[PATCH rtems-libbsd v2 2/5] usb_template: Configure template driver only for CDC Ethernet
Christian MAUDERER
christian.mauderer at embedded-brains.de
Thu Jul 29 06:20:44 UTC 2021
Hello Chris,
Am 29.07.21 um 02:07 schrieb Chris Johns:
> On 29/7/21 1:10 am, Ahamed Husni wrote:
>> On Wed, 28 Jul 2021, 17:27 Husni Faiz, <ahamedhusni73 at gmail.com
>> <mailto:ahamedhusni73 at gmail.com>> wrote:
>> Add the conditional macro to prevent the driver from referencing
>> the templates which are not imported yet.
>> Include functions which adds the hw.usb.template sysctl variable.
>> Signed-off-by: Husni Faiz <ahamedhusni73 at gmail.com
>> freebsd/sys/dev/usb/template/usb_template.c | 4 ++++
>> freebsd/sys/dev/usb/usb_device.c | 8 ++++++--
>> 2 files changed, 10 insertions(+), 2 deletions(-)
>> diff --git a/freebsd/sys/dev/usb/template/usb_template.c
>> b/freebsd/sys/dev/usb/template/usb_template.c
>> index 0650da15..76567e85 100644
>> --- a/freebsd/sys/dev/usb/template/usb_template.c
>> +++ b/freebsd/sys/dev/usb/template/usb_template.c
>> @@ -1433,12 +1433,15 @@ usb_temp_setup_by_index(struct usb_device *udev,
>> uint16_t index)
>> usb_error_t err;
>> switch (index) {
>> +#ifndef __rtems__
>> case USB_TEMP_MSC:
>> err = usb_temp_setup(udev, &usb_template_msc);
>> break;
>> +#endif /* __rtems__ */
>> case USB_TEMP_CDCE:
>> err = usb_temp_setup(udev, &usb_template_cdce);
>> break;
>> +#ifndef __rtems__
>> case USB_TEMP_MTP:
>> err = usb_temp_setup(udev, &usb_template_mtp);
>> break;
>> @@ -1469,6 +1472,7 @@ usb_temp_setup_by_index(struct usb_device *udev,
>> uint16_t index)
>> case USB_TEMP_CDCEEM:
>> err = usb_temp_setup(udev, &usb_template_cdceem);
>> break;
>> default:
>> return (USB_ERR_INVAL);
>> diff --git a/freebsd/sys/dev/usb/usb_device.c b/freebsd/sys/dev/usb/usb_device.c
>> index ee240949..619cae5a 100644
>> --- a/freebsd/sys/dev/usb/usb_device.c
>> +++ b/freebsd/sys/dev/usb/usb_device.c
>> @@ -28,6 +28,10 @@
>> * SUCH DAMAGE.
>> +#ifdef __rtems__
>> +#include <rtems/bsd/modules.h>
>> +#endif
>> #ifdef USB_GLOBAL_INCLUDE_FILE
>> #include USB_GLOBAL_INCLUDE_FILE
>> #else
>> @@ -123,7 +127,7 @@ int usb_template = USB_TEMPLATE;
>> int usb_template = -1;
>> #endif
>> -#ifndef __rtems__
>> +#if !defined(__rtems__) || defined(RTEMS_BSD_MODULE_DEV_USB_TEMPLATE)
> Is doing this supported by the freebsd-to-rtems.py script?
