[PATCH rtems 1/2] bsps/imxrt: Allow different ARM PLL setting
Christian Mauderer
christian.mauderer at embedded-brains.de
Fri Jun 4 07:48:06 UTC 2021
Update #4180
.../nxp/boards/evkbimxrt1050/clock_config.c | 5 +++
bsps/arm/imxrt/start/clock-arm-pll-config.c | 33 +++++++++++++++++++
spec/build/bsps/arm/imxrt/bspimxrt.yml | 1 +
3 files changed, 39 insertions(+)
create mode 100644 bsps/arm/imxrt/start/clock-arm-pll-config.c
diff --git a/bsps/arm/imxrt/nxp/boards/evkbimxrt1050/clock_config.c b/bsps/arm/imxrt/nxp/boards/evkbimxrt1050/clock_config.c
index c23d5da356..ea28d06dd8 100644
--- a/bsps/arm/imxrt/nxp/boards/evkbimxrt1050/clock_config.c
+++ b/bsps/arm/imxrt/nxp/boards/evkbimxrt1050/clock_config.c
@@ -33,6 +33,7 @@ board: IMXRT1050-EVKB
#ifndef __rtems__
#include "clock_config.h"
#else /* __rtems__ */
+#include <bspopts.h>
#include "fsl_clock_config.h"
#endif /* __rtems__ */
#include "fsl_iomuxc.h"
@@ -146,10 +147,14 @@ sources:
* Variables for BOARD_BootClockRUN configuration
+#ifndef __rtems__
const clock_arm_pll_config_t armPllConfig_BOARD_BootClockRUN = {
.loopDivider = 100, /* PLL loop divider, Fout = Fin * 50 */
.src = 0, /* Bypass clock source, 0 - OSC 24M, 1 - CLK1_P and CLK1_N */
+#else /* __rtems__ */
+/* Moved to a separate file so an application can overwrite it. */
+#endif /* __rtems__ */
const clock_sys_pll_config_t sysPllConfig_BOARD_BootClockRUN = {
.loopDivider = 1, /* PLL loop divider, Fout = Fin * ( 20 + loopDivider*2 + numerator / denominator ) */
.numerator = 0, /* 30 bit numerator of fractional loop divider */
diff --git a/bsps/arm/imxrt/start/clock-arm-pll-config.c b/bsps/arm/imxrt/start/clock-arm-pll-config.c
new file mode 100644
index 0000000000..12ad1867eb
--- /dev/null
+++ b/bsps/arm/imxrt/start/clock-arm-pll-config.c
@@ -0,0 +1,33 @@
+ * Copyright (C) 2021 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#include "fsl_clock_config.h"
+const clock_arm_pll_config_t armPllConfig_BOARD_BootClockRUN = {
+ .loopDivider = 100,
+ .src = 0,
diff --git a/spec/build/bsps/arm/imxrt/bspimxrt.yml b/spec/build/bsps/arm/imxrt/bspimxrt.yml
index f543a14394..c6ea904754 100644
--- a/spec/build/bsps/arm/imxrt/bspimxrt.yml
+++ b/spec/build/bsps/arm/imxrt/bspimxrt.yml
@@ -238,6 +238,7 @@ source:
- bsps/arm/imxrt/spi/imxrt-lpspi.c
- bsps/arm/imxrt/start/bspstart.c
- bsps/arm/imxrt/start/bspstarthooks.c
+- bsps/arm/imxrt/start/clock-arm-pll-config.c
- bsps/arm/imxrt/start/flash-boot-data.c
- bsps/arm/imxrt/start/flash-config.c
- bsps/arm/imxrt/start/flash-dcd.c
2.26.2
