[PATCH v1 1/2] rtemsbd: Remove machine dependent files and use the ones from freebsd
Christian Mauderer
oss at c-mauderer.de
Tue Jun 1 17:57:43 UTC 2021
Hello Gedare and Jan,
On 01/06/2021 19:16, Gedare Bloom wrote:
> Someone needs to check this wrt libbsd way of importing code.
> Something about this looks off, but I haven't much experience with
> libbsd code import. I think the import should be first "clean" from
> upstream, followed by the tailoring for RTEMS?
Yes, that's correct. The best case is a clean "import only" commit
followed by one making the necessary changes. Reason for that is that it
makes it a lot simpler to track down changes in case there are problems
during an update to a newer BSD version.
I haven't checked but I think most files are only imported without changes?
If there is no reason like "it doesn't compile" it would be good to move
the changes from rtemsbsd into a separate commit.
> On Mon, May 10, 2021 at 11:26 AM Jan Sommer <jan.sommer at dlr.de> wrote:
>> - Remove cpufunc.h, bus.h and _bus.h from rtemsbd. Otherwise the same
>> files will be installed for all target architectures which can lead to
>> incompatibilities
>> - Instead use the machine dependent header files from freebsd
>> freebsd/sys/arm/include/machine/_bus.h | 47 +
>> freebsd/sys/arm/include/machine/bus.h | 769 ++++++++++++++++
>> freebsd/sys/arm64/include/machine/_bus.h | 46 +
>> freebsd/sys/arm64/include/machine/bus.h | 469 ++++++++++
>> freebsd/sys/powerpc/include/machine/_bus.h | 50 +
>> freebsd/sys/powerpc/include/machine/bus.h | 467 ++++++++++
>> freebsd/sys/riscv/include/machine/_bus.h | 46 +
>> freebsd/sys/riscv/include/machine/bus.h | 469 ++++++++++
>> freebsd/sys/riscv/include/machine/cpufunc.h | 135 +++
>> freebsd/sys/riscv/include/machine/riscvreg.h | 246 +++++
>> .../sys/sparc}/include/machine/_bus.h | 0
>> .../sys/sparc}/include/machine/bus.h | 0
>> freebsd/sys/sparc/include/machine/cpufunc.h | 0
>> freebsd/sys/sparc64/include/machine/_bus.h | 41 +
>> freebsd/sys/sparc64/include/machine/bus.h | 852 ++++++++++++++++++
>> rtemsbsd/include/machine/cpufunc.h | 1 -
>> 16 files changed, 3637 insertions(+), 1 deletion(-)
>> create mode 100644 freebsd/sys/arm/include/machine/_bus.h
>> create mode 100644 freebsd/sys/arm/include/machine/bus.h
>> create mode 100644 freebsd/sys/arm64/include/machine/_bus.h
>> create mode 100644 freebsd/sys/arm64/include/machine/bus.h
>> create mode 100644 freebsd/sys/powerpc/include/machine/_bus.h
>> create mode 100644 freebsd/sys/powerpc/include/machine/bus.h
>> create mode 100644 freebsd/sys/riscv/include/machine/_bus.h
>> create mode 100644 freebsd/sys/riscv/include/machine/bus.h
>> create mode 100644 freebsd/sys/riscv/include/machine/cpufunc.h
>> create mode 100644 freebsd/sys/riscv/include/machine/riscvreg.h
>> rename {rtemsbsd => freebsd/sys/sparc}/include/machine/_bus.h (100%)
>> rename {rtemsbsd => freebsd/sys/sparc}/include/machine/bus.h (100%)
>> create mode 100644 freebsd/sys/sparc/include/machine/cpufunc.h
>> create mode 100644 freebsd/sys/sparc64/include/machine/_bus.h
>> create mode 100644 freebsd/sys/sparc64/include/machine/bus.h
>> delete mode 100644 rtemsbsd/include/machine/cpufunc.h
>> diff --git a/freebsd/sys/arm/include/machine/_bus.h b/freebsd/sys/arm/include/machine/_bus.h
>> new file mode 100644
>> index 00000000..9bb51e98
>> --- /dev/null
>> +++ b/freebsd/sys/arm/include/machine/_bus.h
>> @@ -0,0 +1,47 @@
>> + * SPDX-License-Identifier: BSD-2-Clause-FreeBSD
>> + * Copyright (c) 2005 M. Warner Losh.
>> + * Redistribution and use in source and binary forms, with or without
>> + * modification, are permitted provided that the following conditions
>> + * are met:
>> + * 1. Redistributions of source code must retain the above copyright
>> + * notice, this list of conditions, and the following disclaimer,
>> + * without modification, immediately at the beginning of the file.
>> + * 2. Redistributions in binary form must reproduce the above copyright
>> + * notice, this list of conditions and the following disclaimer in
>> + * the documentation and/or other materials provided with the
>> + * distribution.
>> + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
>> + * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
>> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
>> + * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE FOR
>> + * ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
>> + * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
>> + * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
>> + * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
>> + * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
>> + * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
>> + * SUCH DAMAGE.
>> + * $FreeBSD$
>> +#ifndef ARM_INCLUDE__BUS_H
>> +#define ARM_INCLUDE__BUS_H
>> + * Addresses (in bus space).
>> +typedef u_long bus_addr_t;
>> +typedef u_long bus_size_t;
>> + * Access methods for bus space.
>> +typedef struct bus_space *bus_space_tag_t;
>> +typedef u_long bus_space_handle_t;
>> +#endif /* ARM_INCLUDE__BUS_H */
>> diff --git a/freebsd/sys/arm/include/machine/bus.h b/freebsd/sys/arm/include/machine/bus.h
>> index 00000000..37994f68
>> --- /dev/null
>> +++ b/freebsd/sys/arm/include/machine/bus.h
>> @@ -0,0 +1,769 @@
>> +/* $NetBSD: bus.h,v 1.11 2003/07/28 17:35:54 thorpej Exp $ */
>> + * Copyright (c) 1996, 1997, 1998, 2001 The NetBSD Foundation, Inc.
>> + * All rights reserved.
>> + * This code is derived from software contributed to The NetBSD Foundation
>> + * by Jason R. Thorpe of the Numerical Aerospace Simulation Facility,
>> + * NASA Ames Research Center.
>> + * are met:
>> + * notice, this list of conditions and the following disclaimer.
>> + * notice, this list of conditions and the following disclaimer in the
>> + * documentation and/or other materials provided with the distribution.
>> + * THIS SOFTWARE IS PROVIDED BY THE NETBSD FOUNDATION, INC. AND CONTRIBUTORS
>> + * ``AS IS'' AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
>> + * TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
>> + * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE FOUNDATION OR CONTRIBUTORS
>> + * BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
>> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
>> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
>> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
>> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
>> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
>> + * POSSIBILITY OF SUCH DAMAGE.
>> + * SPDX-License-Identifier: BSD-4-Clause
>> + * Copyright (c) 1996 Charles M. Hannum. All rights reserved.
>> + * Copyright (c) 1996 Christopher G. Demetriou. All rights reserved.
>> + * are met:
>> + * 3. All advertising materials mentioning features or use of this software
>> + * must display the following acknowledgement:
>> + * This product includes software developed by Christopher G. Demetriou
>> + * for the NetBSD Project.
>> + * 4. The name of the author may not be used to endorse or promote products
>> + * derived from this software without specific prior written permission
>> + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR
>> + * IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
>> + * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
>> + * IN NO EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT,
>> + * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT
>> + * NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
>> + * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
>> + * THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
>> + * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF
>> + * THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
>> + * $FreeBSD$
>> +#ifndef _MACHINE_BUS_H_
>> +#define _MACHINE_BUS_H_
>> +#include <machine/_bus.h>
>> + * int bus_space_map (bus_space_tag_t t, bus_addr_t addr,
>> + * bus_size_t size, int flags, bus_space_handle_t *bshp);
>> + * Map a region of bus space.
>> +#define BUS_SPACE_MAP_CACHEABLE 0x01
>> +#define BUS_SPACE_MAP_LINEAR 0x02
>> +#define BUS_SPACE_MAP_PREFETCHABLE 0x04
>> + * Bus space for ARM.
>> + * The functions used most often are grouped together at the beginning to ensure
>> + * that all the data fits into a single cache line. The inline implementations
>> + * of single read/write access these values a lot.
>> +struct bus_space {
>> + /* Read/write single and barrier: the most commonly used functions. */
>> + uint8_t (*bs_r_1)(bus_space_tag_t, bus_space_handle_t, bus_size_t);
>> + uint32_t (*bs_r_4)(bus_space_tag_t, bus_space_handle_t, bus_size_t);
>> + void (*bs_w_1)(bus_space_tag_t, bus_space_handle_t,
>> + bus_size_t, uint8_t);
>> + void (*bs_w_4)(bus_space_tag_t, bus_space_handle_t,
>> + bus_size_t, uint32_t);
>> + void (*bs_barrier)(bus_space_tag_t, bus_space_handle_t,
>> + bus_size_t, bus_size_t, int);
>> + /* Backlink to parent (if copied), and implementation private data. */
>> + struct bus_space *bs_parent;
>> + void *bs_privdata;
>> + /* mapping/unmapping */
>> + int (*bs_map) (bus_space_tag_t, bus_addr_t, bus_size_t,
>> + int, bus_space_handle_t *);
>> + void (*bs_unmap) (bus_space_tag_t, bus_space_handle_t, bus_size_t);
>> + int (*bs_subregion) (bus_space_tag_t, bus_space_handle_t,
>> + bus_size_t, bus_size_t, bus_space_handle_t *);
>> + /* allocation/deallocation */
>> + int (*bs_alloc) (bus_space_tag_t, bus_addr_t, bus_addr_t,
>> + bus_size_t, bus_size_t, bus_size_t, int,
>> + bus_addr_t *, bus_space_handle_t *);
>> + void (*bs_free) (bus_space_tag_t, bus_space_handle_t,
>> + bus_size_t);
>> + /* Read single, the less commonly used functions. */
>> + uint16_t (*bs_r_2) (bus_space_tag_t, bus_space_handle_t, bus_size_t);
>> + uint64_t (*bs_r_8) (bus_space_tag_t, bus_space_handle_t, bus_size_t);
>> + /* read multiple */
>> + void (*bs_rm_1) (bus_space_tag_t, bus_space_handle_t, bus_size_t,
>> + uint8_t *, bus_size_t);
>> + void (*bs_rm_2) (bus_space_tag_t, bus_space_handle_t, bus_size_t,
>> + uint16_t *, bus_size_t);
>> + void (*bs_rm_4) (bus_space_tag_t, bus_space_handle_t,
>> + bus_size_t, uint32_t *, bus_size_t);
>> + void (*bs_rm_8) (bus_space_tag_t, bus_space_handle_t,
>> + bus_size_t, uint64_t *, bus_size_t);
>> + /* read region */
>> + void (*bs_rr_1) (bus_space_tag_t, bus_space_handle_t,
>> + bus_size_t, uint8_t *, bus_size_t);
>> + void (*bs_rr_2) (bus_space_tag_t, bus_space_handle_t,
>> + bus_size_t, uint16_t *, bus_size_t);
>> + void (*bs_rr_4) (bus_space_tag_t, bus_space_handle_t,
>> + void (*bs_rr_8) (bus_space_tag_t, bus_space_handle_t,
>> + /* Write single, the less commonly used functions. */
>> + void (*bs_w_2) (bus_space_tag_t, bus_space_handle_t,
>> + bus_size_t, uint16_t);
>> + void (*bs_w_8) (bus_space_tag_t, bus_space_handle_t,
>> + bus_size_t, uint64_t);
>> + /* write multiple */
>> + void (*bs_wm_1) (bus_space_tag_t, bus_space_handle_t,
>> + bus_size_t, const uint8_t *, bus_size_t);
>> + void (*bs_wm_2) (bus_space_tag_t, bus_space_handle_t,
>> + bus_size_t, const uint16_t *, bus_size_t);
>> + void (*bs_wm_4) (bus_space_tag_t, bus_space_handle_t,
>> + bus_size_t, const uint32_t *, bus_size_t);
>> + void (*bs_wm_8) (bus_space_tag_t, bus_space_handle_t,
>> + bus_size_t, const uint64_t *, bus_size_t);
>> + /* write region */
>> + void (*bs_wr_1) (bus_space_tag_t, bus_space_handle_t,
>> + void (*bs_wr_2) (bus_space_tag_t, bus_space_handle_t,
>> + void (*bs_wr_4) (bus_space_tag_t, bus_space_handle_t,
>> + void (*bs_wr_8) (bus_space_tag_t, bus_space_handle_t,
>> + /* set multiple */
>> + void (*bs_sm_1) (bus_space_tag_t, bus_space_handle_t,
>> + bus_size_t, uint8_t, bus_size_t);
>> + void (*bs_sm_2) (bus_space_tag_t, bus_space_handle_t,
>> + bus_size_t, uint16_t, bus_size_t);
>> + void (*bs_sm_4) (bus_space_tag_t, bus_space_handle_t,
>> + bus_size_t, uint32_t, bus_size_t);
>> + void (*bs_sm_8) (bus_space_tag_t, bus_space_handle_t,
>> + bus_size_t, uint64_t, bus_size_t);
>> + /* set region */
>> + void (*bs_sr_1) (bus_space_tag_t, bus_space_handle_t,
>> + void (*bs_sr_2) (bus_space_tag_t, bus_space_handle_t,
>> + void (*bs_sr_4) (bus_space_tag_t, bus_space_handle_t,
>> + void (*bs_sr_8) (bus_space_tag_t, bus_space_handle_t,
>> + /* copy */
>> + void (*bs_c_1) (bus_space_tag_t, bus_space_handle_t, bus_size_t,
>> + bus_space_handle_t, bus_size_t, bus_size_t);
>> + void (*bs_c_2) (bus_space_tag_t, bus_space_handle_t, bus_size_t,
>> + void (*bs_c_4) (bus_space_tag_t, bus_space_handle_t, bus_size_t,
>> + void (*bs_c_8) (bus_space_tag_t, bus_space_handle_t, bus_size_t,
>> + /* read stream (single) */
>> + uint8_t (*bs_r_1_s) (bus_space_tag_t, bus_space_handle_t, bus_size_t);
>> + uint16_t (*bs_r_2_s) (bus_space_tag_t, bus_space_handle_t, bus_size_t);
>> + uint32_t (*bs_r_4_s) (bus_space_tag_t, bus_space_handle_t, bus_size_t);
>> + uint64_t (*bs_r_8_s) (bus_space_tag_t, bus_space_handle_t, bus_size_t);
>> + /* read multiple stream */
>> + void (*bs_rm_1_s) (bus_space_tag_t, bus_space_handle_t, bus_size_t,
>> + void (*bs_rm_2_s) (bus_space_tag_t, bus_space_handle_t, bus_size_t,
>> + void (*bs_rm_4_s) (bus_space_tag_t, bus_space_handle_t,
>> + void (*bs_rm_8_s) (bus_space_tag_t, bus_space_handle_t,
>> + /* read region stream */
>> + void (*bs_rr_1_s) (bus_space_tag_t, bus_space_handle_t,
>> + void (*bs_rr_2_s) (bus_space_tag_t, bus_space_handle_t,
>> + void (*bs_rr_4_s) (bus_space_tag_t, bus_space_handle_t,
>> + void (*bs_rr_8_s) (bus_space_tag_t, bus_space_handle_t,
>> + /* write stream (single) */
>> + void (*bs_w_1_s) (bus_space_tag_t, bus_space_handle_t,
>> + void (*bs_w_2_s) (bus_space_tag_t, bus_space_handle_t,
>> + void (*bs_w_4_s) (bus_space_tag_t, bus_space_handle_t,
>> + void (*bs_w_8_s) (bus_space_tag_t, bus_space_handle_t,
>> + /* write multiple stream */
>> + void (*bs_wm_1_s) (bus_space_tag_t, bus_space_handle_t,
>> + void (*bs_wm_2_s) (bus_space_tag_t, bus_space_handle_t,
>> + void (*bs_wm_4_s) (bus_space_tag_t, bus_space_handle_t,
>> + void (*bs_wm_8_s) (bus_space_tag_t, bus_space_handle_t,
>> + /* write region stream */
>> + void (*bs_wr_1_s) (bus_space_tag_t, bus_space_handle_t,
>> + void (*bs_wr_2_s) (bus_space_tag_t, bus_space_handle_t,
>> + void (*bs_wr_4_s) (bus_space_tag_t, bus_space_handle_t,
>> + void (*bs_wr_8_s) (bus_space_tag_t, bus_space_handle_t,
>> +#if __ARM_ARCH < 6
>> +extern bus_space_tag_t arm_base_bs_tag;
>> +#endif
>> + * Utility macros; INTERNAL USE ONLY.
