[PATCH v1 1/4] rtemsbsd: Added original TTCP code
Tue Jun 8 17:09:34 UTC 2021
Minor note, please use the the --subject-prefix="PATCH rtems-libbsd"
as mentioned in
https://docs.rtems.org/branches/master/eng/vc-users.html#creating-a-patch
This helps set the context of the patch review better for non-rtems.git patches.
On Tue, Jun 8, 2021 at 9:50 AM Stephen Clark <stephen.clark at oarcorp.com> wrote:
> Added the original Test TCP (TTCP) program in unmodified form.
> Also added the associated README.
>  rtemsbsd/ttcp/README |  27 ++
>  rtemsbsd/ttcp/ttcp.c | 841 +++++++++++++++++++++++++++++++++++++++++++
>  2 files changed, 868 insertions(+)
>  create mode 100644 rtemsbsd/ttcp/README
>  create mode 100644 rtemsbsd/ttcp/ttcp.c
> diff --git a/rtemsbsd/ttcp/README b/rtemsbsd/ttcp/README
> new file mode 100644
> index 00000000..215ddacc
> --- /dev/null
> +++ b/rtemsbsd/ttcp/README
> @@ -0,0 +1,27 @@
> +TTCP is a benchmarking tool for determining TCP and UDP performance
> +between 2 systems.
> +The program was created at the US Army Ballistics Research Lab (BRL)
> +and is in the public domain. Feel free to distribute this program
> +but please do leave the credit notices in the source and man page intact.
> +Contents of this directory:
> +ttcp.c          Source that runs on IRIX 3.3.x and 4.0.x systems
> +                and BSD-based systems.  This version also uses getopt(3)
> +                and has 2 new options: -f and -T.
> +ttcp.c-brl      Original source from BRL.
> +ttcp.1          Manual page (describes ttcp.c options, which are a
> +                superset of the other version).
> +How to get TCP performance numbers:
> +        receiver                                sender
> +host1%  ttcp -r -s                      host2% ttcp -t -s host1
> +-n and -l options change the number and size of the buffers.
Does this code come from somewhere that should be documented in the README?
> diff --git a/rtemsbsd/ttcp/ttcp.c b/rtemsbsd/ttcp/ttcp.c
> index 00000000..305a7c7d
> --- /dev/null
> +++ b/rtemsbsd/ttcp/ttcp.c
> @@ -0,0 +1,841 @@
> + *     T T C P . C
> + * Test TCP connection.  Makes a connection on port 5001
> + * and transfers fabricated buffers or data copied from stdin.
> + * Usable on 4.2, 4.3, and 4.1a systems by defining one of
> + * BSD42 BSD43 (BSD41a)
> + * Machines using System V with BSD sockets should define SYSV.
> + * Modified for operation under 4.2BSD, 18 Dec 84
> + *      T.C. Slattery, USNA
> + * Minor improvements, Mike Muuss and Terry Slattery, 16-Oct-85.
> + * Modified in 1989 at Silicon Graphics, Inc.
> + *     catch SIGPIPE to be able to print stats when receiver has died
> + *     for tcp, don't look for sentinel during reads to allow small transfers
> + *     increased default buffer size to 8K, nbuf to 2K to transfer 16MB
> + *     moved default port to 5001, beyond IPPORT_USERRESERVED
> + *     make sinkmode default because it is more popular,
> + *             -s now means don't sink/source
> + *     count number of read/write system calls to see effects of
> + *             blocking from full socket buffers
> + *     for tcp, -D option turns off buffered writes (sets TCP_NODELAY sockopt)
> + *     buffer alignment options, -A and -O
> + *     print stats in a format that's a bit easier to use with grep & awk
> + *     for SYSV, mimic BSD routines to use most of the existing timing code
> + * Modified by Steve Miller of the University of Maryland, College Park
> + *     -b sets the socket buffer size (SO_SNDBUF/SO_RCVBUF)
> + * Modified Sept. 1989 at Silicon Graphics, Inc.
> + *     restored -s sense at request of tcs at brl
> + * Modified Oct. 1991 at Silicon Graphics, Inc.
> + *     use getopt(3) for option processing, add -f and -T options.
> + *     SGI IRIX 3.3 and 4.0 releases don't need #define SYSV.
> + * Distribution Status -
> + *      Public Domain.  Distribution Unlimited.
