void) _level; \
> - __asm__ volatile ("mov r0, %0\n" \
> - : "=r" (_error) \
> - : "0" (_error) \
> - : "r0" ); \
> - while (1); \
> - } while (0);
> diff --git a/cpukit/score/cpu/arm/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/arm/include/rtems/score/cpuimpl.h
> index 2c7078b790..0f86710966 100644
> --- a/cpukit/score/cpu/arm/include/rtems/score/cpuimpl.h
> +++ b/cpukit/score/cpu/arm/include/rtems/score/cpuimpl.h
> @@ -112,6 +112,8 @@ static inline struct Per_CPU_Control *_ARM_Get_current_per_CPU_control( void )
> diff --git a/cpukit/score/cpu/bfin/cpu.c b/cpukit/score/cpu/bfin/cpu.c
> index 5a528894d8..962e84d1bc 100644
> --- a/cpukit/score/cpu/bfin/cpu.c
> +++ b/cpukit/score/cpu/bfin/cpu.c
> @@ -18,6 +18,7 @@
> #include "config.h"
> #endif
> #include <rtems/score/isr.h>
> #include <rtems/score/bfin.h>
> #include <rtems/bfin/bfin.h>
> @@ -73,6 +74,14 @@ void _CPU_Initialize(void)
> __asm__ __volatile__ ("syscfg = %0" : : "d" (0x00000004));
> + __asm__ volatile ( "cli R1; R1 = %0; _halt: idle; jump _halt;"
> + : : "r" (error) );
> +/* end of Fatal Error manager macros */
> diff --git a/cpukit/score/cpu/bfin/include/rtems/score/cpu.h b/cpukit/score/cpu/bfin/include/rtems/score/cpu.h
> index b1063c9eee..91b1a91b07 100644
> --- a/cpukit/score/cpu/bfin/include/rtems/score/cpu.h
> +++ b/cpukit/score/cpu/bfin/include/rtems/score/cpu.h
> @@ -460,29 +460,6 @@ void _CPU_Context_Initialize(
> /* end of Context handler macros */
> -/* Fatal Error manager macros */
> - * This routine copies _error into a known place -- typically a stack
> - * location or a register, optionally disables interrupts, and
> - * halts/stops the CPU.
> - * Port Specific Information:
> - * XXX document implementation including references if appropriate
> -#define _CPU_Fatal_halt( _source, _error ) \
> - __asm__ volatile ( "cli R1; \
> - R1 = %0; \
> - _halt: \
> - idle; \
> - jump _halt;"\
> - : : "r" (_error) ); \
> -/* end of Fatal Error manager macros */
> #define CPU_USE_GENERIC_BITFIELD_CODE TRUE
> #define CPU_USE_LIBC_INIT_FINI_ARRAY FALSE
> diff --git a/cpukit/score/cpu/bfin/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/bfin/include/rtems/score/cpuimpl.h
> index 2140487fc3..1485abd365 100644
> --- a/cpukit/score/cpu/bfin/include/rtems/score/cpuimpl.h
> +++ b/cpukit/score/cpu/bfin/include/rtems/score/cpuimpl.h
> @@ -35,6 +35,8 @@
> extern "C" {
> #endif
> RTEMS_INLINE_ROUTINE void _CPU_Context_volatile_clobber( uintptr_t pattern )
> /* TODO */
> diff --git a/cpukit/score/cpu/i386/include/rtems/score/cpu.h b/cpukit/score/cpu/i386/include/rtems/score/cpu.h
> index 813ed526d8..ba2fb8f396 100644
> --- a/cpukit/score/cpu/i386/include/rtems/score/cpu.h
> +++ b/cpukit/score/cpu/i386/include/rtems/score/cpu.h
> @@ -479,19 +479,8 @@ void _CPU_Context_Initialize(
> - * Fatal Error manager macros
> - * These macros perform the following functions:
> - * + disable interrupts and halt the CPU
> -RTEMS_NO_RETURN void _CPU_Fatal_halt( uint32_t source, uint32_t error );
> #endif /* ASM */
> diff --git a/cpukit/score/cpu/i386/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/i386/include/rtems/score/cpuimpl.h
> index 570b5cc167..6665059fef 100644
> --- a/cpukit/score/cpu/i386/include/rtems/score/cpuimpl.h
> +++ b/cpukit/score/cpu/i386/include/rtems/score/cpuimpl.h
> @@ -37,6 +37,8 @@