>> +#define __bs_c(a,b) __CONCAT(a,b)
>> +#define __bs_opname(op,size) __bs_c(__bs_c(__bs_c(bs_,op),_),size)
>> +#define __bs_nonsingle(type, sz, t, h, o, a, c) \
>> + (*(t)->__bs_opname(type,sz))((t), h, o, a, c)
>> +#define __bs_set(type, sz, t, h, o, v, c) \
>> + (*(t)->__bs_opname(type,sz))((t), h, o, v, c)
>> +#define __bs_copy(sz, t, h1, o1, h2, o2, cnt) \
>> + (*(t)->__bs_opname(c,sz))((t), h1, o1, h2, o2, cnt)
>> +#define __bs_opname_s(op,size) __bs_c(__bs_c(__bs_c(__bs_c(bs_,op),_),size),_s)
>> +#define __bs_rs_s(sz, t, h, o) \
>> + (*(t)->__bs_opname_s(r,sz))((t), h, o)
>> +#define __bs_ws_s(sz, t, h, o, v) \
>> + (*(t)->__bs_opname_s(w,sz))((t), h, o, v)
>> +#define __bs_nonsingle_s(type, sz, t, h, o, a, c) \
>> + (*(t)->__bs_opname_s(type,sz))((t), h, o, a, c)
>> +#define __generate_inline_bs_rs(IFN, MBR, TYP) \
>> + static inline TYP \
>> + IFN(bus_space_tag_t t, bus_space_handle_t h, bus_size_t o) \
>> + if (__predict_true(t->MBR == NULL)) \
>> + return (*(volatile TYP *)(h + o)); \
>> + else \
>> + return (t->MBR(t, h, o)); \
>> +#define __generate_inline_bs_ws(IFN, MBR, TYP) \
>> + static inline void \
>> + IFN(bus_space_tag_t t, bus_space_handle_t h, bus_size_t o, TYP v)\
>> + *(volatile TYP *)(h + o) = v; \
>> + else \
>> + t->MBR(t, h, o, v); \
>> + * Mapping and unmapping operations.
>> +#define bus_space_map(t, a, s, c, hp) \
>> + (*(t)->bs_map)((t), (a), (s), (c), (hp))
>> +#define bus_space_unmap(t, h, s) \
>> + (*(t)->bs_unmap)((t), (h), (s))
>> +#define bus_space_subregion(t, h, o, s, hp) \
>> + (*(t)->bs_subregion)((t), (h), (o), (s), (hp))
>> + * Allocation and deallocation operations.
>> +#define bus_space_alloc(t, rs, re, s, a, b, c, ap, hp) \
>> + (*(t)->bs_alloc)((t), (rs), (re), (s), (a), (b), \
>> + (c), (ap), (hp))
>> +#define bus_space_free(t, h, s) \
>> + (*(t)->bs_free)((t), (h), (s))
>> + * Bus barrier operations.
>> +#define bus_space_barrier(t, h, o, l, f) \
>> + (*(t)->bs_barrier)((t), (h), (o), (l), (f))
>> +#define BUS_SPACE_BARRIER_READ 0x01
>> +#define BUS_SPACE_BARRIER_WRITE 0x02
>> + * Bus read (single) operations.
>> +__generate_inline_bs_rs(bus_space_read_1, bs_r_1, uint8_t);
>> +__generate_inline_bs_rs(bus_space_read_2, bs_r_2, uint16_t);
>> +__generate_inline_bs_rs(bus_space_read_4, bs_r_4, uint32_t);
>> +__generate_inline_bs_rs(bus_space_read_8, bs_r_8, uint64_t);
>> +__generate_inline_bs_rs(bus_space_read_stream_1, bs_r_1_s, uint8_t);
>> +__generate_inline_bs_rs(bus_space_read_stream_2, bs_r_2_s, uint16_t);
>> +__generate_inline_bs_rs(bus_space_read_stream_4, bs_r_4_s, uint32_t);
>> +__generate_inline_bs_rs(bus_space_read_stream_8, bs_r_8_s, uint64_t);
>> + * Bus read multiple operations.
>> +#define bus_space_read_multi_1(t, h, o, a, c) \
>> + __bs_nonsingle(rm,1,(t),(h),(o),(a),(c))
>> +#define bus_space_read_multi_2(t, h, o, a, c) \
>> + __bs_nonsingle(rm,2,(t),(h),(o),(a),(c))
>> +#define bus_space_read_multi_4(t, h, o, a, c) \
>> + __bs_nonsingle(rm,4,(t),(h),(o),(a),(c))
>> +#define bus_space_read_multi_8(t, h, o, a, c) \
>> + __bs_nonsingle(rm,8,(t),(h),(o),(a),(c))
>> +#define bus_space_read_multi_stream_1(t, h, o, a, c) \
>> + __bs_nonsingle_s(rm,1,(t),(h),(o),(a),(c))
>> +#define bus_space_read_multi_stream_2(t, h, o, a, c) \
>> + __bs_nonsingle_s(rm,2,(t),(h),(o),(a),(c))
>> +#define bus_space_read_multi_stream_4(t, h, o, a, c) \
>> + __bs_nonsingle_s(rm,4,(t),(h),(o),(a),(c))
>> +#define bus_space_read_multi_stream_8(t, h, o, a, c) \
>> + __bs_nonsingle_s(rm,8,(t),(h),(o),(a),(c))
>> + * Bus read region operations.
>> +#define bus_space_read_region_1(t, h, o, a, c) \
>> + __bs_nonsingle(rr,1,(t),(h),(o),(a),(c))
>> +#define bus_space_read_region_2(t, h, o, a, c) \
>> + __bs_nonsingle(rr,2,(t),(h),(o),(a),(c))
>> +#define bus_space_read_region_4(t, h, o, a, c) \
>> + __bs_nonsingle(rr,4,(t),(h),(o),(a),(c))
>> +#define bus_space_read_region_8(t, h, o, a, c) \
>> + __bs_nonsingle(rr,8,(t),(h),(o),(a),(c))
>> +#define bus_space_read_region_stream_1(t, h, o, a, c) \
>> + __bs_nonsingle_s(rr,1,(t),(h),(o),(a),(c))
>> +#define bus_space_read_region_stream_2(t, h, o, a, c) \
>> + __bs_nonsingle_s(rr,2,(t),(h),(o),(a),(c))
>> +#define bus_space_read_region_stream_4(t, h, o, a, c) \
>> + __bs_nonsingle_s(rr,4,(t),(h),(o),(a),(c))
>> +#define bus_space_read_region_stream_8(t, h, o, a, c) \
>> + __bs_nonsingle_s(rr,8,(t),(h),(o),(a),(c))
>> + * Bus write (single) operations.
>> +__generate_inline_bs_ws(bus_space_write_1, bs_w_1, uint8_t);
>> +__generate_inline_bs_ws(bus_space_write_2, bs_w_2, uint16_t);
>> +__generate_inline_bs_ws(bus_space_write_4, bs_w_4, uint32_t);
>> +__generate_inline_bs_ws(bus_space_write_8, bs_w_8, uint64_t);
>> +__generate_inline_bs_ws(bus_space_write_stream_1, bs_w_1_s, uint8_t);
>> +__generate_inline_bs_ws(bus_space_write_stream_2, bs_w_2_s, uint16_t);
>> +__generate_inline_bs_ws(bus_space_write_stream_4, bs_w_4_s, uint32_t);
>> +__generate_inline_bs_ws(bus_space_write_stream_8, bs_w_8_s, uint64_t);
>> + * Bus write multiple operations.
>> +#define bus_space_write_multi_1(t, h, o, a, c) \
>> + __bs_nonsingle(wm,1,(t),(h),(o),(a),(c))
>> +#define bus_space_write_multi_2(t, h, o, a, c) \
>> + __bs_nonsingle(wm,2,(t),(h),(o),(a),(c))
>> +#define bus_space_write_multi_4(t, h, o, a, c) \
>> + __bs_nonsingle(wm,4,(t),(h),(o),(a),(c))
>> +#define bus_space_write_multi_8(t, h, o, a, c) \
>> + __bs_nonsingle(wm,8,(t),(h),(o),(a),(c))
>> +#define bus_space_write_multi_stream_1(t, h, o, a, c) \
>> + __bs_nonsingle_s(wm,1,(t),(h),(o),(a),(c))
>> +#define bus_space_write_multi_stream_2(t, h, o, a, c) \
>> + __bs_nonsingle_s(wm,2,(t),(h),(o),(a),(c))
>> +#define bus_space_write_multi_stream_4(t, h, o, a, c) \
>> + __bs_nonsingle_s(wm,4,(t),(h),(o),(a),(c))
>> +#define bus_space_write_multi_stream_8(t, h, o, a, c) \
>> + __bs_nonsingle_s(wm,8,(t),(h),(o),(a),(c))
>> + * Bus write region operations.
>> +#define bus_space_write_region_1(t, h, o, a, c) \
>> + __bs_nonsingle(wr,1,(t),(h),(o),(a),(c))
>> +#define bus_space_write_region_2(t, h, o, a, c) \
>> + __bs_nonsingle(wr,2,(t),(h),(o),(a),(c))
>> +#define bus_space_write_region_4(t, h, o, a, c) \
>> + __bs_nonsingle(wr,4,(t),(h),(o),(a),(c))
>> +#define bus_space_write_region_8(t, h, o, a, c) \
>> + __bs_nonsingle(wr,8,(t),(h),(o),(a),(c))
>> +#define bus_space_write_region_stream_1(t, h, o, a, c) \
>> + __bs_nonsingle_s(wr,1,(t),(h),(o),(a),(c))
>> +#define bus_space_write_region_stream_2(t, h, o, a, c) \
>> + __bs_nonsingle_s(wr,2,(t),(h),(o),(a),(c))
>> +#define bus_space_write_region_stream_4(t, h, o, a, c) \
>> + __bs_nonsingle_s(wr,4,(t),(h),(o),(a),(c))
>> +#define bus_space_write_region_stream_8(t, h, o, a, c) \
>> + __bs_nonsingle_s(wr,8,(t),(h),(o),(a),(c))
>> + * Set multiple operations.
