[PATCH] score: Canonicalize _CPU_Fatal_halt()
Wed Jul 28 13:34:22 UTC 2021
Move _CPU_Fatal_halt() declaration to <rtems/score/cpuimpl.h> and make sure it
is a proper declaration of a function which does not return.  Fix the type of
the error code.  If necessary, add the implementation to cpu.c.  Implementing
_CPU_Fatal_halt() makes it possible to wrap this function for example to fully
test _Terminate().
 cpukit/score/cpu/aarch64/cpu.c                | 16 ++++++++--
 .../cpu/aarch64/include/rtems/score/cpu.h     | 13 ---------
 .../cpu/aarch64/include/rtems/score/cpuimpl.h |  2 ++
 cpukit/score/cpu/arm/cpu.c                    | 20 +++++++++++--
 .../score/cpu/arm/include/rtems/score/cpu.h   | 13 ---------
 .../cpu/arm/include/rtems/score/cpuimpl.h     |  2 ++
 cpukit/score/cpu/bfin/cpu.c                   |  9 ++++++
 .../score/cpu/bfin/include/rtems/score/cpu.h  | 23 ---------------
 .../cpu/bfin/include/rtems/score/cpuimpl.h    |  2 ++
 .../score/cpu/i386/include/rtems/score/cpu.h  | 11 -------
 .../cpu/i386/include/rtems/score/cpuimpl.h    |  2 ++
 cpukit/score/cpu/lm32/cpu.c                   | 13 +++++++++
 .../score/cpu/lm32/include/rtems/score/cpu.h  | 17 -----------
 .../cpu/lm32/include/rtems/score/cpuimpl.h    |  2 ++
 cpukit/score/cpu/m68k/cpu.c                   | 24 +++++++++++++++
 .../score/cpu/m68k/include/rtems/score/cpu.h  | 29 -------------------
 .../cpu/m68k/include/rtems/score/cpuimpl.h    |  2 ++
 cpukit/score/cpu/mips/cpu.c                   | 13 +++++++++
 .../score/cpu/mips/include/rtems/score/cpu.h  | 17 -----------
 .../cpu/mips/include/rtems/score/cpuimpl.h    |  2 ++
 cpukit/score/cpu/moxie/cpu.c                  |  8 +++++
 .../score/cpu/moxie/include/rtems/score/cpu.h | 17 -----------
 .../cpu/moxie/include/rtems/score/cpuimpl.h   |  2 ++
 .../score/cpu/nios2/include/rtems/score/cpu.h |  2 --
 .../cpu/nios2/include/rtems/score/cpuimpl.h   |  2 ++
 cpukit/score/cpu/nios2/nios2-fatal-halt.c     |  4 +--
 .../cpu/no_cpu/include/rtems/score/cpu.h      | 17 -----------
 .../cpu/no_cpu/include/rtems/score/cpuimpl.h  | 13 +++++++++
 cpukit/score/cpu/or1k/cpu.c                   | 10 ++++++-
 .../score/cpu/or1k/include/rtems/score/cpu.h  | 17 -----------
 .../cpu/or1k/include/rtems/score/cpuimpl.h    |  2 ++
 cpukit/score/cpu/powerpc/cpu.c                | 14 +++++++++
 .../cpu/powerpc/include/rtems/score/cpu.h     | 14 ---------
 .../cpu/powerpc/include/rtems/score/cpuimpl.h |  2 ++
 .../score/cpu/riscv/include/rtems/score/cpu.h |  2 --
 .../cpu/riscv/include/rtems/score/cpuimpl.h   |  2 ++
 cpukit/score/cpu/sh/cpu.c                     |  9 +++++-
 cpukit/score/cpu/sh/include/rtems/score/cpu.h | 26 -----------------
 .../cpu/sh/include/rtems/score/cpuimpl.h      |  2 ++
 .../score/cpu/sparc/include/rtems/score/cpu.h | 11 -------
 .../cpu/sparc/include/rtems/score/cpuimpl.h   |  2 ++
 cpukit/score/cpu/sparc64/cpu.c                | 10 +++++++
 .../cpu/sparc64/include/rtems/score/cpu.h     | 19 ------------
 .../cpu/sparc64/include/rtems/score/cpuimpl.h |  2 ++
 cpukit/score/cpu/v850/cpu.c                   |  8 +++++
 .../score/cpu/v850/include/rtems/score/cpu.h  | 20 -------------
 .../cpu/v850/include/rtems/score/cpuimpl.h    |  2 ++
 cpukit/score/cpu/x86_64/cpu.c                 | 13 +++++++++
 .../cpu/x86_64/include/rtems/score/cpu.h      |  8 -----
 .../cpu/x86_64/include/rtems/score/cpuimpl.h  |  2 ++
 cpukit/score/src/interr.c                     |  4 +--
 51 files changed, 211 insertions(+), 287 deletions(-)
diff --git a/cpukit/score/cpu/aarch64/cpu.c b/cpukit/score/cpu/aarch64/cpu.c
index 75b1125cf7..d09403a349 100644
--- a/cpukit/score/cpu/aarch64/cpu.c
+++ b/cpukit/score/cpu/aarch64/cpu.c
@@ -38,8 +38,7 @@
 #include "config.h"
 #endif
-#include <rtems/score/assert.h>
-#include <rtems/score/cpu.h>
+#include <rtems/score/cpuimpl.h>
 #include <rtems/score/tls.h>
@@ -195,3 +194,16 @@ void _CPU_Initialize( void )
   /* Do nothing */
+void _CPU_Fatal_halt( uint32_t source, CPU_Uint32ptr error )
+  ISR_Level level;
+  _CPU_ISR_Disable( level );
+  (void) level;
+  __asm__ volatile ("mov x0, %0\n"
+                : "=r" (error)
+                : "0" (error)
+                : "x0" );
