[PATCH v1 2/4] rtemsbsd:Updated TTCP code with network demo code
Tue Jun 8 17:12:27 UTC 2021
Are these updates from OAR? Do you want to scope them with #ifdef
#endif for RTEMS? Or this is clone-and-own software now?
Why not import from network-demos?
On Tue, Jun 8, 2021 at 10:12 AM Stephen Clark <stephen.clark at oarcorp.com> wrote:
> Updated the TTCP code to match the ttcp.c in RTEMS network-demos
> repository (https://git.rtems.org/network-demos/).
>  rtemsbsd/ttcp/ttcp.c | 91 +++++++++++++++++++++++++++++++-------------
>  1 file changed, 65 insertions(+), 26 deletions(-)
> diff --git a/rtemsbsd/ttcp/ttcp.c b/rtemsbsd/ttcp/ttcp.c
> index 305a7c7d..dc62c64b 100644
> --- a/rtemsbsd/ttcp/ttcp.c
> +++ b/rtemsbsd/ttcp/ttcp.c
> @@ -35,8 +35,9 @@
>   * Distribution Status -
>   *      Public Domain.  Distribution Unlimited.
>  #ifndef lint
> -static char RCSid[] = "ttcp.c $Revision$";
> +/* static char RCSid[] = "ttcp.c $Revision$"; */
>  #endif
>  #define BSD43
> @@ -44,6 +45,8 @@ static char RCSid[] = "ttcp.c $Revision$";
>  /* #define BSD41a */
>  /* #define SYSV */     /* required on SGI IRIX releases before 3.3 */
> +#define ENABLE_NANOSLEEP_DELAY
>  #include <stdio.h>
>  #include <signal.h>
>  #include <ctype.h>
> @@ -54,8 +57,12 @@ static char RCSid[] = "ttcp.c $Revision$";
>  #include <netinet/tcp.h>
>  #include <arpa/inet.h>
>  #include <netdb.h>
> +#include <string.h>
>  #include <sys/time.h>          /* struct timeval */
> +#include <unistd.h>
> +#include <stdlib.h>
>  #if defined(SYSV)
>  #include <sys/times.h>
>  #include <sys/param.h>
> @@ -71,7 +78,13 @@ struct sockaddr_in sinme;
>  struct sockaddr_in sinhim;
>  struct sockaddr_in frominet;
> -int domain, fromlen;
> +/* these make it easier to avoid warnings */
> +struct sockaddr *sinhim_p = (struct sockaddr *) &sinhim;
> +struct sockaddr *sinme_p = (struct sockaddr *) &sinme;
> +struct sockaddr *frominet_p = (struct sockaddr *) &frominet;
> +int domain;
> +socklen_t fromlen;
>  int fd;                                /* fd of network socket */
>  int buflen = 8 * 1024;         /* length of buffer */
> @@ -97,6 +110,7 @@ char fmt = 'K';                      /* output format: k = kilobits, K = kilobytes,
>                                  *  m = megabits, M = megabytes,
>                                  *  g = gigabits, G = gigabytes */
>  int touchdata = 0;             /* access data after reading */
> +long milliseconds = 0;          /* delay in milliseconds */
>  struct hostent *addr;
>  extern int errno;
> @@ -124,6 +138,7 @@ Options specific to -t:\n\
>  Options specific to -r:\n\
>         -B      for -s, only output full blocks as specified by -l (for TAR)\n\
>         -T      \"touch\": access each byte as it's read\n\
> +       -m ##   delay for specified milliseconds between each write\n\
>  char stats[128];
> @@ -133,7 +148,7 @@ double cput, realt;         /* user, real time (seconds) */
>  void err();
>  void mes();
> -int pattern();
> +void pattern();
>  void prep_timer();
>  double read_timer();
>  int Nread();
> @@ -147,7 +162,18 @@ sigpipe()
> -main(argc,argv)
> +void millisleep(long msec)
> +#if defined(ENABLE_NANOSLEEP_DELAY)
> +  struct timespec req;
> +  req.tv_sec = msec / 1000;
> +  req.tv_nsec = (msec % 1000) * 1000000;
> +  nanosleep( &req, NULL );
> +#endif
> +int main(argc,argv)
>  int argc;
>  char **argv;
> @@ -156,7 +182,7 @@ char **argv;
>         if (argc < 2) goto usage;
> -       while ((c = getopt(argc, argv, "drstuvBDTb:f:l:n:p:A:O:")) != -1) {