>> +#define bus_space_set_multi_1(t, h, o, v, c) \
>> + __bs_set(sm,1,(t),(h),(o),(v),(c))
>> +#define bus_space_set_multi_2(t, h, o, v, c) \
>> + __bs_set(sm,2,(t),(h),(o),(v),(c))
>> +#define bus_space_set_multi_4(t, h, o, v, c) \
>> + __bs_set(sm,4,(t),(h),(o),(v),(c))
>> +#define bus_space_set_multi_8(t, h, o, v, c) \
>> + __bs_set(sm,8,(t),(h),(o),(v),(c))
>> + * Set region operations.
>> +#define bus_space_set_region_1(t, h, o, v, c) \
>> + __bs_set(sr,1,(t),(h),(o),(v),(c))
>> +#define bus_space_set_region_2(t, h, o, v, c) \
>> + __bs_set(sr,2,(t),(h),(o),(v),(c))
>> +#define bus_space_set_region_4(t, h, o, v, c) \
>> + __bs_set(sr,4,(t),(h),(o),(v),(c))
>> +#define bus_space_set_region_8(t, h, o, v, c) \
>> + __bs_set(sr,8,(t),(h),(o),(v),(c))
>> + * Copy operations.
>> +#define bus_space_copy_region_1(t, h1, o1, h2, o2, c) \
>> + __bs_copy(1, t, h1, o1, h2, o2, c)
>> +#define bus_space_copy_region_2(t, h1, o1, h2, o2, c) \
>> + __bs_copy(2, t, h1, o1, h2, o2, c)
>> +#define bus_space_copy_region_4(t, h1, o1, h2, o2, c) \
>> + __bs_copy(4, t, h1, o1, h2, o2, c)
>> +#define bus_space_copy_region_8(t, h1, o1, h2, o2, c) \
>> + __bs_copy(8, t, h1, o1, h2, o2, c)
>> + * Macros to provide prototypes for all the functions used in the
>> + * bus_space structure
>> +#define bs_map_proto(f) \
>> +int __bs_c(f,_bs_map) (bus_space_tag_t t, bus_addr_t addr, \
>> + bus_size_t size, int cacheable, bus_space_handle_t *bshp);
>> +#define bs_unmap_proto(f) \
>> +void __bs_c(f,_bs_unmap) (bus_space_tag_t t, bus_space_handle_t bsh, \
>> + bus_size_t size);
>> +#define bs_subregion_proto(f) \
>> +int __bs_c(f,_bs_subregion) (bus_space_tag_t t, bus_space_handle_t bsh, \
>> + bus_size_t offset, bus_size_t size, \
>> + bus_space_handle_t *nbshp);
>> +#define bs_alloc_proto(f) \
>> +int __bs_c(f,_bs_alloc) (bus_space_tag_t t, bus_addr_t rstart, \
>> + bus_addr_t rend, bus_size_t size, bus_size_t align, \
>> + bus_size_t boundary, int cacheable, bus_addr_t *addrp, \
>> + bus_space_handle_t *bshp);
>> +#define bs_free_proto(f) \
>> +void __bs_c(f,_bs_free) (bus_space_tag_t t, bus_space_handle_t bsh, \
>> + bus_size_t size);
>> +#define bs_mmap_proto(f) \
>> +int __bs_c(f,_bs_mmap) (struct cdev *, vm_offset_t, vm_paddr_t *, int);
>> +#define bs_barrier_proto(f) \
>> +void __bs_c(f,_bs_barrier) (bus_space_tag_t t, bus_space_handle_t bsh, \
>> + bus_size_t offset, bus_size_t len, int flags);
>> +#define bs_r_1_proto(f) \
>> +uint8_t __bs_c(f,_bs_r_1) (bus_space_tag_t t, bus_space_handle_t bsh, \
>> + bus_size_t offset);
>> +#define bs_r_2_proto(f) \
>> +uint16_t __bs_c(f,_bs_r_2) (bus_space_tag_t t, bus_space_handle_t bsh, \
>> +#define bs_r_4_proto(f) \
>> +uint32_t __bs_c(f,_bs_r_4) (bus_space_tag_t t, bus_space_handle_t bsh, \
>> +#define bs_r_8_proto(f) \
>> +uint64_t __bs_c(f,_bs_r_8) (bus_space_tag_t t, bus_space_handle_t bsh, \
>> +#define bs_r_1_s_proto(f) \
>> +uint8_t __bs_c(f,_bs_r_1_s) (bus_space_tag_t t, bus_space_handle_t bsh, \
>> +#define bs_r_2_s_proto(f) \
>> +uint16_t __bs_c(f,_bs_r_2_s) (bus_space_tag_t t, bus_space_handle_t bsh, \
>> +#define bs_r_4_s_proto(f) \
>> +uint32_t __bs_c(f,_bs_r_4_s) (bus_space_tag_t t, bus_space_handle_t bsh, \
>> +#define bs_w_1_proto(f) \
>> +void __bs_c(f,_bs_w_1) (bus_space_tag_t t, bus_space_handle_t bsh, \
>> + bus_size_t offset, uint8_t value);
>> +#define bs_w_2_proto(f) \
>> +void __bs_c(f,_bs_w_2) (bus_space_tag_t t, bus_space_handle_t bsh, \
>> + bus_size_t offset, uint16_t value);
>> +#define bs_w_4_proto(f) \
>> +void __bs_c(f,_bs_w_4) (bus_space_tag_t t, bus_space_handle_t bsh, \
>> + bus_size_t offset, uint32_t value);
>> +#define bs_w_8_proto(f) \
>> +void __bs_c(f,_bs_w_8) (bus_space_tag_t t, bus_space_handle_t bsh, \
>> + bus_size_t offset, uint64_t value);
>> +#define bs_w_1_s_proto(f) \
>> +void __bs_c(f,_bs_w_1_s) (bus_space_tag_t t, bus_space_handle_t bsh, \
>> +#define bs_w_2_s_proto(f) \
>> +void __bs_c(f,_bs_w_2_s) (bus_space_tag_t t, bus_space_handle_t bsh, \
>> +#define bs_w_4_s_proto(f) \
>> +void __bs_c(f,_bs_w_4_s) (bus_space_tag_t t, bus_space_handle_t bsh, \
>> +#define bs_rm_1_proto(f) \
>> +void __bs_c(f,_bs_rm_1) (bus_space_tag_t t, bus_space_handle_t bsh, \
>> + bus_size_t offset, uint8_t *addr, bus_size_t count);
>> +#define bs_rm_2_proto(f) \
>> +void __bs_c(f,_bs_rm_2) (bus_space_tag_t t, bus_space_handle_t bsh, \
>> + bus_size_t offset, uint16_t *addr, bus_size_t count);
>> +#define bs_rm_4_proto(f) \
>> +void __bs_c(f,_bs_rm_4) (bus_space_tag_t t, bus_space_handle_t bsh, \
>> + bus_size_t offset, uint32_t *addr, bus_size_t count);
>> +#define bs_rm_8_proto(f) \
>> +void __bs_c(f,_bs_rm_8) (bus_space_tag_t t, bus_space_handle_t bsh, \
>> + bus_size_t offset, uint64_t *addr, bus_size_t count);
>> +#define bs_wm_1_proto(f) \
>> +void __bs_c(f,_bs_wm_1) (bus_space_tag_t t, bus_space_handle_t bsh, \
>> + bus_size_t offset, const uint8_t *addr, bus_size_t count);
>> +#define bs_wm_2_proto(f) \
>> +void __bs_c(f,_bs_wm_2) (bus_space_tag_t t, bus_space_handle_t bsh, \
>> + bus_size_t offset, const uint16_t *addr, bus_size_t count);
>> +#define bs_wm_4_proto(f) \
>> +void __bs_c(f,_bs_wm_4) (bus_space_tag_t t, bus_space_handle_t bsh, \
>> + bus_size_t offset, const uint32_t *addr, bus_size_t count);
>> +#define bs_wm_8_proto(f) \
>> +void __bs_c(f,_bs_wm_8) (bus_space_tag_t t, bus_space_handle_t bsh, \
>> + bus_size_t offset, const uint64_t *addr, bus_size_t count);
>> +#define bs_rr_1_proto(f) \
>> +void __bs_c(f, _bs_rr_1) (bus_space_tag_t t, bus_space_handle_t bsh, \
>> +#define bs_rr_2_proto(f) \
>> +void __bs_c(f, _bs_rr_2) (bus_space_tag_t t, bus_space_handle_t bsh, \
>> +#define bs_rr_4_proto(f) \
>> +void __bs_c(f, _bs_rr_4) (bus_space_tag_t t, bus_space_handle_t bsh, \
>> +#define bs_rr_8_proto(f) \
>> +void __bs_c(f, _bs_rr_8) (bus_space_tag_t t, bus_space_handle_t bsh, \
>> +#define bs_wr_1_proto(f) \
>> +void __bs_c(f, _bs_wr_1) (bus_space_tag_t t, bus_space_handle_t bsh, \
>> +#define bs_wr_2_proto(f) \
>> +void __bs_c(f, _bs_wr_2) (bus_space_tag_t t, bus_space_handle_t bsh, \
>> +#define bs_wr_4_proto(f) \
>> +void __bs_c(f, _bs_wr_4) (bus_space_tag_t t, bus_space_handle_t bsh, \
>> +#define bs_wr_8_proto(f) \
>> +void __bs_c(f, _bs_wr_8) (bus_space_tag_t t, bus_space_handle_t bsh, \
>> +#define bs_sm_1_proto(f) \
>> +void __bs_c(f,_bs_sm_1) (bus_space_tag_t t, bus_space_handle_t bsh, \
>> + bus_size_t offset, uint8_t value, bus_size_t count);
>> +#define bs_sm_2_proto(f) \
>> +void __bs_c(f,_bs_sm_2) (bus_space_tag_t t, bus_space_handle_t bsh, \
>> + bus_size_t offset, uint16_t value, bus_size_t count);
>> +#define bs_sm_4_proto(f) \
>> +void __bs_c(f,_bs_sm_4) (bus_space_tag_t t, bus_space_handle_t bsh, \
>> + bus_size_t offset, uint32_t value, bus_size_t count);
>> +#define bs_sm_8_proto(f) \
>> +void __bs_c(f,_bs_sm_8) (bus_space_tag_t t, bus_space_handle_t bsh, \
>> + bus_size_t offset, uint64_t value, bus_size_t count);
>> +#define bs_sr_1_proto(f) \
>> +void __bs_c(f,_bs_sr_1) (bus_space_tag_t t, bus_space_handle_t bsh, \
>> +#define bs_sr_2_proto(f) \
>> +void __bs_c(f,_bs_sr_2) (bus_space_tag_t t, bus_space_handle_t bsh, \
>> +#define bs_sr_4_proto(f) \
>> +void __bs_c(f,_bs_sr_4) (bus_space_tag_t t, bus_space_handle_t bsh, \
>> +#define bs_sr_8_proto(f) \
>> +void __bs_c(f,_bs_sr_8) (bus_space_tag_t t, bus_space_handle_t bsh, \
>> +#define bs_c_1_proto(f) \
>> +void __bs_c(f,_bs_c_1) (bus_space_tag_t t, bus_space_handle_t bsh1, \
>> + bus_size_t offset1, bus_space_handle_t bsh2, \
>> + bus_size_t offset2, bus_size_t count);
>> +#define bs_c_2_proto(f) \
>> +void __bs_c(f,_bs_c_2) (bus_space_tag_t t, bus_space_handle_t bsh1, \
>> +#define bs_c_4_proto(f) \
>> +void __bs_c(f,_bs_c_4) (bus_space_tag_t t, bus_space_handle_t bsh1, \
>> +#define bs_c_8_proto(f) \
>> +void __bs_c(f,_bs_c_8) (bus_space_tag_t t, bus_space_handle_t bsh1, \
>> +#define bs_protos(f) \
>> +bs_map_proto(f); \
>> +bs_unmap_proto(f); \
>> +bs_subregion_proto(f); \
>> +bs_alloc_proto(f); \
>> +bs_free_proto(f); \
>> +bs_mmap_proto(f); \
>> +bs_barrier_proto(f); \
>> +bs_r_1_proto(f); \
>> +bs_r_2_proto(f); \
>> +bs_r_4_proto(f); \
>> +bs_r_8_proto(f); \
>> +bs_r_1_s_proto(f); \
>> +bs_r_2_s_proto(f); \
>> +bs_r_4_s_proto(f); \
>> +bs_w_1_proto(f); \
>> +bs_w_2_proto(f); \
>> +bs_w_4_proto(f); \
>> +bs_w_8_proto(f); \
>> +bs_w_1_s_proto(f); \
>> +bs_w_2_s_proto(f); \
>> +bs_w_4_s_proto(f); \
>> +bs_rm_1_proto(f); \
>> +bs_rm_2_proto(f); \
>> +bs_rm_4_proto(f); \
>> +bs_rm_8_proto(f); \
>> +bs_wm_1_proto(f); \
>> +bs_wm_2_proto(f); \
>> +bs_wm_4_proto(f); \
>> +bs_wm_8_proto(f); \
>> +bs_rr_1_proto(f); \
>> +bs_rr_2_proto(f); \
>> +bs_rr_4_proto(f); \
>> +bs_rr_8_proto(f); \
>> +bs_wr_1_proto(f); \
>> +bs_wr_2_proto(f); \
>> +bs_wr_4_proto(f); \
>> +bs_wr_8_proto(f); \
>> +bs_sm_1_proto(f); \
>> +bs_sm_2_proto(f); \
>> +bs_sm_4_proto(f); \
>> +bs_sm_8_proto(f); \
>> +bs_sr_1_proto(f); \
>> +bs_sr_2_proto(f); \
>> +bs_sr_4_proto(f); \
>> +bs_sr_8_proto(f); \
>> +bs_c_1_proto(f); \
>> +bs_c_2_proto(f); \
>> +bs_c_4_proto(f); \
>> +bs_c_8_proto(f);
>> +void generic_bs_unimplemented(void);
>> +#define BS_UNIMPLEMENTED (void *)generic_bs_unimplemented
>> +#define BUS_SPACE_ALIGNED_POINTER(p, t) ALIGNED_POINTER(p, t)
>> +#define BUS_SPACE_MAXADDR_24BIT 0xFFFFFF
>> +#define BUS_SPACE_MAXADDR_32BIT 0xFFFFFFFF
>> +#define BUS_SPACE_MAXADDR 0xFFFFFFFF
>> +#define BUS_SPACE_MAXSIZE_24BIT 0xFFFFFF
>> +#define BUS_SPACE_MAXSIZE_32BIT 0xFFFFFFFF
>> +#define BUS_SPACE_MAXSIZE 0xFFFFFFFF
>> +#define BUS_SPACE_UNRESTRICTED (~0)
>> +#include <machine/bus_dma.h>
>> + * Get the physical address of a bus space memory-mapped resource.
