[PATCH] cpukit/libblock/src: Add better memory handling in flashdisk.c
Harrison Edward Gerber
gerberhe11 at gmail.com
Fri Jun 4 18:27:11 UTC 2021
See also CID 1439298
Closes #3570
cpukit/libblock/src/flashdisk.c | 16 ++++++++++++++++
1 file changed, 16 insertions(+)
diff --git a/cpukit/libblock/src/flashdisk.c b/cpukit/libblock/src/flashdisk.c
index 91f99e0d52..4de6ecd807 100644
--- a/cpukit/libblock/src/flashdisk.c
+++ b/cpukit/libblock/src/flashdisk.c
@@ -2486,17 +2486,29 @@ rtems_fdisk_initialize (rtems_device_major_number major,
fd->copy_buffer = malloc (c->block_size);
if (!fd->copy_buffer)
+ free(fd);
return RTEMS_NO_MEMORY;
fd->blocks = calloc (blocks, sizeof (rtems_fdisk_block_ctl));
if (!fd->blocks)
+ free(fd->copy_buffer);
+ free(fd);
fd->block_count = blocks;
fd->devices = calloc (c->device_count, sizeof (rtems_fdisk_device_ctl));
if (!fd->devices)
+ free(fd->blocks);
+ free(fd);
rtems_mutex_init (&fd->lock, "Flash Disk");
@@ -2508,6 +2520,7 @@ rtems_fdisk_initialize (rtems_device_major_number major,
free (fd->copy_buffer);
free (fd->blocks);
free (fd->devices);
+ free(fd);
rtems_fdisk_error ("disk create phy failed");
return sc;
@@ -2529,6 +2542,7 @@ rtems_fdisk_initialize (rtems_device_major_number major,
free (fd->blocks);
free (fd->devices);
+ free(fd);
@@ -2564,6 +2578,7 @@ rtems_fdisk_initialize (rtems_device_major_number major,
free (fd->blocks);
free (fd->devices);
+ free(fd);
rtems_fdisk_error ("recovery of disk failed: %s (%d)",
strerror (ret), ret);
return ret;
@@ -2577,6 +2592,7 @@ rtems_fdisk_initialize (rtems_device_major_number major,
free (fd->blocks);
free (fd->devices);
+ free(fd);
rtems_fdisk_error ("compacting of disk failed: %s (%d)",
return ret;
2.25.1
