[PATCH rtems-docs] eng/vc-authors: Add section on migrating personal repo to top-level
Gedare Bloom
gedare at rtems.org
Wed Jun 2 15:21:09 UTC 2021
looks ok
On Sun, May 30, 2021 at 3:12 PM Vijay Kumar Banerjee <vijay at rtems.org> wrote:
> eng/vc-authors.rst | 46 ++++++++++++++++++++++++++++++++++++++++++++++
> 1 file changed, 46 insertions(+)
> diff --git a/eng/vc-authors.rst b/eng/vc-authors.rst
> index dcbbeb9..179ad08 100644
> --- a/eng/vc-authors.rst
> +++ b/eng/vc-authors.rst
> @@ -166,6 +166,52 @@ flag to prevent merge from issuing an automatic merge commit message.
> When you have committed changes on a branch that is public/shared with another
> developer you should not rebase that branch.
> +Migrate a Personal Repository to top-level
> +Once a project is production ready in the personal repository, it's time to
> +migrate it to the top-level RTEMS git directory. First, the project directory
> +needs to be copied and then the permissions need to be set, so that everyone can
> +push into that repository.
> +.. code-block:: shell
> + cp -R /data/git/user/my-rtems-project.git /data/git
> + cd /data/git/my-rtems-project.git
> + chgrp -R gitrw ./
> + chmod -R g+rws ./
> +Then copy the post-receive script from the rtems.git directory and change the
> +name of REPO.
> + cp /data/git/rtems.git/hooks/post-receive /data/git/my-rtems-project.git/hooks/
> +After making the change the post-receive script in the new repository should
> +look like this
> + #!/bin/sh
> + # The "post-receive" script is run after receive-pack has accepted a pack
> + # and the repository has been updated. It is passed arguments in through
> + # stdin in the form
> + # <oldrev> <newrev> <refname>
> + # For example:
> + # aa453216d1b3e49e7f6f98441fa56946ddcd6a20 68f7abf4e6f922807889f52bc043ecd31b79f814 refs/heads/master
> + REPO=my-rtems-project
> + . /data/support/git-support/hooks/post-receive-0
> + . /data/support/git-support/hooks/post-receive-1
> + #. /data/support/git-support/hooks/post-receive-2
> + . /data/support/git-support/hooks/post-receive-3
> + . /data/support/git-support/hooks/post-receive-4
> + . /data/support/git-support/hooks/post-receive-5
> GIT Push Configuration
> 2.26.2
> devel mailing list
> devel at rtems.org
