[PATCH v1] Explanations.cc: Convert to c++ file handling
Ryan Long
ryan.long at oarcorp.com
Fri Jun 4 18:17:41 UTC 2021
tester/covoar/Explanations.cc | 45 ++++++++++++++++---------------------------
1 file changed, 17 insertions(+), 28 deletions(-)
diff --git a/tester/covoar/Explanations.cc b/tester/covoar/Explanations.cc
index d94cd2e..1449fb2 100644
--- a/tester/covoar/Explanations.cc
+++ b/tester/covoar/Explanations.cc
@@ -10,6 +10,8 @@
#include <unistd.h>
+#include <fstream>
#include <rld.h>
#include "Explanations.h"
@@ -30,15 +32,14 @@ namespace Coverage {
#define MAX_LINE_LENGTH 512
- FILE *explain;
- char *cStatus;
- Explanation e;
- int line = 1;
+ std::ifstream explain;
+ Explanation e;
+ int line = 1;
if (!explanations)
return;
- explain = ::fopen( explanations, "r" );
+ explain.open( explanations );
if (!explain) {
std::ostringstream what;
what << "Unable to open " << explanations;
@@ -50,9 +51,9 @@ namespace Coverage {
// skip blank lines between
do {
inputBuffer[0] = '\0';
- cStatus = fgets( inputBuffer, MAX_LINE_LENGTH, explain );
- if (cStatus == NULL) {
- goto done;
+ explain.getline( inputBuffer, MAX_LINE_LENGTH );
+ if (explain.fail()) {
+ return;
inputBuffer[ strlen(inputBuffer) - 1] = '\0';
line++;
@@ -64,7 +65,6 @@ namespace Coverage {
what << "line " << line
<< "contains a duplicate explanation ("
<< inputBuffer << ")";
- fclose( explain );
throw rld::error( what, "Explanations::load" );
@@ -73,12 +73,11 @@ namespace Coverage {
e.found = false;
// Get the classification
<< "out of sync at the classification";
@@ -87,13 +86,12 @@ namespace Coverage {
// Get the explanation
while (1) {
// fprintf( stderr, "%d - %s\n", line, inputBuffer );
<< "out of sync at the explanation";
@@ -110,10 +108,6 @@ namespace Coverage {
// Add this to the set of Explanations
set[ e.startingPoint ] = e;
-done:
#undef MAX_LINE_LENGTH
@@ -137,14 +131,14 @@ done:
const char* const fileName
- FILE* notFoundFile;
+ std::ofstream notFoundFile;
bool notFoundOccurred = false;
if (!fileName)
return;
- notFoundFile = fopen( fileName, "w" );
- if (notFoundFile == nullptr) {
+ notFoundFile.open( fileName );
+ if (!notFoundFile) {
what << "Unable to open " << fileName
<< " out of sync at the explanation";
@@ -159,14 +153,9 @@ done:
if (!e.found) {
notFoundOccurred = true;
- fprintf(
- notFoundFile,
- "%s\n",
- e.startingPoint.c_str()
+ notFoundFile << e.startingPoint << std::endl;
- fclose( notFoundFile );
if (!notFoundOccurred) {
if (!unlink( fileName )) {
1.8.3.1
