[PATCH v1] Explanations.cc: Convert to c++ file handling
Sat Jun 5 05:24:36 UTC 2021
Ok
On 5/6/21 4:17 am, Ryan Long wrote:
>  tester/covoar/Explanations.cc | 45 ++++++++++++++++---------------------------
>  1 file changed, 17 insertions(+), 28 deletions(-)
> diff --git a/tester/covoar/Explanations.cc b/tester/covoar/Explanations.cc
> index d94cd2e..1449fb2 100644
> --- a/tester/covoar/Explanations.cc
> +++ b/tester/covoar/Explanations.cc
> @@ -10,6 +10,8 @@
>  #include <string.h>
>  #include <unistd.h>
> +#include <fstream>
>  #include <rld.h>
>  #include "Explanations.h"
> @@ -30,15 +32,14 @@ namespace Coverage {
>      #define MAX_LINE_LENGTH 512
> -    FILE       *explain;
> -    char        *cStatus;
> -    Explanation  e;
> -    int          line = 1;
> +    std::ifstream  explain;
> +    Explanation    e;
> +    int            line = 1;
>      if (!explanations)
>        return;
> -    explain = ::fopen( explanations, "r" );
> +    explain.open( explanations );
>      if (!explain) {
>        std::ostringstream what;
>        what << "Unable to open " << explanations;
> @@ -50,9 +51,9 @@ namespace Coverage {
>        // skip blank lines between
>        do {
>          inputBuffer[0] = '\0';
> -        cStatus = fgets( inputBuffer, MAX_LINE_LENGTH, explain );
> -        if (cStatus == NULL) {
> -          goto done;
> +        explain.getline( inputBuffer, MAX_LINE_LENGTH );
> +        if (explain.fail()) {
> +          return;
>          inputBuffer[ strlen(inputBuffer) - 1] = '\0';
>          line++;
> @@ -64,7 +65,6 @@ namespace Coverage {
>          what << "line " << line
>               << "contains a duplicate explanation ("
>               << inputBuffer << ")";
> -        fclose( explain );
>          throw rld::error( what, "Explanations::load" );
> @@ -73,12 +73,11 @@ namespace Coverage {
>        e.found = false;
>        // Get the classification
>               << "out of sync at the classification";
> @@ -87,13 +86,12 @@ namespace Coverage {
>        // Get the explanation
>        while (1) {
>          // fprintf( stderr, "%d - %s\n", line, inputBuffer );
>                 << "out of sync at the explanation";
> @@ -110,10 +108,6 @@ namespace Coverage {
>        // Add this to the set of Explanations
>        set[ e.startingPoint ] = e;
> -done:
>      #undef MAX_LINE_LENGTH
> @@ -137,14 +131,14 @@ done:
>      const char* const fileName
> -    FILE* notFoundFile;
> +    std::ofstream notFoundFile;
>      bool  notFoundOccurred = false;
>      if (!fileName)
>        return;
> -    notFoundFile = fopen( fileName, "w" );
> -    if (notFoundFile == nullptr) {
> +    notFoundFile.open( fileName );
> +    if (!notFoundFile) {
>        what << "Unable to open " << fileName
>             << " out of sync at the explanation";
> @@ -159,14 +153,9 @@ done:
>        if (!e.found) {
>          notFoundOccurred = true;
> -        fprintf(
> -          notFoundFile,
> -          "%s\n",
> -          e.startingPoint.c_str()
> +        notFoundFile << e.startingPoint << std::endl;
> -    fclose( notFoundFile );
>      if (!notFoundOccurred) {
>        if (!unlink( fileName )) {