+  while (1);
diff --git a/cpukit/score/cpu/aarch64/include/rtems/score/cpu.h b/cpukit/score/cpu/aarch64/include/rtems/score/cpu.h
index 595f6c7351..dacc18638e 100644
--- a/cpukit/score/cpu/aarch64/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/aarch64/include/rtems/score/cpu.h
@@ -295,19 +295,6 @@ void _CPU_Context_Initialize(
     *(*(_destination)) = _CPU_Null_fp_context; \
   } while (0)
-#define _CPU_Fatal_halt( _source, _err )    \
-   do {                                     \
-     uint64_t _level;                       \
-     uint32_t _error = _err;                \
-     _CPU_ISR_Disable( _level );            \
-     (void) _level;                         \
-     __asm__ volatile ("mov x0, %0\n"       \
-                   : "=r" (_error)          \
-                   : "0" (_error)           \
-                   : "x0" );                \
-     while (1);                             \
-   } while (0);
  * @brief CPU initialization.
diff --git a/cpukit/score/cpu/aarch64/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/aarch64/include/rtems/score/cpuimpl.h
index 4c3da6794a..0536ecd860 100644
--- a/cpukit/score/cpu/aarch64/include/rtems/score/cpuimpl.h
+++ b/cpukit/score/cpu/aarch64/include/rtems/score/cpuimpl.h
@@ -58,6 +58,8 @@
 extern "C" {
 #endif
+RTEMS_NO_RETURN void _CPU_Fatal_halt( uint32_t source, CPU_Uint32ptr error );
 void _CPU_Context_volatile_clobber( uintptr_t pattern );
 void _CPU_Context_validate( uintptr_t pattern );
diff --git a/cpukit/score/cpu/arm/cpu.c b/cpukit/score/cpu/arm/cpu.c
index 07b9588afd..d3471dc99f 100644
--- a/cpukit/score/cpu/arm/cpu.c
+++ b/cpukit/score/cpu/arm/cpu.c
@@ -26,8 +26,7 @@
 #include "config.h"
 #endif
@@ -171,3 +170,20 @@ void _CPU_Initialize( void )
 #endif /* ARM_MULTILIB_ARCH_V4 */
+  ISR_Level level;
+  (void) level;
+  __asm__ volatile ("mov r0, %0\n"
+                : "=r" (error)
+                : "0" (error)
+                : "r0" );
+  while ( true ) {
+    /* Do nothing */
diff --git a/cpukit/score/cpu/arm/include/rtems/score/cpu.h b/cpukit/score/cpu/arm/include/rtems/score/cpu.h
index b554aa263e..b8e3604fbb 100644
--- a/cpukit/score/cpu/arm/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/arm/include/rtems/score/cpu.h
@@ -434,19 +434,6 @@ void _CPU_Context_Initialize(
   } while (0)
-   do {                                     \
-     uint32_t _level;                       \
-     (void) _level;                         \
-     __asm__ volatile ("mov r0, %0\n"       \
-                   : "=r" (_error)          \
-                   : "0" (_error)           \
-                   : "r0" );                \
-     while (1);                             \
-   } while (0);
diff --git a/cpukit/score/cpu/arm/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/arm/include/rtems/score/cpuimpl.h
index 2c7078b790..0f86710966 100644
--- a/cpukit/score/cpu/arm/include/rtems/score/cpuimpl.h
+++ b/cpukit/score/cpu/arm/include/rtems/score/cpuimpl.h
@@ -112,6 +112,8 @@ static inline struct Per_CPU_Control *_ARM_Get_current_per_CPU_control( void )
diff --git a/cpukit/score/cpu/bfin/cpu.c b/cpukit/score/cpu/bfin/cpu.c
index 5a528894d8..962e84d1bc 100644
--- a/cpukit/score/cpu/bfin/cpu.c
+++ b/cpukit/score/cpu/bfin/cpu.c
@@ -18,6 +18,7 @@
 #include "config.h"
 #endif
 #include <rtems/score/isr.h>
 #include <rtems/score/bfin.h>
 #include <rtems/bfin/bfin.h>
@@ -73,6 +74,14 @@ void _CPU_Initialize(void)
   __asm__ __volatile__ ("syscfg = %0" : : "d" (0x00000004));
+  __asm__ volatile ( "cli R1; R1 = %0; _halt: idle; jump _halt;"
+                     : : "r" (error) );
+/* end of Fatal Error manager macros */
diff --git a/cpukit/score/cpu/bfin/include/rtems/score/cpu.h b/cpukit/score/cpu/bfin/include/rtems/score/cpu.h
index b1063c9eee..91b1a91b07 100644
--- a/cpukit/score/cpu/bfin/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/bfin/include/rtems/score/cpu.h
@@ -460,29 +460,6 @@ void _CPU_Context_Initialize(
 /* end of Context handler macros */
-/* Fatal Error manager macros */
- * This routine copies _error into a known place -- typically a stack
- * location or a register, optionally disables interrupts, and
- * halts/stops the CPU.