>> + * Doing this as a macro is a temporary solution until a more robust fix is
>> + * designed. It also serves to mark the locations needing that fix.
>> +#define BUS_SPACE_PHYSADDR(res, offs) \
>> + ((u_int)(rman_get_start(res)+(offs)))
>> +#endif /* _MACHINE_BUS_H_ */
>> diff --git a/freebsd/sys/arm64/include/machine/_bus.h b/freebsd/sys/arm64/include/machine/_bus.h
>> index 00000000..f11991f6
>> --- /dev/null
>> +++ b/freebsd/sys/arm64/include/machine/_bus.h
>> @@ -0,0 +1,46 @@
>> + * are met:
>> + * distribution.
>> + * SUCH DAMAGE.
>> + * $FreeBSD$
>> +#ifndef _MACHINE__BUS_H_
>> +#define _MACHINE__BUS_H_
>> +#endif /* !_MACHINE__BUS_H_ */
>> diff --git a/freebsd/sys/arm64/include/machine/bus.h b/freebsd/sys/arm64/include/machine/bus.h
>> index 00000000..8aaf1d3e
>> --- /dev/null
>> +++ b/freebsd/sys/arm64/include/machine/bus.h
>> @@ -0,0 +1,469 @@
>> + * are met:
>> + * are met:
>> + * From: sys/arm/include/bus.h
>> + * $FreeBSD$
>> +#define BUS_SPACE_MAXADDR_24BIT 0xFFFFFFUL
>> +#define BUS_SPACE_MAXADDR_32BIT 0xFFFFFFFFUL
>> +#define BUS_SPACE_MAXSIZE_24BIT 0xFFFFFFUL
>> +#define BUS_SPACE_MAXSIZE_32BIT 0xFFFFFFFFUL
>> +#define BUS_SPACE_MAXADDR 0xFFFFFFFFFFFFFFFFUL
>> +#define BUS_SPACE_MAXSIZE 0xFFFFFFFFFFFFFFFFUL
>> +struct bus_space {
>> + /* cookie */
>> + void *bs_cookie;
>> + int (*bs_map) (void *, bus_addr_t, bus_size_t,
>> + void (*bs_unmap) (void *, bus_space_handle_t, bus_size_t);
>> + int (*bs_subregion) (void *, bus_space_handle_t,
>> + int (*bs_alloc) (void *, bus_addr_t, bus_addr_t,
>> + void (*bs_free) (void *, bus_space_handle_t,
>> + bus_size_t);
>> + /* get kernel virtual address */
>> + /* barrier */
>> + void (*bs_barrier) (void *, bus_space_handle_t,
>> + /* read single */
>> + u_int8_t (*bs_r_1) (void *, bus_space_handle_t, bus_size_t);
>> + u_int16_t (*bs_r_2) (void *, bus_space_handle_t, bus_size_t);
>> + u_int32_t (*bs_r_4) (void *, bus_space_handle_t, bus_size_t);
>> + u_int64_t (*bs_r_8) (void *, bus_space_handle_t, bus_size_t);
>> + void (*bs_rm_1) (void *, bus_space_handle_t, bus_size_t,
>> + u_int8_t *, bus_size_t);
>> + void (*bs_rm_2) (void *, bus_space_handle_t, bus_size_t,
>> + u_int16_t *, bus_size_t);
>> + void (*bs_rm_4) (void *, bus_space_handle_t,
>> + bus_size_t, u_int32_t *, bus_size_t);
>> + void (*bs_rm_8) (void *, bus_space_handle_t,
>> + bus_size_t, u_int64_t *, bus_size_t);
>> + /* read region */
>> + void (*bs_rr_1) (void *, bus_space_handle_t,
>> + bus_size_t, u_int8_t *, bus_size_t);
>> + void (*bs_rr_2) (void *, bus_space_handle_t,
>> + bus_size_t, u_int16_t *, bus_size_t);
>> + void (*bs_rr_4) (void *, bus_space_handle_t,
>> + void (*bs_rr_8) (void *, bus_space_handle_t,
>> + /* write single */
>> + void (*bs_w_1) (void *, bus_space_handle_t,
>> + bus_size_t, u_int8_t);
>> + void (*bs_w_2) (void *, bus_space_handle_t,
>> + bus_size_t, u_int16_t);
>> + void (*bs_w_4) (void *, bus_space_handle_t,
>> + bus_size_t, u_int32_t);
>> + void (*bs_w_8) (void *, bus_space_handle_t,
>> + bus_size_t, u_int64_t);
>> + void (*bs_wm_1) (void *, bus_space_handle_t,
>> + bus_size_t, const u_int8_t *, bus_size_t);
>> + void (*bs_wm_2) (void *, bus_space_handle_t,
>> + bus_size_t, const u_int16_t *, bus_size_t);
>> + void (*bs_wm_4) (void *, bus_space_handle_t,
>> + bus_size_t, const u_int32_t *, bus_size_t);
>> + void (*bs_wm_8) (void *, bus_space_handle_t,
>> + bus_size_t, const u_int64_t *, bus_size_t);
>> + void (*bs_wr_1) (void *, bus_space_handle_t,
>> + void (*bs_wr_2) (void *, bus_space_handle_t,
>> + void (*bs_wr_4) (void *, bus_space_handle_t,
>> + void (*bs_wr_8) (void *, bus_space_handle_t,
>> + void (*bs_sm_1) (void *, bus_space_handle_t,
>> + bus_size_t, u_int8_t, bus_size_t);
>> + void (*bs_sm_2) (void *, bus_space_handle_t,
>> + bus_size_t, u_int16_t, bus_size_t);
>> + void (*bs_sm_4) (void *, bus_space_handle_t,
>> + bus_size_t, u_int32_t, bus_size_t);
>> + void (*bs_sm_8) (void *, bus_space_handle_t,
>> + bus_size_t, u_int64_t, bus_size_t);
>> + /* set region */
>> + void (*bs_sr_1) (void *, bus_space_handle_t,
>> + void (*bs_sr_2) (void *, bus_space_handle_t,
>> + void (*bs_sr_4) (void *, bus_space_handle_t,
>> + void (*bs_sr_8) (void *, bus_space_handle_t,
>> + /* copy */
>> + void (*bs_c_1) (void *, bus_space_handle_t, bus_size_t,
>> + void (*bs_c_2) (void *, bus_space_handle_t, bus_size_t,
>> + void (*bs_c_4) (void *, bus_space_handle_t, bus_size_t,
>> + void (*bs_c_8) (void *, bus_space_handle_t, bus_size_t,
>> + /* read single stream */
>> + u_int8_t (*bs_r_1_s) (void *, bus_space_handle_t, bus_size_t);
>> + u_int16_t (*bs_r_2_s) (void *, bus_space_handle_t, bus_size_t);
>> + u_int32_t (*bs_r_4_s) (void *, bus_space_handle_t, bus_size_t);
>> + u_int64_t (*bs_r_8_s) (void *, bus_space_handle_t, bus_size_t);
>> + void (*bs_rm_1_s) (void *, bus_space_handle_t, bus_size_t,
>> + void (*bs_rm_2_s) (void *, bus_space_handle_t, bus_size_t,
>> + void (*bs_rm_4_s) (void *, bus_space_handle_t,
>> + void (*bs_rm_8_s) (void *, bus_space_handle_t,
>> + void (*bs_rr_1_s) (void *, bus_space_handle_t,
>> + void (*bs_rr_2_s) (void *, bus_space_handle_t,
>> + void (*bs_rr_4_s) (void *, bus_space_handle_t,
>> + void (*bs_rr_8_s) (void *, bus_space_handle_t,
>> + /* write single stream */
>> + void (*bs_w_1_s) (void *, bus_space_handle_t,
>> + void (*bs_w_2_s) (void *, bus_space_handle_t,
>> + void (*bs_w_4_s) (void *, bus_space_handle_t,
>> + void (*bs_w_8_s) (void *, bus_space_handle_t,
>> + void (*bs_wm_1_s) (void *, bus_space_handle_t,
>> + void (*bs_wm_2_s) (void *, bus_space_handle_t,
>> + void (*bs_wm_4_s) (void *, bus_space_handle_t,
>> + void (*bs_wm_8_s) (void *, bus_space_handle_t,
>> + void (*bs_wr_1_s) (void *, bus_space_handle_t,
>> + void (*bs_wr_2_s) (void *, bus_space_handle_t,
>> + void (*bs_wr_4_s) (void *, bus_space_handle_t,
>> + void (*bs_wr_8_s) (void *, bus_space_handle_t,
>> +#define __bs_rs(sz, t, h, o) \
>> + (*(t)->__bs_opname(r,sz))((t)->bs_cookie, h, o)
>> +#define __bs_ws(sz, t, h, o, v) \
>> + (*(t)->__bs_opname(w,sz))((t)->bs_cookie, h, o, v)
>> + (*(t)->__bs_opname(type,sz))((t)->bs_cookie, h, o, a, c)
>> + (*(t)->__bs_opname(type,sz))((t)->bs_cookie, h, o, v, c)
>> + (*(t)->__bs_opname(c,sz))((t)->bs_cookie, h1, o1, h2, o2, cnt)
>> + (*(t)->__bs_opname_s(r,sz))((t)->bs_cookie, h, o)
>> + (*(t)->__bs_opname_s(w,sz))((t)->bs_cookie, h, o, v)
>> + (*(t)->__bs_opname_s(type,sz))((t)->bs_cookie, h, o, a, c)
>> + (*(t)->bs_map)((t)->bs_cookie, (a), (s), (c), (hp))
>> + (*(t)->bs_unmap)((t)->bs_cookie, (h), (s))
>> + (*(t)->bs_subregion)((t)->bs_cookie, (h), (o), (s), (hp))
>> + (*(t)->bs_alloc)((t)->bs_cookie, (rs), (re), (s), (a), (b), \
>> + (c), (ap), (hp))
>> + (*(t)->bs_free)((t)->bs_cookie, (h), (s))
>> + (*(t)->bs_barrier)((t)->bs_cookie, (h), (o), (l), (f))
>> +#define bus_space_read_1(t, h, o) __bs_rs(1,(t),(h),(o))
>> +#define bus_space_read_2(t, h, o) __bs_rs(2,(t),(h),(o))
>> +#define bus_space_read_4(t, h, o) __bs_rs(4,(t),(h),(o))
>> +#define bus_space_read_8(t, h, o) __bs_rs(8,(t),(h),(o))
>> +#define bus_space_read_stream_1(t, h, o) __bs_rs_s(1,(t), (h), (o))
>> +#define bus_space_read_stream_2(t, h, o) __bs_rs_s(2,(t), (h), (o))
>> +#define bus_space_read_stream_4(t, h, o) __bs_rs_s(4,(t), (h), (o))
>> +#define bus_space_read_stream_8(t, h, o) __bs_rs_s(8,8,(t),(h),(o))
>> +#define bus_space_write_1(t, h, o, v) __bs_ws(1,(t),(h),(o),(v))
>> +#define bus_space_write_2(t, h, o, v) __bs_ws(2,(t),(h),(o),(v))
>> +#define bus_space_write_4(t, h, o, v) __bs_ws(4,(t),(h),(o),(v))
>> +#define bus_space_write_8(t, h, o, v) __bs_ws(8,(t),(h),(o),(v))
>> +#define bus_space_write_stream_1(t, h, o, v) __bs_ws_s(1,(t),(h),(o),(v))
>> +#define bus_space_write_stream_2(t, h, o, v) __bs_ws_s(2,(t),(h),(o),(v))
>> +#define bus_space_write_stream_4(t, h, o, v) __bs_ws_s(4,(t),(h),(o),(v))
>> +#define bus_space_write_stream_8(t, h, o, v) __bs_ws_s(8,(t),(h),(o),(v))
>> diff --git a/freebsd/sys/powerpc/include/machine/_bus.h b/freebsd/sys/powerpc/include/machine/_bus.h
>> index 00000000..d39fb003
>> --- /dev/null
>> +++ b/freebsd/sys/powerpc/include/machine/_bus.h
>> @@ -0,0 +1,50 @@
>> + * are met:
>> + * distribution.
>> + * SUCH DAMAGE.