> extern "C" {
> #endif
> /* TODO */
> diff --git a/cpukit/score/cpu/lm32/cpu.c b/cpukit/score/cpu/lm32/cpu.c
> index cd2c4b055f..3301a3099b 100644
> --- a/cpukit/score/cpu/lm32/cpu.c
> +++ b/cpukit/score/cpu/lm32/cpu.c
> @@ -20,6 +20,7 @@
> #include "config.h"
> #endif
> /* _CPU_Initialize
> @@ -45,6 +46,18 @@ void _CPU_Initialize(void)
> /* FP context initialization support goes here */
> + ISR_Level level;
> + (void) level;
> + while ( true ) {
> + /* Do nothing */
> uint32_t _CPU_ISR_Get_level( void )
> diff --git a/cpukit/score/cpu/lm32/include/rtems/score/cpu.h b/cpukit/score/cpu/lm32/include/rtems/score/cpu.h
> index 29af53a53b..9bceb3b892 100644
> --- a/cpukit/score/cpu/lm32/include/rtems/score/cpu.h
> +++ b/cpukit/score/cpu/lm32/include/rtems/score/cpu.h
> @@ -590,23 +590,6 @@ extern char _gp[];
> diff --git a/cpukit/score/cpu/lm32/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/lm32/include/rtems/score/cpuimpl.h
> index ab43ddbf7d..eb0c058723 100644
> --- a/cpukit/score/cpu/lm32/include/rtems/score/cpuimpl.h
> +++ b/cpukit/score/cpu/lm32/include/rtems/score/cpuimpl.h
> @@ -34,6 +34,8 @@
> extern "C" {
> #endif
> /* TODO */
> diff --git a/cpukit/score/cpu/m68k/cpu.c b/cpukit/score/cpu/m68k/cpu.c
> index be63351e9c..e6a5c9dbf3 100644
> --- a/cpukit/score/cpu/m68k/cpu.c
> +++ b/cpukit/score/cpu/m68k/cpu.c
> @@ -17,6 +17,7 @@
> #include "config.h"
> #endif
> #include <rtems/score/percpu.h>
> @@ -88,6 +89,29 @@ void _CPU_Initialize(void)
> m68k_install_interrupt_stack();
> +#if ( defined(__mcoldfire__) )
> + __asm__ volatile( "move.w %%sr,%%d0\n\t"
> + "or.l %2,%%d0\n\t"
> + "move.w %%d0,%%sr\n\t"
> + "move.l %1,%%d0\n\t"
> + "move.l #0xDEADBEEF,%%d1\n\t"
> + "halt"
> + : "=g" (error)
> + : "0" (error), "d"(0x0700)
> + : "d0", "d1" );
> +#else
> + __asm__ volatile( "movl %0,%%d0; "
> + "orw #0x0700,%%sr; "
> + "stop #0x2700" : "=d" ((error)) : "0" ((error)) );
> +#endif
> uint32_t level;
> diff --git a/cpukit/score/cpu/m68k/include/rtems/score/cpu.h b/cpukit/score/cpu/m68k/include/rtems/score/cpu.h
> index 65ba0ef496..95e75ad1eb 100644
> --- a/cpukit/score/cpu/m68k/include/rtems/score/cpu.h
> +++ b/cpukit/score/cpu/m68k/include/rtems/score/cpu.h
> @@ -401,35 +401,6 @@ void _CPU_Context_Initialize(
> void *_CPU_Thread_Idle_body( uintptr_t ignored );
> -#if ( defined(__mcoldfire__) )
> - { __asm__ volatile( "move.w %%sr,%%d0\n\t" \
> - "or.l %2,%%d0\n\t" \
> - "move.w %%d0,%%sr\n\t" \
> - "move.l %1,%%d0\n\t" \
> - "move.l #0xDEADBEEF,%%d1\n\t" \
> - "halt" \
> - : "=g" (_error) \
> - : "0" (_error), "d"(0x0700) \
> - : "d0", "d1" ); \
> -#else
> - { __asm__ volatile( "movl %0,%%d0; " \
> - "orw #0x0700,%%sr; " \
> - "stop #0x2700" : "=d" ((_error)) : "0" ((_error)) ); \
> -#endif
> diff --git a/cpukit/score/cpu/m68k/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/m68k/include/rtems/score/cpuimpl.h
> index dda5727142..833ff071b8 100644
> --- a/cpukit/score/cpu/m68k/include/rtems/score/cpuimpl.h
> +++ b/cpukit/score/cpu/m68k/include/rtems/score/cpuimpl.h
> @@ -35,6 +35,8 @@
> extern "C" {
> #endif
> /* TODO */
> diff --git a/cpukit/score/cpu/mips/cpu.c b/cpukit/score/cpu/mips/cpu.c
> index c8cf960db5..8d1018dbf6 100644
> --- a/cpukit/score/cpu/mips/cpu.c
> +++ b/cpukit/score/cpu/mips/cpu.c
> @@ -50,6 +50,7 @@
> #include "config.h"
> #endif
> #if CPU_HARDWARE_FP
