[PATCH v1 1/6] Explanations.cc: Fix resource leaks
Ryan Long
ryan.long at oarcorp.com
Fri Jun 4 16:47:38 UTC 2021
We'll submit the C++ conversions as separate patches since they are larger. That patch will be submitted shortly.
-----Original Message-----
Sent: Friday, May 28, 2021 8:05 PM
To: Ryan Long <ryan.long at oarcorp.com>; devel at rtems.org
Subject: Re: [PATCH v1 1/6] Explanations.cc: Fix resource leaks
On 29/5/21 8:08 am, Ryan Long wrote:
> CID 1399608: Resource leak in load().
> CID 1399611: Resource leak in load().
> Closes #4417
> tester/covoar/Explanations.cc | 18 +++++++++++-------
> 1 file changed, 11 insertions(+), 7 deletions(-)
> diff --git a/tester/covoar/Explanations.cc
> b/tester/covoar/Explanations.cc index 12bd809..d94cd2e 100644
> --- a/tester/covoar/Explanations.cc
> +++ b/tester/covoar/Explanations.cc
> @@ -32,7 +32,7 @@ namespace Coverage {
> #define MAX_LINE_LENGTH 512
> FILE *explain;
> char *cStatus;
> - Explanation *e;
> + Explanation e;
> int line = 1;
> if (!explanations)
> @@ -46,7 +46,6 @@ namespace Coverage {
> while ( 1 ) {
> - e = new Explanation;
> // Read the starting line of this explanation and
> // skip blank lines between
> do {
> @@ -65,12 +64,13 @@ namespace Coverage {
> what << "line " << line
> << "contains a duplicate explanation ("
> << inputBuffer << ")";
> + fclose( explain );
> throw rld::error( what, "Explanations::load" );
If you used a std::ostream type object it would be automatically closed when that object destructs via any exit path.
While this patch fixes the bug(s) the mixing of C here is generating these issues and effort cleaning that up will reward you.
> // Add the starting line and file
> - e->startingPoint = std::string(inputBuffer);
> - e->found = false;
> + e.startingPoint = std::string(inputBuffer);
> + e.found = false;
> // Get the classification
> cStatus = fgets( inputBuffer, MAX_LINE_LENGTH, explain ); @@
> -78,10 +78,11 @@ namespace Coverage {
> std::ostringstream what;
> << "out of sync at the classification";
> inputBuffer[ strlen(inputBuffer) - 1] = '\0';
> - e->classification = inputBuffer;
> + e.classification = inputBuffer;
> line++;
> // Get the explanation
> @@ -92,6 +93,7 @@ namespace Coverage {
> << "out of sync at the explanation";
> inputBuffer[ strlen(inputBuffer) - 1] = '\0'; @@ -102,15
> +104,17 @@ namespace Coverage {
> break;
> // XXX only taking last line. Needs to be a vector
> - e->explanation.push_back( inputBuffer );
> + e.explanation.push_back( inputBuffer );
> // Add this to the set of Explanations
> - set[ e->startingPoint ] = *e;
> + set[ e.startingPoint ] = e;
> done:
> #undef MAX_LINE_LENGTH
