[PATCH v1] bsps/riscv: Give enough time for clock driver initialization
Joel Sherrill
joel at rtems.org
Mon Jun 7 19:11:53 UTC 2021
On Mon, Jun 7, 2021 at 1:57 PM <Jan.Sommer at dlr.de> wrote:
> > -----Original Message-----
> > From: Gedare Bloom <gedare at rtems.org>
> > Sent: Monday, June 7, 2021 7:00 PM
> > To: Sommer, Jan <Jan.Sommer at dlr.de>
> > Cc: devel at rtems.org
> > Subject: Re: [PATCH v1] bsps/riscv: Give enough time for clock driver
> > initialization
> > On Mon, Jun 7, 2021 at 9:47 AM Jan Sommer <jan.sommer at dlr.de> wrote:
> > > - Clock driver initialization for secondary cores had to take less
> > > than one tick
> > > - If tick time is small (i.e. <= 1ms) setting up all cores could take
> > > too long and a fatal error is thrown.
> > > - Give at least 10 ms time for clock initialization to avoid this
> > > error
> > Is there a reason to pick 10?
> In qemu I (coarsely) measured 1.5ms for 8 cores.
> So I thought this should add enough buffer to prevent a fatal error.
> I probably could also reduce it to 5 ms.
> > I assume this blocks/idles the system until the interval elapses, so it
> would be
> > good to minimize waste (subject to Joel's noted rant about premature
> > optimization).
No. I'm more worried about boot time. :)
> If you take a look at the clock initialization of the secondary cores (
> https://git.rtems.org/rtems/tree/bsps/riscv/riscv/clock/clockdrv.c#n178):
> _SMP_Othercast_action(riscv_clock_secondary_action, &cmpval);
> if (cmpval - riscv_clock_read_mtime(&clint->mtime) >= interval) {
> bsp_fatal(RISCV_FATAL_CLOCK_SMP_INIT);
> It will put the first clock tick 10ms into the future (instead of just one
> tick), but it won't block the system initialization.
> It only prevents entering the if condition by having a large enough value
> for interval, but the runtime of the clock initialization is the same.
How does this impact the timeline for boot to first application thread?
Is there a period where the system is up but only one core?
Any other oddities I might be missing?
> > > bsps/riscv/riscv/clock/clockdrv.c | 8 +++++++-
> > > 1 file changed, 7 insertions(+), 1 deletion(-)
> > > diff --git a/bsps/riscv/riscv/clock/clockdrv.c
> > > b/bsps/riscv/riscv/clock/clockdrv.c
> > > index 3afe86576f..102137aeab 100644
> > > --- a/bsps/riscv/riscv/clock/clockdrv.c
> > > +++ b/bsps/riscv/riscv/clock/clockdrv.c
> > > @@ -211,7 +211,13 @@ static void riscv_clock_initialize(void)
> > > tc->interval = interval;
> > > cmpval = riscv_clock_read_mtime(&clint->mtime);
> > > - cmpval += interval;
> > > + * For very short intervals the time of 1 tick is not enough to
> > > + * set up the timer on all cores in SMP systems.
> > > + * Give the CPU at least 10 ms.
> > > + interval = (10000 / us_per_tick) * interval; cmpval += interval;
> > > riscv_clock_clint_init(clint, cmpval, 0);
> > > riscv_clock_secondary_initialization(clint, cmpval, interval);
> > > 2.17.1
> > > _______________________________________________
> > > devel mailing list
> > > devel at rtems.org
> > > http://lists.rtems.org/mailman/listinfo/devel
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210607/b30d1fed/attachment.html>