> @@ -93,6 +94,18 @@ void _CPU_Initialize(void)
> #endif
> + ISR_Level level;
> + (void) level;
> + while ( true ) {
> + /* Do nothing */
> unsigned int sr;
> diff --git a/cpukit/score/cpu/mips/include/rtems/score/cpu.h b/cpukit/score/cpu/mips/include/rtems/score/cpu.h
> index cdb0e64013..67d1465daa 100644
> --- a/cpukit/score/cpu/mips/include/rtems/score/cpu.h
> +++ b/cpukit/score/cpu/mips/include/rtems/score/cpu.h
> @@ -710,23 +710,6 @@ void _CPU_Context_Initialize(
> - do { \
> - unsigned int _level; \
> - _CPU_ISR_Disable(_level); \
> - (void)_level; \
> - loop: goto loop; \
> - } while (0)
> extern void mips_break( int error );
> diff --git a/cpukit/score/cpu/mips/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/mips/include/rtems/score/cpuimpl.h
> index 932784fc8f..554d8be1c8 100644
> --- a/cpukit/score/cpu/mips/include/rtems/score/cpuimpl.h
> +++ b/cpukit/score/cpu/mips/include/rtems/score/cpuimpl.h
> @@ -35,6 +35,8 @@
> extern "C" {
> #endif
> /* TODO */
> diff --git a/cpukit/score/cpu/moxie/cpu.c b/cpukit/score/cpu/moxie/cpu.c
> index 5522890c59..b4dad060b6 100644
> --- a/cpukit/score/cpu/moxie/cpu.c
> +++ b/cpukit/score/cpu/moxie/cpu.c
> @@ -17,7 +17,9 @@
> #include "config.h"
> #endif
> +#include <rtems/bspIo.h>
> /* _CPU_Initialize
> @@ -37,6 +39,12 @@ void _CPU_Initialize(void)
> + printk("Fatal Error %d.%lu Halted\n",source,error);
> + for(;;);
> * _CPU_ISR_Get_level
> diff --git a/cpukit/score/cpu/moxie/include/rtems/score/cpu.h b/cpukit/score/cpu/moxie/include/rtems/score/cpu.h
> index 9959892689..a3991016f1 100644
> --- a/cpukit/score/cpu/moxie/include/rtems/score/cpu.h
> +++ b/cpukit/score/cpu/moxie/include/rtems/score/cpu.h
> @@ -391,23 +391,6 @@ uint32_t _CPU_ISR_Get_level( void );
> - * MOXIE Specific Information:
> - * XXX
> - printk("Fatal Error %d.%lu Halted\n",_source,_error); \
> - for(;;)
> diff --git a/cpukit/score/cpu/moxie/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/moxie/include/rtems/score/cpuimpl.h
> index 9c81cb6193..76068fe8b8 100644
> --- a/cpukit/score/cpu/moxie/include/rtems/score/cpuimpl.h
> +++ b/cpukit/score/cpu/moxie/include/rtems/score/cpuimpl.h
> @@ -35,6 +35,8 @@
> extern "C" {
> #endif
> /* TODO */
> diff --git a/cpukit/score/cpu/nios2/include/rtems/score/cpu.h b/cpukit/score/cpu/nios2/include/rtems/score/cpu.h
> index 69c96280f4..c26e57f88b 100644
> --- a/cpukit/score/cpu/nios2/include/rtems/score/cpu.h
> +++ b/cpukit/score/cpu/nios2/include/rtems/score/cpu.h
> @@ -290,8 +290,6 @@ void _CPU_Context_Initialize(
> #define _CPU_Context_Restart_self( _the_context ) \
> _CPU_Context_restore( (_the_context) );
> -RTEMS_NO_RETURN void _CPU_Fatal_halt( uint32_t _source, uint32_t _error );
> diff --git a/cpukit/score/cpu/nios2/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/nios2/include/rtems/score/cpuimpl.h
> index e5f326eeb7..ad28960fe5 100644
> --- a/cpukit/score/cpu/nios2/include/rtems/score/cpuimpl.h
> +++ b/cpukit/score/cpu/nios2/include/rtems/score/cpuimpl.h
> @@ -35,6 +35,8 @@
> extern "C" {
> #endif
> diff --git a/cpukit/score/cpu/nios2/nios2-fatal-halt.c b/cpukit/score/cpu/nios2/nios2-fatal-halt.c
> index 40cae874c0..e2ea8ef13d 100644
> --- a/cpukit/score/cpu/nios2/nios2-fatal-halt.c
> +++ b/cpukit/score/cpu/nios2/nios2-fatal-halt.c
> @@ -11,10 +11,10 @@
> * http://www.rtems.org/license/LICENSE.
