[PATCH v1 1/4] rtemsbsd: Added original TTCP code
Stephen Clark
stephen.clark at oarcorp.com
Tue Jun 8 15:33:32 UTC 2021
Added the original Test TCP (TTCP) program in unmodified form.
Also added the associated README.
rtemsbsd/ttcp/README | 27 ++
rtemsbsd/ttcp/ttcp.c | 841 +++++++++++++++++++++++++++++++++++++++++++
2 files changed, 868 insertions(+)
create mode 100644 rtemsbsd/ttcp/README
create mode 100644 rtemsbsd/ttcp/ttcp.c
diff --git a/rtemsbsd/ttcp/README b/rtemsbsd/ttcp/README
new file mode 100644
index 00000000..215ddacc
--- /dev/null
+++ b/rtemsbsd/ttcp/README
@@ -0,0 +1,27 @@
+TTCP is a benchmarking tool for determining TCP and UDP performance
+between 2 systems.
+The program was created at the US Army Ballistics Research Lab (BRL)
+and is in the public domain. Feel free to distribute this program
+but please do leave the credit notices in the source and man page intact.
+Contents of this directory:
+ttcp.c Source that runs on IRIX 3.3.x and 4.0.x systems
+ and BSD-based systems. This version also uses getopt(3)
+ and has 2 new options: -f and -T.
+ttcp.c-brl Original source from BRL.
+ttcp.1 Manual page (describes ttcp.c options, which are a
+ superset of the other version).
+How to get TCP performance numbers:
+ receiver sender
+host1% ttcp -r -s host2% ttcp -t -s host1
+-n and -l options change the number and size of the buffers.
diff --git a/rtemsbsd/ttcp/ttcp.c b/rtemsbsd/ttcp/ttcp.c
index 00000000..305a7c7d
--- /dev/null
+++ b/rtemsbsd/ttcp/ttcp.c
@@ -0,0 +1,841 @@
+ * T T C P . C
+ * Test TCP connection. Makes a connection on port 5001
+ * and transfers fabricated buffers or data copied from stdin.
+ * Usable on 4.2, 4.3, and 4.1a systems by defining one of
+ * BSD42 BSD43 (BSD41a)
+ * Machines using System V with BSD sockets should define SYSV.
+ * Modified for operation under 4.2BSD, 18 Dec 84
+ * T.C. Slattery, USNA
+ * Minor improvements, Mike Muuss and Terry Slattery, 16-Oct-85.
+ * Modified in 1989 at Silicon Graphics, Inc.
+ * catch SIGPIPE to be able to print stats when receiver has died
+ * for tcp, don't look for sentinel during reads to allow small transfers
+ * increased default buffer size to 8K, nbuf to 2K to transfer 16MB
+ * moved default port to 5001, beyond IPPORT_USERRESERVED
+ * make sinkmode default because it is more popular,
+ * -s now means don't sink/source
+ * count number of read/write system calls to see effects of
+ * blocking from full socket buffers
+ * for tcp, -D option turns off buffered writes (sets TCP_NODELAY sockopt)
+ * buffer alignment options, -A and -O
+ * print stats in a format that's a bit easier to use with grep & awk
+ * for SYSV, mimic BSD routines to use most of the existing timing code
+ * Modified by Steve Miller of the University of Maryland, College Park
+ * -b sets the socket buffer size (SO_SNDBUF/SO_RCVBUF)
+ * Modified Sept. 1989 at Silicon Graphics, Inc.
+ * restored -s sense at request of tcs at brl
+ * Modified Oct. 1991 at Silicon Graphics, Inc.
+ * use getopt(3) for option processing, add -f and -T options.
+ * SGI IRIX 3.3 and 4.0 releases don't need #define SYSV.
+ * Distribution Status -
+ * Public Domain. Distribution Unlimited.