- * Port Specific Information:
- * XXX document implementation including references if appropriate
-#define _CPU_Fatal_halt( _source, _error ) \
-    __asm__ volatile ( "cli R1; \
-                    R1 = %0; \
-                    _halt: \
-                    idle; \
-                    jump _halt;"\
-                    : : "r" (_error) ); \
-/* end of Fatal Error manager macros */
 #define CPU_USE_GENERIC_BITFIELD_CODE TRUE
 #define CPU_USE_LIBC_INIT_FINI_ARRAY FALSE
diff --git a/cpukit/score/cpu/bfin/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/bfin/include/rtems/score/cpuimpl.h
index 2140487fc3..1485abd365 100644
--- a/cpukit/score/cpu/bfin/include/rtems/score/cpuimpl.h
+++ b/cpukit/score/cpu/bfin/include/rtems/score/cpuimpl.h
@@ -35,6 +35,8 @@
 extern "C" {
 #endif
 RTEMS_INLINE_ROUTINE void _CPU_Context_volatile_clobber( uintptr_t pattern )
   /* TODO */
diff --git a/cpukit/score/cpu/i386/include/rtems/score/cpu.h b/cpukit/score/cpu/i386/include/rtems/score/cpu.h
index 813ed526d8..ba2fb8f396 100644
--- a/cpukit/score/cpu/i386/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/i386/include/rtems/score/cpu.h
@@ -479,19 +479,8 @@ void _CPU_Context_Initialize(
- *  Fatal Error manager macros
- *  These macros perform the following functions:
- *    + disable interrupts and halt the CPU
-RTEMS_NO_RETURN void _CPU_Fatal_halt( uint32_t source, uint32_t error );
 #endif /* ASM */
diff --git a/cpukit/score/cpu/i386/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/i386/include/rtems/score/cpuimpl.h
index 570b5cc167..6665059fef 100644
--- a/cpukit/score/cpu/i386/include/rtems/score/cpuimpl.h
+++ b/cpukit/score/cpu/i386/include/rtems/score/cpuimpl.h
@@ -37,6 +37,8 @@
 extern "C" {
 #endif
   /* TODO */
diff --git a/cpukit/score/cpu/lm32/cpu.c b/cpukit/score/cpu/lm32/cpu.c
index cd2c4b055f..3301a3099b 100644
--- a/cpukit/score/cpu/lm32/cpu.c
+++ b/cpukit/score/cpu/lm32/cpu.c
@@ -20,6 +20,7 @@
 #include "config.h"
 #endif
 /*  _CPU_Initialize
@@ -45,6 +46,18 @@ void _CPU_Initialize(void)
   /* FP context initialization support goes here */
+  ISR_Level level;
+  (void) level;
+  while ( true ) {
+    /* Do nothing */
 uint32_t   _CPU_ISR_Get_level( void )
diff --git a/cpukit/score/cpu/lm32/include/rtems/score/cpu.h b/cpukit/score/cpu/lm32/include/rtems/score/cpu.h
index 29af53a53b..9bceb3b892 100644
--- a/cpukit/score/cpu/lm32/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/lm32/include/rtems/score/cpu.h
@@ -590,23 +590,6 @@ extern char _gp[];
diff --git a/cpukit/score/cpu/lm32/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/lm32/include/rtems/score/cpuimpl.h
index ab43ddbf7d..eb0c058723 100644
--- a/cpukit/score/cpu/lm32/include/rtems/score/cpuimpl.h
+++ b/cpukit/score/cpu/lm32/include/rtems/score/cpuimpl.h
@@ -34,6 +34,8 @@
 extern "C" {
 #endif
   /* TODO */
diff --git a/cpukit/score/cpu/m68k/cpu.c b/cpukit/score/cpu/m68k/cpu.c
index be63351e9c..e6a5c9dbf3 100644
--- a/cpukit/score/cpu/m68k/cpu.c
+++ b/cpukit/score/cpu/m68k/cpu.c
@@ -17,6 +17,7 @@
 #include "config.h"
 #endif
@@ -88,6 +89,29 @@ void _CPU_Initialize(void)
   m68k_install_interrupt_stack();
+#if ( defined(__mcoldfire__) )