> #include <rtems/score/nios2-utility.h>
> -void _CPU_Fatal_halt( uint32_t _source, uint32_t _error )
> +void _CPU_Fatal_halt( uint32_t _source, CPU_Uint32ptr _error )
> /* write 0 to status register (disable interrupts) */
> __builtin_wrctl( NIOS2_CTLREG_INDEX_STATUS, 0 );
> diff --git a/cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h b/cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h
> index c4cb512e20..e224a5e56e 100644
> --- a/cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h
> +++ b/cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h
> @@ -824,23 +824,6 @@ uint32_t _CPU_ISR_Get_level( void );
> /* Bitfield handler macros */
> diff --git a/cpukit/score/cpu/no_cpu/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/no_cpu/include/rtems/score/cpuimpl.h
> index c8c86f4ec7..5f9196042c 100644
> --- a/cpukit/score/cpu/no_cpu/include/rtems/score/cpuimpl.h
> +++ b/cpukit/score/cpu/no_cpu/include/rtems/score/cpuimpl.h
> @@ -83,6 +83,19 @@ register struct Per_CPU_Control *_CPU_Per_CPU_current asm( "rX" );
> #define _CPU_Get_thread_executing() ( _CPU_Per_CPU_current->executing )
> + * This routine copies _error into a known place -- typically a stack
> + * location or a register, optionally disables interrupts, and
> + * halts/stops the CPU.
> + * Port Specific Information:
> + * XXX document implementation including references if appropriate
> * @addtogroup RTEMSScoreCPUExampleContext
> diff --git a/cpukit/score/cpu/or1k/cpu.c b/cpukit/score/cpu/or1k/cpu.c
> index 79cb76812f..d030a0cab4 100644
> --- a/cpukit/score/cpu/or1k/cpu.c
> +++ b/cpukit/score/cpu/or1k/cpu.c
> @@ -11,8 +11,8 @@
> /* bsp_start_vector_table_begin is the start address of the vector table
> * containing addresses to ISR Handlers. It's defined at the BSP linkcmds
> @@ -28,6 +28,14 @@ void _CPU_Initialize(void)
> /* Do nothing */
> + _OR1KSIM_CPU_Halt();
> + for(;;);
> * @brief Sets the hardware interrupt level by the level value.