> +#ifndef lint
> +static char RCSid[] = "ttcp.c $Revision$";
> +#endif
> +#define BSD43
> +/* #define BSD42 */
> +/* #define BSD41a */
> +/* #define SYSV */     /* required on SGI IRIX releases before 3.3 */
> +#include <stdio.h>
> +#include <signal.h>
> +#include <ctype.h>
> +#include <errno.h>
> +#include <sys/types.h>
> +#include <sys/socket.h>
> +#include <netinet/in.h>
> +#include <netinet/tcp.h>
> +#include <arpa/inet.h>
> +#include <netdb.h>
> +#include <sys/time.h>          /* struct timeval */
> +#if defined(SYSV)
> +#include <sys/times.h>
> +#include <sys/param.h>
> +struct rusage {
> +    struct timeval ru_utime, ru_stime;
> +#define RUSAGE_SELF 0
> +#else
> +#include <sys/resource.h>
> +#endif
> +struct sockaddr_in sinme;
> +struct sockaddr_in sinhim;
> +struct sockaddr_in frominet;
> +int domain, fromlen;
> +int fd;                                /* fd of network socket */
> +int buflen = 8 * 1024;         /* length of buffer */
> +char *buf;                     /* ptr to dynamic buffer */
> +int nbuf = 2 * 1024;           /* number of buffers to send in sinkmode */
> +int bufoffset = 0;             /* align buffer to this */
> +int bufalign = 16*1024;                /* modulo this */
> +int udp = 0;                   /* 0 = tcp, !0 = udp */
> +int options = 0;               /* socket options */
> +int one = 1;                    /* for 4.3 BSD style setsockopt() */
> +short port = 5001;             /* TCP port number */
> +char *host;                    /* ptr to name of host */
> +int trans;                     /* 0=receive, !0=transmit mode */
> +int sinkmode = 0;              /* 0=normal I/O, !0=sink/source mode */
> +int verbose = 0;               /* 0=print basic info, 1=print cpu rate, proc
> +                                * resource usage. */
> +int nodelay = 0;               /* set TCP_NODELAY socket option */
> +int b_flag = 0;                        /* use mread() */
> +int sockbufsize = 0;           /* socket buffer size to use */
> +char fmt = 'K';                        /* output format: k = kilobits, K = kilobytes,
> +                                *  m = megabits, M = megabytes,
> +                                *  g = gigabits, G = gigabytes */
> +int touchdata = 0;             /* access data after reading */
> +struct hostent *addr;
> +extern int errno;
> +extern int optind;
> +extern char *optarg;
> +char Usage[] = "\
> +Usage: ttcp -t [-options] host [ < in ]\n\
> +       ttcp -r [-options > out]\n\
> +Common options:\n\
> +       -l ##   length of bufs read from or written to network (default 8192)\n\
> +       -u      use UDP instead of TCP\n\
> +       -p ##   port number to send to or listen at (default 5001)\n\
> +       -s      -t: source a pattern to network\n\
> +               -r: sink (discard) all data from network\n\
> +       -A      align the start of buffers to this modulus (default 16384)\n\
> +       -O      start buffers at this offset from the modulus (default 0)\n\
> +       -v      verbose: print more statistics\n\
> +       -d      set SO_DEBUG socket option\n\
> +       -b ##   set socket buffer size (if supported)\n\
> +       -f X    format for rate: k,K = kilo{bit,byte}; m,M = mega; g,G = giga\n\
> +Options specific to -t:\n\
> +       -n##    number of source bufs written to network (default 2048)\n\
> +       -D      don't buffer TCP writes (sets TCP_NODELAY socket option)\n\
> +Options specific to -r:\n\
> +       -B      for -s, only output full blocks as specified by -l (for TAR)\n\
> +       -T      \"touch\": access each byte as it's read\n\
> +char stats[128];
> +double nbytes;                 /* bytes on net */
> +unsigned long numCalls;                /* # of I/O system calls */
> +double cput, realt;            /* user, real time (seconds) */
> +void err();
> +void mes();
> +int pattern();
> +void prep_timer();
> +double read_timer();
> +int Nread();
> +int Nwrite();
> +void delay();
> +int mread();
> +char *outfmt();
> +void
> +sigpipe()
> +main(argc,argv)
> +int argc;
> +char **argv;
> +       unsigned long addr_tmp;
> +       int c;
