[PATCH rtems 1/2] bsps/imxrt: Allow different ARM PLL setting
Christian MAUDERER
christian.mauderer at embedded-brains.de
Mon Jun 21 14:54:37 UTC 2021
Hello Gedare,
sorry, I nearly missed that mail.
Am 04.06.21 um 19:43 schrieb Gedare Bloom:
> On Fri, Jun 4, 2021 at 1:48 AM Christian Mauderer
> <christian.mauderer at embedded-brains.de> wrote:
>> Update #4180
>> .../nxp/boards/evkbimxrt1050/clock_config.c | 5 +++
>> bsps/arm/imxrt/start/clock-arm-pll-config.c | 33 +++++++++++++++++++
>> spec/build/bsps/arm/imxrt/bspimxrt.yml | 1 +
>> 3 files changed, 39 insertions(+)
>> create mode 100644 bsps/arm/imxrt/start/clock-arm-pll-config.c
>> diff --git a/bsps/arm/imxrt/nxp/boards/evkbimxrt1050/clock_config.c b/bsps/arm/imxrt/nxp/boards/evkbimxrt1050/clock_config.c
>> index c23d5da356..ea28d06dd8 100644
>> --- a/bsps/arm/imxrt/nxp/boards/evkbimxrt1050/clock_config.c
>> +++ b/bsps/arm/imxrt/nxp/boards/evkbimxrt1050/clock_config.c
>> @@ -33,6 +33,7 @@ board: IMXRT1050-EVKB
>> #ifndef __rtems__
>> #include "clock_config.h"
>> #else /* __rtems__ */
>> +#include <bspopts.h>
>> #include "fsl_clock_config.h"
>> #endif /* __rtems__ */
>> #include "fsl_iomuxc.h"
>> @@ -146,10 +147,14 @@ sources:
>> * Variables for BOARD_BootClockRUN configuration
>> +#ifndef __rtems__
>> const clock_arm_pll_config_t armPllConfig_BOARD_BootClockRUN = {
>> .loopDivider = 100, /* PLL loop divider, Fout = Fin * 50 */
>> .src = 0, /* Bypass clock source, 0 - OSC 24M, 1 - CLK1_P and CLK1_N */
>> +#else /* __rtems__ */
>> +/* Moved to a separate file so an application can overwrite it. */
> although it may be trivial, perhaps add the filename/path
> (bsps/arm/imxrt/start/clock-arm-pll-config.c) in the comment?
I'll do that.
> BSP doco provided how to override it?
I already have a patch prepared for it. But it seems that I missed to
send it. I'll send it soon.
Best regards
Christian
>> +#endif /* __rtems__ */
>> const clock_sys_pll_config_t sysPllConfig_BOARD_BootClockRUN = {
>> .loopDivider = 1, /* PLL loop divider, Fout = Fin * ( 20 + loopDivider*2 + numerator / denominator ) */
>> .numerator = 0, /* 30 bit numerator of fractional loop divider */
>> diff --git a/bsps/arm/imxrt/start/clock-arm-pll-config.c b/bsps/arm/imxrt/start/clock-arm-pll-config.c
>> new file mode 100644
>> index 0000000000..12ad1867eb
>> --- /dev/null
>> +++ b/bsps/arm/imxrt/start/clock-arm-pll-config.c
>> @@ -0,0 +1,33 @@
>> +/* SPDX-License-Identifier: BSD-2-Clause */
>> + * Copyright (C) 2021 embedded brains GmbH (http://www.embedded-brains.de)
>> + * Redistribution and use in source and binary forms, with or without
>> + * modification, are permitted provided that the following conditions
>> + * are met:
>> + * 1. Redistributions of source code must retain the above copyright
>> + * notice, this list of conditions and the following disclaimer.
>> + * 2. Redistributions in binary form must reproduce the above copyright
>> + * notice, this list of conditions and the following disclaimer in the
>> + * documentation and/or other materials provided with the distribution.
>> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
>> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
>> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
>> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
>> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
>> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
>> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
>> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
>> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
>> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
>> + * POSSIBILITY OF SUCH DAMAGE.
>> +#include "fsl_clock_config.h"
>> +const clock_arm_pll_config_t armPllConfig_BOARD_BootClockRUN = {
>> + .loopDivider = 100,
>> + .src = 0,
>> diff --git a/spec/build/bsps/arm/imxrt/bspimxrt.yml b/spec/build/bsps/arm/imxrt/bspimxrt.yml
>> index f543a14394..c6ea904754 100644
>> --- a/spec/build/bsps/arm/imxrt/bspimxrt.yml
>> +++ b/spec/build/bsps/arm/imxrt/bspimxrt.yml
>> @@ -238,6 +238,7 @@ source:
>> - bsps/arm/imxrt/spi/imxrt-lpspi.c
>> - bsps/arm/imxrt/start/bspstart.c
>> - bsps/arm/imxrt/start/bspstarthooks.c
>> +- bsps/arm/imxrt/start/clock-arm-pll-config.c
>> - bsps/arm/imxrt/start/flash-boot-data.c
>> - bsps/arm/imxrt/start/flash-config.c
>> - bsps/arm/imxrt/start/flash-dcd.c
>> 2.26.2
>> devel mailing list
>> devel at rtems.org
Herr Christian MAUDERER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 18
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