>> + * $FreeBSD$
>> +#ifndef POWERPC_INCLUDE__BUS_H
>> +#define POWERPC_INCLUDE__BUS_H
>> +#include <vm/vm_param.h>
>> + * Bus address and size types
>> +typedef vm_paddr_t bus_addr_t;
>> +typedef vm_size_t bus_size_t;
>> + * Access methods for bus resources and address space.
>> +typedef vm_offset_t bus_space_handle_t;
>> +#endif /* POWERPC_INCLUDE__BUS_H */
>> diff --git a/freebsd/sys/powerpc/include/machine/bus.h b/freebsd/sys/powerpc/include/machine/bus.h
>> index 00000000..f45678f6
>> --- /dev/null
>> +++ b/freebsd/sys/powerpc/include/machine/bus.h
>> @@ -0,0 +1,467 @@
>> + * SPDX-License-Identifier: BSD-2-Clause-NetBSD AND BSD-4-Clause
>> + * are met:
>> + * are met:
>> + * $FreeBSD$
>> +#ifdef __powerpc64__
>> +#else
>> +#ifdef BOOKE
>> +#define BUS_SPACE_MAXADDR 0xFFFFFFFFFULL
>> +#define BUS_SPACE_MAXSIZE 0xFFFFFFFFUL
>> +#else
>> +#define BUS_SPACE_MAXADDR 0xFFFFFFFFUL
>> +#endif
>> +#endif
>> +struct bus_space_access;
>> +struct bus_space {
>> + int (*bs_map)(bus_addr_t, bus_size_t, int,
>> + bus_space_handle_t *);
>> + void (*bs_unmap)(bus_size_t);
>> + int (*bs_subregion)(bus_space_handle_t, bus_size_t,
>> + bus_size_t, bus_space_handle_t *);
>> + int (*bs_alloc)(bus_addr_t, bus_addr_t, bus_size_t,
>> + bus_size_t, bus_size_t, int, bus_addr_t *, bus_space_handle_t *);
>> + void (*bs_free)(bus_space_handle_t, bus_size_t);
>> + void (*bs_barrier)(bus_space_handle_t, bus_size_t,
>> + bus_size_t, int);
>> + /* Read single. */
>> + uint8_t (*bs_r_1)(bus_space_handle_t, bus_size_t);
>> + uint16_t (*bs_r_2)(bus_space_handle_t, bus_size_t);
>> + uint32_t (*bs_r_4)(bus_space_handle_t, bus_size_t);
>> + uint64_t (*bs_r_8)(bus_space_handle_t, bus_size_t);
>> + uint16_t (*bs_r_s_2)(bus_space_handle_t, bus_size_t);
>> + uint32_t (*bs_r_s_4)(bus_space_handle_t, bus_size_t);
>> + uint64_t (*bs_r_s_8)(bus_space_handle_t, bus_size_t);
>> + void (*bs_rm_1)(bus_space_handle_t, bus_size_t, uint8_t *,
>> + bus_size_t);
>> + void (*bs_rm_2)(bus_space_handle_t, bus_size_t, uint16_t *,
>> + bus_size_t);
>> + void (*bs_rm_4)(bus_space_handle_t, bus_size_t, uint32_t *,
>> + bus_size_t);
>> + void (*bs_rm_8)(bus_space_handle_t, bus_size_t, uint64_t *,
>> + bus_size_t);
>> + void (*bs_rm_s_2)(bus_space_handle_t, bus_size_t, uint16_t *,
>> + bus_size_t);
>> + void (*bs_rm_s_4)(bus_space_handle_t, bus_size_t, uint32_t *,
>> + bus_size_t);
>> + void (*bs_rm_s_8)(bus_space_handle_t, bus_size_t, uint64_t *,
>> + bus_size_t);
>> + /* read region */
>> + void (*bs_rr_1)(bus_space_handle_t, bus_size_t, uint8_t *,
>> + bus_size_t);
>> + void (*bs_rr_2)(bus_space_handle_t, bus_size_t, uint16_t *,
>> + bus_size_t);
>> + void (*bs_rr_4)(bus_space_handle_t, bus_size_t, uint32_t *,
>> + bus_size_t);
>> + void (*bs_rr_8)(bus_space_handle_t, bus_size_t, uint64_t *,
>> + bus_size_t);
>> + void (*bs_rr_s_2)(bus_space_handle_t, bus_size_t, uint16_t *,
>> + bus_size_t);
>> + void (*bs_rr_s_4)(bus_space_handle_t, bus_size_t, uint32_t *,
>> + bus_size_t);
>> + void (*bs_rr_s_8)(bus_space_handle_t, bus_size_t, uint64_t *,
>> + bus_size_t);
>> + /* write */
>> + void (*bs_w_1)(bus_space_handle_t, bus_size_t, uint8_t);
>> + void (*bs_w_2)(bus_space_handle_t, bus_size_t, uint16_t);
>> + void (*bs_w_4)(bus_space_handle_t, bus_size_t, uint32_t);
>> + void (*bs_w_8)(bus_space_handle_t, bus_size_t, uint64_t);
>> + void (*bs_w_s_2)(bus_space_handle_t, bus_size_t, uint16_t);
>> + void (*bs_w_s_4)(bus_space_handle_t, bus_size_t, uint32_t);
>> + void (*bs_w_s_8)(bus_space_handle_t, bus_size_t, uint64_t);
>> + void (*bs_wm_1)(bus_space_handle_t, bus_size_t,
>> + const uint8_t *, bus_size_t);
>> + void (*bs_wm_2)(bus_space_handle_t, bus_size_t,
>> + const uint16_t *, bus_size_t);
>> + void (*bs_wm_4)(bus_space_handle_t, bus_size_t,
>> + const uint32_t *, bus_size_t);
>> + void (*bs_wm_8)(bus_space_handle_t, bus_size_t,
>> + const uint64_t *, bus_size_t);
>> + void (*bs_wm_s_2)(bus_space_handle_t, bus_size_t,
>> + void (*bs_wm_s_4)(bus_space_handle_t, bus_size_t,
>> + void (*bs_wm_s_8)(bus_space_handle_t, bus_size_t,
>> + void (*bs_wr_1)(bus_space_handle_t, bus_size_t,
>> + void (*bs_wr_2)(bus_space_handle_t, bus_size_t,
>> + void (*bs_wr_4)(bus_space_handle_t, bus_size_t,
>> + void (*bs_wr_8)(bus_space_handle_t, bus_size_t,
>> + void (*bs_wr_s_2)(bus_space_handle_t, bus_size_t,
>> + void (*bs_wr_s_4)(bus_space_handle_t, bus_size_t,
>> + void (*bs_wr_s_8)(bus_space_handle_t, bus_size_t,
>> + void (*bs_sm_1)(bus_space_handle_t, bus_size_t, uint8_t,
>> + bus_size_t);
>> + void (*bs_sm_2)(bus_space_handle_t, bus_size_t, uint16_t,
>> + bus_size_t);
>> + void (*bs_sm_4)(bus_space_handle_t, bus_size_t, uint32_t,
>> + bus_size_t);
>> + void (*bs_sm_8)(bus_space_handle_t, bus_size_t, uint64_t,
>> + bus_size_t);
>> + void (*bs_sm_s_2)(bus_space_handle_t, bus_size_t, uint16_t,
>> + bus_size_t);
>> + void (*bs_sm_s_4)(bus_space_handle_t, bus_size_t, uint32_t,
>> + bus_size_t);
>> + void (*bs_sm_s_8)(bus_space_handle_t, bus_size_t, uint64_t,
>> + bus_size_t);
>> + /* set region */
>> + void (*bs_sr_1)(bus_space_handle_t, bus_size_t, uint8_t,
>> + bus_size_t);
>> + void (*bs_sr_2)(bus_space_handle_t, bus_size_t, uint16_t,
>> + bus_size_t);
>> + void (*bs_sr_4)(bus_space_handle_t, bus_size_t, uint32_t,
>> + bus_size_t);
>> + void (*bs_sr_8)(bus_space_handle_t, bus_size_t, uint64_t,
>> + bus_size_t);
>> + void (*bs_sr_s_2)(bus_space_handle_t, bus_size_t, uint16_t,
>> + bus_size_t);
>> + void (*bs_sr_s_4)(bus_space_handle_t, bus_size_t, uint32_t,
>> + bus_size_t);
>> + void (*bs_sr_s_8)(bus_space_handle_t, bus_size_t, uint64_t,
>> + bus_size_t);
>> + /* copy region */
>> + void (*bs_cr_1)(bus_space_handle_t, bus_size_t,
>> + void (*bs_cr_2)(bus_space_handle_t, bus_size_t,
>> + void (*bs_cr_4)(bus_space_handle_t, bus_size_t,
>> + void (*bs_cr_8)(bus_space_handle_t, bus_size_t,
>> + void (*bs_cr_s_2)(bus_space_handle_t, bus_size_t,
>> + void (*bs_cr_s_4)(bus_space_handle_t, bus_size_t,
>> + void (*bs_cr_s_8)(bus_space_handle_t, bus_size_t,
>> +extern struct bus_space bs_be_tag;
>> +extern struct bus_space bs_le_tag;
>> + (*(t)->__bs_opname(r,sz))(h, o)
>> + (*(t)->__bs_opname(w,sz))(h, o, v)
>> + (*(t)->__bs_opname(type,sz))(h, o, a, c)
>> + (*(t)->__bs_opname(type,sz))(h, o, v, c)
>> + (*(t)->__bs_opname(c,sz))(h1, o1, h2, o2, cnt)
>> +#define bus_space_map(t, a, s, c, hp) (*(t)->bs_map)(a, s, c, hp)
>> +#define bus_space_unmap(t, h, s) (*(t)->bs_unmap)(h, s)
>> +#define bus_space_subregion(t, h, o, s, hp) (*(t)->bs_subregion)(h, o, s, hp)
>> + (*(t)->bs_alloc)(rs, re, s, a, b, c, ap, hp)
>> + (*(t)->bs_free)(h, s)
>> +#define bus_space_barrier(t, h, o, l, f) (*(t)->bs_barrier)(h, o, l, f)
>> +#define bus_space_read_1(t, h, o) __bs_rs(1,t,h,o)
>> +#define bus_space_read_2(t, h, o) __bs_rs(2,t,h,o)
>> +#define bus_space_read_4(t, h, o) __bs_rs(4,t,h,o)
>> +#define bus_space_read_8(t, h, o) __bs_rs(8,t,h,o)
>> +#define bus_space_read_stream_1 bus_space_read_1
>> +#define bus_space_read_stream_2(t, h, o) __bs_rs(s_2,t,h,o)
>> +#define bus_space_read_stream_4(t, h, o) __bs_rs(s_4,t,h,o)
>> +#define bus_space_read_stream_8(t, h, o) __bs_rs(s_8,t,h,o)
>> +#define bus_space_read_multi_stream_1 bus_space_read_multi_1
>> + __bs_nonsingle(rm,s_2,(t),(h),(o),(a),(c))
>> + __bs_nonsingle(rm,s_4,(t),(h),(o),(a),(c))
>> + __bs_nonsingle(rm,s_8,(t),(h),(o),(a),(c))
>> +#define bus_space_read_region_stream_1 bus_space_read_region_1
>> + __bs_nonsingle(rr,s_2,(t),(h),(o),(a),(c))
>> + __bs_nonsingle(rr,s_4,(t),(h),(o),(a),(c))
>> + __bs_nonsingle(rr,s_8,(t),(h),(o),(a),(c))
>> +#define bus_space_write_stream_1 bus_space_write_1
>> +#define bus_space_write_stream_2(t, h, o, v) __bs_ws(s_2,(t),(h),(o),(v))
>> +#define bus_space_write_stream_4(t, h, o, v) __bs_ws(s_4,(t),(h),(o),(v))
>> +#define bus_space_write_stream_8(t, h, o, v) __bs_ws(s_8,(t),(h),(o),(v))
>> +#define bus_space_write_multi_stream_1 bus_space_write_multi_1
>> + __bs_nonsingle(wm,s_2,(t),(h),(o),(a),(c))
>> + __bs_nonsingle(wm,s_4,(t),(h),(o),(a),(c))
>> + __bs_nonsingle(wm,s_8,(t),(h),(o),(a),(c))
>> +#define bus_space_write_region_stream_1 bus_space_write_region_1
>> + __bs_nonsingle(wr,s_2,(t),(h),(o),(a),(c))
>> + __bs_nonsingle(wr,s_4,(t),(h),(o),(a),(c))
>> + __bs_nonsingle(wr,s_8,(t),(h),(o),(a),(c))
>> +#define bus_space_set_multi_stream_1 bus_space_set_multi_1
>> +#define bus_space_set_multi_stream_2(t, h, o, v, c) \
>> + __bs_set(sm,s_2,(t),(h),(o),(v),(c))
>> +#define bus_space_set_multi_stream_4(t, h, o, v, c) \
>> + __bs_set(sm,s_4,(t),(h),(o),(v),(c))
>> +#define bus_space_set_multi_stream_8(t, h, o, v, c) \
>> + __bs_set(sm,s_8,(t),(h),(o),(v),(c))
>> +#define bus_space_set_region_stream_1 bus_space_set_region_1
>> +#define bus_space_set_region_stream_2(t, h, o, v, c) \
>> + __bs_set(sr,s_2,(t),(h),(o),(v),(c))
>> +#define bus_space_set_region_stream_4(t, h, o, v, c) \
>> + __bs_set(sr,s_4,(t),(h),(o),(v),(c))
>> +#define bus_space_set_region_stream_8(t, h, o, v, c) \
>> + __bs_set(sr,s_8,(t),(h),(o),(v),(c))
>> +#if 0
>> +#define bus_space_copy_region_stream_1 bus_space_copy_region_1
>> +#define bus_space_copy_region_stream_2(t, h1, o1, h2, o2, c) \
>> + __bs_copy(s_2, t, h1, o1, h2, o2, c)
>> +#define bus_space_copy_region_stream_4(t, h1, o1, h2, o2, c) \
>> + __bs_copy(s_4, t, h1, o1, h2, o2, c)
>> +#define bus_space_copy_region_stream_8(t, h1, o1, h2, o2, c) \
>> + __bs_copy(s_8, t, h1, o1, h2, o2, c)
>> +#endif
>> diff --git a/freebsd/sys/riscv/include/machine/_bus.h b/freebsd/sys/riscv/include/machine/_bus.h
>> --- /dev/null
>> +++ b/freebsd/sys/riscv/include/machine/_bus.h
>> @@ -0,0 +1,46 @@
>> + * are met:
>> + * distribution.