> +       while ((c = getopt(argc, argv, "drstuvBDTb:f:l:m:n:p:A:O:")) != -1) {
>                 switch (c) {
>                 case 'B':
> @@ -179,6 +205,12 @@ char **argv;
>         "ttcp: -D option ignored: TCP_NODELAY socket option not supported\n");
>  #endif
>                         break;
> +               case 'm':
> +                       milliseconds = atoi(optarg);
> +                       #if !defined(ENABLE_NANOSLEEP_DELAY)
> +                               fprintf(stderr, "millisecond delay disabled\n");
> +                       #endif
> +                       break;
>                 case 'n':
>                         nbuf = atoi(optarg);
>                         break;
> @@ -285,7 +317,7 @@ char **argv;
>                 err("socket");
>         mes("socket");
> -       if (bind(fd, &sinme, sizeof(sinme)) < 0)
> +       if (bind(fd, sinme_p, sizeof(sinme)) < 0)
>                 err("bind");
>  #if defined(SO_SNDBUF) || defined(SO_RCVBUF)
> @@ -305,7 +337,9 @@ char **argv;
>  #endif
>         if (!udp)  {
> +#if !defined(__rtems__)
>             signal(SIGPIPE, sigpipe);
> +#endif
>             if (trans) {
>                 /* We are the client if transmitting */
>                 if (options)  {
> @@ -326,7 +360,7 @@ char **argv;
>                         mes("nodelay");
>  #endif
> -               if(connect(fd, &sinhim, sizeof(sinhim) ) < 0)
> +               if(connect(fd, sinhim_p, sizeof(sinhim) ) < 0)
>                         err("connect");
>                 mes("connect");
>             } else {
> @@ -348,11 +382,11 @@ char **argv;
>                 fromlen = sizeof(frominet);
>                 domain = AF_INET;
> -               if((fd=accept(fd, &frominet, &fromlen) ) < 0)
> +               if((fd=accept(fd, frominet_p, &fromlen) ) < 0)
>                         err("accept");
>                 { struct sockaddr_in peer;
> -                 int peerlen = sizeof(peer);
> -                 if (getpeername(fd, (struct sockaddr_in *) &peer,
> +                 socklen_t peerlen = sizeof(peer);
> +                 if (getpeername(fd, (struct sockaddr *) &peer,
>                                 &peerlen) < 0) {
>                         err("getpeername");
> @@ -368,8 +402,10 @@ char **argv;
>                 if (trans)  {
>                         pattern( buf, buflen );
>                         if(udp)  (void)Nwrite( fd, buf, 4 ); /* rcvr start */
> -                       while (nbuf-- && Nwrite(fd,buf,buflen) == buflen)
> +                       while (nbuf-- && Nwrite(fd,buf,buflen) == buflen) {
>                                 nbytes += buflen;
> +                               millisleep( milliseconds );
>                         if(udp)  (void)Nwrite( fd, buf, 4 ); /* rcvr end */
>                 } else {
>                         if (udp) {
> @@ -423,7 +459,7 @@ char **argv;
>                 nbytes, cput, outfmt(nbytes/cput));
>         fprintf(stdout,
> -               "ttcp%s: %d I/O calls, msec/call = %.2f, calls/sec = %.2f\n",
> +               "ttcp%s: %ld I/O calls, msec/call = %.2f, calls/sec = %.2f\n",
>                 trans?"-t":"-r",
>                 numCalls,
>                 1024.0 * realt/((double)numCalls),
> @@ -431,7 +467,7 @@ char **argv;
>         fprintf(stdout,"ttcp%s: %s\n", trans?"-t":"-r", stats);
>         if (verbose) {
>             fprintf(stdout,
> -               "ttcp%s: buffer address %#x\n",
> +               "ttcp%s: buffer address %p\n",
