[PATCH] cpukit/libblock/src: Add better memory handling in flashdisk.c
    Joel Sherrill
    joel at rtems.org
    Fri Jun  4 19:16:36 UTC 2021
On the surface, this looks OK to me. But I remember looking at this one
and wondering if there was any cleanup required because of the various
subroutine calls as you work down through this method.
Did you look into each of the subroutines called and make sure they
didn't do further allocations?
--joel
On Fri, Jun 4, 2021 at 1:27 PM Harrison Edward Gerber <gerberhe11 at gmail.com>
wrote:
> See also CID 1439298
> Closes #3570
>  cpukit/libblock/src/flashdisk.c | 16 ++++++++++++++++
>  1 file changed, 16 insertions(+)
> diff --git a/cpukit/libblock/src/flashdisk.c
> b/cpukit/libblock/src/flashdisk.c
> index 91f99e0d52..4de6ecd807 100644
> --- a/cpukit/libblock/src/flashdisk.c
> +++ b/cpukit/libblock/src/flashdisk.c
> @@ -2486,17 +2486,29 @@ rtems_fdisk_initialize (rtems_device_major_number
> major,
>      fd->copy_buffer = malloc (c->block_size);
>      if (!fd->copy_buffer)
> +      free(fd);
>        return RTEMS_NO_MEMORY;
>      fd->blocks = calloc (blocks, sizeof (rtems_fdisk_block_ctl));
>      if (!fd->blocks)
> +      free(fd->copy_buffer);
> +      free(fd);
>      fd->block_count = blocks;
>      fd->devices = calloc (c->device_count, sizeof
> (rtems_fdisk_device_ctl));
>      if (!fd->devices)
> +      free(fd->blocks);
> +      free(fd);
>      rtems_mutex_init (&fd->lock, "Flash Disk");
> @@ -2508,6 +2520,7 @@ rtems_fdisk_initialize (rtems_device_major_number
> major,
>        free (fd->copy_buffer);
>        free (fd->blocks);
>        free (fd->devices);
> +      free(fd);
>        rtems_fdisk_error ("disk create phy failed");
>        return sc;
> @@ -2529,6 +2542,7 @@ rtems_fdisk_initialize (rtems_device_major_number
> major,
>          free (fd->blocks);
>          free (fd->devices);
> +        free(fd);
> @@ -2564,6 +2578,7 @@ rtems_fdisk_initialize (rtems_device_major_number
> major,
>        free (fd->blocks);
>        free (fd->devices);
> +      free(fd);
>        rtems_fdisk_error ("recovery of disk failed: %s (%d)",
>                           strerror (ret), ret);
>        return ret;
> @@ -2577,6 +2592,7 @@ rtems_fdisk_initialize (rtems_device_major_number
> major,
>        free (fd->blocks);
>        free (fd->devices);
> +      free(fd);
>        rtems_fdisk_error ("compacting of disk failed: %s (%d)",
>        return ret;
> 2.25.1
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210604/3a894eca/attachment.html>
