[PATCH rtems-docs] eng/vc-authors: Add section on migrating personal repo to top-level
Vijay Kumar Banerjee vijay at rtems.org
Wed Jun 2 15:34:02 UTC 2021
On Wed, Jun 2, 2021 at 9:21 AM Gedare Bloom <gedare at rtems.org> wrote:
> looks ok
Thanks. Pushed!
> On Sun, May 30, 2021 at 3:12 PM Vijay Kumar Banerjee <vijay at rtems.org> wrote:
> >  eng/vc-authors.rst | 46 ++++++++++++++++++++++++++++++++++++++++++++++
> >  1 file changed, 46 insertions(+)
> > diff --git a/eng/vc-authors.rst b/eng/vc-authors.rst
> > index dcbbeb9..179ad08 100644
> > --- a/eng/vc-authors.rst
> > +++ b/eng/vc-authors.rst
> > @@ -166,6 +166,52 @@ flag to prevent merge from issuing an automatic merge commit message.
> >  When you have committed changes on a branch that is public/shared with another
> >  developer you should not rebase that branch.
> > +Migrate a Personal Repository to top-level
> > +Once a project is production ready in the personal repository, it's time to
> > +migrate it to the top-level RTEMS git directory. First, the project directory
> > +needs to be copied and then the permissions need to be set, so that everyone can
> > +push into that repository.
> > +.. code-block:: shell
> > +  cp -R /data/git/user/my-rtems-project.git /data/git
> > +  cd /data/git/my-rtems-project.git
> > +  chgrp -R gitrw ./
> > +  chmod -R g+rws ./
> > +Then copy the post-receive script from the rtems.git directory and change the
> > +name of REPO.
> > +  cp /data/git/rtems.git/hooks/post-receive  /data/git/my-rtems-project.git/hooks/
> > +After making the change the post-receive script in the new repository should
> > +look like this
> > +  #!/bin/sh
> > +  # The "post-receive" script is run after receive-pack has accepted a pack
> > +  # and the repository has been updated.  It is passed arguments in through
> > +  # stdin in the form
> > +  #  <oldrev> <newrev> <refname>
> > +  # For example:
> > +  #  aa453216d1b3e49e7f6f98441fa56946ddcd6a20 68f7abf4e6f922807889f52bc043ecd31b79f814 refs/heads/master
> > +  REPO=my-rtems-project
> > +  . /data/support/git-support/hooks/post-receive-0
> > +  . /data/support/git-support/hooks/post-receive-1
> > +  #. /data/support/git-support/hooks/post-receive-2
> > +  . /data/support/git-support/hooks/post-receive-3
> > +  . /data/support/git-support/hooks/post-receive-4
> > +  . /data/support/git-support/hooks/post-receive-5
> >  GIT Push Configuration
> > 2.26.2
> > devel mailing list
> > devel at rtems.org