+  __asm__ volatile( "move.w %%sr,%%d0\n\t"
+      	  "or.l %2,%%d0\n\t"
+      	  "move.w %%d0,%%sr\n\t"
+      	  "move.l %1,%%d0\n\t"
+      	  "move.l #0xDEADBEEF,%%d1\n\t"
+                "halt"
+      	  : "=g" (error)
+      	  : "0" (error), "d"(0x0700)
+      	  : "d0", "d1" );
+#else
+  __asm__ volatile( "movl  %0,%%d0; "
+                "orw   #0x0700,%%sr; "
+                "stop  #0x2700" : "=d" ((error)) : "0" ((error)) );
+#endif
   uint32_t   level;
diff --git a/cpukit/score/cpu/m68k/include/rtems/score/cpu.h b/cpukit/score/cpu/m68k/include/rtems/score/cpu.h
index 65ba0ef496..95e75ad1eb 100644
--- a/cpukit/score/cpu/m68k/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/m68k/include/rtems/score/cpu.h
@@ -401,35 +401,6 @@ void _CPU_Context_Initialize(
 void *_CPU_Thread_Idle_body( uintptr_t ignored );
-#if ( defined(__mcoldfire__) )
-  { __asm__ volatile( "move.w %%sr,%%d0\n\t" \
-		  "or.l %2,%%d0\n\t" \
-		  "move.w %%d0,%%sr\n\t" \
-		  "move.l %1,%%d0\n\t" \
-		  "move.l #0xDEADBEEF,%%d1\n\t" \
-                  "halt" \
-		  : "=g" (_error) \
-		  : "0" (_error), "d"(0x0700) \
-		  : "d0", "d1" ); \
-#else
-  { __asm__ volatile( "movl  %0,%%d0; " \
-                  "orw   #0x0700,%%sr; " \
-                  "stop  #0x2700" : "=d" ((_error)) : "0" ((_error)) ); \
-#endif
diff --git a/cpukit/score/cpu/m68k/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/m68k/include/rtems/score/cpuimpl.h
index dda5727142..833ff071b8 100644
--- a/cpukit/score/cpu/m68k/include/rtems/score/cpuimpl.h
+++ b/cpukit/score/cpu/m68k/include/rtems/score/cpuimpl.h
@@ -35,6 +35,8 @@
 extern "C" {
 #endif
   /* TODO */
diff --git a/cpukit/score/cpu/mips/cpu.c b/cpukit/score/cpu/mips/cpu.c
index c8cf960db5..8d1018dbf6 100644
--- a/cpukit/score/cpu/mips/cpu.c
+++ b/cpukit/score/cpu/mips/cpu.c
@@ -50,6 +50,7 @@
 #include "config.h"
 #endif
 #if CPU_HARDWARE_FP
@@ -93,6 +94,18 @@ void _CPU_Initialize(void)
 #endif
+  ISR_Level level;
+  (void) level;
+  while ( true ) {
+    /* Do nothing */
   unsigned int sr;
diff --git a/cpukit/score/cpu/mips/include/rtems/score/cpu.h b/cpukit/score/cpu/mips/include/rtems/score/cpu.h
index cdb0e64013..67d1465daa 100644
--- a/cpukit/score/cpu/mips/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/mips/include/rtems/score/cpu.h
@@ -710,23 +710,6 @@ void _CPU_Context_Initialize(
-  do { \
-    unsigned int _level; \
-    _CPU_ISR_Disable(_level); \
-    (void)_level; \
-    loop: goto loop; \
-  } while (0)
 extern void mips_break( int error );
diff --git a/cpukit/score/cpu/mips/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/mips/include/rtems/score/cpuimpl.h
index 932784fc8f..554d8be1c8 100644
--- a/cpukit/score/cpu/mips/include/rtems/score/cpuimpl.h
+++ b/cpukit/score/cpu/mips/include/rtems/score/cpuimpl.h
@@ -35,6 +35,8 @@
 extern "C" {
 #endif
   /* TODO */
diff --git a/cpukit/score/cpu/moxie/cpu.c b/cpukit/score/cpu/moxie/cpu.c
index 5522890c59..b4dad060b6 100644
--- a/cpukit/score/cpu/moxie/cpu.c
+++ b/cpukit/score/cpu/moxie/cpu.c
@@ -17,7 +17,9 @@
 #include "config.h"
 #endif
+#include <rtems/bspIo.h>
 /*  _CPU_Initialize
@@ -37,6 +39,12 @@ void _CPU_Initialize(void)