>                 trans?"-t":"-r",
>                 buf);
> @@ -440,6 +476,7 @@ char **argv;
>  usage:
>         fprintf(stderr,Usage);
>         exit(1);
> +       return 0;
>  void
> @@ -459,7 +496,7 @@ char *s;
>         fprintf(stderr,"ttcp%s: %s\n", trans?"-t":"-r", s);
> -pattern( cp, cnt )
> +void pattern( cp, cnt )
>  register char *cp;
>  register int cnt;
> @@ -554,6 +591,7 @@ prep_timer()
>  double
>  read_timer(str,len)
>  char *str;
> +int len;
>         struct timeval timedol;
>         struct rusage ru1;
> @@ -614,13 +652,13 @@ prusage(r0, r1, e, b, outp)
>                 case 'U':
>                         tvsub(&tdiff, &r1->ru_utime, &r0->ru_utime);
> -                       sprintf(outp,"%d.%01d", tdiff.tv_sec, tdiff.tv_usec/100000);
> +                       sprintf(outp,"%ld.%01ld", tdiff.tv_sec, tdiff.tv_usec/100000);
>                         END(outp);
>                         break;
>                 case 'S':
>                         tvsub(&tdiff, &r1->ru_stime, &r0->ru_stime);
>                         END(outp);
>                         break;
> @@ -642,18 +680,18 @@ prusage(r0, r1, e, b, outp)
>                         break;
>                 case 'X':
> -                       sprintf(outp,"%d", t == 0 ? 0 : (r1->ru_ixrss-r0->ru_ixrss)/t);
> +                       sprintf(outp,"%ld", t == 0 ? 0 : (r1->ru_ixrss-r0->ru_ixrss)/t);
>                         END(outp);
>                         break;
>                 case 'D':
>                             (r1->ru_idrss+r1->ru_isrss-(r0->ru_idrss+r0->ru_isrss))/t);
>                         END(outp);
>                         break;
>                 case 'K':
>                             ((r1->ru_ixrss+r1->ru_isrss+r1->ru_idrss) -
>                             (r0->ru_ixrss+r0->ru_idrss+r0->ru_isrss))/t);
>                         END(outp);
> @@ -743,16 +781,16 @@ register char *cp;
>   *                     N R E A D
> -Nread( fd, buf, count )
> +int Nread( fd, buf, count )
>  int fd;
>  void *buf;
>  int count;
>         struct sockaddr_in from;
> -       int len = sizeof(from);
> +       socklen_t len = sizeof(from);
>         register int cnt;
>         if( udp )  {
> -               cnt = recvfrom( fd, buf, count, 0, &from, &len );
> +               cnt = recvfrom( fd, buf, count, 0, (struct sockaddr *)&from, &len );
>                 numCalls++;
>         } else {
>                 if( b_flag )
> @@ -774,7 +812,7 @@ int count;
>   *                     N W R I T E
> -Nwrite( fd, buf, count )
> +int Nwrite( fd, buf, count )
>  int fd;
>  void *buf;
>  int count;
> @@ -782,9 +820,10 @@ int count;
>         register int cnt;
>         if( udp )  {
>  again:
> -               cnt = sendto( fd, buf, count, 0, &sinhim, sizeof(sinhim) );
> +               cnt = sendto( fd, buf, count, 0, sinhim_p, sizeof(sinhim) );
>                 numCalls++;
>                 if( cnt<0 && errno == ENOBUFS )  {
> +                       printf("ttcp: out of buffers -- delaying\n"); /*JRS*/
>                         delay(18000);
>                         errno = 0;
>                         goto again;
> @@ -797,13 +836,13 @@ again:
>  void
> -delay(us)
> +delay(int us)
>         struct timeval tv;
>         tv.tv_sec = 0;
>         tv.tv_usec = us;
> -       (void)select( 1, (char *)0, (char *)0, (char *)0, &tv );
> +       (void)select( 1, (fd_set *)0, (fd_set *)0, (fd_set *)0, &tv );
> 2.27.0
> devel mailing list
> devel at rtems.org