> +       if (argc < 2) goto usage;
> +       while ((c = getopt(argc, argv, "drstuvBDTb:f:l:n:p:A:O:")) != -1) {
> +               switch (c) {
> +               case 'B':
> +                       b_flag = 1;
> +                       break;
> +               case 't':
> +                       trans = 1;
> +                       break;
> +               case 'r':
> +                       trans = 0;
> +                       break;
> +               case 'd':
> +                       options |= SO_DEBUG;
> +                       break;
> +               case 'D':
> +#ifdef TCP_NODELAY
> +                       nodelay = 1;
> +#else
> +                       fprintf(stderr,
> +       "ttcp: -D option ignored: TCP_NODELAY socket option not supported\n");
> +#endif
> +                       break;
> +               case 'n':
> +                       nbuf = atoi(optarg);
> +                       break;
> +               case 'l':
> +                       buflen = atoi(optarg);
> +                       break;
> +               case 's':
> +                       sinkmode = !sinkmode;
> +                       break;
> +               case 'p':
> +                       port = atoi(optarg);
> +                       break;
> +               case 'u':
> +                       udp = 1;
> +                       break;
> +               case 'v':
> +                       verbose = 1;
> +                       break;
> +               case 'A':
> +                       bufalign = atoi(optarg);
> +                       break;
> +               case 'O':
> +                       bufoffset = atoi(optarg);
> +                       break;
> +               case 'b':
> +#if defined(SO_SNDBUF) || defined(SO_RCVBUF)
> +                       sockbufsize = atoi(optarg);
> +#else
> +                       fprintf(stderr,
> +"ttcp: -b option ignored: SO_SNDBUF/SO_RCVBUF socket options not supported\n");
> +#endif
> +                       break;
> +               case 'f':
> +                       fmt = *optarg;
> +                       break;
> +               case 'T':
> +                       touchdata = 1;
> +                       break;
> +               default:
> +                       goto usage;
> +       if(trans)  {
> +               /* xmitr */
> +               if (optind == argc)
> +                       goto usage;
> +               bzero((char *)&sinhim, sizeof(sinhim));
> +               host = argv[optind];
> +               if (atoi(host) > 0 )  {
> +                       /* Numeric */
> +                       sinhim.sin_family = AF_INET;
> +#if defined(cray)
> +                       addr_tmp = inet_addr(host);
> +                       sinhim.sin_addr = addr_tmp;
> +#else
> +                       sinhim.sin_addr.s_addr = inet_addr(host);
> +#endif
> +               } else {
> +                       if ((addr=gethostbyname(host)) == NULL)
> +                               err("bad hostname");
> +                       sinhim.sin_family = addr->h_addrtype;
> +                       bcopy(addr->h_addr,(char*)&addr_tmp, addr->h_length);
> +#if defined(cray)
> +#else
> +                       sinhim.sin_addr.s_addr = addr_tmp;
> +#endif /* cray */
> +               sinhim.sin_port = htons(port);
> +               sinme.sin_port = 0;             /* free choice */
> +       } else {
> +               /* rcvr */
> +               sinme.sin_port =  htons(port);
> +       if (udp && buflen < 5) {
> +           buflen = 5;         /* send more than the sentinel size */
> +       if ( (buf = (char *)malloc(buflen+bufalign)) == (char *)NULL)
> +               err("malloc");
> +       if (bufalign != 0)
> +               buf +=(bufalign - ((int)buf % bufalign) + bufoffset) % bufalign;
> +       if (trans) {
> +           fprintf(stdout,
> +           "ttcp-t: buflen=%d, nbuf=%d, align=%d/%d, port=%d",
> +               buflen, nbuf, bufalign, bufoffset, port);
> +           if (sockbufsize)
> +               fprintf(stdout, ", sockbufsize=%d", sockbufsize);
> +           fprintf(stdout, "  %s  -> %s\n", udp?"udp":"tcp", host);