+  printk("Fatal Error %d.%lu Halted\n",source,error);
+  for(;;);
  *  _CPU_ISR_Get_level
diff --git a/cpukit/score/cpu/moxie/include/rtems/score/cpu.h b/cpukit/score/cpu/moxie/include/rtems/score/cpu.h
index 9959892689..a3991016f1 100644
--- a/cpukit/score/cpu/moxie/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/moxie/include/rtems/score/cpu.h
@@ -391,23 +391,6 @@ uint32_t   _CPU_ISR_Get_level( void );
- *  MOXIE Specific Information:
- *  XXX
-        printk("Fatal Error %d.%lu Halted\n",_source,_error); \
-        for(;;)
diff --git a/cpukit/score/cpu/moxie/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/moxie/include/rtems/score/cpuimpl.h
index 9c81cb6193..76068fe8b8 100644
--- a/cpukit/score/cpu/moxie/include/rtems/score/cpuimpl.h
+++ b/cpukit/score/cpu/moxie/include/rtems/score/cpuimpl.h
@@ -35,6 +35,8 @@
 extern "C" {
 #endif
   /* TODO */
diff --git a/cpukit/score/cpu/nios2/include/rtems/score/cpu.h b/cpukit/score/cpu/nios2/include/rtems/score/cpu.h
index 69c96280f4..c26e57f88b 100644
--- a/cpukit/score/cpu/nios2/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/nios2/include/rtems/score/cpu.h
@@ -290,8 +290,6 @@ void _CPU_Context_Initialize(
 #define _CPU_Context_Restart_self( _the_context ) \
   _CPU_Context_restore( (_the_context) );
-RTEMS_NO_RETURN void _CPU_Fatal_halt( uint32_t _source, uint32_t _error );
diff --git a/cpukit/score/cpu/nios2/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/nios2/include/rtems/score/cpuimpl.h
index e5f326eeb7..ad28960fe5 100644
--- a/cpukit/score/cpu/nios2/include/rtems/score/cpuimpl.h
+++ b/cpukit/score/cpu/nios2/include/rtems/score/cpuimpl.h
@@ -35,6 +35,8 @@
 extern "C" {
 #endif
diff --git a/cpukit/score/cpu/nios2/nios2-fatal-halt.c b/cpukit/score/cpu/nios2/nios2-fatal-halt.c
index 40cae874c0..e2ea8ef13d 100644
--- a/cpukit/score/cpu/nios2/nios2-fatal-halt.c
+++ b/cpukit/score/cpu/nios2/nios2-fatal-halt.c
@@ -11,10 +11,10 @@
  *  http://www.rtems.org/license/LICENSE.
 #include <rtems/score/nios2-utility.h>
-void _CPU_Fatal_halt( uint32_t _source, uint32_t _error )
+void _CPU_Fatal_halt( uint32_t _source, CPU_Uint32ptr _error )
   /* write 0 to status register (disable interrupts) */
   __builtin_wrctl( NIOS2_CTLREG_INDEX_STATUS, 0 );
diff --git a/cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h b/cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h
index c4cb512e20..e224a5e56e 100644
--- a/cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h
@@ -824,23 +824,6 @@ uint32_t   _CPU_ISR_Get_level( void );
 /* Bitfield handler macros */
diff --git a/cpukit/score/cpu/no_cpu/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/no_cpu/include/rtems/score/cpuimpl.h
index c8c86f4ec7..5f9196042c 100644
--- a/cpukit/score/cpu/no_cpu/include/rtems/score/cpuimpl.h
+++ b/cpukit/score/cpu/no_cpu/include/rtems/score/cpuimpl.h
@@ -83,6 +83,19 @@ register struct Per_CPU_Control *_CPU_Per_CPU_current asm( "rX" );
 #define _CPU_Get_thread_executing() ( _CPU_Per_CPU_current->executing )
+ * This routine copies _error into a known place -- typically a stack
+ * location or a register, optionally disables interrupts, and
+ * halts/stops the CPU.