+#ifndef lint
+static char RCSid[] = "ttcp.c $Revision$";
+#endif
+#define BSD43
+/* #define BSD42 */
+/* #define BSD41a */
+/* #define SYSV */ /* required on SGI IRIX releases before 3.3 */
+#include <stdio.h>
+#include <signal.h>
+#include <ctype.h>
+#include <errno.h>
+#include <sys/types.h>
+#include <sys/socket.h>
+#include <netinet/in.h>
+#include <netinet/tcp.h>
+#include <arpa/inet.h>
+#include <netdb.h>
+#include <sys/time.h> /* struct timeval */
+#if defined(SYSV)
+#include <sys/times.h>
+#include <sys/param.h>
+struct rusage {
+ struct timeval ru_utime, ru_stime;
+#define RUSAGE_SELF 0
+#else
+#include <sys/resource.h>
+#endif
+struct sockaddr_in sinme;
+struct sockaddr_in sinhim;
+struct sockaddr_in frominet;
+int domain, fromlen;
+int fd; /* fd of network socket */
+int buflen = 8 * 1024; /* length of buffer */
+char *buf; /* ptr to dynamic buffer */
+int nbuf = 2 * 1024; /* number of buffers to send in sinkmode */
+int bufoffset = 0; /* align buffer to this */
+int bufalign = 16*1024; /* modulo this */
+int udp = 0; /* 0 = tcp, !0 = udp */
+int options = 0; /* socket options */
+int one = 1; /* for 4.3 BSD style setsockopt() */
+short port = 5001; /* TCP port number */
+char *host; /* ptr to name of host */
+int trans; /* 0=receive, !0=transmit mode */
+int sinkmode = 0; /* 0=normal I/O, !0=sink/source mode */
+int verbose = 0; /* 0=print basic info, 1=print cpu rate, proc
+ * resource usage. */
+int nodelay = 0; /* set TCP_NODELAY socket option */
+int b_flag = 0; /* use mread() */
+int sockbufsize = 0; /* socket buffer size to use */
+char fmt = 'K'; /* output format: k = kilobits, K = kilobytes,
+ * m = megabits, M = megabytes,
+ * g = gigabits, G = gigabytes */
+int touchdata = 0; /* access data after reading */
+struct hostent *addr;
+extern int errno;
+extern int optind;
+extern char *optarg;
+char Usage[] = "\
+Usage: ttcp -t [-options] host [ < in ]\n\
+ ttcp -r [-options > out]\n\
+Common options:\n\
+ -l ## length of bufs read from or written to network (default 8192)\n\
+ -u use UDP instead of TCP\n\
+ -p ## port number to send to or listen at (default 5001)\n\
+ -s -t: source a pattern to network\n\
+ -r: sink (discard) all data from network\n\
+ -A align the start of buffers to this modulus (default 16384)\n\
+ -O start buffers at this offset from the modulus (default 0)\n\
+ -v verbose: print more statistics\n\
+ -d set SO_DEBUG socket option\n\
+ -b ## set socket buffer size (if supported)\n\
+ -f X format for rate: k,K = kilo{bit,byte}; m,M = mega; g,G = giga\n\
+Options specific to -t:\n\
+ -n## number of source bufs written to network (default 2048)\n\
+ -D don't buffer TCP writes (sets TCP_NODELAY socket option)\n\