> +       } else {
> +           fprintf(stdout,
> +           "ttcp-r: buflen=%d, nbuf=%d, align=%d/%d, port=%d",
> +           if (sockbufsize)
> +           fprintf(stdout, "  %s\n", udp?"udp":"tcp");
> +       if ((fd = socket(AF_INET, udp?SOCK_DGRAM:SOCK_STREAM, 0)) < 0)
> +               err("socket");
> +       mes("socket");
> +       if (bind(fd, &sinme, sizeof(sinme)) < 0)
> +               err("bind");
> +       if (sockbufsize) {
> +           if (trans) {
> +               if (setsockopt(fd, SOL_SOCKET, SO_SNDBUF, &sockbufsize,
> +                   sizeof sockbufsize) < 0)
> +                       err("setsockopt: sndbuf");
> +               mes("sndbuf");
> +           } else {
> +               if (setsockopt(fd, SOL_SOCKET, SO_RCVBUF, &sockbufsize,
> +                       err("setsockopt: rcvbuf");
> +               mes("rcvbuf");
> +#endif
> +       if (!udp)  {
> +           signal(SIGPIPE, sigpipe);
> +           if (trans) {
> +               /* We are the client if transmitting */
> +               if (options)  {
> +#if defined(BSD42)
> +                       if( setsockopt(fd, SOL_SOCKET, options, 0, 0) < 0)
> +#else /* BSD43 */
> +                       if( setsockopt(fd, SOL_SOCKET, options, &one, sizeof(one)) < 0)
> +#endif
> +                               err("setsockopt");
> +#ifdef TCP_NODELAY
> +               if (nodelay) {
> +                       struct protoent *p;
> +                       p = getprotobyname("tcp");
> +                       if( p && setsockopt(fd, p->p_proto, TCP_NODELAY,
> +                           &one, sizeof(one)) < 0)
> +                               err("setsockopt: nodelay");
> +                       mes("nodelay");
> +#endif
> +               if(connect(fd, &sinhim, sizeof(sinhim) ) < 0)
> +                       err("connect");
> +               mes("connect");
> +           } else {
> +               /* otherwise, we are the server and
> +                * should listen for the connections
> +#if defined(ultrix) || defined(sgi)
> +               listen(fd,1);   /* workaround for alleged u4.2 bug */
> +#else
> +               listen(fd,0);   /* allow a queue of 0 */
> +#endif
> +               if(options)  {
> +#if defined(BSD42)
> +#else /* BSD43 */
> +#endif
> +               fromlen = sizeof(frominet);
> +               domain = AF_INET;
> +               if((fd=accept(fd, &frominet, &fromlen) ) < 0)
> +                       err("accept");
> +               { struct sockaddr_in peer;
> +                 int peerlen = sizeof(peer);
> +                 if (getpeername(fd, (struct sockaddr_in *) &peer,
> +                               &peerlen) < 0) {
> +                       err("getpeername");
> +                 fprintf(stderr,"ttcp-r: accept from %s\n",
> +                       inet_ntoa(peer.sin_addr));
> +       prep_timer();
> +       errno = 0;
> +       if (sinkmode) {
> +               register int cnt;
> +               if (trans)  {
> +                       pattern( buf, buflen );
> +                       if(udp)  (void)Nwrite( fd, buf, 4 ); /* rcvr start */
> +                       while (nbuf-- && Nwrite(fd,buf,buflen) == buflen)
> +                               nbytes += buflen;
> +                       if(udp)  (void)Nwrite( fd, buf, 4 ); /* rcvr end */
> +               } else {
> +                       if (udp) {
> +                           while ((cnt=Nread(fd,buf,buflen)) > 0)  {
> +                                   static int going = 0;
> +                                   if( cnt <= 4 )  {
> +                                           if( going )
> +                                                   break;      /* "EOF" */
> +                                           going = 1;
> +                                           prep_timer();
> +                                   } else {
> +                                           nbytes += cnt;
> +                       } else {
> +                                   nbytes += cnt;
> +       } else {
> +               register int cnt;
> +               if (trans)  {