+ * Port Specific Information:
+ * XXX document implementation including references if appropriate
  * @addtogroup RTEMSScoreCPUExampleContext
diff --git a/cpukit/score/cpu/or1k/cpu.c b/cpukit/score/cpu/or1k/cpu.c
index 79cb76812f..d030a0cab4 100644
--- a/cpukit/score/cpu/or1k/cpu.c
+++ b/cpukit/score/cpu/or1k/cpu.c
@@ -11,8 +11,8 @@
 /* bsp_start_vector_table_begin is the start address of the vector table
  * containing addresses to ISR Handlers. It's defined at the BSP linkcmds
@@ -28,6 +28,14 @@ void _CPU_Initialize(void)
   /* Do nothing */
+  _OR1KSIM_CPU_Halt();
+  for(;;);
  * @brief Sets the hardware interrupt level by the level value.
diff --git a/cpukit/score/cpu/or1k/include/rtems/score/cpu.h b/cpukit/score/cpu/or1k/include/rtems/score/cpu.h
index 5cd59df3f4..02a574affa 100644
--- a/cpukit/score/cpu/or1k/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/or1k/include/rtems/score/cpu.h
@@ -390,23 +390,6 @@ void _CPU_Context_Initialize(
-#include <inttypes.h>
-#define _CPU_Fatal_halt(_source, _error ) \
-        _OR1KSIM_CPU_Halt(); \
-        for(;;)
 #define CPU_USE_LIBC_INIT_FINI_ARRAY TRUE
diff --git a/cpukit/score/cpu/or1k/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/or1k/include/rtems/score/cpuimpl.h
index 76da91fdec..ace9273da9 100644
--- a/cpukit/score/cpu/or1k/include/rtems/score/cpuimpl.h
+++ b/cpukit/score/cpu/or1k/include/rtems/score/cpuimpl.h
@@ -35,6 +35,8 @@
 extern "C" {
 #endif
diff --git a/cpukit/score/cpu/powerpc/cpu.c b/cpukit/score/cpu/powerpc/cpu.c
index 1367d9d2c0..41f1c202cc 100644
--- a/cpukit/score/cpu/powerpc/cpu.c
+++ b/cpukit/score/cpu/powerpc/cpu.c
@@ -325,3 +325,17 @@ RTEMS_STATIC_ASSERT(
   sizeof(CPU_Exception_frame) + FRAME_LINK_SPACE <= PPC_EXC_FRAME_SIZE,
   CPU_Exception_frame
+  ppc_interrupt_disable();
+    "mr 3, %0\n"
+    "mr 4, %1\n"
+    "1:\n"
+    "b 1b\n"
+    : "r" (source), "r" (error)
+    : "memory"
diff --git a/cpukit/score/cpu/powerpc/include/rtems/score/cpu.h b/cpukit/score/cpu/powerpc/include/rtems/score/cpu.h
index ee02bd4ee4..9cb47bcaa6 100644
--- a/cpukit/score/cpu/powerpc/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/powerpc/include/rtems/score/cpu.h
@@ -613,20 +613,6 @@ void ppc_set_interrupt_level( uint32_t level );
 #endif /* ASM */
-  do { \
-    ppc_interrupt_disable(); \
-    __asm__ volatile ( \
-      "mr 3, %0\n" \
-      "mr 4, %1\n" \
-      "1:\n" \
-      "b 1b\n" \
-      : "r" (_source), "r" (_error) \
-      : "memory" \
-  } while ( 0 )
  *  Should be large enough to run all RTEMS tests.  This ensures
  *  that a "reasonable" small application should not have any problems.