>> + * SUCH DAMAGE.
>> + * $FreeBSD$
>> diff --git a/freebsd/sys/riscv/include/machine/bus.h b/freebsd/sys/riscv/include/machine/bus.h
>> --- /dev/null
>> +++ b/freebsd/sys/riscv/include/machine/bus.h
>> @@ -0,0 +1,469 @@
>> + * are met:
>> + * are met:
>> + * $FreeBSD$
>> +struct bus_space {
>> + /* cookie */
>> + void *bs_cookie;
>> + bus_size_t);
>> + /* barrier */
>> + /* read single */
>> + /* read region */
>> + /* set region */
>> + /* copy */
>> + (c), (ap), (hp))
>> diff --git a/freebsd/sys/riscv/include/machine/cpufunc.h b/freebsd/sys/riscv/include/machine/cpufunc.h
>> index 00000000..0f27fc45
>> --- /dev/null
>> +++ b/freebsd/sys/riscv/include/machine/cpufunc.h
>> @@ -0,0 +1,135 @@
>> + * Copyright (c) 2015-2016 Ruslan Bukin <br at bsdpad.com>
>> + * Portions of this software were developed by SRI International and the
>> + * University of Cambridge Computer Laboratory under DARPA/AFRL contract
>> + * FA8750-10-C-0237 ("CTSRD"), as part of the DARPA CRASH research programme.
>> + * Portions of this software were developed by the University of Cambridge
>> + * Computer Laboratory as part of the CTSRD Project, with support from the
>> + * UK Higher Education Innovation Fund (HEIF).
>> + * are met:
>> + * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
>> + * SUCH DAMAGE.
>> + * $FreeBSD$
>> +#ifndef _MACHINE_CPUFUNC_H_
>> +#define _MACHINE_CPUFUNC_H_
>> +static __inline void
>> +breakpoint(void)
>> + __asm("ebreak");
>> +#ifdef _KERNEL
>> +#include <machine/riscvreg.h>
>> +static __inline register_t
>> +intr_disable(void)
>> + uint64_t ret;
>> + __asm __volatile(
>> + "csrrci %0, sstatus, %1"
>> + : "=&r" (ret) : "i" (SSTATUS_SIE)
>> + return (ret & (SSTATUS_SIE));
>> +intr_restore(register_t s)
>> + __asm __volatile(
>> + "csrs sstatus, %0"
>> + :: "r" (s)
>> +intr_enable(void)
>> + __asm __volatile(
>> + "csrsi sstatus, %0"
>> + :: "i" (SSTATUS_SIE)
>> +/* NB: fence() is defined as a macro in <machine/atomic.h>. */
>> +fence_i(void)
>> + __asm __volatile("fence.i" ::: "memory");
>> +sfence_vma(void)
>> + __asm __volatile("sfence.vma" ::: "memory");
>> +sfence_vma_page(uintptr_t addr)
>> + __asm __volatile("sfence.vma %0" :: "r" (addr) : "memory");
>> +#define rdcycle() csr_read64(cycle)
>> +#define rdtime() csr_read64(time)
>> +#define rdinstret() csr_read64(instret)
>> +#define rdhpmcounter(n) csr_read64(hpmcounter##n)
>> +extern int64_t dcache_line_size;
>> +extern int64_t icache_line_size;
>> +#define cpu_dcache_wbinv_range(a, s)
>> +#define cpu_dcache_inv_range(a, s)
>> +#define cpu_dcache_wb_range(a, s)
>> +#define cpu_idcache_wbinv_range(a, s)
>> +#define cpu_icache_sync_range(a, s)
>> +#define cpu_icache_sync_range_checked(a, s)
>> +load_satp(uint64_t val)
>> + __asm __volatile("csrw satp, %0" :: "r"(val));
>> +#define cpufunc_nullop() riscv_nullop()
>> +void riscv_nullop(void);
>> +#endif /* _KERNEL */
>> +#endif /* _MACHINE_CPUFUNC_H_ */
>> diff --git a/freebsd/sys/riscv/include/machine/riscvreg.h b/freebsd/sys/riscv/include/machine/riscvreg.h
>> index 00000000..ab99ed8a
>> --- /dev/null
>> +++ b/freebsd/sys/riscv/include/machine/riscvreg.h
>> @@ -0,0 +1,246 @@
>> + * Copyright (c) 2015-2017 Ruslan Bukin <br at bsdpad.com>
>> + * are met:
>> + * SUCH DAMAGE.
>> + * $FreeBSD$
>> +#ifndef _MACHINE_RISCVREG_H_
>> +#define _MACHINE_RISCVREG_H_
>> +#define EXCP_SHIFT 0
>> +#define EXCP_MASK (0xf << EXCP_SHIFT)
>> +#define EXCP_MISALIGNED_FETCH 0
>> +#define EXCP_FAULT_FETCH 1
>> +#define EXCP_ILLEGAL_INSTRUCTION 2
>> +#define EXCP_BREAKPOINT 3
>> +#define EXCP_MISALIGNED_LOAD 4
>> +#define EXCP_FAULT_LOAD 5
>> +#define EXCP_MISALIGNED_STORE 6
>> +#define EXCP_FAULT_STORE 7
>> +#define EXCP_USER_ECALL 8
>> +#define EXCP_SUPERVISOR_ECALL 9
>> +#define EXCP_HYPERVISOR_ECALL 10
>> +#define EXCP_MACHINE_ECALL 11
>> +#define EXCP_INST_PAGE_FAULT 12
>> +#define EXCP_LOAD_PAGE_FAULT 13
>> +#define EXCP_STORE_PAGE_FAULT 15
>> +#define EXCP_INTR (1ul << 63)
>> +#define SSTATUS_UIE (1 << 0)
>> +#define SSTATUS_SIE (1 << 1)
>> +#define SSTATUS_UPIE (1 << 4)
>> +#define SSTATUS_SPIE (1 << 5)
>> +#define SSTATUS_SPIE_SHIFT 5
>> +#define SSTATUS_SPP (1 << 8)
>> +#define SSTATUS_SPP_SHIFT 8
>> +#define SSTATUS_FS_SHIFT 13
>> +#define SSTATUS_FS_OFF (0x0 << SSTATUS_FS_SHIFT)
>> +#define SSTATUS_FS_INITIAL (0x1 << SSTATUS_FS_SHIFT)
>> +#define SSTATUS_FS_CLEAN (0x2 << SSTATUS_FS_SHIFT)
>> +#define SSTATUS_FS_DIRTY (0x3 << SSTATUS_FS_SHIFT)
>> +#define SSTATUS_FS_MASK (0x3 << SSTATUS_FS_SHIFT)
>> +#define SSTATUS_XS_SHIFT 15
>> +#define SSTATUS_XS_MASK (0x3 << SSTATUS_XS_SHIFT)
>> +#define SSTATUS_SUM (1 << 18)
>> +#define SSTATUS32_SD (1 << 63)
>> +#define SSTATUS64_SD (1 << 31)
>> +#define MSTATUS_UIE (1 << 0)
>> +#define MSTATUS_SIE (1 << 1)
>> +#define MSTATUS_HIE (1 << 2)
>> +#define MSTATUS_MIE (1 << 3)
>> +#define MSTATUS_UPIE (1 << 4)
>> +#define MSTATUS_SPIE (1 << 5)
>> +#define MSTATUS_SPIE_SHIFT 5
>> +#define MSTATUS_HPIE (1 << 6)
>> +#define MSTATUS_MPIE (1 << 7)
>> +#define MSTATUS_MPIE_SHIFT 7
>> +#define MSTATUS_SPP (1 << 8)
>> +#define MSTATUS_SPP_SHIFT 8
>> +#define MSTATUS_HPP_MASK 0x3
>> +#define MSTATUS_HPP_SHIFT 9
>> +#define MSTATUS_MPP_MASK 0x3
>> +#define MSTATUS_MPP_SHIFT 11
>> +#define MSTATUS_FS_MASK 0x3
>> +#define MSTATUS_FS_SHIFT 13
>> +#define MSTATUS_XS_MASK 0x3
>> +#define MSTATUS_XS_SHIFT 15
>> +#define MSTATUS_MPRV (1 << 17)
>> +#define MSTATUS_PUM (1 << 18)
>> +#define MSTATUS_VM_MASK 0x1f
>> +#define MSTATUS_VM_SHIFT 24
>> +#define MSTATUS_VM_MBARE 0
>> +#define MSTATUS_VM_MBB 1
>> +#define MSTATUS_VM_MBBID 2
>> +#define MSTATUS_VM_SV32 8
>> +#define MSTATUS_VM_SV39 9
>> +#define MSTATUS_VM_SV48 10
>> +#define MSTATUS_VM_SV57 11
>> +#define MSTATUS_VM_SV64 12
>> +#define MSTATUS32_SD (1 << 63)
>> +#define MSTATUS64_SD (1 << 31)
>> +#define MSTATUS_PRV_U 0 /* user */
>> +#define MSTATUS_PRV_S 1 /* supervisor */
>> +#define MSTATUS_PRV_H 2 /* hypervisor */
>> +#define MSTATUS_PRV_M 3 /* machine */
>> +#define MIE_USIE (1 << 0)
>> +#define MIE_SSIE (1 << 1)
>> +#define MIE_HSIE (1 << 2)
>> +#define MIE_MSIE (1 << 3)
>> +#define MIE_UTIE (1 << 4)
>> +#define MIE_STIE (1 << 5)
>> +#define MIE_HTIE (1 << 6)
>> +#define MIE_MTIE (1 << 7)
>> +#define MIP_USIP (1 << 0)
>> +#define MIP_SSIP (1 << 1)
>> +#define MIP_HSIP (1 << 2)
>> +#define MIP_MSIP (1 << 3)
>> +#define MIP_UTIP (1 << 4)
>> +#define MIP_STIP (1 << 5)
>> +#define MIP_HTIP (1 << 6)
>> +#define MIP_MTIP (1 << 7)
>> +#define SIE_USIE (1 << 0)
>> +#define SIE_SSIE (1 << 1)
>> +#define SIE_UTIE (1 << 4)
>> +#define SIE_STIE (1 << 5)
>> +#define SIE_UEIE (1 << 8)
>> +#define SIE_SEIE (1 << 9)
>> +#define MIP_SEIP (1 << 9)
>> +/* Note: sip register has no SIP_STIP bit in Spike simulator */
>> +#define SIP_SSIP (1 << 1)
>> +#define SIP_STIP (1 << 5)
>> +#define SATP_PPN_S 0
>> +#define SATP_PPN_M (0xfffffffffff << SATP_PPN_S)
>> +#define SATP_ASID_S 44
>> +#define SATP_ASID_M (0xffff << SATP_ASID_S)
>> +#define SATP_MODE_S 60
>> +#define SATP_MODE_M (0xf << SATP_MODE_S)
>> +#define SATP_MODE_SV39 (8ULL << SATP_MODE_S)
>> +#define SATP_MODE_SV48 (9ULL << SATP_MODE_S)
>> +#define XLEN __riscv_xlen
>> +#define XLEN_BYTES (XLEN / 8)
>> +#define INSN_SIZE 4
>> +#define INSN_C_SIZE 2
>> +#define X_RA 1
>> +#define X_SP 2
>> +#define X_GP 3
>> +#define X_TP 4
>> +#define X_T0 5
>> +#define X_T1 6
>> +#define X_T2 7
>> +#define X_T3 28
>> +#define RD_SHIFT 7
>> +#define RD_MASK (0x1f << RD_SHIFT)
>> +#define RS1_SHIFT 15
>> +#define RS1_MASK (0x1f << RS1_SHIFT)
>> +#define RS1_SP (X_SP << RS1_SHIFT)
>> +#define RS2_SHIFT 20
>> +#define RS2_MASK (0x1f << RS2_SHIFT)
>> +#define RS2_RA (X_RA << RS2_SHIFT)
>> +#define IMM_SHIFT 20
>> +#define IMM_MASK (0xfff << IMM_SHIFT)
>> +#define RS2_C_SHIFT 2
>> +#define RS2_C_MASK (0x1f << RS2_C_SHIFT)
>> +#define RS2_C_RA (X_RA << RS2_C_SHIFT)
>> +#define CSR_ZIMM(val) \
>> + (__builtin_constant_p(val) && ((u_long)(val) < 32))
>> +#define csr_swap(csr, val) \
>> +({ if (CSR_ZIMM(val)) \
>> + __asm __volatile("csrrwi %0, " #csr ", %1" \
>> + : "=r" (val) : "i" (val)); \
>> + else \
>> + __asm __volatile("csrrw %0, " #csr ", %1" \
>> + : "=r" (val) : "r" (val)); \
>> + val; \
>> +#define csr_write(csr, val) \
>> + __asm __volatile("csrwi " #csr ", %0" :: "i" (val)); \
>> + else \
>> + __asm __volatile("csrw " #csr ", %0" :: "r" (val)); \
>> +#define csr_set(csr, val) \
>> + __asm __volatile("csrsi " #csr ", %0" :: "i" (val)); \
>> + else \
>> + __asm __volatile("csrs " #csr ", %0" :: "r" (val)); \
>> +#define csr_clear(csr, val) \
>> + __asm __volatile("csrci " #csr ", %0" :: "i" (val)); \
>> + else \
>> + __asm __volatile("csrc " #csr ", %0" :: "r" (val)); \
>> +#define csr_read(csr) \
>> +({ u_long val; \
>> + __asm __volatile("csrr %0, " #csr : "=r" (val)); \
>> + val; \
>> +#if __riscv_xlen == 32
>> +#define csr_read64(csr) \
>> +({ uint64_t val; \
>> + uint32_t high, low; \
>> + __asm __volatile("1: " \
>> + "csrr t0, " #csr "h\n" \
>> + "csrr %0, " #csr "\n" \
>> + "csrr %1, " #csr "h\n" \
>> + "bne t0, %1, 1b" \
>> + : "=r" (low), "=r" (high) \
>> + : "t0"); \
>> + val = (low | ((uint64_t)high << 32)); \
>> + val; \
>> +#else
>> +#define csr_read64(csr) ((uint64_t)csr_read(csr))
>> +#endif
>> +#endif /* !_MACHINE_RISCVREG_H_ */
>> diff --git a/rtemsbsd/include/machine/_bus.h b/freebsd/sys/sparc/include/machine/_bus.h
>> similarity index 100%
>> rename from rtemsbsd/include/machine/_bus.h
>> rename to freebsd/sys/sparc/include/machine/_bus.h
>> diff --git a/rtemsbsd/include/machine/bus.h b/freebsd/sys/sparc/include/machine/bus.h
>> rename from rtemsbsd/include/machine/bus.h
>> rename to freebsd/sys/sparc/include/machine/bus.h
>> diff --git a/freebsd/sys/sparc/include/machine/cpufunc.h b/freebsd/sys/sparc/include/machine/cpufunc.h
>> index 00000000..e69de29b
>> diff --git a/freebsd/sys/sparc64/include/machine/_bus.h b/freebsd/sys/sparc64/include/machine/_bus.h
>> index 00000000..55496461
>> --- /dev/null
>> +++ b/freebsd/sys/sparc64/include/machine/_bus.h
>> @@ -0,0 +1,41 @@
>> + * are met:
>> + * distribution.
