Selection of ethernet peripheral by application
Christian MAUDERER christian.mauderer at embedded-brains.de
Fri Jun 4 07:32:15 UTC 2021
Am 02.06.21 um 20:37 schrieb Kinsey Moore:
> Hello,
>  From what I’ve seen of the various BSPs supported by LibBSD that have
> multiple ethernet peripherals,
> only one tends to be chosen and supported. I’ve encountered a situation
> where the majority of platform
> examples (Zynq Ultrascale+ MPSoC dev boards) use CGEM3 as the
> only/primary ethernet interface and I
> need to have the option of selecting a different peripheral as the
> primary interface.
> Unfortunately, the current configuration of LibBSD/RTEMS does not allow
> for easy switching among the
> available interfaces. The easy one-off option is to just create a BSP
> variant with a little bit of extra logic
> to select the correct interface in LibBSD, but this problem seems more
> generally applicable than just
> ethernet and just this one BSP. Is the best alternative to configure all
> available devices in
> nexus-devices.h and let LibBSD figure it out?
> Thanks,
> Kinsey
If the problem is with "nexus-devices.h": You can always just add
further devices or a completely own set of devices in your application.
For example it should be no problem to use
SYSINIT_MODULE_REFERENCE(wlan_ratectl_none);
SYSINIT_MODULE_REFERENCE(wlan_sta);
SYSINIT_MODULE_REFERENCE(wlan_amrr);
SYSINIT_MODULE_REFERENCE(wlan_wep);
SYSINIT_MODULE_REFERENCE(wlan_tkip);
SYSINIT_MODULE_REFERENCE(wlan_ccmp);
SYSINIT_DRIVER_REFERENCE(rtwn_usb, uhub);
SYSINIT_REFERENCE(rtwn_rtl8188eufw);
#define RTEMS_BSD_CONFIG_BSP_CONFIG
#define RTEMS_BSD_CONFIG_TERMIOS_KQUEUE_AND_POLL
#define RTEMS_BSD_CONFIG_INIT
#include <machine/rtems-bsd-config.h>
in your application to add WLAN support. You could also remove the
RTEMS_BSD_CONFIG_BSP_CONFIG (which has the effect that nexus-devices.h
is not included in the rtems-bsd-config.h) and define a different set of
modules for your application.
Best regards
Christian
embedded brains GmbH
Herr Christian MAUDERER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 18
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
