[PATCH rtems-libbsd v2 2/5] usb_template: Configure template driver only for CDC Ethernet
Thu Jul 29 08:40:34 UTC 2021
On 29/7/21 4:20 pm, Christian MAUDERER wrote:
> Hello Chris,
> Am 29.07.21 um 02:07 schrieb Chris Johns:
>> On 29/7/21 1:10 am, Ahamed Husni wrote:
>>> On Wed, 28 Jul 2021, 17:27 Husni Faiz, <ahamedhusni73 at gmail.com
>>> <mailto:ahamedhusni73 at gmail.com>> wrote:
>>>      Add the conditional macro to prevent the driver from referencing
>>>      the templates which are not imported yet.
>>>      Include functions which adds the hw.usb.template sysctl variable.
>>>      Signed-off-by: Husni Faiz <ahamedhusni73 at gmail.com
>>>       freebsd/sys/dev/usb/template/usb_template.c | 4 ++++
>>>       freebsd/sys/dev/usb/usb_device.c            | 8 ++++++--
>>>       2 files changed, 10 insertions(+), 2 deletions(-)
>>>      diff --git a/freebsd/sys/dev/usb/template/usb_template.c
>>>      b/freebsd/sys/dev/usb/template/usb_template.c
>>>      index 0650da15..76567e85 100644
>>>      --- a/freebsd/sys/dev/usb/template/usb_template.c
>>>      +++ b/freebsd/sys/dev/usb/template/usb_template.c
>>>      @@ -1433,12 +1433,15 @@ usb_temp_setup_by_index(struct usb_device *udev,
>>>      uint16_t index)
>>>              usb_error_t err;
>>>              switch (index) {
>>>      +#ifndef __rtems__
>>>              case USB_TEMP_MSC:
>>>                      err = usb_temp_setup(udev, &usb_template_msc);
>>>                      break;
>>>      +#endif /* __rtems__ */
>>>              case USB_TEMP_CDCE:
>>>                      err = usb_temp_setup(udev, &usb_template_cdce);
>>>                      break;
>>>      +#ifndef __rtems__
>>>              case USB_TEMP_MTP:
>>>                      err = usb_temp_setup(udev, &usb_template_mtp);
>>>                      break;
>>>      @@ -1469,6 +1472,7 @@ usb_temp_setup_by_index(struct usb_device *udev,
>>>      uint16_t index)
>>>              case USB_TEMP_CDCEEM:
>>>                      err = usb_temp_setup(udev, &usb_template_cdceem);
>>>                      break;
>>>              default:
>>>                      return (USB_ERR_INVAL);
>>>      diff --git a/freebsd/sys/dev/usb/usb_device.c
>>> b/freebsd/sys/dev/usb/usb_device.c
>>>      index ee240949..619cae5a 100644
>>>      --- a/freebsd/sys/dev/usb/usb_device.c
>>>      +++ b/freebsd/sys/dev/usb/usb_device.c
>>>      @@ -28,6 +28,10 @@
>>>        * SUCH DAMAGE.
>>>      +#ifdef __rtems__
>>>      +#include <rtems/bsd/modules.h>
>>>      +#endif
>>>       #ifdef USB_GLOBAL_INCLUDE_FILE
>>>       #include USB_GLOBAL_INCLUDE_FILE
>>>       #else
>>>      @@ -123,7 +127,7 @@ int usb_template = USB_TEMPLATE;
>>>       int    usb_template = -1;
>>>       #endif
>>>      -#ifndef __rtems__
>>>      +#if !defined(__rtems__) || defined(RTEMS_BSD_MODULE_DEV_USB_TEMPLATE)
>> Is doing this supported by the freebsd-to-rtems.py script?
> I sure hope that it is. I know that I used similar constructions in the past and
> it seems that I'm not the only one, because I'm sure that I haven't touched some
> of these files:
Hmm I thought this was being handled but it seems it is not.
> (Hope that get's through the mail well enoguth that it is readable. If not: Just
> grep for "defined(__rtems__)" yourself.)
> I don't think that our script touches the "#ifdef(__rtems__)" except maybe in
> some special header cases, does it? I thought that's basically how the rebase
> works: Just copying all that stuff unchanged to freebsd-org and then do a rebase
> with all changes. The guards are more or less to make it simpler to see what's
> been added by RTEMS.
Yes.