>> + * SUCH DAMAGE.
>> + * $FreeBSD$
>> +#ifndef SPARC64_INCLUDE__BUS_H
>> +#define SPARC64_INCLUDE__BUS_H
>> +typedef struct bus_space_tag *bus_space_tag_t;
>> +#endif /* SPARC64_INCLUDE__BUS_H */
>> diff --git a/freebsd/sys/sparc64/include/machine/bus.h b/freebsd/sys/sparc64/include/machine/bus.h
>> index 00000000..e36c6863
>> --- /dev/null
>> +++ b/freebsd/sys/sparc64/include/machine/bus.h
>> @@ -0,0 +1,852 @@
>> + * are met:
>> + * Copyright (c) 1997-1999 Eduardo E. Horvath. All rights reserved.
>> + * are met:
>> + * from: NetBSD: bus.h,v 1.58 2008/04/28 20:23:36 martin Exp
>> + * and
>> + * from: FreeBSD: src/sys/alpha/include/bus.h,v 1.9 2001/01/09
>> + * $FreeBSD$
>> +#ifdef BUS_SPACE_DEBUG
>> +#include <sys/ktr.h>
>> +#endif
>> +#include <machine/cpufunc.h>
>> + * Nexus and SBus spaces are non-cached and big endian
>> + * (except for RAM and PROM)
>> + * PCI spaces are non-cached and little endian
>> +#define NEXUS_BUS_SPACE 0
>> +#define SBUS_BUS_SPACE 1
>> +#define PCI_CONFIG_BUS_SPACE 2
>> +#define PCI_IO_BUS_SPACE 3
>> +#define PCI_MEMORY_BUS_SPACE 4
>> +#define LAST_BUS_SPACE 5
>> +extern const int bus_type_asi[];
>> +extern const int bus_stream_asi[];
>> +#define __BUS_SPACE_HAS_STREAM_METHODS 1
>> +struct bus_space_tag {
>> + void *bst_cookie;
>> + int bst_type;
>> + * Bus space function prototypes.
>> +static void bus_space_barrier(bus_space_tag_t, bus_space_handle_t, bus_size_t,
>> + bus_size_t, int);
>> +static int bus_space_subregion(bus_space_tag_t, bus_space_handle_t,
>> + * Map a region of device bus space into CPU virtual address space.
>> +int bus_space_map(bus_space_tag_t tag, bus_addr_t address, bus_size_t size,
>> + int flags, bus_space_handle_t *handlep);
>> + * Unmap a region of device bus space.
>> +void bus_space_unmap(bus_space_tag_t tag, bus_space_handle_t handle,
>> + bus_size_t size);
>> +bus_space_barrier(bus_space_tag_t t __unused, bus_space_handle_t h __unused,
>> + bus_size_t o __unused, bus_size_t s __unused, int f __unused)
>> + * We have lots of alternatives depending on whether we're
>> + * synchronizing loads with loads, loads with stores, stores
>> + * with loads, or stores with stores. The only ones that seem
>> + * generic are #Sync and #MemIssue. We use #Sync for safety.
>> + membar(Sync);
>> +static __inline int
>> +bus_space_subregion(bus_space_tag_t t __unused, bus_space_handle_t h,
>> + bus_size_t o __unused, bus_size_t s __unused, bus_space_handle_t *hp)
>> + *hp = h + o;
>> + return (0);
>> +/* flags for bus space map functions */
>> +#define BUS_SPACE_MAP_CACHEABLE 0x0001
>> +#define BUS_SPACE_MAP_LINEAR 0x0002
>> +#define BUS_SPACE_MAP_READONLY 0x0004
>> +#define BUS_SPACE_MAP_PREFETCHABLE 0x0008
>> +/* placeholders for bus functions... */
>> +#define BUS_SPACE_MAP_BUS1 0x0100
>> +#define BUS_SPACE_MAP_BUS2 0x0200
>> +#define BUS_SPACE_MAP_BUS3 0x0400
>> +#define BUS_SPACE_MAP_BUS4 0x0800
>> +/* flags for bus_space_barrier() */
>> +#define BUS_SPACE_BARRIER_READ 0x01 /* force read barrier */
>> +#define BUS_SPACE_BARRIER_WRITE 0x02 /* force write barrier */
>> +#define KTR_BUS KTR_SPARE2
>> +#define __BUS_DEBUG_ACCESS(h, o, desc, sz) do { \
>> + CTR4(KTR_BUS, "bus space: %s %d: handle %#lx, offset %#lx", \
>> + (desc), (sz), (h), (o)); \
>> +} while (0)
>> +#else
>> +#endif
>> +static __inline uint8_t
>> +bus_space_read_1(bus_space_tag_t t, bus_space_handle_t h, bus_size_t o)
>> + __BUS_DEBUG_ACCESS(h, o, "read", 1);
>> + return (lduba_nc((caddr_t)(h + o), bus_type_asi[t->bst_type]));
>> +static __inline uint16_t
>> +bus_space_read_2(bus_space_tag_t t, bus_space_handle_t h, bus_size_t o)
>> + __BUS_DEBUG_ACCESS(h, o, "read", 2);
>> + return (lduha_nc((caddr_t)(h + o), bus_type_asi[t->bst_type]));
>> +static __inline uint32_t
>> +bus_space_read_4(bus_space_tag_t t, bus_space_handle_t h, bus_size_t o)
>> + __BUS_DEBUG_ACCESS(h, o, "read", 4);
>> + return (lduwa_nc((caddr_t)(h + o), bus_type_asi[t->bst_type]));
>> +static __inline uint64_t
>> +bus_space_read_8(bus_space_tag_t t, bus_space_handle_t h, bus_size_t o)
>> + __BUS_DEBUG_ACCESS(h, o, "read", 8);
>> + return (ldxa_nc((caddr_t)(h + o), bus_type_asi[t->bst_type]));
>> +bus_space_read_multi_1(bus_space_tag_t t, bus_space_handle_t h, bus_size_t o,
>> + uint8_t *a, size_t c)
>> + while (c-- > 0)
>> + *a++ = bus_space_read_1(t, h, o);
>> +bus_space_read_multi_2(bus_space_tag_t t, bus_space_handle_t h, bus_size_t o,
>> + uint16_t *a, size_t c)
>> + while (c-- > 0)
>> + *a++ = bus_space_read_2(t, h, o);
>> +bus_space_read_multi_4(bus_space_tag_t t, bus_space_handle_t h, bus_size_t o,
>> + uint32_t *a, size_t c)
>> + while (c-- > 0)
>> + *a++ = bus_space_read_4(t, h, o);
>> +bus_space_read_multi_8(bus_space_tag_t t, bus_space_handle_t h, bus_size_t o,
>> + uint64_t *a, size_t c)
>> + while (c-- > 0)
>> + *a++ = bus_space_read_8(t, h, o);
>> +bus_space_write_1(bus_space_tag_t t, bus_space_handle_t h, bus_size_t o,
>> + uint8_t v)
>> + __BUS_DEBUG_ACCESS(h, o, "write", 1);
>> + stba_nc((caddr_t)(h + o), bus_type_asi[t->bst_type], v);
>> +bus_space_write_2(bus_space_tag_t t, bus_space_handle_t h, bus_size_t o,
>> + uint16_t v)
>> + __BUS_DEBUG_ACCESS(h, o, "write", 2);
>> + stha_nc((caddr_t)(h + o), bus_type_asi[t->bst_type], v);
>> +bus_space_write_4(bus_space_tag_t t, bus_space_handle_t h, bus_size_t o,
>> + uint32_t v)
>> + __BUS_DEBUG_ACCESS(h, o, "write", 4);
>> + stwa_nc((caddr_t)(h + o), bus_type_asi[t->bst_type], v);
>> +bus_space_write_8(bus_space_tag_t t, bus_space_handle_t h, bus_size_t o,
>> + uint64_t v)
>> + __BUS_DEBUG_ACCESS(h, o, "write", 8);
>> + stxa_nc((caddr_t)(h + o), bus_type_asi[t->bst_type], v);
>> +bus_space_write_multi_1(bus_space_tag_t t, bus_space_handle_t h, bus_size_t o,
>> + const uint8_t *a, size_t c)
>> + while (c-- > 0)
>> + bus_space_write_1(t, h, o, *a++);
>> +bus_space_write_multi_2(bus_space_tag_t t, bus_space_handle_t h, bus_size_t o,
>> + const uint16_t *a, size_t c)
>> + while (c-- > 0)
>> + bus_space_write_2(t, h, o, *a++);
>> +bus_space_write_multi_4(bus_space_tag_t t, bus_space_handle_t h, bus_size_t o,
>> + const uint32_t *a, size_t c)
>> + while (c-- > 0)
>> + bus_space_write_4(t, h, o, *a++);
>> +bus_space_write_multi_8(bus_space_tag_t t, bus_space_handle_t h, bus_size_t o,
>> + const uint64_t *a, size_t c)
>> + while (c-- > 0)
>> + bus_space_write_8(t, h, o, *a++);
>> +bus_space_set_multi_1(bus_space_tag_t t, bus_space_handle_t h, bus_size_t o,
>> + uint8_t v, size_t c)
>> + while (c-- > 0)
>> + bus_space_write_1(t, h, o, v);
>> +bus_space_set_multi_2(bus_space_tag_t t, bus_space_handle_t h, bus_size_t o,
>> + uint16_t v, size_t c)
>> + while (c-- > 0)
>> + bus_space_write_2(t, h, o, v);
>> +bus_space_set_multi_4(bus_space_tag_t t, bus_space_handle_t h, bus_size_t o,
>> + uint32_t v, size_t c)
>> + while (c-- > 0)
>> + bus_space_write_4(t, h, o, v);
>> +bus_space_set_multi_8(bus_space_tag_t t, bus_space_handle_t h, bus_size_t o,
>> + uint64_t v, size_t c)
>> + while (c-- > 0)
>> + bus_space_write_8(t, h, o, v);
>> +bus_space_read_region_1(bus_space_tag_t t, bus_space_handle_t h, bus_size_t o,
>> + uint8_t *a, bus_size_t c)
>> + for (; c; a++, c--, o++)
>> + *a = bus_space_read_1(t, h, o);
>> +bus_space_read_region_2(bus_space_tag_t t, bus_space_handle_t h, bus_size_t o,
>> + uint16_t *a, bus_size_t c)
>> + for (; c; a++, c--, o += 2)
>> + *a = bus_space_read_2(t, h, o);
>> +bus_space_read_region_4(bus_space_tag_t t, bus_space_handle_t h, bus_size_t o,
>> + uint32_t *a, bus_size_t c)
>> + for (; c; a++, c--, o += 4)
>> + *a = bus_space_read_4(t, h, o);
>> +bus_space_read_region_8(bus_space_tag_t t, bus_space_handle_t h, bus_size_t o,
>> + uint64_t *a, bus_size_t c)
>> + for (; c; a++, c--, o += 8)
>> + *a = bus_space_read_8(t, h, o);
>> +bus_space_write_region_1(bus_space_tag_t t, bus_space_handle_t h, bus_size_t o,
>> + const uint8_t *a, bus_size_t c)
>> + bus_space_write_1(t, h, o, *a);
>> +bus_space_write_region_2(bus_space_tag_t t, bus_space_handle_t h, bus_size_t o,
>> + const uint16_t *a, bus_size_t c)
>> + bus_space_write_2(t, h, o, *a);
>> +bus_space_write_region_4(bus_space_tag_t t, bus_space_handle_t h, bus_size_t o,
>> + const uint32_t *a, bus_size_t c)
>> + bus_space_write_4(t, h, o, *a);
>> +bus_space_write_region_8(bus_space_tag_t t, bus_space_handle_t h, bus_size_t o,
>> + const uint64_t *a, bus_size_t c)
>> + bus_space_write_8(t, h, o, *a);
>> +bus_space_set_region_1(bus_space_tag_t t, bus_space_handle_t h, bus_size_t o,
>> + const uint8_t v, bus_size_t c)
>> + for (; c; c--, o++)