+Options specific to -r:\n\
+ -B for -s, only output full blocks as specified by -l (for TAR)\n\
+ -T \"touch\": access each byte as it's read\n\
+char stats[128];
+double nbytes; /* bytes on net */
+unsigned long numCalls; /* # of I/O system calls */
+double cput, realt; /* user, real time (seconds) */
+void err();
+void mes();
+int pattern();
+void prep_timer();
+double read_timer();
+int Nread();
+int Nwrite();
+void delay();
+int mread();
+char *outfmt();
+void
+sigpipe()
+main(argc,argv)
+int argc;
+char **argv;
+ unsigned long addr_tmp;
+ int c;
+ if (argc < 2) goto usage;
+ while ((c = getopt(argc, argv, "drstuvBDTb:f:l:n:p:A:O:")) != -1) {
+ switch (c) {
+ case 'B':
+ b_flag = 1;
+ break;
+ case 't':
+ trans = 1;
+ break;
+ case 'r':
+ trans = 0;
+ break;
+ case 'd':
+ options |= SO_DEBUG;
+ break;
+ case 'D':
+#ifdef TCP_NODELAY
+ nodelay = 1;
+#else
+ fprintf(stderr,
+ "ttcp: -D option ignored: TCP_NODELAY socket option not supported\n");
+#endif
+ break;
+ case 'n':
+ nbuf = atoi(optarg);
+ break;
+ case 'l':
+ buflen = atoi(optarg);
+ break;
+ case 's':
+ sinkmode = !sinkmode;
+ break;
+ case 'p':
+ port = atoi(optarg);
+ break;
+ case 'u':
+ udp = 1;
+ break;
+ case 'v':
+ verbose = 1;
+ break;
+ case 'A':
+ bufalign = atoi(optarg);
+ break;
+ case 'O':
+ bufoffset = atoi(optarg);
+ break;
+ case 'b':
+#if defined(SO_SNDBUF) || defined(SO_RCVBUF)
+ sockbufsize = atoi(optarg);
+#else
+ fprintf(stderr,
+"ttcp: -b option ignored: SO_SNDBUF/SO_RCVBUF socket options not supported\n");
+#endif
+ break;
+ case 'f':
+ fmt = *optarg;
+ break;
+ case 'T':
+ touchdata = 1;
+ break;
+ default:
+ goto usage;
+ if(trans) {
+ /* xmitr */
+ if (optind == argc)
+ goto usage;
+ bzero((char *)&sinhim, sizeof(sinhim));
+ host = argv[optind];
+ if (atoi(host) > 0 ) {
+ /* Numeric */
+ sinhim.sin_family = AF_INET;
+#if defined(cray)
+ addr_tmp = inet_addr(host);
+ sinhim.sin_addr = addr_tmp;
+#else
+ sinhim.sin_addr.s_addr = inet_addr(host);
+#endif
+ } else {
+ if ((addr=gethostbyname(host)) == NULL)
+ err("bad hostname");
+ sinhim.sin_family = addr->h_addrtype;
+ bcopy(addr->h_addr,(char*)&addr_tmp, addr->h_length);
+#if defined(cray)
+#else
+ sinhim.sin_addr.s_addr = addr_tmp;
+#endif /* cray */
+ sinhim.sin_port = htons(port);
+ sinme.sin_port = 0; /* free choice */
+ } else {
+ /* rcvr */
+ sinme.sin_port = htons(port);
+ if (udp && buflen < 5) {
+ buflen = 5; /* send more than the sentinel size */
+ if ( (buf = (char *)malloc(buflen+bufalign)) == (char *)NULL)
+ err("malloc");
+ if (bufalign != 0)
+ buf +=(bufalign - ((int)buf % bufalign) + bufoffset) % bufalign;
+ if (trans) {
+ fprintf(stdout,
+ "ttcp-t: buflen=%d, nbuf=%d, align=%d/%d, port=%d",
+ buflen, nbuf, bufalign, bufoffset, port);
