[PATCH] bsps/zynqmp: Allow any or all CGEMs to be enabled
Kinsey Moore
kinsey.moore at oarcorp.com
Tue Jun 8 20:18:26 UTC 2021
Provide the options necessary to enable any combination of CGEM ethernet
interfaces in LibBSD. The default is still CGEM3, so this should
continue to operate as expected on typical Zynq Ultrascale+ MPSoC
development hardware.
spec/build/bsps/aarch64/xilinx-zynqmp/grp.yml | 8 ++++++++
.../bsps/aarch64/xilinx-zynqmp/optcgem0.yml | 16 ++++++++++++++++
.../bsps/aarch64/xilinx-zynqmp/optcgem1.yml | 16 ++++++++++++++++
.../bsps/aarch64/xilinx-zynqmp/optcgem2.yml | 16 ++++++++++++++++
.../bsps/aarch64/xilinx-zynqmp/optcgem3.yml | 16 ++++++++++++++++
5 files changed, 72 insertions(+)
create mode 100644 spec/build/bsps/aarch64/xilinx-zynqmp/optcgem0.yml
create mode 100644 spec/build/bsps/aarch64/xilinx-zynqmp/optcgem1.yml
create mode 100644 spec/build/bsps/aarch64/xilinx-zynqmp/optcgem2.yml
create mode 100644 spec/build/bsps/aarch64/xilinx-zynqmp/optcgem3.yml
diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/grp.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/grp.yml
index 16e2b8a7e9..1b6b756912 100644
--- a/spec/build/bsps/aarch64/xilinx-zynqmp/grp.yml
+++ b/spec/build/bsps/aarch64/xilinx-zynqmp/grp.yml
@@ -27,6 +27,14 @@ links:
uid: optramori
- role: build-dependency
uid: optclkuart
+- role: build-dependency
+ uid: optcgem0
+ uid: optcgem1
+ uid: optcgem2
+ uid: optcgem3
uid: ../../optconminor
diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/optcgem0.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/optcgem0.yml
new file mode 100644
index 0000000000..fc878fda60
--- /dev/null
+++ b/spec/build/bsps/aarch64/xilinx-zynqmp/optcgem0.yml
@@ -0,0 +1,16 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+actions:
+- get-boolean: null
+- env-enable: null
+- define-condition: null
+build-type: option
+copyrights:
+- Copyright (C) 2021 On-Line Applications Research
+default: false
+default-by-variant: []
+description: |
+ Enable support for CGEM0
+enabled-by: true
+links: []
+name: BSP_XILINX_ZYNQMP_USE_CGEM0
+type: build
diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/optcgem1.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/optcgem1.yml
index 0000000000..6d5096bbde
--- /dev/null
+++ b/spec/build/bsps/aarch64/xilinx-zynqmp/optcgem1.yml
@@ -0,0 +1,16 @@
+actions:
+- env-enable: null
+build-type: option
+copyrights:
+default: false
+description: |
+ Enable support for CGEM1
+enabled-by: true
+links: []
+name: BSP_XILINX_ZYNQMP_USE_CGEM1
+type: build
diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/optcgem2.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/optcgem2.yml
index 0000000000..a8aca3ebbd
--- /dev/null
+++ b/spec/build/bsps/aarch64/xilinx-zynqmp/optcgem2.yml
@@ -0,0 +1,16 @@
+actions:
+- env-enable: null
+build-type: option
+copyrights:
+default: false
+description: |
+ Enable support for CGEM2
+enabled-by: true
+links: []
+name: BSP_XILINX_ZYNQMP_USE_CGEM2
+type: build
diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/optcgem3.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/optcgem3.yml
index 0000000000..8275ad3440
--- /dev/null
+++ b/spec/build/bsps/aarch64/xilinx-zynqmp/optcgem3.yml
@@ -0,0 +1,16 @@
+actions:
+- env-enable: null
+build-type: option
+copyrights:
+default: true
+description: |
+ Enable support for CGEM3
+enabled-by: true
+links: []
+name: BSP_XILINX_ZYNQMP_USE_CGEM3
+type: build
2.20.1
