[PATCH] cpukit/libdebugger: Fix for sockaddr_in not being initialized
Harrison Edward Gerber gerberhe11 at gmail.com
Tue Jun 1 18:05:54 UTC 2021
From: Harrison Edward Gerber <gerberhe11 at gmail.com>
See also CID 1468684
Closes #4445
 cpukit/libdebugger/rtems-debugger-remote-tcp.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/cpukit/libdebugger/rtems-debugger-remote-tcp.c b/cpukit/libdebugger/rtems-debugger-remote-tcp.c
index 696e2deb8c..440baa9b66 100644
--- a/cpukit/libdebugger/rtems-debugger-remote-tcp.c
+++ b/cpukit/libdebugger/rtems-debugger-remote-tcp.c
@@ -122,7 +122,7 @@ static int
 tcp_remote_connect(rtems_debugger_remote* remote)
   int                        ld;
-  struct sockaddr_in         addr;
+  struct sockaddr_in         addr = {0};
   socklen_t                  opt;
   socklen_t                  len;
   bool                       running;
2.25.1