> diff --git a/cpukit/score/cpu/or1k/include/rtems/score/cpu.h b/cpukit/score/cpu/or1k/include/rtems/score/cpu.h
> index 5cd59df3f4..02a574affa 100644
> --- a/cpukit/score/cpu/or1k/include/rtems/score/cpu.h
> +++ b/cpukit/score/cpu/or1k/include/rtems/score/cpu.h
> @@ -390,23 +390,6 @@ void _CPU_Context_Initialize(
> -#include <inttypes.h>
> -#define _CPU_Fatal_halt(_source, _error ) \
> - _OR1KSIM_CPU_Halt(); \
> - for(;;)
> #define CPU_USE_LIBC_INIT_FINI_ARRAY TRUE
> diff --git a/cpukit/score/cpu/or1k/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/or1k/include/rtems/score/cpuimpl.h
> index 76da91fdec..ace9273da9 100644
> --- a/cpukit/score/cpu/or1k/include/rtems/score/cpuimpl.h
> +++ b/cpukit/score/cpu/or1k/include/rtems/score/cpuimpl.h
> @@ -35,6 +35,8 @@
> extern "C" {
> #endif
> diff --git a/cpukit/score/cpu/powerpc/cpu.c b/cpukit/score/cpu/powerpc/cpu.c
> index 1367d9d2c0..41f1c202cc 100644
> --- a/cpukit/score/cpu/powerpc/cpu.c
> +++ b/cpukit/score/cpu/powerpc/cpu.c
> @@ -325,3 +325,17 @@ RTEMS_STATIC_ASSERT(
> sizeof(CPU_Exception_frame) + FRAME_LINK_SPACE <= PPC_EXC_FRAME_SIZE,
> CPU_Exception_frame
> + ppc_interrupt_disable();
> + "mr 3, %0\n"
> + "mr 4, %1\n"
> + "1:\n"
> + "b 1b\n"
> + : "r" (source), "r" (error)
> + : "memory"
> diff --git a/cpukit/score/cpu/powerpc/include/rtems/score/cpu.h b/cpukit/score/cpu/powerpc/include/rtems/score/cpu.h
> index ee02bd4ee4..9cb47bcaa6 100644
> --- a/cpukit/score/cpu/powerpc/include/rtems/score/cpu.h
> +++ b/cpukit/score/cpu/powerpc/include/rtems/score/cpu.h
> @@ -613,20 +613,6 @@ void ppc_set_interrupt_level( uint32_t level );
> #endif /* ASM */
> - do { \
> - ppc_interrupt_disable(); \
> - __asm__ volatile ( \
> - "mr 3, %0\n" \
> - "mr 4, %1\n" \
> - "1:\n" \
> - "b 1b\n" \
> - : "r" (_source), "r" (_error) \
> - : "memory" \
> - } while ( 0 )
> * Should be large enough to run all RTEMS tests. This ensures
> * that a "reasonable" small application should not have any problems.
> diff --git a/cpukit/score/cpu/powerpc/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/powerpc/include/rtems/score/cpuimpl.h
> index bd23602827..69eeeb183c 100644
> --- a/cpukit/score/cpu/powerpc/include/rtems/score/cpuimpl.h
> +++ b/cpukit/score/cpu/powerpc/include/rtems/score/cpuimpl.h
> @@ -248,6 +248,8 @@ static inline struct Per_CPU_Control *_PPC_Get_current_per_CPU_control( void )
> #endif /* RTEMS_SMP */
> diff --git a/cpukit/score/cpu/riscv/include/rtems/score/cpu.h b/cpukit/score/cpu/riscv/include/rtems/score/cpu.h
> index 16dde8204c..3f3c8de74c 100644
> --- a/cpukit/score/cpu/riscv/include/rtems/score/cpu.h
> +++ b/cpukit/score/cpu/riscv/include/rtems/score/cpu.h
> @@ -211,8 +211,6 @@ void _CPU_Context_Initialize(
> #define CPU_USE_GENERIC_BITFIELD_DATA TRUE
> diff --git a/cpukit/score/cpu/riscv/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/riscv/include/rtems/score/cpuimpl.h
> index c381cce110..eee6ad7328 100644
> --- a/cpukit/score/cpu/riscv/include/rtems/score/cpuimpl.h
> +++ b/cpukit/score/cpu/riscv/include/rtems/score/cpuimpl.h
> @@ -408,6 +408,8 @@ static inline struct Per_CPU_Control *_RISCV_Get_current_per_CPU_control( void )
> diff --git a/cpukit/score/cpu/sh/cpu.c b/cpukit/score/cpu/sh/cpu.c
> index c10086534b..558f95be4d 100644
> --- a/cpukit/score/cpu/sh/cpu.c
> +++ b/cpukit/score/cpu/sh/cpu.c
> @@ -30,9 +30,9 @@
> #include "config.h"
> #endif
> #include <rtems/score/sh_io.h>
> #include <rtems/score/sh.h>
> /* referenced in start.S */
> @@ -76,6 +76,13 @@ void _CPU_Initialize(void)
> _CPU_ISR_Set_level( level ) ;
> + __asm__ volatile("mov.l %0,r0"::"m" (error));
> + __asm__ volatile("mov #1, r4");
> + __asm__ volatile("trapa #34");
> diff --git a/cpukit/score/cpu/sh/include/rtems/score/cpu.h b/cpukit/score/cpu/sh/include/rtems/score/cpu.h
> index 364a2bc310..2805e4244c 100644
> --- a/cpukit/score/cpu/sh/include/rtems/score/cpu.h
> +++ b/cpukit/score/cpu/sh/include/rtems/score/cpu.h
> @@ -490,32 +490,6 @@ void _CPU_Context_Initialize(
> - * FIXME: Trap32 ???