> +                       while((cnt=read(0,buf,buflen)) > 0 &&
> +                           Nwrite(fd,buf,cnt) == cnt)
> +                               nbytes += cnt;
> +               }  else  {
> +                       while((cnt=Nread(fd,buf,buflen)) > 0 &&
> +                           write(1,buf,cnt) == cnt)
> +                               nbytes += cnt;
> +       if(errno) err("IO");
> +       (void)read_timer(stats,sizeof(stats));
> +       if(udp&&trans)  {
> +               (void)Nwrite( fd, buf, 4 ); /* rcvr end */
> +       if( cput <= 0.0 )  cput = 0.001;
> +       if( realt <= 0.0 )  realt = 0.001;
> +       fprintf(stdout,
> +               "ttcp%s: %.0f bytes in %.2f real seconds = %s/sec +++\n",
> +               trans?"-t":"-r",
> +               nbytes, realt, outfmt(nbytes/realt));
> +       if (verbose) {
> +           fprintf(stdout,
> +               "ttcp%s: %.0f bytes in %.2f CPU seconds = %s/cpu sec\n",
> +               trans?"-t":"-r",
> +               nbytes, cput, outfmt(nbytes/cput));
> +       fprintf(stdout,
> +               "ttcp%s: %d I/O calls, msec/call = %.2f, calls/sec = %.2f\n",
> +               trans?"-t":"-r",
> +               numCalls,
> +               1024.0 * realt/((double)numCalls),
> +               ((double)numCalls)/realt);
> +       fprintf(stdout,"ttcp%s: %s\n", trans?"-t":"-r", stats);
> +       if (verbose) {
> +           fprintf(stdout,
> +               "ttcp%s: buffer address %#x\n",
> +               trans?"-t":"-r",
> +               buf);
> +       exit(0);
> +usage:
> +       fprintf(stderr,Usage);
> +       exit(1);
> +void
> +err(s)
> +char *s;
> +       fprintf(stderr,"ttcp%s: ", trans?"-t":"-r");
> +       perror(s);
> +       fprintf(stderr,"errno=%d\n",errno);
> +       exit(1);
> +void
> +mes(s)
> +char *s;
> +       fprintf(stderr,"ttcp%s: %s\n", trans?"-t":"-r", s);
> +pattern( cp, cnt )
> +register char *cp;
> +register int cnt;
> +       register char c;
> +       c = 0;
> +       while( cnt-- > 0 )  {
> +               while( !isprint((c&0x7F)) )  c++;
> +               *cp++ = (c++&0x7F);
> +char *
> +outfmt(b)
> +double b;
> +    static char obuf[50];
> +    switch (fmt) {
> +       case 'G':
> +           sprintf(obuf, "%.2f GB", b / 1024.0 / 1024.0 / 1024.0);
> +           break;
> +       default:
> +       case 'K':
> +           sprintf(obuf, "%.2f KB", b / 1024.0);
> +           break;
> +       case 'M':
> +           sprintf(obuf, "%.2f MB", b / 1024.0 / 1024.0);
> +           break;
> +       case 'g':
> +           sprintf(obuf, "%.2f Gbit", b * 8.0 / 1024.0 / 1024.0 / 1024.0);
> +           break;
> +       case 'k':
> +           sprintf(obuf, "%.2f Kbit", b * 8.0 / 1024.0);
> +           break;
> +       case 'm':
> +           sprintf(obuf, "%.2f Mbit", b * 8.0 / 1024.0 / 1024.0);
> +           break;
> +    return obuf;
> +static struct  timeval time0;  /* Time at which timing started */
> +static struct  rusage ru0;     /* Resource utilization at the start */
> +static void prusage();
> +static void tvadd();
> +static void tvsub();
> +static void psecs();
> +#if defined(SYSV)
> +/*ARGSUSED*/
> +static
> +getrusage(ignored, ru)
> +    int ignored;
> +    register struct rusage *ru;
> +    struct tms buf;
> +    times(&buf);
> +    /* Assumption: HZ <= 2147 (LONG_MAX/1000000) */
> +    ru->ru_stime.tv_sec  = buf.tms_stime / HZ;
> +    ru->ru_stime.tv_usec = ((buf.tms_stime % HZ) * 1000000) / HZ;
> +    ru->ru_utime.tv_sec  = buf.tms_utime / HZ;
> +    ru->ru_utime.tv_usec = ((buf.tms_utime % HZ) * 1000000) / HZ;
> +/*ARGSUSED*/
> +static
> +gettimeofday(tp, zp)
> +    struct timeval *tp;
> +    struct timezone *zp;
> +    tp->tv_sec = time(0);
> +    tp->tv_usec = 0;
> +#endif /* SYSV */
> + *                     P R E P _ T I M E R
> +void
> +prep_timer()
> +       gettimeofday(&time0, (struct timezone *)0);
> +       getrusage(RUSAGE_SELF, &ru0);
> + *                     R E A D _ T I M E R
> +double
> +read_timer(str,len)
> +char *str;
> +       struct timeval timedol;
> +       struct rusage ru1;
> +       struct timeval td;