I sure hope that it is. I know that I used similar constructions in the
past and it seems that I'm not the only one, because I'm sure that I
haven't touched some of these files:
freebsd/crypto/openssl/crypto/init.c:188:# elif !defined(DSO_NONE) &&
!defined(__rtems__)
freebsd/crypto/openssl/crypto/arm_arch.h:13:#if defined(__rtems__) &&
defined(__arm__)
freebsd/contrib/wpa/src/utils/os_unix.c:236:#if defined(__uClinux__) ||
defined(__sun__) || defined(__rtems__)
freebsd/sbin/ping6/ping6.c:74:#if defined(__rtems__) && defined(INET6)
freebsd/sbin/ping6/ping6.c:2935:#endif /* defined(__rtems__) &&
defined(INET6) */
freebsd/sys/net/bpf.h:49:#if defined(__rtems__) && !defined(__FreeBSD__)
freebsd/sys/net/bpf.h:51:#endif /* defined(__rtems__) &&
!defined(__FreeBSD__) */
freebsd/sys/cam/cam_debug.h:49:#if defined(_KERNEL) && !defined(__rtems__)
freebsd/sys/dev/e1000/e1000_osdep.h:256:#if defined(INVARIANTS) &&
!defined(__rtems__)
freebsd/sys/dev/rtwn/usb/rtwn_usb_tx.c:177:#if defined(__rtems__) &&
defined(CPU_DATA_CACHE_ALIGNMENT)
freebsd/sys/dev/rtwn/usb/rtwn_usb_attach.c:122:#if defined(__rtems__) &&
freebsd/sys/dev/pci/pci.c:5403:#if defined(__rtems__) && defined(__i386__)
freebsd/sys/dev/extres/regulator/regulator.c:54:#if !defined(__rtems__)
|| defined(FDT)
freebsd/sys/dev/gpio/ofw_gpiobus.c:46:#if defined(__rtems__) && defined(FDT)
freebsd/sys/dev/usb/usb_busdma.c:549:#if defined(__rtems__) &&
freebsd/sys/dev/usb/usb_busdma.c:599:#if !defined(__rtems__) ||
USB_NEED_BUSDMA_COHERENT_ALLOC
freebsd/sys/dev/usb/usb_busdma.c:620:#if defined(__rtems__) &&
freebsd/sys/contrib/ck/include/gcc/arm/ck_pr.h:63:#if
defined(__FreeBSD__) && !defined(__rtems__)
freebsd/sys/kern/subr_sleepqueue.c:152:#if defined(__rtems__) &&
defined(RTEMS_SMP)
freebsd/sys/kern/subr_sbuf.c:611:#if defined(_KERNEL) && !defined(__rtems__)
freebsd/sys/kern/kern_timeout.c:46:#if defined(__arm__) ||
defined(__rtems__)
freebsd/sys/sys/sigio.h:69:#elif defined(__rtems__) && defined(_KERNEL)
freebsd/sys/sys/mbuf.h:351:#if defined(__rtems__) && !defined(__i386__)
dhcpcd/dhcp6.c:33:#if defined(__rtems__) && defined(INET6)
dhcpcd/dhcp6.c:2816:#endif /* defined(__rtems__) && defined(INET6) */
dhcpcd/ipv6.c:31:#if defined(__rtems__) && defined(INET6)
dhcpcd/ipv6.c:1052:#endif /* defined(__rtems__) && defined(INET6) */
dhcpcd/ipv6nd.c:31:#if defined(__rtems__) && defined(INET6)
dhcpcd/ipv6nd.c:1840:#endif /* defined(__rtems__) && defined(INET6) */
rtemsbsd/nfsclient/nfs_prot_xdr.c:17: #if !defined(__rtems__)
rtemsbsd/sys/arm/at91/at91_mci.c:73:#if defined(__rtems__) &&
defined(LIBBSP_ARM_ATSAM_BSP_H)
freebsd-org/contrib/libstdc++/config/cpu/m68k/atomicity.h:53:#elif
defined(__rtems__)
freebsd-org/contrib/compiler-rt/lib/ubsan/ubsan_platform.h:20:
defined(_WIN32) || defined(__Fuchsia__) || defined(__rtems__)
freebsd-org/contrib/compiler-rt/lib/sanitizer_common/sanitizer_platform.h:18:
!defined(__Fuchsia__) && !defined(__rtems__) && \
freebsd-org/contrib/compiler-rt/lib/sanitizer_common/sanitizer_platform.h:108:#if
defined(__rtems__)
(Hope that get's through the mail well enoguth that it is readable. If
not: Just grep for "defined(__rtems__)" yourself.)
I don't think that our script touches the "#ifdef(__rtems__)" except
maybe in some special header cases, does it? I thought that's basically
how the rebase works: Just copying all that stuff unchanged to
freebsd-org and then do a rebase with all changes. The guards are more
or less to make it simpler to see what's been added by RTEMS.
Best regards
Christian
> Why is the RTEMS_BSD_MODULE_DEV_USB_TEMPLATE needed? >
>> SYSCTL_PROC(_hw_usb, OID_AUTO, template,
>> CTLTYPE_INT | CTLFLAG_RWTUN | CTLFLAG_MPSAFE,
>> NULL, 0, sysctl_hw_usb_template,
>> @@ -255,7 +259,7 @@ sysctl_hw_usb_template(SYSCTL_HANDLER_ARGS)
>> return (0);
>> -#endif /* __rtems__ */
>> +#endif /* !__rtmes__ || RTEMS_BSD_MODULE_DEV_USB_TEMPLATE */
>> Ah, a typo here (rtmes). Should I send a new set of patches?
> Yes it needs to be correct for the script to work but I would check the
> freebsd-to-rtems.py script works with these guard comments.
> Chris
> devel mailing list
> devel at rtems.org
embedded brains GmbH
Herr Christian MAUDERER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 18
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