diff --git a/cpukit/score/cpu/powerpc/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/powerpc/include/rtems/score/cpuimpl.h
index bd23602827..69eeeb183c 100644
--- a/cpukit/score/cpu/powerpc/include/rtems/score/cpuimpl.h
+++ b/cpukit/score/cpu/powerpc/include/rtems/score/cpuimpl.h
@@ -248,6 +248,8 @@ static inline struct Per_CPU_Control *_PPC_Get_current_per_CPU_control( void )
 #endif /* RTEMS_SMP */
diff --git a/cpukit/score/cpu/riscv/include/rtems/score/cpu.h b/cpukit/score/cpu/riscv/include/rtems/score/cpu.h
index 16dde8204c..3f3c8de74c 100644
--- a/cpukit/score/cpu/riscv/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/riscv/include/rtems/score/cpu.h
@@ -211,8 +211,6 @@ void _CPU_Context_Initialize(
 #define CPU_USE_GENERIC_BITFIELD_DATA TRUE
diff --git a/cpukit/score/cpu/riscv/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/riscv/include/rtems/score/cpuimpl.h
index c381cce110..eee6ad7328 100644
--- a/cpukit/score/cpu/riscv/include/rtems/score/cpuimpl.h
+++ b/cpukit/score/cpu/riscv/include/rtems/score/cpuimpl.h
@@ -408,6 +408,8 @@ static inline struct Per_CPU_Control *_RISCV_Get_current_per_CPU_control( void )
diff --git a/cpukit/score/cpu/sh/cpu.c b/cpukit/score/cpu/sh/cpu.c
index c10086534b..558f95be4d 100644
--- a/cpukit/score/cpu/sh/cpu.c
+++ b/cpukit/score/cpu/sh/cpu.c
@@ -30,9 +30,9 @@
 #include "config.h"
 #endif
 #include <rtems/score/sh_io.h>
 #include <rtems/score/sh.h>
 /* referenced in start.S */
@@ -76,6 +76,13 @@ void _CPU_Initialize(void)
   _CPU_ISR_Set_level( level ) ;
+  __asm__ volatile("mov.l %0,r0"::"m" (error));
+  __asm__ volatile("mov #1, r4");
+  __asm__ volatile("trapa #34");
diff --git a/cpukit/score/cpu/sh/include/rtems/score/cpu.h b/cpukit/score/cpu/sh/include/rtems/score/cpu.h
index 364a2bc310..2805e4244c 100644
--- a/cpukit/score/cpu/sh/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/sh/include/rtems/score/cpu.h
@@ -490,32 +490,6 @@ void _CPU_Context_Initialize(
- * FIXME: Trap32 ???
- *  invokes a Trap32 Instruction which returns to the breakpoint
- *  routine of cmon.
-#ifdef BSP_FATAL_HALT
-  /* we manage the fatal error in the board support package */
-  void bsp_fatal_halt( uint32_t   _error);
-#define _CPU_Fatal_halt( _source, _error ) bsp_fatal_halt( _error)
-#else
-#define _CPU_Fatal_halt( _source, _error)\
-  __asm__ volatile("mov.l %0,r0"::"m" (_error)); \
-  __asm__ volatile("mov #1, r4"); \
-  __asm__ volatile("trapa #34"); \
-#endif
diff --git a/cpukit/score/cpu/sh/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/sh/include/rtems/score/cpuimpl.h
index 6dcbc00f6b..745a185d1a 100644
--- a/cpukit/score/cpu/sh/include/rtems/score/cpuimpl.h
+++ b/cpukit/score/cpu/sh/include/rtems/score/cpuimpl.h
@@ -35,6 +35,8 @@
 extern "C" {
 #endif
   /* TODO */
diff --git a/cpukit/score/cpu/sparc/include/rtems/score/cpu.h b/cpukit/score/cpu/sparc/include/rtems/score/cpu.h
index 910ec83a87..af15f35b62 100644
--- a/cpukit/score/cpu/sparc/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/sparc/include/rtems/score/cpu.h
@@ -883,17 +883,6 @@ void _CPU_Context_Initialize(
   do { } while ( 0 )
diff --git a/cpukit/score/cpu/sparc/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/sparc/include/rtems/score/cpuimpl.h
index 8aa4030a45..14038cbdbe 100644
--- a/cpukit/score/cpu/sparc/include/rtems/score/cpuimpl.h
+++ b/cpukit/score/cpu/sparc/include/rtems/score/cpuimpl.h
@@ -199,6 +199,8 @@ register struct Per_CPU_Control *_SPARC_Per_CPU_current __asm__( "g6" );
 #define _CPU_Get_thread_executing() ( _SPARC_Per_CPU_current->executing )
diff --git a/cpukit/score/cpu/sparc64/cpu.c b/cpukit/score/cpu/sparc64/cpu.c
index 2d92aa7286..e8d6017d2c 100644
--- a/cpukit/score/cpu/sparc64/cpu.c
+++ b/cpukit/score/cpu/sparc64/cpu.c
@@ -16,6 +16,7 @@
 #include <rtems/rtems/cache.h>
@@ -63,6 +64,15 @@ void _CPU_Initialize(void)
   _CPU_ISR_Dispatch_disable = 0;
+  uint32_t   level;
+  level = sparc_disable_interrupts();
+  __asm__ volatile ( "mov  %0, %%g1 " : "=r" (level) : "0" (level) );
