[PATCH 4/4] score: Move per-CPU jobs support
Thu Jul 29 00:44:52 UTC 2021
On 28/7/21 9:18 pm, Sebastian Huber wrote:
> Add percpujobs.c to contain the per-CPU jobs implementation.
>  cpukit/Makefile.am                    |   1 +
>  cpukit/score/src/percpujobs.c         | 124 ++++++++++++++++++++++++++
>  cpukit/score/src/smpmulticastaction.c |  89 +-----------------
>  spec/build/cpukit/objsmp.yml          |   4 +-
>  4 files changed, 130 insertions(+), 88 deletions(-)
>  create mode 100644 cpukit/score/src/percpujobs.c
> diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
> index c83167668d..5673c4e8fb 100644
> --- a/cpukit/Makefile.am
> +++ b/cpukit/Makefile.am
> @@ -1150,6 +1150,7 @@ endif
>  if HAS_SMP
> +librtemscpu_a_SOURCES += score/src/percpujobs.c
>  librtemscpu_a_SOURCES += score/src/percpustatewait.c
>  librtemscpu_a_SOURCES += score/src/profilingsmplock.c
>  librtemscpu_a_SOURCES += score/src/schedulerdefaultpinunpin.c
> diff --git a/cpukit/score/src/percpujobs.c b/cpukit/score/src/percpujobs.c
> new file mode 100644
> index 0000000000..4ce96dc738
> --- /dev/null
> +++ b/cpukit/score/src/percpujobs.c
> @@ -0,0 +1,124 @@
> +/* SPDX-License-Identifier: BSD-2-Clause */
> + * @file
> + * @ingroup RTEMSScorePerCPU
> + * @brief This source file contains the implementation of _Per_CPU_Add_job(),
> + *   _Per_CPU_Perform_jobs(), and _Per_CPU_Wait_for_job().
> + * Copyright (C) 2019 embedded brains GmbH
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + *    notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + *    notice, this list of conditions and the following disclaimer in the
> + *    documentation and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> + * POSSIBILITY OF SUCH DAMAGE.
> +#ifdef HAVE_CONFIG_H
> +#include "config.h"
> +#endif
> +#include <rtems/score/smpimpl.h>
> +#include <rtems/score/assert.h>
> +#define _Per_CPU_Jobs_ISR_disable_and_acquire( cpu, lock_context ) \
> +  _ISR_lock_ISR_disable_and_acquire( &( cpu )->Jobs.Lock, lock_context )
> +#define _Per_CPU_Jobs_release_and_ISR_enable( cpu, lock_context ) \
> +  _ISR_lock_Release_and_ISR_enable( &( cpu )->Jobs.Lock, lock_context )
> +void _Per_CPU_Perform_jobs( Per_CPU_Control *cpu )
> +  ISR_lock_Context  lock_context;
> +  Per_CPU_Job      *job;
> +  _Per_CPU_Jobs_ISR_disable_and_acquire( cpu, &lock_context );
> +  job = cpu->Jobs.head;
> +  cpu->Jobs.head = NULL;
> +  _Per_CPU_Jobs_release_and_ISR_enable( cpu, &lock_context );
> +  while ( job != NULL ) {
> +    const Per_CPU_Job_context *context;
> +    Per_CPU_Job               *next;
> +    context = job->context;
> +    next = job->next;
> +    ( *context->handler )( context->arg );
> +    _Atomic_Store_ulong( &job->done, PER_CPU_JOB_DONE, ATOMIC_ORDER_RELEASE );
> +    job = next;
> +void _Per_CPU_Add_job( Per_CPU_Control *cpu, Per_CPU_Job *job )
> +  _Atomic_Store_ulong( &job->done, 0, ATOMIC_ORDER_RELAXED );
> +  _Assert( job->next == NULL );
Given the dispatch does not check the handler is adding ...
 _Assert( job->context->handler != NULL );
worth doing ?
> +  if ( cpu->Jobs.head == NULL ) {
> +    cpu->Jobs.head = job;
> +  } else {
> +    *cpu->Jobs.tail = job;
> +  cpu->Jobs.tail = &job->next;
> +void _Per_CPU_Wait_for_job(
> +  const Per_CPU_Control *cpu,
> +  const Per_CPU_Job     *job
> +  while (
> +    _Atomic_Load_ulong( &job->done, ATOMIC_ORDER_ACQUIRE )
> +      != PER_CPU_JOB_DONE
> +    Per_CPU_Control *cpu_self;
> +    switch ( _Per_CPU_Get_state( cpu ) ) {
> +      case PER_CPU_STATE_INITIAL:
> +      case PER_CPU_STATE_READY_TO_START_MULTITASKING:
> +      case PER_CPU_STATE_UP:
> +         * Calling this function with the current processor is intentional.  We
> +         * have to perform our own jobs here in case inter-processor interrupts
> +         * are not working.
