[PATCH] bsps/zynqmp: Allow any or all CGEMs to be enabled
Tue Jun 8 20:29:01 UTC 2021
ok
On Tue, Jun 8, 2021 at 2:18 PM Kinsey Moore <kinsey.moore at oarcorp.com> wrote:
> Provide the options necessary to enable any combination of CGEM ethernet
> interfaces in LibBSD. The default is still CGEM3, so this should
> continue to operate as expected on typical Zynq Ultrascale+ MPSoC
> development hardware.
>  spec/build/bsps/aarch64/xilinx-zynqmp/grp.yml    |  8 ++++++++
>  .../bsps/aarch64/xilinx-zynqmp/optcgem0.yml      | 16 ++++++++++++++++
>  .../bsps/aarch64/xilinx-zynqmp/optcgem1.yml      | 16 ++++++++++++++++
>  .../bsps/aarch64/xilinx-zynqmp/optcgem2.yml      | 16 ++++++++++++++++
>  .../bsps/aarch64/xilinx-zynqmp/optcgem3.yml      | 16 ++++++++++++++++
>  5 files changed, 72 insertions(+)
>  create mode 100644 spec/build/bsps/aarch64/xilinx-zynqmp/optcgem0.yml
>  create mode 100644 spec/build/bsps/aarch64/xilinx-zynqmp/optcgem1.yml
>  create mode 100644 spec/build/bsps/aarch64/xilinx-zynqmp/optcgem2.yml
>  create mode 100644 spec/build/bsps/aarch64/xilinx-zynqmp/optcgem3.yml
> diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/grp.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/grp.yml
> index 16e2b8a7e9..1b6b756912 100644
> --- a/spec/build/bsps/aarch64/xilinx-zynqmp/grp.yml
> +++ b/spec/build/bsps/aarch64/xilinx-zynqmp/grp.yml
> @@ -27,6 +27,14 @@ links:
>    uid: optramori
>  - role: build-dependency
>    uid: optclkuart
> +- role: build-dependency
> +  uid: optcgem0
> +  uid: optcgem1
> +  uid: optcgem2
> +  uid: optcgem3
>    uid: ../../optconminor
> diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/optcgem0.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/optcgem0.yml
> new file mode 100644
> index 0000000000..fc878fda60
> --- /dev/null
> +++ b/spec/build/bsps/aarch64/xilinx-zynqmp/optcgem0.yml
> @@ -0,0 +1,16 @@
> +SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
> +actions:
> +- get-boolean: null
> +- env-enable: null
> +- define-condition: null
> +build-type: option
> +copyrights:
> +- Copyright (C) 2021 On-Line Applications Research
> +default: false
> +default-by-variant: []
> +description: |
> +  Enable support for CGEM0
> +enabled-by: true
> +links: []
> +name: BSP_XILINX_ZYNQMP_USE_CGEM0
> +type: build
> diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/optcgem1.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/optcgem1.yml
> index 0000000000..6d5096bbde
> --- /dev/null
> +++ b/spec/build/bsps/aarch64/xilinx-zynqmp/optcgem1.yml
> @@ -0,0 +1,16 @@
> +actions:
> +- env-enable: null
> +build-type: option
> +copyrights:
> +default: false
> +description: |
> +  Enable support for CGEM1
> +enabled-by: true
> +links: []
> +name: BSP_XILINX_ZYNQMP_USE_CGEM1
> +type: build
> diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/optcgem2.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/optcgem2.yml
> index 0000000000..a8aca3ebbd
> --- /dev/null
> +++ b/spec/build/bsps/aarch64/xilinx-zynqmp/optcgem2.yml
> @@ -0,0 +1,16 @@
> +actions:
> +- env-enable: null
> +build-type: option
> +copyrights:
> +default: false
> +description: |
> +  Enable support for CGEM2
> +enabled-by: true
> +links: []
> +name: BSP_XILINX_ZYNQMP_USE_CGEM2
> +type: build
> diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/optcgem3.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/optcgem3.yml
> index 0000000000..8275ad3440
> --- /dev/null
> +++ b/spec/build/bsps/aarch64/xilinx-zynqmp/optcgem3.yml
> @@ -0,0 +1,16 @@
> +actions:
> +- env-enable: null
> +build-type: option
> +copyrights:
> +default: true
> +description: |
> +  Enable support for CGEM3
> +enabled-by: true
> +links: []
> +name: BSP_XILINX_ZYNQMP_USE_CGEM3
> +type: build
> 2.20.1
> devel mailing list
> devel at rtems.org