+ if (sockbufsize)
+ fprintf(stdout, ", sockbufsize=%d", sockbufsize);
+ fprintf(stdout, " %s -> %s\n", udp?"udp":"tcp", host);
+ } else {
+ fprintf(stdout,
+ "ttcp-r: buflen=%d, nbuf=%d, align=%d/%d, port=%d",
+ if (sockbufsize)
+ fprintf(stdout, " %s\n", udp?"udp":"tcp");
+ if ((fd = socket(AF_INET, udp?SOCK_DGRAM:SOCK_STREAM, 0)) < 0)
+ err("socket");
+ mes("socket");
+ if (bind(fd, &sinme, sizeof(sinme)) < 0)
+ err("bind");
+ if (sockbufsize) {
+ if (trans) {
+ if (setsockopt(fd, SOL_SOCKET, SO_SNDBUF, &sockbufsize,
+ sizeof sockbufsize) < 0)
+ err("setsockopt: sndbuf");
+ mes("sndbuf");
+ } else {
+ if (setsockopt(fd, SOL_SOCKET, SO_RCVBUF, &sockbufsize,
+ err("setsockopt: rcvbuf");
+ mes("rcvbuf");
+#endif
+ if (!udp) {
+ signal(SIGPIPE, sigpipe);
+ if (trans) {
+ /* We are the client if transmitting */
+ if (options) {
+#if defined(BSD42)
+ if( setsockopt(fd, SOL_SOCKET, options, 0, 0) < 0)
+#else /* BSD43 */
+ if( setsockopt(fd, SOL_SOCKET, options, &one, sizeof(one)) < 0)
+#endif
+ err("setsockopt");
+#ifdef TCP_NODELAY
+ if (nodelay) {
+ struct protoent *p;
+ p = getprotobyname("tcp");
+ if( p && setsockopt(fd, p->p_proto, TCP_NODELAY,
+ &one, sizeof(one)) < 0)
+ err("setsockopt: nodelay");
+ mes("nodelay");
+#endif
+ if(connect(fd, &sinhim, sizeof(sinhim) ) < 0)
+ err("connect");
+ mes("connect");
+ } else {
+ /* otherwise, we are the server and
+ * should listen for the connections
+#if defined(ultrix) || defined(sgi)
+ listen(fd,1); /* workaround for alleged u4.2 bug */
+#else
+ listen(fd,0); /* allow a queue of 0 */
+#endif
+ if(options) {
+#if defined(BSD42)
+#else /* BSD43 */
+#endif
+ fromlen = sizeof(frominet);
+ domain = AF_INET;
+ if((fd=accept(fd, &frominet, &fromlen) ) < 0)
+ err("accept");
+ { struct sockaddr_in peer;
+ int peerlen = sizeof(peer);
+ if (getpeername(fd, (struct sockaddr_in *) &peer,
+ &peerlen) < 0) {
+ err("getpeername");
+ fprintf(stderr,"ttcp-r: accept from %s\n",
+ inet_ntoa(peer.sin_addr));
+ prep_timer();
+ errno = 0;
+ if (sinkmode) {
+ register int cnt;
+ if (trans) {
+ pattern( buf, buflen );
+ if(udp) (void)Nwrite( fd, buf, 4 ); /* rcvr start */
+ while (nbuf-- && Nwrite(fd,buf,buflen) == buflen)
+ nbytes += buflen;
+ if(udp) (void)Nwrite( fd, buf, 4 ); /* rcvr end */
+ } else {
+ if (udp) {
+ while ((cnt=Nread(fd,buf,buflen)) > 0) {
+ static int going = 0;
+ if( cnt <= 4 ) {
+ if( going )
+ break; /* "EOF" */
+ going = 1;
+ prep_timer();
+ } else {
+ nbytes += cnt;
+ } else {
+ nbytes += cnt;
+ } else {
+ register int cnt;
+ if (trans) {
+ while((cnt=read(0,buf,buflen)) > 0 &&
+ Nwrite(fd,buf,cnt) == cnt)
+ nbytes += cnt;
+ } else {
+ while((cnt=Nread(fd,buf,buflen)) > 0 &&
+ write(1,buf,cnt) == cnt)