> +        cpu_self = _Per_CPU_Get();
> +        _SMP_Try_to_process_message(
> +          cpu_self,
> +          _Atomic_Load_ulong( &cpu_self->message, ATOMIC_ORDER_RELAXED )
> +        break;
> +      default:
> +        _SMP_Fatal( SMP_FATAL_WRONG_CPU_STATE_TO_PERFORM_JOBS );
> +        break;
> diff --git a/cpukit/score/src/smpmulticastaction.c b/cpukit/score/src/smpmulticastaction.c
> index 8dbdef80c7..03d9e064fe 100644
> --- a/cpukit/score/src/smpmulticastaction.c
> +++ b/cpukit/score/src/smpmulticastaction.c
> @@ -3,12 +3,11 @@
>   * @file
> - * @ingroup RTEMSScorePerCPU
>   * @ingroup RTEMSScoreSMP
> - * @brief This source file contains the implementation of _Per_CPU_Add_job(),
> - *   _Per_CPU_Perform_jobs(), _Per_CPU_Wait_for_job(), _SMP_Broadcast_action(),
> - *   _SMP_Multicast_action(), _SMP_Othercast_action(), and _SMP_Synchronize().
> + *   _SMP_Broadcast_action(), _SMP_Multicast_action(), _SMP_Othercast_action(),
> + *   and _SMP_Synchronize().
> @@ -43,88 +42,6 @@
> -#define _Per_CPU_Jobs_ISR_disable_and_acquire( cpu, lock_context ) \
> -  _ISR_lock_ISR_disable_and_acquire( &( cpu )->Jobs.Lock, lock_context )
> -#define _Per_CPU_Jobs_release_and_ISR_enable( cpu, lock_context ) \
> -  _ISR_lock_Release_and_ISR_enable( &( cpu )->Jobs.Lock, lock_context )
> -void _Per_CPU_Perform_jobs( Per_CPU_Control *cpu )
> -  ISR_lock_Context  lock_context;
> -  Per_CPU_Job      *job;
> -  _Per_CPU_Jobs_ISR_disable_and_acquire( cpu, &lock_context );
> -  job = cpu->Jobs.head;
> -  cpu->Jobs.head = NULL;
> -  _Per_CPU_Jobs_release_and_ISR_enable( cpu, &lock_context );
> -  while ( job != NULL ) {
> -    const Per_CPU_Job_context *context;
> -    Per_CPU_Job               *next;
> -    context = job->context;
> -    next = job->next;
> -    ( *context->handler )( context->arg );
> -    _Atomic_Store_ulong( &job->done, PER_CPU_JOB_DONE, ATOMIC_ORDER_RELEASE );
> -    job = next;
> -void _Per_CPU_Add_job( Per_CPU_Control *cpu, Per_CPU_Job *job )
> -  _Atomic_Store_ulong( &job->done, 0, ATOMIC_ORDER_RELAXED );
> -  _Assert( job->next == NULL );
> -  if ( cpu->Jobs.head == NULL ) {
> -    cpu->Jobs.head = job;
> -  } else {
> -    *cpu->Jobs.tail = job;
> -  cpu->Jobs.tail = &job->next;
> -void _Per_CPU_Wait_for_job(
> -  const Per_CPU_Control *cpu,
> -  const Per_CPU_Job     *job
> -  while (
> -    _Atomic_Load_ulong( &job->done, ATOMIC_ORDER_ACQUIRE )
> -      != PER_CPU_JOB_DONE
> -    Per_CPU_Control *cpu_self;
> -    switch ( _Per_CPU_Get_state( cpu ) ) {
> -      case PER_CPU_STATE_INITIAL:
> -      case PER_CPU_STATE_READY_TO_START_MULTITASKING:
> -      case PER_CPU_STATE_UP:
> -         * Calling this function with the current processor is intentional.  We
> -         * have to perform our own jobs here in case inter-processor interrupts
> -         * are not working.
> -        cpu_self = _Per_CPU_Get();
> -        _SMP_Try_to_process_message(
> -          cpu_self,
> -          _Atomic_Load_ulong( &cpu_self->message, ATOMIC_ORDER_RELAXED )
> -        break;
> -      default:
> -        _SMP_Fatal( SMP_FATAL_WRONG_CPU_STATE_TO_PERFORM_JOBS );
> -        break;
>  typedef struct {
>    Per_CPU_Job_context Context;
>    Per_CPU_Job         Jobs[ CPU_MAXIMUM_PROCESSORS ];
> diff --git a/spec/build/cpukit/objsmp.yml b/spec/build/cpukit/objsmp.yml
> index 1eb1faa3d6..992ed50666 100644
> --- a/spec/build/cpukit/objsmp.yml
> +++ b/spec/build/cpukit/objsmp.yml
> @@ -5,12 +5,12 @@ copyrights:
>  - Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
>  cppflags: []
>  cxxflags: []
> -enabled-by:
> -- RTEMS_SMP
> +enabled-by: RTEMS_SMP
>  includes: []
>  install: []
>  links: []
>  source:
> +- cpukit/score/src/percpujobs.c
>  - cpukit/score/src/percpustatewait.c
>  - cpukit/score/src/profilingsmplock.c
>  - cpukit/score/src/schedulerdefaultaskforhelp.c
