[PATCH rtems 2/2] bsps/imxrt: Simplify linkcmds and make it flexible
Tue Jun 8 23:52:54 UTC 2021
On 8/6/21 8:26 pm, Sebastian Huber wrote:
> On 08/06/2021 05:07, Chris Johns wrote:
>> On 7/6/21 6:40 pm, Christian Mauderer wrote:> I think the Options don't need
>> documentation changes because the options in the
>>> waf based build system are now documented directly in the yaml files and printed
>>> if you generate the default config.
>> Hmm I am not sure I agree with the premise the YAML is the documentation. The
>> user manual exists for this purpose and user wanting to explore RTEMS would look
>> there rather than cloning the repo, running commands etc.
>> I accept the current defaults etc work flow is a good place to start for the waf
>> conversion project but we need to do a lot more to make accessing the YAML
>> easier. The wscript contains the only rtems.git repo means to read the YAML and
>> the pickled data and that limits how we can change and evolve this.
> We could use rtems-central to generate sections for the user manual from the
> build specification. This would be similar to the generation of the glossaries,
> application configuration option documentation, and the directive documentation.
Of course we could use it and there are a number of other possible ways we do
this as well without that repo. The rtems-central repo and work flows have clear
and defined boundary we have put in place for very good reasons. A move that way
would be considered creep.