> - * invokes a Trap32 Instruction which returns to the breakpoint
> - * routine of cmon.
> -#ifdef BSP_FATAL_HALT
> - /* we manage the fatal error in the board support package */
> - void bsp_fatal_halt( uint32_t _error);
> -#define _CPU_Fatal_halt( _source, _error ) bsp_fatal_halt( _error)
> -#else
> -#define _CPU_Fatal_halt( _source, _error)\
> - __asm__ volatile("mov.l %0,r0"::"m" (_error)); \
> - __asm__ volatile("mov #1, r4"); \
> - __asm__ volatile("trapa #34"); \
> -#endif
> diff --git a/cpukit/score/cpu/sh/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/sh/include/rtems/score/cpuimpl.h
> index 6dcbc00f6b..745a185d1a 100644
> --- a/cpukit/score/cpu/sh/include/rtems/score/cpuimpl.h
> +++ b/cpukit/score/cpu/sh/include/rtems/score/cpuimpl.h
> @@ -35,6 +35,8 @@
> extern "C" {
> #endif
> /* TODO */
> diff --git a/cpukit/score/cpu/sparc/include/rtems/score/cpu.h b/cpukit/score/cpu/sparc/include/rtems/score/cpu.h
> index 910ec83a87..af15f35b62 100644
> --- a/cpukit/score/cpu/sparc/include/rtems/score/cpu.h
> +++ b/cpukit/score/cpu/sparc/include/rtems/score/cpu.h
> @@ -883,17 +883,6 @@ void _CPU_Context_Initialize(
> do { } while ( 0 )
> diff --git a/cpukit/score/cpu/sparc/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/sparc/include/rtems/score/cpuimpl.h
> index 8aa4030a45..14038cbdbe 100644
> --- a/cpukit/score/cpu/sparc/include/rtems/score/cpuimpl.h
> +++ b/cpukit/score/cpu/sparc/include/rtems/score/cpuimpl.h
> @@ -199,6 +199,8 @@ register struct Per_CPU_Control *_SPARC_Per_CPU_current __asm__( "g6" );
> #define _CPU_Get_thread_executing() ( _SPARC_Per_CPU_current->executing )
> diff --git a/cpukit/score/cpu/sparc64/cpu.c b/cpukit/score/cpu/sparc64/cpu.c
> index 2d92aa7286..e8d6017d2c 100644
> --- a/cpukit/score/cpu/sparc64/cpu.c
> +++ b/cpukit/score/cpu/sparc64/cpu.c
> @@ -16,6 +16,7 @@
> #include <rtems/rtems/cache.h>
> @@ -63,6 +64,15 @@ void _CPU_Initialize(void)
> _CPU_ISR_Dispatch_disable = 0;
> + uint32_t level;
> + level = sparc_disable_interrupts();
> + __asm__ volatile ( "mov %0, %%g1 " : "=r" (level) : "0" (level) );
> + while (1); /* loop forever */
> Context_Control *the_context,
> void *stack_base,
> diff --git a/cpukit/score/cpu/sparc64/include/rtems/score/cpu.h b/cpukit/score/cpu/sparc64/include/rtems/score/cpu.h
> index 3c41a922e7..1d8813da35 100644
> --- a/cpukit/score/cpu/sparc64/include/rtems/score/cpu.h
> +++ b/cpukit/score/cpu/sparc64/include/rtems/score/cpu.h
> @@ -769,25 +769,6 @@ void _CPU_Context_Initialize(
> - do { \
> - uint32_t level; \
> - level = sparc_disable_interrupts(); \
> - __asm__ volatile ( "mov %0, %%g1 " : "=r" (level) : "0" (level) ); \
> - while (1); /* loop forever */ \
> - } while (0)
> diff --git a/cpukit/score/cpu/sparc64/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/sparc64/include/rtems/score/cpuimpl.h
> index e137756e62..521612d555 100644
> --- a/cpukit/score/cpu/sparc64/include/rtems/score/cpuimpl.h
> +++ b/cpukit/score/cpu/sparc64/include/rtems/score/cpuimpl.h
> @@ -35,6 +35,8 @@
> extern "C" {
> #endif
> /* TODO */
> diff --git a/cpukit/score/cpu/v850/cpu.c b/cpukit/score/cpu/v850/cpu.c
> index a921775413..d659d9257e 100644
> --- a/cpukit/score/cpu/v850/cpu.c
> +++ b/cpukit/score/cpu/v850/cpu.c
> @@ -17,6 +17,7 @@
> #include "config.h"
> #endif
> #include <string.h> /* for memset */
> @@ -30,6 +31,13 @@ void _CPU_Initialize(void)
> + __asm__ __volatile__ ( "di" );
> + __asm__ __volatile__ ( "mov %0, r10; " : "=r" ((error)) );
> + __asm__ __volatile__ ( "halt" );
> * v850 Specific Information:
> diff --git a/cpukit/score/cpu/v850/include/rtems/score/cpu.h b/cpukit/score/cpu/v850/include/rtems/score/cpu.h
> index 1921216e2d..6bf69de3e6 100644
> --- a/cpukit/score/cpu/v850/include/rtems/score/cpu.h
> +++ b/cpukit/score/cpu/v850/include/rtems/score/cpu.h
> @@ -461,26 +461,6 @@ void _CPU_Context_Initialize(
> - * Move the error code into r10, disable interrupts and halt.
