[PATCH] cpukit/libdebugger: Fix for sockaddr_in not being initialized
Joel Sherrill
joel at rtems.org
Tue Jun 1 18:20:21 UTC 2021
This looks like it should fix the issue.
OK to push.
On Tue, Jun 1, 2021 at 1:06 PM Harrison Edward Gerber <gerberhe11 at gmail.com>
wrote:
> From: Harrison Edward Gerber <gerberhe11 at gmail.com>
> See also CID 1468684
> Closes #4445
> cpukit/libdebugger/rtems-debugger-remote-tcp.c | 2 +-
> 1 file changed, 1 insertion(+), 1 deletion(-)
> diff --git a/cpukit/libdebugger/rtems-debugger-remote-tcp.c
> b/cpukit/libdebugger/rtems-debugger-remote-tcp.c
> index 696e2deb8c..440baa9b66 100644
> --- a/cpukit/libdebugger/rtems-debugger-remote-tcp.c
> +++ b/cpukit/libdebugger/rtems-debugger-remote-tcp.c
> @@ -122,7 +122,7 @@ static int
> tcp_remote_connect(rtems_debugger_remote* remote)
> int ld;
> - struct sockaddr_in addr;
> + struct sockaddr_in addr = {0};
> socklen_t opt;
> socklen_t len;
> bool running;
> 2.25.1
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210601/0a93eaab/attachment.html>