+ nbytes += cnt;
+ if(errno) err("IO");
+ (void)read_timer(stats,sizeof(stats));
+ if(udp&&trans) {
+ (void)Nwrite( fd, buf, 4 ); /* rcvr end */
+ if( cput <= 0.0 ) cput = 0.001;
+ if( realt <= 0.0 ) realt = 0.001;
+ fprintf(stdout,
+ "ttcp%s: %.0f bytes in %.2f real seconds = %s/sec +++\n",
+ trans?"-t":"-r",
+ nbytes, realt, outfmt(nbytes/realt));
+ if (verbose) {
+ fprintf(stdout,
+ "ttcp%s: %.0f bytes in %.2f CPU seconds = %s/cpu sec\n",
+ trans?"-t":"-r",
+ nbytes, cput, outfmt(nbytes/cput));
+ fprintf(stdout,
+ "ttcp%s: %d I/O calls, msec/call = %.2f, calls/sec = %.2f\n",
+ trans?"-t":"-r",
+ numCalls,
+ 1024.0 * realt/((double)numCalls),
+ ((double)numCalls)/realt);
+ fprintf(stdout,"ttcp%s: %s\n", trans?"-t":"-r", stats);
+ if (verbose) {
+ fprintf(stdout,
+ "ttcp%s: buffer address %#x\n",
+ trans?"-t":"-r",
+ buf);
+ exit(0);
+usage:
+ fprintf(stderr,Usage);
+ exit(1);
+void
+err(s)
+char *s;
+ fprintf(stderr,"ttcp%s: ", trans?"-t":"-r");
+ perror(s);
+ fprintf(stderr,"errno=%d\n",errno);
+ exit(1);
+void
+mes(s)
+char *s;
+ fprintf(stderr,"ttcp%s: %s\n", trans?"-t":"-r", s);
+pattern( cp, cnt )
+register char *cp;
+register int cnt;
+ register char c;
+ c = 0;
+ while( cnt-- > 0 ) {
+ while( !isprint((c&0x7F)) ) c++;
+ *cp++ = (c++&0x7F);
+char *
+outfmt(b)
+double b;
+ static char obuf[50];
+ switch (fmt) {
+ case 'G':
+ sprintf(obuf, "%.2f GB", b / 1024.0 / 1024.0 / 1024.0);
+ break;
+ default:
+ case 'K':
+ sprintf(obuf, "%.2f KB", b / 1024.0);
+ break;
+ case 'M':
+ sprintf(obuf, "%.2f MB", b / 1024.0 / 1024.0);
+ break;
+ case 'g':
+ sprintf(obuf, "%.2f Gbit", b * 8.0 / 1024.0 / 1024.0 / 1024.0);
+ break;
+ case 'k':
+ sprintf(obuf, "%.2f Kbit", b * 8.0 / 1024.0);
+ break;
+ case 'm':
+ sprintf(obuf, "%.2f Mbit", b * 8.0 / 1024.0 / 1024.0);
+ break;
+ return obuf;
+static struct timeval time0; /* Time at which timing started */
+static struct rusage ru0; /* Resource utilization at the start */
+static void prusage();
+static void tvadd();
+static void tvsub();
+static void psecs();
+#if defined(SYSV)
+/*ARGSUSED*/
+static
+getrusage(ignored, ru)
+ int ignored;
+ register struct rusage *ru;
+ struct tms buf;
+ times(&buf);
+ /* Assumption: HZ <= 2147 (LONG_MAX/1000000) */
+ ru->ru_stime.tv_sec = buf.tms_stime / HZ;
+ ru->ru_stime.tv_usec = ((buf.tms_stime % HZ) * 1000000) / HZ;
+ ru->ru_utime.tv_sec = buf.tms_utime / HZ;
+ ru->ru_utime.tv_usec = ((buf.tms_utime % HZ) * 1000000) / HZ;
+/*ARGSUSED*/
+static
+gettimeofday(tp, zp)
+ struct timeval *tp;
+ struct timezone *zp;
+ tp->tv_sec = time(0);
+ tp->tv_usec = 0;
+#endif /* SYSV */
+ * P R E P _ T I M E R
+void
+prep_timer()
+ gettimeofday(&time0, (struct timezone *)0);
+ getrusage(RUSAGE_SELF, &ru0);
