[PATCH v1 4/4] rtemsbsd: Added a test for the TTCP command.
Stephen Clark
stephen.clark at oarcorp.com
Tue Jun 8 15:55:29 UTC 2021
Added a new test for the TTCP command. Modified default-network-init.h
to conditionally build the shell with TTCP. Modified libbsd.py to build
the new TTCP test.
libbsd.py | 1 +
.../rtems/bsd/test/default-network-init.h | 7 +++
testsuite/ttcpshell01/test_main.c | 55 +++++++++++++++++++
3 files changed, 63 insertions(+)
create mode 100644 testsuite/ttcpshell01/test_main.c
diff --git a/libbsd.py b/libbsd.py
index 2badfdee..cb310770 100644
--- a/libbsd.py
+++ b/libbsd.py
@@ -5189,6 +5189,7 @@ class tests(builder.Module):
def generate(self):
mm = self.manager
+ self.addTest(mm.generator['test']('ttcpshell01', ['test_main'], netTest = True, runTest = False))
self.addTest(mm.generator['test']('epoch01', ['test_main'], extraLibs = ['rtemstest']))
self.addTest(mm.generator['test']('nfs01', ['test_main'],
netTest = True, modules = ['nfsv2']))
diff --git a/testsuite/include/rtems/bsd/test/default-network-init.h b/testsuite/include/rtems/bsd/test/default-network-init.h
index b367d956..20c0b2e7 100644
--- a/testsuite/include/rtems/bsd/test/default-network-init.h
+++ b/testsuite/include/rtems/bsd/test/default-network-init.h
@@ -318,9 +318,16 @@ Init(rtems_task_argument arg)
#define SHELL_WPA_SUPPLICANT_COMMAND
#endif
+#ifdef SHELL_TTCP_COMMAND_ENABLE
+ #define SHELL_TTCP_COMMAND &rtems_shell_TTCP_Command,
+#else
+#endif
#define CONFIGURE_SHELL_USER_COMMANDS \
SHELL_WLANSTATS_COMMAND \
SHELL_WPA_SUPPLICANT_COMMAND \
+ SHELL_TTCP_COMMAND \
&bsp_interrupt_shell_command, \
&rtems_shell_ARP_Command, \
&rtems_shell_HOSTNAME_Command, \
diff --git a/testsuite/ttcpshell01/test_main.c b/testsuite/ttcpshell01/test_main.c
new file mode 100644
index 00000000..c7631d14
--- /dev/null
+++ b/testsuite/ttcpshell01/test_main.c
@@ -0,0 +1,55 @@
+ * @file
+ * @brief RTEMS shell is started with DHCP client. It is possible to run TTCP.
+ * COPYRIGHT (c) 2021. On-Line Applications Research Corporation (OAR).
+ * All rights reserved.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+#include <assert.h>
+#include <rtems.h>
+#include <rtems/shell.h>
+#include <rtems/console.h>
+#define TEST_NAME "LIBBSD TTCP 1"
+#define TEST_STATE_USER_INPUT 1
+static void
+test_main(void)
+ rtems_task_delete(RTEMS_SELF);
+ assert(0);
+#define SHELL_TTCP_COMMAND_ENABLE
+#define DEFAULT_NETWORK_DHCPCD_ENABLE
+#define DEFAULT_NETWORK_SHELL
+#include <rtems/bsd/test/default-network-init.h>
2.27.0