+  while (1); /* loop forever */
   Context_Control  *the_context,
   void         *stack_base,
diff --git a/cpukit/score/cpu/sparc64/include/rtems/score/cpu.h b/cpukit/score/cpu/sparc64/include/rtems/score/cpu.h
index 3c41a922e7..1d8813da35 100644
--- a/cpukit/score/cpu/sparc64/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/sparc64/include/rtems/score/cpu.h
@@ -769,25 +769,6 @@ void _CPU_Context_Initialize(
-  do { \
-    uint32_t   level; \
-    level = sparc_disable_interrupts(); \
-    __asm__ volatile ( "mov  %0, %%g1 " : "=r" (level) : "0" (level) ); \
-    while (1); /* loop forever */ \
-  } while (0)
diff --git a/cpukit/score/cpu/sparc64/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/sparc64/include/rtems/score/cpuimpl.h
index e137756e62..521612d555 100644
--- a/cpukit/score/cpu/sparc64/include/rtems/score/cpuimpl.h
+++ b/cpukit/score/cpu/sparc64/include/rtems/score/cpuimpl.h
@@ -35,6 +35,8 @@
 extern "C" {
 #endif
   /* TODO */
diff --git a/cpukit/score/cpu/v850/cpu.c b/cpukit/score/cpu/v850/cpu.c
index a921775413..d659d9257e 100644
--- a/cpukit/score/cpu/v850/cpu.c
+++ b/cpukit/score/cpu/v850/cpu.c
@@ -17,6 +17,7 @@
 #include "config.h"
 #endif
 #include <string.h> /* for memset */
@@ -30,6 +31,13 @@ void _CPU_Initialize(void)
+  __asm__ __volatile__ ( "di" );
+  __asm__ __volatile__ ( "mov %0, r10; " : "=r" ((error)) );
+  __asm__ __volatile__ ( "halt" );
  *  v850 Specific Information:
diff --git a/cpukit/score/cpu/v850/include/rtems/score/cpu.h b/cpukit/score/cpu/v850/include/rtems/score/cpu.h
index 1921216e2d..6bf69de3e6 100644
--- a/cpukit/score/cpu/v850/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/v850/include/rtems/score/cpu.h
@@ -461,26 +461,6 @@ void _CPU_Context_Initialize(
- * Move the error code into r10, disable interrupts and halt.
-  do { \
-    __asm__ __volatile__ ( "di" ); \
-    __asm__ __volatile__ ( "mov %0, r10; " : "=r" ((_error)) ); \
-    __asm__ __volatile__ ( "halt" ); \
-  } while (0)
diff --git a/cpukit/score/cpu/v850/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/v850/include/rtems/score/cpuimpl.h
index f7b02ccb6b..2e95738ed6 100644
--- a/cpukit/score/cpu/v850/include/rtems/score/cpuimpl.h
+++ b/cpukit/score/cpu/v850/include/rtems/score/cpuimpl.h
@@ -35,6 +35,8 @@
 extern "C" {
 #endif
   /* TODO */
diff --git a/cpukit/score/cpu/x86_64/cpu.c b/cpukit/score/cpu/x86_64/cpu.c
index 6846c431ef..0ad2d1ff3c 100644
--- a/cpukit/score/cpu/x86_64/cpu.c
+++ b/cpukit/score/cpu/x86_64/cpu.c
@@ -37,6 +37,7 @@
 #include "config.h"
 #endif
 #include <rtems/score/idt.h>
@@ -48,3 +49,15 @@ void _CPU_Exception_frame_print(const CPU_Exception_frame *ctx)
+  ISR_Level level;
+  (void) level;
+  while ( true ) {
+    /* Do nothing */
diff --git a/cpukit/score/cpu/x86_64/include/rtems/score/cpu.h b/cpukit/score/cpu/x86_64/include/rtems/score/cpu.h
index 056c0224a9..bea8e05e39 100644
--- a/cpukit/score/cpu/x86_64/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/x86_64/include/rtems/score/cpu.h
@@ -232,14 +232,6 @@ void _CPU_Context_Initialize(
diff --git a/cpukit/score/cpu/x86_64/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/x86_64/include/rtems/score/cpuimpl.h
index 1730799952..d3a4b848e6 100644
--- a/cpukit/score/cpu/x86_64/include/rtems/score/cpuimpl.h
+++ b/cpukit/score/cpu/x86_64/include/rtems/score/cpuimpl.h
@@ -38,6 +38,8 @@
 extern "C" {
 #endif
   /* TODO */
diff --git a/cpukit/score/src/interr.c b/cpukit/score/src/interr.c
index fd5a4c92b8..0b4ad1f7f9 100644
--- a/cpukit/score/src/interr.c
+++ b/cpukit/score/src/interr.c
@@ -21,6 +21,7 @@
 #endif
 #include <rtems/score/interr.h>
 #include <rtems/score/smpimpl.h>
 #include <rtems/score/sysstate.h>
 #include <rtems/score/userextimpl.h>
@@ -36,9 +37,6 @@ void _Terminate(
   _System_state_Set( SYSTEM_STATE_TERMINATED );
   _SMP_Request_shutdown();
   _CPU_Fatal_halt( the_source, the_error );
-  /* will not return from this routine */
-  while (true);
 void _Internal_error( Internal_errors_Core_list core_error )
2.26.2