+ * R E A D _ T I M E R
+double
+read_timer(str,len)
+char *str;
+ struct timeval timedol;
+ struct rusage ru1;
+ struct timeval td;
+ struct timeval tend, tstart;
+ char line[132];
+ getrusage(RUSAGE_SELF, &ru1);
+ gettimeofday(&timedol, (struct timezone *)0);
+ prusage(&ru0, &ru1, &timedol, &time0, line);
+ (void)strncpy( str, line, len );
+ /* Get real time */
+ tvsub( &td, &timedol, &time0 );
+ realt = td.tv_sec + ((double)td.tv_usec) / 1000000;
+ /* Get CPU time (user+sys) */
+ tvadd( &tend, &ru1.ru_utime, &ru1.ru_stime );
+ tvadd( &tstart, &ru0.ru_utime, &ru0.ru_stime );
+ tvsub( &td, &tend, &tstart );
+ cput = td.tv_sec + ((double)td.tv_usec) / 1000000;
+ if( cput < 0.00001 ) cput = 0.00001;
+ return( cput );
+static void
+prusage(r0, r1, e, b, outp)
+ register struct rusage *r0, *r1;
+ struct timeval *e, *b;
+ char *outp;
+ struct timeval tdiff;
+ register time_t t;
+ register char *cp;
+ register int i;
+ int ms;
+ t = (r1->ru_utime.tv_sec-r0->ru_utime.tv_sec)*100+
+ (r1->ru_utime.tv_usec-r0->ru_utime.tv_usec)/10000+
+ (r1->ru_stime.tv_sec-r0->ru_stime.tv_sec)*100+
+ (r1->ru_stime.tv_usec-r0->ru_stime.tv_usec)/10000;
+ ms = (e->tv_sec-b->tv_sec)*100 + (e->tv_usec-b->tv_usec)/10000;
+#define END(x) {while(*x) x++;}
+#if defined(SYSV)
+ cp = "%Uuser %Ssys %Ereal %P";
+#else
+#if defined(sgi) /* IRIX 3.3 will show 0 for %M,%F,%R,%C */
+ cp = "%Uuser %Ssys %Ereal %P %Mmaxrss %F+%Rpf %Ccsw";
+#else
+ cp = "%Uuser %Ssys %Ereal %P %Xi+%Dd %Mmaxrss %F+%Rpf %Ccsw";
+#endif
+#endif
+ for (; *cp; cp++) {
+ if (*cp != '%')
+ *outp++ = *cp;
+ else if (cp[1]) switch(*++cp) {
+ case 'U':
+ tvsub(&tdiff, &r1->ru_utime, &r0->ru_utime);
+ sprintf(outp,"%d.%01d", tdiff.tv_sec, tdiff.tv_usec/100000);
+ END(outp);
+ break;
+ case 'S':
+ tvsub(&tdiff, &r1->ru_stime, &r0->ru_stime);
+ END(outp);
+ break;
+ case 'E':
+ psecs(ms / 100, outp);
+ END(outp);
+ break;
+ case 'P':
+ sprintf(outp,"%d%%", (int) (t*100 / ((ms ? ms : 1))));
+ END(outp);
+ break;
+#if !defined(SYSV)
+ case 'W':
+ i = r1->ru_nswap - r0->ru_nswap;
+ sprintf(outp,"%d", i);
+ END(outp);
+ break;
+ case 'X':
+ sprintf(outp,"%d", t == 0 ? 0 : (r1->ru_ixrss-r0->ru_ixrss)/t);
+ END(outp);
+ break;
+ case 'D':
+ (r1->ru_idrss+r1->ru_isrss-(r0->ru_idrss+r0->ru_isrss))/t);
+ END(outp);
+ break;
+ case 'K':
+ ((r1->ru_ixrss+r1->ru_isrss+r1->ru_idrss) -
+ (r0->ru_ixrss+r0->ru_idrss+r0->ru_isrss))/t);
+ END(outp);
+ break;
+ case 'M':
+ sprintf(outp,"%d", r1->ru_maxrss/2);
+ END(outp);
+ break;
+ case 'F':
+ sprintf(outp,"%d", r1->ru_majflt-r0->ru_majflt);
+ END(outp);
+ break;
+ case 'R':
+ sprintf(outp,"%d", r1->ru_minflt-r0->ru_minflt);
+ END(outp);
+ break;
+ case 'I':
+ sprintf(outp,"%d", r1->ru_inblock-r0->ru_inblock);
