[PATCH rtems 2/2] bsps/imxrt: Simplify linkcmds and make it flexible
Tue Jun 8 10:26:45 UTC 2021
On 08/06/2021 05:07, Chris Johns wrote:
> On 7/6/21 6:40 pm, Christian Mauderer wrote:> I think the Options don't need
> documentation changes because the options in the
>> waf based build system are now documented directly in the yaml files and printed
>> if you generate the default config.
> Hmm I am not sure I agree with the premise the YAML is the documentation. The
> user manual exists for this purpose and user wanting to explore RTEMS would look
> there rather than cloning the repo, running commands etc.
> I accept the current defaults etc work flow is a good place to start for the waf
> conversion project but we need to do a lot more to make accessing the YAML
> easier. The wscript contains the only rtems.git repo means to read the YAML and
> the pickled data and that limits how we can change and evolve this.
We could use rtems-central to generate sections for the user manual from
the build specification. This would be similar to the generation of the
glossaries, application configuration option documentation, and the
directive documentation.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