> +       struct timeval tend, tstart;
> +       char line[132];
> +       getrusage(RUSAGE_SELF, &ru1);
> +       gettimeofday(&timedol, (struct timezone *)0);
> +       prusage(&ru0, &ru1, &timedol, &time0, line);
> +       (void)strncpy( str, line, len );
> +       /* Get real time */
> +       tvsub( &td, &timedol, &time0 );
> +       realt = td.tv_sec + ((double)td.tv_usec) / 1000000;
> +       /* Get CPU time (user+sys) */
> +       tvadd( &tend, &ru1.ru_utime, &ru1.ru_stime );
> +       tvadd( &tstart, &ru0.ru_utime, &ru0.ru_stime );
> +       tvsub( &td, &tend, &tstart );
> +       cput = td.tv_sec + ((double)td.tv_usec) / 1000000;
> +       if( cput < 0.00001 )  cput = 0.00001;
> +       return( cput );
> +static void
> +prusage(r0, r1, e, b, outp)
> +       register struct rusage *r0, *r1;
> +       struct timeval *e, *b;
> +       char *outp;
> +       struct timeval tdiff;
> +       register time_t t;
> +       register char *cp;
> +       register int i;
> +       int ms;
> +       t = (r1->ru_utime.tv_sec-r0->ru_utime.tv_sec)*100+
> +           (r1->ru_utime.tv_usec-r0->ru_utime.tv_usec)/10000+
> +           (r1->ru_stime.tv_sec-r0->ru_stime.tv_sec)*100+
> +           (r1->ru_stime.tv_usec-r0->ru_stime.tv_usec)/10000;
> +       ms =  (e->tv_sec-b->tv_sec)*100 + (e->tv_usec-b->tv_usec)/10000;
> +#define END(x) {while(*x) x++;}
> +#if defined(SYSV)
> +       cp = "%Uuser %Ssys %Ereal %P";
> +#else
> +#if defined(sgi)               /* IRIX 3.3 will show 0 for %M,%F,%R,%C */
> +       cp = "%Uuser %Ssys %Ereal %P %Mmaxrss %F+%Rpf %Ccsw";
> +#else
> +       cp = "%Uuser %Ssys %Ereal %P %Xi+%Dd %Mmaxrss %F+%Rpf %Ccsw";
> +#endif
> +#endif
> +       for (; *cp; cp++)  {
> +               if (*cp != '%')
> +                       *outp++ = *cp;
> +               else if (cp[1]) switch(*++cp) {
> +               case 'U':
> +                       tvsub(&tdiff, &r1->ru_utime, &r0->ru_utime);
> +                       sprintf(outp,"%d.%01d", tdiff.tv_sec, tdiff.tv_usec/100000);
> +                       END(outp);
> +                       break;
> +               case 'S':
> +                       tvsub(&tdiff, &r1->ru_stime, &r0->ru_stime);
> +                       END(outp);
> +                       break;
> +               case 'E':
> +                       psecs(ms / 100, outp);
> +                       END(outp);
> +                       break;
> +               case 'P':
> +                       sprintf(outp,"%d%%", (int) (t*100 / ((ms ? ms : 1))));
> +                       END(outp);
> +                       break;
> +#if !defined(SYSV)
> +               case 'W':
> +                       i = r1->ru_nswap - r0->ru_nswap;
> +                       sprintf(outp,"%d", i);
> +                       END(outp);
> +                       break;
> +               case 'X':
> +                       sprintf(outp,"%d", t == 0 ? 0 : (r1->ru_ixrss-r0->ru_ixrss)/t);
> +                       END(outp);
> +                       break;
> +               case 'D':
> +                           (r1->ru_idrss+r1->ru_isrss-(r0->ru_idrss+r0->ru_isrss))/t);
> +                       END(outp);
> +                       break;
> +               case 'K':
> +                           ((r1->ru_ixrss+r1->ru_isrss+r1->ru_idrss) -
> +                           (r0->ru_ixrss+r0->ru_idrss+r0->ru_isrss))/t);
> +                       END(outp);
> +                       break;
> +               case 'M':
> +                       sprintf(outp,"%d", r1->ru_maxrss/2);
> +                       END(outp);
> +                       break;
> +               case 'F':
> +                       sprintf(outp,"%d", r1->ru_majflt-r0->ru_majflt);
> +                       END(outp);
> +                       break;
> +               case 'R':
> +                       sprintf(outp,"%d", r1->ru_minflt-r0->ru_minflt);
> +                       END(outp);
> +                       break;
> +               case 'I':
> +                       sprintf(outp,"%d", r1->ru_inblock-r0->ru_inblock);
> +                       END(outp);