+ END(outp);
+ break;
+ case 'O':
+ sprintf(outp,"%d", r1->ru_oublock-r0->ru_oublock);
+ END(outp);
+ break;
+ case 'C':
+ sprintf(outp,"%d+%d", r1->ru_nvcsw-r0->ru_nvcsw,
+ r1->ru_nivcsw-r0->ru_nivcsw );
+ END(outp);
+ break;
+#endif /* !SYSV */
+ *outp = '\0';
+static void
+tvadd(tsum, t0, t1)
+ struct timeval *tsum, *t0, *t1;
+ tsum->tv_sec = t0->tv_sec + t1->tv_sec;
+ tsum->tv_usec = t0->tv_usec + t1->tv_usec;
+ if (tsum->tv_usec > 1000000)
+ tsum->tv_sec++, tsum->tv_usec -= 1000000;
+static void
+tvsub(tdiff, t1, t0)
+ struct timeval *tdiff, *t1, *t0;
+ tdiff->tv_sec = t1->tv_sec - t0->tv_sec;
+ tdiff->tv_usec = t1->tv_usec - t0->tv_usec;
+ if (tdiff->tv_usec < 0)
+ tdiff->tv_sec--, tdiff->tv_usec += 1000000;
+static void
+psecs(l,cp)
+long l;
+register char *cp;
+ register int i;
+ i = l / 3600;
+ if (i) {
+ sprintf(cp,"%d:", i);
+ END(cp);
+ i = l % 3600;
+ sprintf(cp,"%d%d", (i/60) / 10, (i/60) % 10);
+ END(cp);
+ } else {
+ i = l;
+ sprintf(cp,"%d", i / 60);
+ END(cp);
+ i %= 60;
+ *cp++ = ':';
+ sprintf(cp,"%d%d", i / 10, i % 10);
+ * N R E A D
+Nread( fd, buf, count )
+int fd;
+void *buf;
+int count;
+ struct sockaddr_in from;
+ int len = sizeof(from);
+ register int cnt;
+ if( udp ) {
+ cnt = recvfrom( fd, buf, count, 0, &from, &len );
+ numCalls++;
+ } else {
+ if( b_flag )
+ cnt = mread( fd, buf, count ); /* fill buf */
+ else {
+ cnt = read( fd, buf, count );
+ numCalls++;
+ if (touchdata && cnt > 0) {
+ register int c = cnt, sum;
+ register char *b = buf;
+ while (c--)
+ sum += *b++;
+ return(cnt);
+ * N W R I T E
+Nwrite( fd, buf, count )
+int fd;
+void *buf;
+int count;
+ register int cnt;
+ if( udp ) {
+again:
+ cnt = sendto( fd, buf, count, 0, &sinhim, sizeof(sinhim) );
+ numCalls++;
+ if( cnt<0 && errno == ENOBUFS ) {
+ delay(18000);
+ errno = 0;
+ goto again;
+ } else {
+ cnt = write( fd, buf, count );
+ numCalls++;
+ return(cnt);
+void
+delay(us)
+ struct timeval tv;
+ tv.tv_sec = 0;
+ tv.tv_usec = us;
+ (void)select( 1, (char *)0, (char *)0, (char *)0, &tv );
+ * M R E A D
+ * This function performs the function of a read(II) but will
+ * call read(II) multiple times in order to get the requested
+ * number of characters. This can be necessary because
+ * network connections don't deliver data with the same
+ * grouping as it is written with. Written by Robert S. Miles, BRL.
+int
+mread(fd, bufp, n)
+int fd;
+register char *bufp;
+unsigned n;
+ register unsigned count = 0;
+ register int nread;
+ do {
+ nread = read(fd, bufp, n-count);
+ numCalls++;
+ if(nread < 0) {
+ perror("ttcp_mread");
+ return(-1);
+ if(nread == 0)
+ return((int)count);
+ count += (unsigned)nread;
+ bufp += nread;
+ } while(count < n);
2.27.0