>> +bus_space_set_region_2(bus_space_tag_t t, bus_space_handle_t h, bus_size_t o,
>> + const uint16_t v, bus_size_t c)
>> + for (; c; c--, o += 2)
>> +bus_space_set_region_4(bus_space_tag_t t, bus_space_handle_t h, bus_size_t o,
>> + const uint32_t v, bus_size_t c)
>> + for (; c; c--, o += 4)
>> +bus_space_set_region_8(bus_space_tag_t t, bus_space_handle_t h, bus_size_t o,
>> + const uint64_t v, bus_size_t c)
>> + for (; c; c--, o += 8)
>> +bus_space_copy_region_1(bus_space_tag_t t, bus_space_handle_t h1,
>> + bus_size_t o1, bus_space_handle_t h2, bus_size_t o2, bus_size_t c)
>> + for (; c; c--, o1++, o2++)
>> + bus_space_write_1(t, h1, o1, bus_space_read_1(t, h2, o2));
>> +bus_space_copy_region_2(bus_space_tag_t t, bus_space_handle_t h1,
>> + for (; c; c--, o1 += 2, o2 += 2)
>> + bus_space_write_2(t, h1, o1, bus_space_read_2(t, h2, o2));
>> +bus_space_copy_region_4(bus_space_tag_t t, bus_space_handle_t h1,
>> + for (; c; c--, o1 += 4, o2 += 4)
>> + bus_space_write_4(t, h1, o1, bus_space_read_4(t, h2, o2));
>> +bus_space_copy_region_8(bus_space_tag_t t, bus_space_handle_t h1,
>> + for (; c; c--, o1 += 8, o2 += 8)
>> + bus_space_write_8(t, h1, o1, bus_space_read_8(t, h2, o2));
>> +bus_space_read_stream_1(bus_space_tag_t t, bus_space_handle_t h, bus_size_t o)
>> + __BUS_DEBUG_ACCESS(h, o, "read stream", 1);
>> + return (lduba_nc((caddr_t)(h + o), bus_stream_asi[t->bst_type]));
>> +bus_space_read_stream_2(bus_space_tag_t t, bus_space_handle_t h, bus_size_t o)
>> + __BUS_DEBUG_ACCESS(h, o, "read stream", 2);
>> + return (lduha_nc((caddr_t)(h + o), bus_stream_asi[t->bst_type]));
>> +bus_space_read_stream_4(bus_space_tag_t t, bus_space_handle_t h, bus_size_t o)
>> + __BUS_DEBUG_ACCESS(h, o, "read stream", 4);
>> + return (lduwa_nc((caddr_t)(h + o), bus_stream_asi[t->bst_type]));
>> +bus_space_read_stream_8(bus_space_tag_t t, bus_space_handle_t h, bus_size_t o)
>> + __BUS_DEBUG_ACCESS(h, o, "read stream", 8);
>> + return (ldxa_nc((caddr_t)(h + o), bus_stream_asi[t->bst_type]));
>> +bus_space_read_multi_stream_1(bus_space_tag_t t, bus_space_handle_t h,
>> + bus_size_t o, uint8_t *a, size_t c)
>> + while (c-- > 0)
>> + *a++ = bus_space_read_stream_1(t, h, o);
>> +bus_space_read_multi_stream_2(bus_space_tag_t t, bus_space_handle_t h,
>> + bus_size_t o, uint16_t *a, size_t c)
>> + while (c-- > 0)
>> + *a++ = bus_space_read_stream_2(t, h, o);
>> +bus_space_read_multi_stream_4(bus_space_tag_t t, bus_space_handle_t h,
>> + bus_size_t o, uint32_t *a, size_t c)
>> + while (c-- > 0)
>> + *a++ = bus_space_read_stream_4(t, h, o);
>> +bus_space_read_multi_stream_8(bus_space_tag_t t, bus_space_handle_t h,
>> + bus_size_t o, uint64_t *a, size_t c)
>> + while (c-- > 0)
>> + *a++ = bus_space_read_stream_8(t, h, o);
>> +bus_space_write_stream_1(bus_space_tag_t t, bus_space_handle_t h, bus_size_t o,
>> + uint8_t v)
>> + __BUS_DEBUG_ACCESS(h, o, "write stream", 1);
>> + stba_nc((caddr_t)(h + o), bus_stream_asi[t->bst_type], v);
>> +bus_space_write_stream_2(bus_space_tag_t t, bus_space_handle_t h, bus_size_t o,
>> + uint16_t v)
>> + __BUS_DEBUG_ACCESS(h, o, "write stream", 2);
>> + stha_nc((caddr_t)(h + o), bus_stream_asi[t->bst_type], v);
>> +bus_space_write_stream_4(bus_space_tag_t t, bus_space_handle_t h, bus_size_t o,
>> + uint32_t v)
>> + __BUS_DEBUG_ACCESS(h, o, "write stream", 4);
>> + stwa_nc((caddr_t)(h + o), bus_stream_asi[t->bst_type], v);
>> +bus_space_write_stream_8(bus_space_tag_t t, bus_space_handle_t h, bus_size_t o,
>> + uint64_t v)
>> + __BUS_DEBUG_ACCESS(h, o, "write stream", 8);
>> + stxa_nc((caddr_t)(h + o), bus_stream_asi[t->bst_type], v);
>> +bus_space_write_multi_stream_1(bus_space_tag_t t, bus_space_handle_t h,
>> + bus_size_t o, const uint8_t *a, size_t c)
>> + while (c-- > 0)
>> + bus_space_write_stream_1(t, h, o, *a++);
>> +bus_space_write_multi_stream_2(bus_space_tag_t t, bus_space_handle_t h,
>> + bus_size_t o, const uint16_t *a, size_t c)
>> + while (c-- > 0)
>> + bus_space_write_stream_2(t, h, o, *a++);
>> +bus_space_write_multi_stream_4(bus_space_tag_t t, bus_space_handle_t h,
>> + bus_size_t o, const uint32_t *a, size_t c)
>> + while (c-- > 0)
>> + bus_space_write_stream_4(t, h, o, *a++);
>> +bus_space_write_multi_stream_8(bus_space_tag_t t, bus_space_handle_t h,
>> + bus_size_t o, const uint64_t *a, size_t c)
>> + while (c-- > 0)
>> + bus_space_write_stream_8(t, h, o, *a++);
>> +bus_space_set_multi_stream_1(bus_space_tag_t t, bus_space_handle_t h,
>> + bus_size_t o, uint8_t v, size_t c)
>> + while (c-- > 0)
>> + bus_space_write_stream_1(t, h, o, v);
>> +bus_space_set_multi_stream_2(bus_space_tag_t t, bus_space_handle_t h,
>> + bus_size_t o, uint16_t v, size_t c)
>> + while (c-- > 0)
>> + bus_space_write_stream_2(t, h, o, v);
>> +bus_space_set_multi_stream_4(bus_space_tag_t t, bus_space_handle_t h,
>> + bus_size_t o, uint32_t v, size_t c)
>> + while (c-- > 0)
>> + bus_space_write_stream_4(t, h, o, v);
>> +bus_space_set_multi_stream_8(bus_space_tag_t t, bus_space_handle_t h,
>> + bus_size_t o, uint64_t v, size_t c)
>> + while (c-- > 0)
>> + bus_space_write_stream_8(t, h, o, v);
>> +bus_space_read_region_stream_1(bus_space_tag_t t, bus_space_handle_t h,
>> + bus_size_t o, uint8_t *a, bus_size_t c)
>> + *a = bus_space_read_stream_1(t, h, o);
>> +bus_space_read_region_stream_2(bus_space_tag_t t, bus_space_handle_t h,
>> + bus_size_t o, uint16_t *a, bus_size_t c)
>> + *a = bus_space_read_stream_2(t, h, o);
>> +bus_space_read_region_stream_4(bus_space_tag_t t, bus_space_handle_t h,
>> + bus_size_t o, uint32_t *a, bus_size_t c)
>> + *a = bus_space_read_stream_4(t, h, o);
>> +bus_space_read_region_stream_8(bus_space_tag_t t, bus_space_handle_t h,
>> + bus_size_t o, uint64_t *a, bus_size_t c)
>> + *a = bus_space_read_stream_8(t, h, o);
>> +bus_space_write_region_stream_1(bus_space_tag_t t, bus_space_handle_t h,
>> + bus_size_t o, const uint8_t *a, bus_size_t c)
>> + bus_space_write_stream_1(t, h, o, *a);
>> +bus_space_write_region_stream_2(bus_space_tag_t t, bus_space_handle_t h,
>> + bus_size_t o, const uint16_t *a, bus_size_t c)
>> + bus_space_write_stream_2(t, h, o, *a);
>> +bus_space_write_region_stream_4(bus_space_tag_t t, bus_space_handle_t h,
>> + bus_size_t o, const uint32_t *a, bus_size_t c)
>> + bus_space_write_stream_4(t, h, o, *a);
>> +bus_space_write_region_stream_8(bus_space_tag_t t, bus_space_handle_t h,
>> + bus_size_t o, const uint64_t *a, bus_size_t c)
>> + bus_space_write_stream_8(t, h, o, *a);
>> +bus_space_set_region_stream_1(bus_space_tag_t t, bus_space_handle_t h,
>> + bus_size_t o, const uint8_t v, bus_size_t c)
>> +bus_space_set_region_stream_2(bus_space_tag_t t, bus_space_handle_t h,
>> + bus_size_t o, const uint16_t v, bus_size_t c)
>> +bus_space_set_region_stream_4(bus_space_tag_t t, bus_space_handle_t h,
>> + bus_size_t o, const uint32_t v, bus_size_t c)
>> +bus_space_set_region_stream_8(bus_space_tag_t t, bus_space_handle_t h,
>> + bus_size_t o, const uint64_t v, bus_size_t c)
>> +bus_space_copy_region_stream_1(bus_space_tag_t t, bus_space_handle_t h1,
>> + bus_space_write_stream_1(t, h1, o1, bus_space_read_stream_1(t, h2,
>> + o2));
>> +bus_space_copy_region_stream_2(bus_space_tag_t t, bus_space_handle_t h1,
>> + bus_space_write_stream_2(t, h1, o1, bus_space_read_stream_2(t, h2,
>> + o2));
>> +bus_space_copy_region_stream_4(bus_space_tag_t t, bus_space_handle_t h1,
>> + bus_space_write_stream_4(t, h1, o1, bus_space_read_stream_4(t, h2,
>> + o2));
>> +bus_space_copy_region_stream_8(bus_space_tag_t t, bus_space_handle_t h1,
>> + bus_space_write_stream_8(t, h1, o1, bus_space_read_8(t, h2, o2));
>> +bus_space_peek_1(bus_space_tag_t t, bus_space_handle_t h, bus_size_t o,
>> + uint8_t *a)
>> + __BUS_DEBUG_ACCESS(h, o, "peek", 1);
>> + return (fasword8(bus_type_asi[t->bst_type], (caddr_t)(h + o), a));
>> +bus_space_peek_2(bus_space_tag_t t, bus_space_handle_t h, bus_size_t o,
>> + uint16_t *a)
>> + __BUS_DEBUG_ACCESS(h, o, "peek", 2);
>> + return (fasword16(bus_type_asi[t->bst_type], (caddr_t)(h + o), a));
>> +bus_space_peek_4(bus_space_tag_t t, bus_space_handle_t h, bus_size_t o,
>> + uint32_t *a)
>> + __BUS_DEBUG_ACCESS(h, o, "peek", 4);
>> + return (fasword32(bus_type_asi[t->bst_type], (caddr_t)(h + o), a));
>> +#endif /* !_MACHINE_BUS_H_ */
>> diff --git a/rtemsbsd/include/machine/cpufunc.h b/rtemsbsd/include/machine/cpufunc.h
>> deleted file mode 100644
>> index fa882cb5..00000000
>> --- a/rtemsbsd/include/machine/cpufunc.h
>> +++ /dev/null
>> @@ -1 +0,0 @@
>> -/* empty file */
>> 2.17.1
>> devel mailing list
>> devel at rtems.org
> devel mailing list
> devel at rtems.org