> - do { \
> - __asm__ __volatile__ ( "di" ); \
> - __asm__ __volatile__ ( "mov %0, r10; " : "=r" ((_error)) ); \
> - __asm__ __volatile__ ( "halt" ); \
> - } while (0)
> diff --git a/cpukit/score/cpu/v850/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/v850/include/rtems/score/cpuimpl.h
> index f7b02ccb6b..2e95738ed6 100644
> --- a/cpukit/score/cpu/v850/include/rtems/score/cpuimpl.h
> +++ b/cpukit/score/cpu/v850/include/rtems/score/cpuimpl.h
> @@ -35,6 +35,8 @@
> extern "C" {
> #endif
> /* TODO */
> diff --git a/cpukit/score/cpu/x86_64/cpu.c b/cpukit/score/cpu/x86_64/cpu.c
> index 6846c431ef..0ad2d1ff3c 100644
> --- a/cpukit/score/cpu/x86_64/cpu.c
> +++ b/cpukit/score/cpu/x86_64/cpu.c
> @@ -37,6 +37,7 @@
> #include "config.h"
> #endif
> #include <rtems/score/idt.h>
> @@ -48,3 +49,15 @@ void _CPU_Exception_frame_print(const CPU_Exception_frame *ctx)
> + ISR_Level level;
> + (void) level;
> + while ( true ) {
> + /* Do nothing */
> diff --git a/cpukit/score/cpu/x86_64/include/rtems/score/cpu.h b/cpukit/score/cpu/x86_64/include/rtems/score/cpu.h
> index 056c0224a9..bea8e05e39 100644
> --- a/cpukit/score/cpu/x86_64/include/rtems/score/cpu.h
> +++ b/cpukit/score/cpu/x86_64/include/rtems/score/cpu.h
> @@ -232,14 +232,6 @@ void _CPU_Context_Initialize(
> diff --git a/cpukit/score/cpu/x86_64/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/x86_64/include/rtems/score/cpuimpl.h
> index 1730799952..d3a4b848e6 100644
> --- a/cpukit/score/cpu/x86_64/include/rtems/score/cpuimpl.h
> +++ b/cpukit/score/cpu/x86_64/include/rtems/score/cpuimpl.h
> @@ -38,6 +38,8 @@
> extern "C" {
> #endif
> /* TODO */
> diff --git a/cpukit/score/src/interr.c b/cpukit/score/src/interr.c
> index fd5a4c92b8..0b4ad1f7f9 100644
> --- a/cpukit/score/src/interr.c
> +++ b/cpukit/score/src/interr.c
> @@ -21,6 +21,7 @@
> #endif
> #include <rtems/score/interr.h>
> #include <rtems/score/smpimpl.h>
> #include <rtems/score/sysstate.h>
> #include <rtems/score/userextimpl.h>
> @@ -36,9 +37,6 @@ void _Terminate(
> _System_state_Set( SYSTEM_STATE_TERMINATED );
> _SMP_Request_shutdown();
> _CPU_Fatal_halt( the_source, the_error );
> - /* will not return from this routine */
> - while (true);
> void _Internal_error( Internal_errors_Core_list core_error )
> 2.26.2
> devel mailing list
> devel at rtems.org