> +                       break;
> +               case 'O':
> +                       sprintf(outp,"%d", r1->ru_oublock-r0->ru_oublock);
> +                       END(outp);
> +                       break;
> +               case 'C':
> +                       sprintf(outp,"%d+%d", r1->ru_nvcsw-r0->ru_nvcsw,
> +                               r1->ru_nivcsw-r0->ru_nivcsw );
> +                       END(outp);
> +                       break;
> +#endif /* !SYSV */
> +       *outp = '\0';
> +static void
> +tvadd(tsum, t0, t1)
> +       struct timeval *tsum, *t0, *t1;
> +       tsum->tv_sec = t0->tv_sec + t1->tv_sec;
> +       tsum->tv_usec = t0->tv_usec + t1->tv_usec;
> +       if (tsum->tv_usec > 1000000)
> +               tsum->tv_sec++, tsum->tv_usec -= 1000000;
> +static void
> +tvsub(tdiff, t1, t0)
> +       struct timeval *tdiff, *t1, *t0;
> +       tdiff->tv_sec = t1->tv_sec - t0->tv_sec;
> +       tdiff->tv_usec = t1->tv_usec - t0->tv_usec;
> +       if (tdiff->tv_usec < 0)
> +               tdiff->tv_sec--, tdiff->tv_usec += 1000000;
> +static void
> +psecs(l,cp)
> +long l;
> +register char *cp;
> +       register int i;
> +       i = l / 3600;
> +       if (i) {
> +               sprintf(cp,"%d:", i);
> +               END(cp);
> +               i = l % 3600;
> +               sprintf(cp,"%d%d", (i/60) / 10, (i/60) % 10);
> +               END(cp);
> +       } else {
> +               i = l;
> +               sprintf(cp,"%d", i / 60);
> +               END(cp);
> +       i %= 60;
> +       *cp++ = ':';
> +       sprintf(cp,"%d%d", i / 10, i % 10);
> + *                     N R E A D
> +Nread( fd, buf, count )
> +int fd;
> +void *buf;
> +int count;
> +       struct sockaddr_in from;
> +       int len = sizeof(from);
> +       register int cnt;
> +       if( udp )  {
> +               cnt = recvfrom( fd, buf, count, 0, &from, &len );
> +               numCalls++;
> +       } else {
> +               if( b_flag )
> +                       cnt = mread( fd, buf, count );  /* fill buf */
> +               else {
> +                       cnt = read( fd, buf, count );
> +                       numCalls++;
> +               if (touchdata && cnt > 0) {
> +                       register int c = cnt, sum;
> +                       register char *b = buf;
> +                       while (c--)
> +                               sum += *b++;
> +       return(cnt);
> + *                     N W R I T E
> +Nwrite( fd, buf, count )
> +int fd;
> +void *buf;
> +int count;
> +       register int cnt;
> +       if( udp )  {
> +again:
> +               cnt = sendto( fd, buf, count, 0, &sinhim, sizeof(sinhim) );
> +               numCalls++;
> +               if( cnt<0 && errno == ENOBUFS )  {
> +                       delay(18000);
> +                       errno = 0;
> +                       goto again;
> +       } else {
> +               cnt = write( fd, buf, count );
> +               numCalls++;
> +       return(cnt);
> +void
> +delay(us)
> +       struct timeval tv;
> +       tv.tv_sec = 0;
> +       tv.tv_usec = us;
> +       (void)select( 1, (char *)0, (char *)0, (char *)0, &tv );
> + *                     M R E A D
> + * This function performs the function of a read(II) but will
> + * call read(II) multiple times in order to get the requested
> + * number of characters.  This can be necessary because
> + * network connections don't deliver data with the same
> + * grouping as it is written with.  Written by Robert S. Miles, BRL.
> +int
> +mread(fd, bufp, n)
> +int fd;
> +register char  *bufp;
> +unsigned       n;
> +       register unsigned       count = 0;
> +       register int            nread;
> +       do {
> +               nread = read(fd, bufp, n-count);
> +               numCalls++;
> +               if(nread < 0)  {
> +                       perror("ttcp_mread");
> +                       return(-1);
> +               if(nread == 0)
> +                       return((int)count);
> +               count += (unsigned)nread;
> +               bufp += nread;
> +        } while(count < n);
> 2.27.0
> devel mailing list
> devel at rtems.org
