Selection of ethernet peripheral by application
Kinsey Moore kinsey.moore at oarcorp.com
Fri Jun 4 12:59:29 UTC 2021
On 6/4/2021 02:32, Christian MAUDERER wrote:
> Am 02.06.21 um 20:37 schrieb Kinsey Moore:
>> Hello,
>>  From what I’ve seen of the various BSPs supported by LibBSD that
>> have multiple ethernet peripherals,
>> only one tends to be chosen and supported. I’ve encountered a
>> situation where the majority of platform
>> examples (Zynq Ultrascale+ MPSoC dev boards) use CGEM3 as the
>> only/primary ethernet interface and I
>> need to have the option of selecting a different peripheral as the
>> primary interface.
>> Unfortunately, the current configuration of LibBSD/RTEMS does not
>> allow for easy switching among the
>> available interfaces. The easy one-off option is to just create a BSP
>> variant with a little bit of extra logic
>> to select the correct interface in LibBSD, but this problem seems
>> more generally applicable than just
>> ethernet and just this one BSP. Is the best alternative to configure
>> all available devices in
>> nexus-devices.h and let LibBSD figure it out?
>> Thanks,
>> Kinsey
> If the problem is with "nexus-devices.h": You can always just add
> further devices or a completely own set of devices in your
> application. For example it should be no problem to use
> SYSINIT_MODULE_REFERENCE(wlan_ratectl_none);
> SYSINIT_MODULE_REFERENCE(wlan_sta);
> SYSINIT_MODULE_REFERENCE(wlan_amrr);
> SYSINIT_MODULE_REFERENCE(wlan_wep);
> SYSINIT_MODULE_REFERENCE(wlan_tkip);
> SYSINIT_MODULE_REFERENCE(wlan_ccmp);
> SYSINIT_DRIVER_REFERENCE(rtwn_usb, uhub);
> SYSINIT_REFERENCE(rtwn_rtl8188eufw);
> #define RTEMS_BSD_CONFIG_BSP_CONFIG
> #define RTEMS_BSD_CONFIG_TERMIOS_KQUEUE_AND_POLL
> #define RTEMS_BSD_CONFIG_INIT
> #include <machine/rtems-bsd-config.h>
> in your application to add WLAN support. You could also remove the
> RTEMS_BSD_CONFIG_BSP_CONFIG (which has the effect that nexus-devices.h
> is not included in the rtems-bsd-config.h) and define a different set
> of modules for your application.
> Best regards
> Christian
I guess this is a misunderstanding on my part. It might still be nice to
have something switchable for testing purposes, but I see that it can be
altered relatively easily on the application side of things.
Thanks,
Kinsey
